SF18G
SF18G
    DY(迪一电子)
    DO-41(DO-204AL)
    耐压:600V 电流:1A 反向恢复时间:35NS
SF18G 数据手册
SF11G THRU SF18 G 1.0 AMP. G lass Super Fast Rectifiers Features · Low forward voltage drop DO-41 · High current capability · High reliability · High surge current capability · Plastic material-UL flammability 94V-0 MIN. Mechanical Data DIA. · Case: Molded plastic DO-41 MAX · Terminals: Plated leads solderable per MIL-STD-202,Method 208 guaranteed · Polarity: Color band dentes cathode end DIA. · Mounting Position: Any MIN. · Making: Type Number · Lead Free: For RoHS/Lead Free Version Dimensions in inches and (millimeters) Maximum Ratings and Electrical Characteristics Rating at 25℃ ambient temperature unless otherwise specified Single phase,half wave,60Hz,resistive or inductive load For capacitive load derate current by 20% SYMBOL SF11G SF12G SF13G SF14G SF15G SF16G SF18G Unit Type Number Maximum Recurrent Peak Reverse Voltage VRRM 50 100 150 200 300 400 600 V Maximum RMS Voltage VRMS 35 70 105 140 210 280 420 V Maximum DC Blocking Voltage VDC 50 100 150 200 300 400 600 V Average Rectified Output Current (Note 1) @TL =90 ℃ Peak Forward Surge Current 8.3ms Single half sine-wave superimposed on rated load (JEDEC Method) I2t Rating for Fusing (t < 8.3ms) Forward Voltage @IF=1.0A Peak Reverse Current @T A =25℃ At Rated DC Blocking Voltage @TA =125℃ IF(AV) 1.0 A IFSM 35 A 5.084 A2s I 2t VFM 0.95 1.3 1.7 5.0 IR V uA 100 Maximum Reverse Recovery Time (Note2 ) TRR 35 nS Typical Junction Capacitance (Note 3) CJ 10 pF RθJA 75 ℃/W TJ -55 to + 150 ℃ TSTG -55 to + 150 ℃ Typical Thermal Resistance Junction to Ambient(Note 4) Operating Temperature Range Storage Temperature Range Note: 1. Leads maintained at ambient temperature at a distance of 9.5mm from the case 2. Reverse Recovery Test Conditions: IF=0.5A, IR=1A, Irr=0.25A. 3. Measured at 1.0 MHz and Applied reverse Voltage of 4.0V D.C 4.Thermal Resistance from Junction to Ambient at 0.375(9.5mm) lead length. version:04 1of3 www.dyelec.com THRU SF18 G SF11G FIG.2-TYPICAL FORWARD CHARACTERISTICS FIG. 1 – FORWARD CURRENT DERATING CURVE 100 INSTANTANEOUS FORWARD CURRENT, (A) AVERAGE FORWARD CURRENT (A) 1.0 0.8 0.6 0.4 0.2 0 50 25 75 100 125 150 175 LEAD TEMPERATURE, . (( ℃)) SF11G-SF14G 10 SF15G-SF16G SF18G 1.0 T A = 25°C PULSE WIDTH 300us 0.1 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 1.8 2.0 INSTANTANEOUS FORWARD VOLTAGE (V) FIG. 4 TYPICAL REVERSE CHARACTERISTICS 100 40 REVERSE LREAKAGE CURRENT (μA) PEAK FORWARD SURGE CURRENT,(A) FIG. 3 – MAXIMUM NON-REPETITIVE SURGE CURRENT 30 20 10 PULSE WIDTH 8.3ms SINGLE HALF-SINE-WAVE (JEDEC METHOD) 0 1 2 10 20 , NUMBER OF CYCLES AT 60Hz 5 50 100 TJ=125°C 10 1 TJ=75°C 0.1 TJ=25°C 0.01 0 20 40 60 80 100 120 140 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) version:04 2of3 www.dyelec.com SF11G THRU SF18 G Important Notice and Disclaimer •Reproducing and modifying information of the document is prohibited without permission from XINNUO. •XINNUOreserves the right to make changes to this document and its products and specifications at any time without notice. Customers should obtain and confirm the latest product information and specifications before final design, purchase or use. •XINNUOdisclaims any and all liability arising out of the application or use of any product including damages incidentally and consequentially occurred. •XINNUO does not assume any and all implied warranties, including warranties of fitness for particular purpose, non-infringement and merchantability. Applications shown on the here in document are examples of standard use and • operation. Customers are responsible in comprehending the suitable use in particular applications. XINNUO makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. •The products shown here in are not designed and authorized for equipments requiring high level of reliability or relating to human life and for any applications concerning life-saving or life-sustaining, such as medical instruments, transportation equipment, aerospace machinery et cetera. Customers using or selling these products for use in such applications do so at their own ris k andagree to fully indemnifyXINNUOfor any damages resulting from such improper use or sale. •Since XINNUO uses lot number as the tracking base, please provide the lot number for tracking when complaining. version:04 3of3 www.dyelec.com
SF18G 价格&库存
很抱歉,暂时无法提供与“SF18G”相匹配的价格&库存,您可以联系我们找货
SF18G
  • 20+0.22443
  • 200+0.18306
  • 600+0.16006
库存:1828
