SB2P50-41
SB2P50-41
    PINGWEI(平伟)
    DO-41(DO-204AL)
    电压:50V 电流:2A
SB2P50-41 数据手册
SB2P50-41 SB2P50-41 2.0AMPS. SCHOTTKY BARRIER RECTIFIERS DO-41 FEATURE .High current capability .Low forward voltage drop .Low power loss, high efficiency .High surge capability .High temperature soldering guaranteed 260°C /1 0sec/0.375" lead length at 5 lbs tension .787(20.0) MIN. .Terminal: Plated axial leads solderable per MIL-STD 202E, method 208C .Case: Molded with UL-94 Class V-0 recognized Flame Retardant Epoxy .Polarity: color band denotes cathode .Mounting position: any DIA. + .205(5.2) .166(4.2) MECHANICAL DATA .110(2.8) .080(2.0) - .787(20.0) MIN. .032(0.8) .025(0.65) DIA. Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25℃ ambient temperature unless otherwise specified. Single phase, half wave, 60Hz,resistive or inductive load. For capacitive load, derate current by 20% SYM BOL Type Number Maximum Recurrent Peak Reverse Voltage Maximum RMS Voltage Maximum DC blocking Voltage Maximum Average Forward Rectified Current .375"(9.5mm) lead length at TL =90°C SB2P50-41 units VRRM VRMS VDC 50 V 35 V 50 V IF(AV) 2.0 A IFSM 50 A VF Max VF Type 0.52 Peak Forward Surge Current 8.3ms single half sine-wave superimposed on rated load (JEDEC method) Maximum Forward Voltage at 2.0A DC @Tj=25°C at 0.5A DC Maximum DC Reverse Current @Tj =25°C atratedDCblockingvoltage @Tj =100°C Typical Junction Capacitance (Note1) Typical Thermal Resistance (Note2) Storage Temperature Operating Junction Temperature 0.36 0.2 IR 10 CJ R(JA) R(JC) TSTG TJ 72 75 10 mA pF °C /W -55 to +150 °C -55 to +150 °C Note: 1. Measured at 1.0 MHz and applied reverse voltage of 4.0Vdc 2. Thermal Resistance from Junction to Ambient at 0.375"(9.5mm)lead length, vertical P.C. Board Mounted -1- V SB2P50-41 RATING AND CHARACTERISTIC CURVES (SB2P50-41) FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE FIG.2-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS 2.0 INSTANEOUS FORWARD CURRENT,(A) AVERGE FORWARD RECTIFIED CURRENT,(A) 10 Single Phase Half Wave 60Hz Resistive or inductive Load 0 0 50 100 150 1 .1 .01 200 TJ=25℃ Pulse Width=300μs 1% Duty Cycle LEAD TEMPERTURE,(℃) .3 .1 0.5 0.9 0.7 INSTANEOUS FORWARD VOLTAGE,(V) FIG.4-TYPICAL REVERSE CHARACTERISTICS FIG.3-MAXIMUN NON-REPETITIVE FORWARD SURGE CURRENT 80 8.3ms Single Half Sine-Wave (JEDEC Method) 60 INSTANEOUS REVERSE CURRENT,(mA) PEAK FORWARD SURGE CURRENT,(A) 10 40 20 0 1 10 1.0 TJ=25℃ .1 .01 100 0 20 40 60 80 100 120 PERCENT OF RATED PEAK REVERSE VOLTAGE,(%) NUMBER OF CYCLES AT 60Hz -2- 140 SB2P50-41 Marking and packaging illustration 1、Marking A SB2P50 PY 41 B C SYMBOL A B C Explanation Color Band Denotes Cathode Product Name Trademark 2、Packaging ITEM SYMBOL SPECIFICATIONS SPECIFICATIONS (mm) (inch) Component alignment Z 1.2max 0.048max Tape width T 6.0±0.4 0.2±0.016 Exposed adhesive E 0.8max 0.032max Body eccentricity |L1-L2| 1.0max 0.040max Component A 5.0±0.5 0.2±0.02 Inner tap B 52.0~53.5 2.06~2.11 NOTE: Each component lead shall be sandwiched between tapes for a minimum of 2.5mm(0.1inch) -3-
SB2P50-41 价格&库存
很抱歉,暂时无法提供与“SB2P50-41”相匹配的价格&库存,您可以联系我们找货
