GR8313KG
GR8313KG
    GRENERGY(南京绿芯)
    SOP-8
    3通道电源监控IC
GR8313KG 数据手册
GR8313 3-Channel Supervisor IC for Power Supply Features Description  Over-voltage protection and lockout GR8313 is designed to monitor the outputs of  Under-voltage protection and lockout switching power supply and generate the power  Open drain power good output signal good signal to inform the system. There are three  Built-in 300mS delay for power good important  38mS de-bounce for PSON/ control protection, under-voltage protection and power  73uS de-bounce for noise immunity good signal generating.  Wide power supply range Over-voltage protection (OVP) monitors 3.3V, 5V functions of GR8313: over-voltage and 12V to protect the power supply and system when one of these supply voltages exceeds their normal operation voltage. Under-voltage protection (UVP) monitors 3.3V, 5V Applications  PC power supply  LCD TV power supply and 12V to protect the power supply and system. When power supply is ready or going to shutdown, power good signal generating notifies personal computers; it provides a reliable power supply environment for system. Ordering and Marking Information GR8313 Package Code RoHS Code G: Green (Halogen Free) Device J: DIP-8 K: SOP-8 DIP-8/SOP-8 GR8313 X X XXX Serial No. Code 1 Code 2 Code 1 Year 8 9 A B 2008 2009 2010 2011 Code 2 1 2 3 4 Month Jan. Feb. Mar. Apr. ● ● ● G H I J 2016 2017 2018 2019 9 A B C Sep. Oct. Nov. Dec. Grenergy OPTO Inc. reserves the right to make changes to improve reliability or manufacture ability without notice, and advise customers to obtain the latest version of relevant information to verify before placing orders. 2010.04 Ver. 1.21 Copyright Grenergy OPTO, Inc. www.grenergy-ic.com 1 GR8313 Pin Configuration Top View PGI 1 8 PGO GND 2 7 VCC FPO/ 3 6 VS5 PSON/ 4 5 VS33 Pin Descriptions Pin No. Name Function 1 PGI Power good input signal pin 2 GND Ground 3 FPO/ Inverted fault protection output, open drain output stage 4 PSON/ 5 VS33 3.3V over/under voltage protection input pin 6 VS5 5.0V over/under voltage protection input pin 7 VCC Power supply 8 PGO Power good output signal pin, open drain output stage Remote ON/OFF control input pin Absolute Maximum Ratings VCC, PGI, FPO/ --------------------------------------------------------------------------------------------------------VS5, VS33, PSON/, PGO ---------------------------------------------------------------------------------- -0.5 ~ 16V -0.5 ~ VCC + 0.5V Junction temperature -------------------------------------------------------------------------------------------------------- 150℃ Operating ambient temperature ---------------------------------------------------------------------------------- -20℃ ~ 85℃ Storage temperature range -------------------------------------------------------------------------------------- -65℃ ~ 150℃ DIP-8 package thermal resistance ------------------------------------------------------------------------------------ 100℃/W Power dissipation (DIP-8, at ambient temperature = 85℃) ------------------------------------------------------ 650mW Lead temperature (All Pb free packages, soldering, 10 sec) ------------------------------------------------------ 260℃ ESD voltage protection, human body model ----------------------------------------------------------------------------- 3KV ESD voltage protection, machine model --------------------------------------------------------------------------------- 250V 2010.04 Ver. 1.21 Copyright Grenergy OPTO, Inc. www.grenergy-ic.com 2 GR8313 Recommended Operating Conditions Item Supply voltage VCC Min. Max. Unit 4.5 15 V Block Diagram VCC Delay 4mS FPO/ 30K PSON/ 38mS De-bounce R 73μ S De-bounce S Q 90K 1.25V VS5 + _UV PGO + _OV VS33 300mS Delay + _UV 73μ S De-bounce + _OV + _UV VCC + _OV PGI Protection Regulator Band-Gap (Vref) Power On Reset Clock Generator 2010.04 Ver. 1.21 Copyright Grenergy OPTO, Inc. www.grenergy-ic.com 75mS Delay PGI GND 3 GR8313 Timing Chart 1. PSON/ Signal Characteristics PSON/ FPO/ PGI VS33 VS5 VS12 PGO Tb1 Tb3+Td1 Tb1 Td3 2. Over-Voltage Characteristics PSON/ FPO/ PGI VS33 VS5 VS33 VS12 VS5 VS12 PGO Tb1 Tb2 Tb1 Tb3+Td1 Tb1 Td3 2010.04 Ver. 1.21 Copyright Grenergy OPTO, Inc. www.grenergy-ic.com 4 GR8313 Timing Chart (Cont.) 3. Under-Voltage Characteristics PSON/ FPO/ PGI 3.3V 5V VS33 12V VS5 VS12 PGO Tb1 Tb1 Td2 Tb1 Tb3+Td1 Tb2 Td3 4. PGI Characteristics PSON/ FPO/ PGI_1 PGI_2 PGI VS33 VS5 VS12 PGO Tb3+Td1 Tb1 Tb3 Tb1 Tb3+Td1 Td3 1.3V PGI 1.2V 1.13V 0.63V Enable UVP 75mS 300mS 2010.04 Ver. 1.21 Copyright Grenergy OPTO, Inc. www.grenergy-ic.com Enable PGO 5 GR8313 Electrical Characteristics (TA = +25℃ Parameter unless otherwise stated, VCC = 12.0V) Conditions Symbol Min. Typ. Max. Unit VCC 4.0 5.0 16.0 V 2 3 mA POWER SUPPLY Supply voltage Supply current VPSON/ = 5V Ivcc OVER-VOLTAGE PROTECTION VS33 3.7 3.9 4.1 V VS5 5.7 6.1 6.5 V VS12 13.2 13.8 14.4 V VS33 2.0 2.2 2.4 V VS5 3.3 3.5 3.7 V VS12 8.5 9.0 9.5 V High-level input threshold voltage VIH 1.4 1.5 Low-level input threshold voltage VIL 1.0 1.1 V PGI_1 VPGI_1 1.3 1.37 V PGI_2 VPGI_2 1.13 1.2 VPGI,Td2 0.6 0.63 0.75 V 1.05 1.13 1.21 V Over-voltage threshold UNDER-VOLTAGE PROTECTION Under-voltage threshold PSON/ V PGI AND PGO, FPO/ PGI threshold voltage Threshold voltage for Td2 Disable UVP threshold voltage Leakage current (PGO) Low level output voltage (PGO) Leakage current (FPO/) Low level output voltage(FPO/) V VPGO = 5V ILKG 5 uA ISINK = 10mA VOL 0.35 V VFPO/ = 5V ILKG 5 uA ISINK = 10mA VOL 0.35 V SWITCHING CHARACTERISTICS PSON/ de-bounce time Tb1 24 38 61 mS FPO/ Noise de-glitch time Tb2 47 73 110 uS PGO Noise de-glitch time Tb3 47 73 110 uS PGI to PGO delay time Td1 200 300 480 mS UVP protection delay time Td2 49 75 114 mS PGO to FPO/ delay time Td3 2 4 6 mS 2010.04 Ver. 1.21 Copyright Grenergy OPTO, Inc. www.grenergy-ic.com 6 GR8313 Function Table PGI PSON_N UV OV FPO/ PGO < 0.63V L No No L L < 0.63V L No Yes H L < 0.63V L Yes No L L 0.63V < PGI < 1.3V L No No L L 0.63V < PGI < 1.3V L No Yes H L 0.63V < PGI < 1.3V L Yes No H L PGI > 1.3V L No No L H PGI > 1.3V L No Yes H L PGI > 1.3V L Yes No H L X H X X H L X = Don't care 1 A 2 3 4 Typical Application Circuit A +5V RAIL +5V OUTPUT +3.3V RAIL +3.3V OUTPUT +12V RAIL +12V OUTPUT B B C1 0.1uF R4 1K +5VD D1 4148 R2 22K D3 4148 R3 2.7K 1 2 PGI PGO GND VCC 8 PGO 7 +5VSB U1 D2 4148 GR8313 3 +5VSB R1 1K C FPO VS5 6 LED1 4 PSON PSON VS33 5 C C2 0.1uF D C3 1uF C4 0.1uF C5 0.1uF Application Information C6 0.1uF Title Size D Number Revision A4 Date: File: 2008/11/24 C:\Documents and Settings\..\GR8313.SCH Sheet of Drawn By : 1 2 3 4 1. The power supply bypass capacitor C3 suggests to be 0.1uF ~ 10uF and around the VCC pin and GND pin while layout. Other bypass capacitors suggests to be 0.01uF ~ 1uF. 2010.04 Ver. 1.21 Copyright Grenergy OPTO, Inc. www.grenergy-ic.com 7 GR8313 Package Information DIP-8 SYMBOL MILLIMETERS MIN. INCHES MAX. A MIN. MAX. 5.33 0.210 A1 0.38 0.015 A2 2.92 4.95 0.115 0.195 b 0.36 0.56 0.014 0.022 b2 1.14 1.78 0.045 0.070 c 0.20 0.35 0.008 0.014 D 9.01 10.16 0.355 0.400 D1 0.13 E 7.62 8.26 0.300 0.325 E1 6.10 7.11 0.240 0.280 0.005 e 2.54 BSC 0.100 BSC eA 7.62 BSC 0.300 BSC eB L 10.92 2.92 3.81 0.430 0.115 0.150 Note: 1. Followed from JEDEC MS-001 BA. 2. Dimension D, D1 and E1 do not include mold flash or protrusions. Mold flash or protrusions shall not exceed 10 mil. 2010.04 Ver. 1.21 Copyright Grenergy OPTO, Inc. www.grenergy-ic.com 8 GR8313 Package Information SOP-8 SYMBOL INCHES MILLIMETERS MIN. MAX. A MIN. MAX. 1.75 A1 0.10 A2 1.25 b 0.31 0.51 0.012 0.020 c 0.17 0.25 0.007 0.010 D 4.80 5.00 0.189 0.197 E 5.80 6.20 0.228 0.244 E1 3.80 4.00 0.150 0.157 e 0.25 0.069 0.004 0.010 0.049 1.27 BSC 0.050 BSC h 0.25 0.50 0.010 0.020 L 0.40 1.27 0.016 0.050 θ o 0 o 8 o 0 o 8 Note: 1. Followed from JEDEC MS-012 AA. 2. Dimension “D” does not include mold flash, protrusions or gate burrs. Mold flash, protrusion or gate burrs shall not exceed 6 mil per side. 3. Dimension “E1” does not include inter-lead flash or protrusions. Inter-lead flash and protrusions shall not exceed 10 mil per side. 2010.04 Ver. 1.21 Copyright Grenergy OPTO, Inc. www.grenergy-ic.com 9 GR8313 Carrier Tape & Reel Dimensions SOP- 8 Application A H 330.0±2.0 50 MIN. P0 P1 P2 D0 D1 4.0±0.10 8.0±0.10 2.0±0.05 1.5+0.10 -0.00 1.5 MIN. SOP-8 T1 C d 12.4+2.00 13.0+0.50 -0.00 -0.20 D 1.5 MIN. W E1 20.2 MIN. 12.0±0.30 1.75±0.10 T A0 B0 F 5.5±0.05 K0 0.6+0.00 6.40±0.20 5.20±0.20 2.10±0.20 -0.40 (mm) Devices Per Unit Application Carrier Width Cover Tape Width Devices Per Reel SOP- 8 12 - 2500 ________________________________________________________________________ Grenergy OPTO, Inc. reserves the right to make corrections, modifications, enhancements, improvements, and other changes to its products and services at any time and to discontinue any product or service without notice. Customers should obtain the latest relevant information before placing orders and should verify that such information is current and complete. 2010.04 Ver. 1.21 Copyright Grenergy OPTO, Inc. www.grenergy-ic.com 10
GR8313KG 价格&库存
很抱歉,暂时无法提供与“GR8313KG”相匹配的价格&库存,您可以联系我们找货
