BZX55C2V2-M
BZX55C2V2-M
    ST(先科)
    DO-35(DO-204AH)
    BZX55C2V2-M 停产
BZX55C2V2-M 数据手册
BZX55C-M Silicon Planar Zener Diodes 注:用 SL-B6 晶片 Max. 0.5 Min. 27.5 Max. 1.9 Black Cathode Band Black Part No. Black "ST" Brand XXX Max. 3.9 ST Min. 27.5 Glass Case DO-35 Dimensions in mm Absolute Maximum Ratings (Ta = 25 OC) Parameter Power Dissipation Junction Temperature Storage Temperature Range 1) Ptot Value Unit 1) mW 500 Tj 175 O C Tstg - 55 to + 175 O C Valid provided that leads are kept at ambient temperature at a distance of 8 mm from case Characteristics at Ta = 25 OC Parameter Thermal Resistance Junction to Ambient Air Forward Voltage at IF = 100 mA 1) Symbol Symbol Max. Unit RθJA 0.3 1) K/mW VF 1 V Valid provided that leads are kept at ambient temperature at a distance of 8 mm from case SEMTECH ELECTRONICS LTD. Subsidiary of Sino-Tech International (BVI) Limited ® Dated:28/11/2011 Rev:02 BZX55C-M Characteristics at Ta = 25 OC Zener Voltage Range Type VZnom (V) 1) VZT Zener Impedance Reverse Current at lZT ZZT at lZT ZZK at IZK IR at VR Min. (V) Max. (V) (mA) Max. (Ω) (mA) Max. (Ω) (mA) Max. (µA) (V) BZX55C2V0 2.0 1.8 2.15 5 85 5 600 1 100 1 BZX55C2V2 2.2 2.08 2.33 5 85 5 600 1 75 1 BZX55C2V4 2.4 2.28 2.56 5 85 5 600 1 50 1 BZX55C2V7 2.7 2.5 2.9 5 85 5 600 1 10 1 BZX55C3V0 3.0 2.8 3.2 5 85 5 600 1 4 1 BZX55C3V3 3.3 3.1 3.5 5 85 5 600 1 2 1 BZX55C3V6 3.6 3.4 3.8 5 85 5 600 1 2 1 BZX55C3V9 3.9 3.7 4.1 5 85 5 600 1 2 1 BZX55C4V3 4.3 4 4.6 5 75 5 600 1 1 1 BZX55C4V7 4.7 4.4 5 5 60 5 600 1 0.5 1 BZX55C5V1 5.1 4.8 5.4 5 35 5 550 1 0.1 1 BZX55C5V6 5.6 5.2 6 5 25 5 450 1 0.1 1 BZX55C6V2 6.2 5.8 6.6 5 10 5 200 1 0.1 2 BZX55C6V8 6.8 6.4 7.2 5 8 5 150 1 0.1 3 BZX55C7V5 7.5 7 7.9 5 7 5 50 1 0.1 5 BZX55C8V2 8.2 7.7 8.7 5 7 5 50 1 0.1 6.2 BZX55C9V1 9.1 8.5 9.6 5 10 5 50 1 0.1 6.8 BZX55C10 10 9.4 10.6 5 15 5 70 1 0.1 7.5 BZX55C11 11 10.4 11.6 5 20 5 70 1 0.1 8.2 BZX55C12 12 11.4 12.7 5 20 5 90 1 0.1 9.1 BZX55C13 13 12.4 14.1 5 26 5 110 1 0.1 10 BZX55C15 15 13.8 15.6 5 30 5 110 1 0.1 11 BZX55C16 16 15.3 17.1 5 40 5 170 1 0.1 12 BZX55C18 18 16.8 19.1 5 50 5 170 1 0.1 13 BZX55C20 20 18.8 21.2 5 55 5 220 1 0.1 15 BZX55C22 22 20.8 23.3 5 55 5 220 1 0.1 16 BZX55C24 24 22.8 25.6 5 80 5 220 1 0.1 18 BZX55C27 27 25.1 28.9 5 80 5 220 1 0.1 20 BZX55C30 30 28 32 5 80 5 220 1 0.1 22 BZX55C33 33 31 35 5 80 5 220 1 0.1 24 BZX55C36 36 34 38 5 80 5 220 1 0.1 27 BZX55C39 39 37 41 2.5 90 2.5 500 0.5 0.1 30 BZX55C43 43 40 46 2.5 90 2.5 500 0.5 0.1 33 BZX55C47 47 44 50 2.5 110 2.5 600 0.5 0.1 36 1) Tested with pulses tp = 20 ms. SEMTECH ELECTRONICS LTD. Subsidiary of Sino-Tech International (BVI) Limited ® Dated:28/11/2011 Rev:02
BZX55C2V2-M 价格&库存
很抱歉,暂时无法提供与“BZX55C2V2-M”相匹配的价格&库存,您可以联系我们找货
