SB3150L
SB3150L
3.0AMPS. SCHOTTKY BARRIER RECTIFIERS
DO-27/DO-201AD
FEATURE
.High current capability
.Low forward voltage drop
.Low power loss, high efficiency
.High surge capability
.High temperature soldering guaranteed
260°C /10sec/ 0.375" lead length at 5 lbs tension
0.96(24.4)
MIN.
.220(5.6)
.187(5.0)
.375(9.5)
.335(8.5)
MECHANICAL DATA
.Terminal: Plated axial leads solderable per
MIL-STD 202E, method 208C
.Case: Molded with UL-94 Class V-0 recognized
Flame Retardant Epoxy
.Polarity: color band denotes cathode
.Mounting position: any
0.96(24.4)
MIN.
DIA.
.051(1.3)
.043(1.1)
DIA.
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25℃ ambient temperature unless otherwise specified.
Single phase, half wave, 60Hz,resistive or inductive load.
For capacitive load, derate current by 20%
SYM
BOL
Type Number
Maximum Recurrent Peak Reverse Voltage
Maximum RMS Voltage
Maximum DC blocking Voltage
Maximum Average Forward Rectified Current
.375"(9.5mm) lead length at TL =90°C
Peak Forward Surge Current 8.3ms single half Sine-wave
superimposed on rated load (JEDEC method)
Maximum Forward Voltage at 3.0A DC
MaximumDCReverse Current
@TA =25°C
atratedDCblockingvoltage
@TA =100°C
SB3150L
units
VRRM
VRMS
VDC
150
V
105
V
150
V
IF(AV)
3.0
A
IFSM
80.0
A
VF
0.78
V
IR
CJ
R(JA)
TSTG
TJ
Typical Junction Capacitance (Note1)
Typical Thermal Resistance (Note2)
Storage Temperature
Operating Junction Temperature
0.1
5.0
80
pF
50
°C/W
-55 to +175
°C
-55 to +175
°C
Note:
1. Measured at 1.0 MHz and applied reverse voltage of 4.0Vdc
2. Thermal Resistance from Junction to Ambient at 0.375"(9.5mm)lead length, vertical P.C.Board Mounted.
1
mA
SB3150L
RATING AND CHARACTERISTIC CURVES (SB3150L)
FIG.1-TYPICAL FORWARD CURRENT
DERATING CURVE
FIG.2-TYPICAL INSTANTANEOUS FORW ARD
CHARACTERISTICS
3.0
INSTANEOUS FORWARD
CURRENT,(A)
AVERGE FORWARD
RECTIFIED CURRENT,(A)
100
1.5
Single Phase Half Wave
60Hz Resistive or
inductive Load
100
150
10
1
.1
200
TJ=25 ℃
Pulse Width=300 μ s
1% Duty Cycle
.2
0.8
.5
1.1
1.4
INSTANEOUS FORWARD
VOLTAGE,(V)
LEAD TEMPERTURE,( ℃ )
FIG.4-TYPICAL REVERSE
CHARACTERISTICS
FIG.3-MAXIMUN NON-REPETITIVE
FORW ARD SURGE CURRENT
80
8.3ms Single Half
Sine-Wave (JEDEC
Method)
60
INSTANEOUS REVERSE
CURRENT,(mA)
PEAK FORWARD SURGE
CURRENT,(A)
10
40
1.0
TJ=25 ℃
.1
.01
100
60
80
100
120
PERCENT OF RATED PEAK REVERSE
VOLTAGE,(%)
NUMBER OF CYCLES AT 60Hz
2
140
很抱歉,暂时无法提供与“SB3150L”相匹配的价格&库存,您可以联系我们找货
