SB10T100 规格书
SB10T100
10.0AMPS. SCHOTTKY BARRIER RECTIFIERS
FEATURE
DO-27/DO-201AD
.For surface mounted application
.High current capability
.Low forward voltage drop
.Low power loss, high efficiency
.High surge current capability
.High temperature soldering guaranteed:
260°C /10sec/ 0.375" lead length at 5 lbs tension
0.96(24.4)
MIN.
.220(5.6)
.187(5.0)
.375(9.5)
.335(8.5)
MECHANICAL DATA
0.96(24.4)
MIN.
.Terminal: Solder plated
.Case: Molded with UL-94 Class V-0 recognized
Flame Retardant Epoxy (free halogen)
.Polarity: color band denotes cathode
.Mounting position: any
DIA.
.051(1.3)
.043(1.1)
DIA.
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25℃ ambient temperature unless otherwise specified.
Single phase, half wave, 60Hz,resistive or inductive load.
For capacitive load, derate current by 20%
SYM
BOL
Type Number
SB10T100
units
100
V
70
V
Maximum DC blocking Voltage
VRRM
VRMS
VDC
100
V
Maximum Average Forward Rectified Current
IF(AV)
10.0
A
IFSM
120
A
VF(MAX)
0.7
V
Maximum Recurrent Peak Reverse Voltage
Maximum RMS Voltage
Peak Forward Surge Current 8.3ms single half
sine-wave
superimposed
on
rated
load
(JEDEC method)
Maximum Forward Voltage
at 10.0A DC
Maximum DC Reverse Current
@TJ=25°C
atrated DCblockingvoltage
@TJ=100°C
Typical Junction Capacitance (Note1)
Typical Thermal Resistance (Note2)
Storage Temperature
Operating Junction Temperature
0.1
IR
10.0
CJ
R(JL)
TSTG
TJ
800
pF
12
°C/W
-55 to +150
°C
-55 to +150
°C
Note:
1. Measured at 1.0 MHz and applied reverse voltage of 4.0Vdc
2. Thermal Resistance from Junction to Ambient at 0.375"(9.5mm)lead length, vertical P.C.Board Mounted
-1-
mA
SB10T100 规格书
RATING AND CHARACTERISTIC CURVES (SB10T100)
10.0
5.0
Single Phase Half Wave
60Hz Resistive or
inductive Load
FIG.2-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
INSTANEOUS FORWARD
CURRENT,(A)
AVERGE FORWARD
RECTIFIED CURRENT,(A)
FIG.1-TYPICAL FORWARD CURRENT
DERATING CURVE
TJ=25℃
Pulse Width=300μs
1% Duty Cycle
2
LEAD TEMPERTURE,(℃)
80
40
0.8
FIG.4-TYPICAL REVERSE
CHARACTERISTICS
INSTANEOUS REVERSE
CURRENT,(mA)
PEAK FORWARD SURGE
CURRENT,(A)
120
8.3ms Single Half
Sine-Wave (JEDEC
Method)
0.6
INSTANEOUS FORWARD VOLTAGE,(V)
FIG.3-MAXIMUN NON-REPETITIVE
FORWARD SURGE CURRENT
160
4
PERCENT OF RATED PEAK REVERSE
VOLTAGE,(%)
NUMBER OF CYCLES AT 60Hz
-2-
SB10T100 规格书
Marking and packaging illustration
1、Marking
A
SB10T100
PY
B
C
SYMBOL
A
B
C
Explanation
Color Band Denotes Cathode
Product Name
Trademark
2、Packaging
ITEM
SYMBOL
SPECIFICATIONS
SPECIFICATIONS
(mm)
(inch)
Component alignment
Z
1.2max
0.048max
Tape width
T
6.0±0.4
0.236±0.016
Exposed adhesive
E
0.8max
0.032max
Body eccentricity
|L1-L2|
1.0max
0.040max
Component
A
10.0±0.5
0.4±0.02
Inner tap
B
52.0~53.5
2.05~2.11
NOTE:
Each component lead shall be sandwiched between tapes for a minimum of 2.5mm(0.1inch)
-3-
很抱歉,暂时无法提供与“SB10T100”相匹配的价格&库存,您可以联系我们找货
