SB380
SB380
    PINGWEI(平伟)
    DO-27(DO-201AA)
    电压:80V 电流:3A
SB380 数据手册
SB380 SB380 3. 0AMPS. SCHOTTKY BARRIER RECTIFIERS DO-27/DO-201AD FEATURE .High current capability .Low forward voltage drop .Low power loss, high efficiency .High surge capability .High temperature soldering guaranteed 260°C /10sec/ 0.375" lead length at 5 lbs tension 0.96(24.4) MIN. .Terminal: Plated axial leads solderable per MIL-STD 202E, method 208C .Case: Molded with UL-94 Class V-0 recognized Flame Retardant Epoxy(free halogen) .Polarity: color band denotes cathode .Mounting position: any DIA. + .375(9.5) .335(8.5) MECHANICAL DATA .220(5.6) .187(5.0) - 0.96(24.4) MIN. .051(1.3) .043(1.1) DIA. Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25℃ ambient temperature unless otherwise specified. Single phase, half wave, 60Hz,resistive or inductive load. For capacitive load, derate current by 20% Type Number Maximum Recurrent Peak Reverse Voltage Maximum RMS Voltage Maximum DC blocking Voltage Maximum Average Forward Rectified Current .375"(9.5mm) lead length at TL =90°C SYM BOL SB380 units VRRM VRMS VDC 80 V 56 V 80 V IF(AV) 3.0 A IFSM 80.0 A VF 0.85 V Peak Forward Surge Current 8.3ms single half sine-wave superimposed on rated load (JEDEC method) Maximum Forward Voltage at 3.0A DC Maximum DC Reverse Current @TA=25°C atratedDCblockingvoltage @ TA =100°C Typical Junction Capacitance(Note1) Typical Thermal Resistance(Note2) Storage Temperature Operating Junction Temperature 0.05 IR 5.0 CJ R(JA) TSTG TJ 300 pF 40 °C /W -55 to +150 °C -55 to +150 °C Note: 1. Measured at 1.0 MHz and applied reverse voltage of 4.0Vdc 2. Thermal Resistance from Junction to Ambient at 0.375"(9.5mm) lead length, vertical P.C. Board Mounted -1- mA SB380 RATING AND CHARACTERISTIC CURVES (SB380) FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE FIG.2-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS INSTANEOUS FORWARD CURRENT,(A) AVERGE FORWARD RECTIFIED CURRENT,(A) 10 3.0 1.5 Single Phase Half Wave 60Hz Resistive or inductive Load 0 0 50 100 150 1 TJ=25℃ Pulse Width=300μs 1% Duty Cycle .1 .01 200 LEAD TEMPERTURE,(℃) .4 .2 .6 1.0 .8 INSTANEOUS FORWARD VOLTAGE,(V) FIG.4-TYPICAL REVERSE CHARACTERISTICS FIG.3-MAXIMUN NON-REPETITIVE FORWARD SURGE CURRENT 120 8.3ms Single Half Sine-Wave (JEDEC Method) 90 INSTANEOUS REVERSE CURRENT,(mA) PEAK FORWARD SURGE CURRENT,(A) 10 60 30 0 0 10 1.0 TJ=25℃ .1 .01 100 0 20 40 60 80 100 120 PERCENT OF RATED PEAK REVERSE VOLTAGE,(%) NUMBER OF CYCLES AT 60Hz -2- 140 SB380 Marking and packaging illustration 1、Marking A SB380 B C SYMBOL A B C Explanation Color Band Denotes Cathode Product Name Trademark 2、Packaging ITEM SYMBOL SPECIFICATIONS SPECIFICATIONS (mm) (inch) Component alignment Z 1.2max 0.048max Tape width T 6.0±0.4 0.236±0.016 Exposed adhesive E 0.8max 0.032max Body eccentricity |L1-L2| 1.0max 0.040max Component A 10.0±0.5 0.4±0.02 Inner tap B 52.0~53.5 2.05~2.11 NOTE: Each component lead shall be sandwiched between tapes for a minimum of 2.5mm(0.1inch) -3-
SB380
PDF文档中包含以下信息: 1. 物料型号:型号为LM324,是一款四运算放大器集成电路。
2. 器件简介:LM324是一种通用的、高增益、直接耦合的放大器,广泛应用于模拟信号处理。
3. 引脚分配:共有14个引脚,包括电源、地、输入和输出引脚。
4. 参数特性:包括电源电压范围、输入偏置电流、增益带宽积等。
5. 功能详解:LM324可以配置为非反相、反相、差分输入等多种放大器模式。
6. 应用信息:适用于音频放大、信号处理、传感器信号放大等。
7. 封装信息:提供多种封装形式,如SOIC、DIP等。
SB380 价格&库存
很抱歉,暂时无法提供与“SB380”相匹配的价格&库存,您可以联系我们找货
