RFC2K THRU RFC4K 规格书 V1.0
RFC2K THRU RFC4K
0.2AMPS. HIGH VOLTAGE FAST RECOVERY RECTIFIERS
FEATURES
DO-41
·Fast switching
·Low leakage
·Low forward voltage drop
·High current capability
·High surge capability
·High reliability
·High voltage
.787(20.0)
MIN.
.205(5.2)
.166(4.2)
MECHANICAL DATA
·Case: Molded plastic
·Epoxy: UL94V-0 rate flame retardant
·Lead: MIL-STD- 202E, Method 208 guaranteed
·Polarity: Color band denotes cathode end
·Mounting position: Any
·Weight: 0.33 grams
.107(2.7) DIA.
.080(2.0)
.787(20.0)
MIN.
.025(0.64) DIA.
.021(0.53)
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRONICAL CHARACTERISTICS
Ratings at 25℃ ambient temperature unless otherwise specified.Single phase, half wave, 60Hz,resistive or inductive load.For
capacitive load, derate current by 20%.
Type Number
Maximum Recurrent Peak Reverse Voltage
Maximum RMS Voltage
Maximum DC Blocking Voltage
Maximum Average Forward rectified Current
at TA=50°C
SYM
BOL
VRRM
VRMS
VDC
RFC2K
RFC3K
RFC4K
units
2000
2400
3000
V
1400
1680
2100
V
2000
2400
3000
V
IF(AV)
0.2
A
IFSM
30
A
Peak Forward Surge Current 8.3ms single half
sine-wave superimposed on rate load (JEDEC
method)
Maximum Instantaneous forward Voltage at 0.2A
DC
VF
4.0
Maximum DC Reverse Current at Rated DC
Blocking Voltage
TA=25°C
Maximum Full Load Reverse Current Average
Storage Temperature
Operation JunctionTemperature
6.5
V
5.0
IR
µA
100
Full Cycle .375”(9.5mm) lead length at TL=55°C
Maximum Reverse Recovery Time (Note )
5.0
TRR
TSTG
TJ
Note:
Test Conditions: IF=0.5A, IR=1.0A, IRR=0.25A
1
500
nS
-55 to +150
°C
-55 to +125
°C
RATING AND CHARACTERISTIC CURVES (RFC2K THRU RFC4K )
FIG .1-TY PIC A L FO R W A R D C U R R EN T
D ER A TIN G C U R V E
Single Phase H alf
W ave 60H z
R esistive or
inductive Load
0.1
150
100
A M B IEN T TEM PER TU R E,( ℃ )
V
V
00
30
24
TJ=25 ℃
Pulse W idth=300 μ s
1% D uty C ycle
0.01
.001
0.5
200
00
00
V
1.0
INSTANEOUS FORWARD
CURRENT,(A)
0.2
AVERGE FORWARD
RECTIFIED CURRENT,(A)
FIG .2-TY PIC A L IN STA N TA N EO U S FO R W A R D
C H A R A C TER ISTIC S
3.5
2.0
5.0
6.5
IN STA N EO U S FO R W A R D V O LTA G E,(V )
FIG .4-TY PIC A L R EV ER SE
FIG .3-M A X IM U N N O N -R EPETITIV E
FO R W A R D SU R G E C U R R EN T
40
INSTANEOUS REVERSE
CURRENT,(μA)
PEAK FORWARD SURGE
CURRENT,(A)
10
8.3m s Single H alf
Sine-W ave (JED EC
M ethod)
30
1.0
TJ=25 ℃
.1
.01
10
60
N U M B ER O F C Y C LES A T 60H z
FIG .5-TEST C IR C U IT D IA G R A M A N D R EV ER SE
R EC O V ER Y TIM E C H A R A C TER SITIC
50 Ω
N O N IN D U C TIV E
25V dc
(approx)
80
100
120
PER C EN T O F R A TED PEA K R EV ER SE
V O LTA G E,(% )
10 Ω
+0.5A
PU L SE
G EN ER A TO R -0.25A
(N O T E 2)
1Ω
(N O T E 1)
N O N - O SC IL O SC O PE
IN D U C TIV E
-1.0A
N O TES:1. R ise Tim e=7ns m ax, Input
Im pedance= 1 m egohm .22pF.
2. R ise Tim e=10ns m ax,
Souce Im pedance= 50 ohm s.
2
trr
140
很抱歉,暂时无法提供与“RFC3K”相匹配的价格&库存,您可以联系我们找货
