N76E003AS20
N76E003AS20
    NUVOTON(新唐)
    SOIC-20
    8051 N76 微控制器 IC 8 位 16MHz 18KB(18K x 8) 闪存 20-SOP
N76E003AS20 数据手册
N76E003 Datasheet Nuvoton 1T 8051-based Microcontroller N76E003 Datasheet Aug. 03, 2020 Page 1 of 274 Rev. 1.09 N76E003 Datasheet TABLE OF CONTENTS 1. GENERAL DESCRIPTION ............................................................................................................................... 6 2. FEATURES ....................................................................................................................................................... 7 3. BLOCK DIAGRAM ......................................................................................................................................... 10 4. PIN CONFIGURATION ................................................................................................................................... 11 5. MEMORY ORGANIZATION ........................................................................................................................... 18 5.1 Program Memory .................................................................................................................................... 18 5.2 Data Memory .......................................................................................................................................... 20 5.3 On-Chip XRAM ....................................................................................................................................... 22 5.4 Non-Volatile Data Storage ...................................................................................................................... 22 6. SPECIAL FUNCTION REGISTER (SFR) ....................................................................................................... 23 6.1 ALL SFR DESCRIPTION........................................................................................................................ 28 7. I/O PORT STRUCTURE AND OPERATION .................................................................................................. 86 7.1 Quasi-Bidirectional Mode........................................................................................................................ 86 7.2 Push-Pull Mode ...................................................................................................................................... 87 7.3 Input-Only Mode ..................................................................................................................................... 88 7.4 Open-Drain Mode ................................................................................................................................... 88 7.5 Read-Modify-Write Instructions .............................................................................................................. 89 7.6 Control Registers of I/O Ports ................................................................................................................. 89 7.6.1 Input and Output Data Control ..................................................................................................... 90 7.6.2 Output Mode Control.................................................................................................................... 91 7.6.3 Input Type .................................................................................................................................... 93 7.6.4 Output Slew Rate Control ............................................................................................................ 95 8. TIMER/COUNTER 0 AND 1............................................................................................................................ 97 8.1 Mode 0 (13-Bit Timer) ........................................................................................................................... 100 8.2 Mode 1 (16-Bit Timer) ........................................................................................................................... 101 8.3 Mode 2 (8-Bit Auto-Reload Timer)........................................................................................................ 101 8.4 Mode 3 (Two Separate 8-Bit Timers) ................................................................................................... 102 9. TIMER 2 AND INPUT CAPTURE ................................................................................................................. 104 9.1 Auto-Reload Mode ................................................................................................................................ 108 9.2 Compare Mode ..................................................................................................................................... 109 9.3 Input Capture Module ........................................................................................................................... 109 10. TIMER 3 ...................................................................................................................................................... 115 11. WATCHDOG TIMER (WDT) ....................................................................................................................... 117 11.1 Time-Out Reset Timer ........................................................................................................................ 119 11.2 General Purpose Timer ...................................................................................................................... 120 12. SELF WAKE-UP TIMER (WKT) ................................................................................................................. 122 13. SERIAL PORT (UART) ............................................................................................................................... 124 13.1 Mode 0 ................................................................................................................................................ 129 13.2 Mode 1 ................................................................................................................................................ 130 13.3 Mode 2 ................................................................................................................................................ 131 13.4 Mode 3 ................................................................................................................................................ 132 13.5 Baud Rate ........................................................................................................................................... 132 13.6 Framing Error Detection ..................................................................................................................... 136 13.7 Multiprocessor Communication .......................................................................................................... 136 13.8 Automatic Address Recognition ......................................................................................................... 137 14. SERIAL PERIPHERAL INTERFACE (SPI) ................................................................................................ 141 14.1 Functional Description ........................................................................................................................ 141 14.2 Operating Modes ................................................................................................................................ 147 Aug. 03, 2020 Page 2 of 274 Rev. 1.09 N76E003 Datasheet 14.2.1 Master Mode ............................................................................................................................ 147 14.2.2 Slave Mode .............................................................................................................................. 147 14.3 Clock Formats and Data Transfer ...................................................................................................... 148 14.4 Slave Select Pin Configuration ........................................................................................................... 150 14.5 Mode Fault Detection.......................................................................................................................... 150 14.6 Write Collision Error ............................................................................................................................ 151 14.7 Overrun Error ...................................................................................................................................... 151 14.8 SPI Interrupt ........................................................................................................................................ 152 2 15. INTER-INTEGRATED CIRCUIT (I C) ......................................................................................................... 153 15.1 Functional Description ........................................................................................................................ 153 15.1.1 START and STOP Condition ................................................................................................... 154 15.1.2 7-Bit Address with Data Format ............................................................................................... 155 15.1.3 Acknowledge ............................................................................................................................ 156 15.1.4 Arbitration ................................................................................................................................. 156 2 15.2 Control Registers of I C ...................................................................................................................... 157 15.3 Operating Modes ................................................................................................................................ 161 15.3.1 Master Transmitter Mode ......................................................................................................... 161 15.3.2 Master Receiver Mode ............................................................................................................. 162 15.3.3 Slave Receiver Mode ............................................................................................................... 163 15.3.4 Slave Transmitter Mode ........................................................................................................... 164 15.3.5 General Call ............................................................................................................................. 165 15.3.6 Miscellaneous States ............................................................................................................... 166 2 15.4 Typical Structure of I C Interrupt Service Routine .............................................................................. 168 2 15.5 I C Time-Out ....................................................................................................................................... 172 2 15.6 I C Interrupt......................................................................................................................................... 172 16. PIN INTERRUPT ......................................................................................................................................... 174 17. PULSE WIDTH MODULATED (PWM) ....................................................................................................... 177 17.1 Functional Description ........................................................................................................................ 177 17.1.1 PWM Generator ....................................................................................................................... 177 17.1.2 PWM Types ............................................................................................................................. 186 17.1.3 Operation Modes ..................................................................................................................... 188 17.1.4 Mask Output Control ................................................................................................................ 190 17.1.5 Fault Brake............................................................................................................................... 191 17.1.6 Polarity Control ........................................................................................................................ 192 17.2 PWM Interrupt ..................................................................................................................................... 193 18. 12-BIT ANALOG-TO-DIGITAL CONVERTER (ADC) ................................................................................ 195 18.1 Functional Description ........................................................................................................................ 195 18.1.1 ADC Operation......................................................................................................................... 195 18.1.2 ADC Conversion Triggered by External Source ...................................................................... 196 18.1.3 ADC Conversion Result Comparator ....................................................................................... 197 18.1.4 Internal Band-gap .................................................................................................................... 198 18.2 Control Registers of ADC ................................................................................................................... 201 19. TIMED ACCESS PROTECTION (TA) ........................................................................................................ 205 20. INTERRUPT SYSTEM ................................................................................................................................ 207 20.1 Interrupt Overview .............................................................................................................................. 207 20.2 Enabling Interrupts .............................................................................................................................. 208 20.3 Interrupt Priorities ............................................................................................................................... 211 20.4 Interrupt Service ................................................................................................................................. 215 20.5 Interrupt Latency ................................................................................................................................. 215 20.6 External Interrupt Pins ........................................................................................................................ 216 Aug. 03, 2020 Page 3 of 274 Rev. 1.09 N76E003 Datasheet 21. IN-APPLICATION-PROGRAMMING (IAP) ................................................................................................ 218 21.1 IAP Commands ................................................................................................................................... 221 21.2 IAP User Guide ................................................................................................................................... 222 21.3 Using Flash Memory as Data Storage ................................................................................................ 222 21.4 In-System-Programming (ISP) ........................................................................................................... 224 22. POWER MANAGEMENT............................................................................................................................ 229 22.1 Power-Down Mode ............................................................................................................................. 230 23. CLOCK SYSTEM ........................................................................................................................................ 231 23.1 System Clock Sources........................................................................................................................ 231 23.1.1 Internal Oscillators ................................................................................................................... 231 23.2 System Clock Switching ..................................................................................................................... 232 23.3 System Clock Divider .......................................................................................................................... 233 23.4 System Clock Output .......................................................................................................................... 234 24. POWER MONITORING .............................................................................................................................. 235 24.1 Power-On Reset (POR) ...................................................................................................................... 235 24.2 Brown-Out Detection (BOD) ............................................................................................................... 236 25. RESET......................................................................................................................................................... 241 25.1 Power-On Reset ................................................................................................................................. 241 25.2 Brown-Out Reset ................................................................................................................................ 241 25.3 External Reset .................................................................................................................................... 242 25.4 Hard Fault Reset ................................................................................................................................. 243 25.5 Watchdog Timer Reset ....................................................................................................................... 243 25.6 Software Reset ................................................................................................................................... 244 25.7 Boot Select ......................................................................................................................................... 245 25.8 Reset State ......................................................................................................................................... 246 26. AUXILIARY FEATURES............................................................................................................................. 247 26.1 96-bit UID ............................................................................................................................................ 247 27. ON-CHIP-DEBUGGER (OCD) .................................................................................................................... 248 27.1 Functional Description ........................................................................................................................ 248 27.2 Limitation of OCD ............................................................................................................................... 248 28. CONFIG BYTES ......................................................................................................................................... 250 29. IN-CIRCUIT-PROGRAMMING (ICP) .......................................................................................................... 253 29.1 Application Circuit ............................................................................................................................... 254 29.1.1 Power Supply Scheme ............................................................................................................ 254 29.1.2 Peripheral Application Scheme ................................................................................................ 255 30. INSTRUCTION SET .................................................................................................................................... 256 31. ELECTRICAL CHARACTERISTICS .......................................................................................................... 260 31.1 Absolute Maximum Ratings ................................................................................................................ 260 31.2 D.C. Electrical Characteristics ............................................................................................................ 260 31.3 A.C. Electrical Characteristics ............................................................................................................ 262 31.4 Analog Electrical Characteristics ........................................................................................................ 264 31.5 ESD Characteristics............................................................................................................................ 265 31.6 EFT Characteristics ............................................................................................................................ 265 31.7 Flash DC Electrical Characteristics .................................................................................................... 266 32. PACKAGE DIMENSIONS........................................................................................................................... 267 32.1 20-pin TSSOP – 4.4 X 6.5 mm ........................................................................................................... 267 32.2 20-pin SOP - 300 mil .......................................................................................................................... 268 32.3 20-pin QFN 3.0 X 3.0 mm for N76E003AQ20 .................................................................................... 269 32.3.1 N76E003AQ20 Package Demission ........................................................................................ 269 32.3.2 N76E003AQ20 PCB Layout Recommend ............................................................................... 270 Aug. 03, 2020 Page 4 of 274 Rev. 1.09 N76E003 Datasheet 32.4 20-pin QFN 3.0 X 3.0 mm for N76E003BQ20 .................................................................................... 271 32.5 20-pin QFN 3.0 X 3.0 mm for N76E003CQ20 .................................................................................... 272 33. DOCUMENT REVISION HISTORY ............................................................................................................ 273 Aug. 03, 2020 Page 5 of 274 Rev. 1.09 N76E003 Datasheet 1. GENERAL DESCRIPTION The N76E003 is an embedded flash type, 8-bit high performance 1T 8051-based microcontroller. The instruction set is fully compatible with the standard 80C51 and performance enhanced. The N76E003 contains a up to 18K Bytes of main Flash called APROM, in which the contents of User Code resides. The N76E003 Flash supports In-Application-Programming (IAP) function, which enables on-chip firmware updates. IAP also makes it possible to configure any block of User Code array to be used as nonvolatile data storage, which is written by IAP and read by IAP or MOVC instruction. There is an additional Flash called LDROM, in which the Boot Code normally resides for carrying out In-System-Programming (ISP). The LDROM size is configurable with a maximum of 4K Bytes. To facilitate programming and verification, the Flash allows to be programmed and read electronically by parallel Writer or In-Circuit-Programming (ICP). Once the code is confirmed, user can lock the code for security. The N76E003 provides rich peripherals including 256 Bytes of SRAM, 768 Bytes of auxiliary RAM (XRAM), Up to 18 general purpose I/O, two 16-bit Timers/Counters 0/1, one 16-bit Timer2 with three-channel input capture module, one Watchdog Timer (WDT), one Self Wake-up Timer (WKT), one 16-bit auto-reload Timer3 for general purpose or baud rate generator, two UARTs with frame error detection and automatic address 2 recognition, one SPI, one I C, five enhanced PWM output channels, eight-channel shared pin interrupt for all I/O, and one 12-bit ADC. The peripherals are equipped with 18 sources with 4-level-priority interrupts capability. The N76E003 is equipped with three clock sources and supports switching on-the-fly via software. The three clock sources include external clock input, 10 kHz internal oscillator, and one 16 MHz internal precise oscillator that is factory trimmed to ±1% at room temperature. The N76E003 provides additional power monitoring detection such as power-on reset and 4-level brown-out detection, which stabilizes the power-on/off sequence for a high reliability system design. The N76E003 microcontroller operation consumes a very low power with two economic power modes to reduce power consumption - Idle and Power-down mode, which are software selectable. Idle mode turns off the CPU clock but allows continuing peripheral operation. Power-down mode stops the whole system clock for minimum power consumption. The system clock of the N76E003 can also be slowed down by software clock divider, which allows for a flexibility between execution performance and power consumption. With high performance CPU core and rich well-designed peripherals, the N76E003 benefits to meet a general purpose, home appliances, or motor control system accomplishment. Aug. 03, 2020 Page 6 of 274 Rev. 1.09 N76E003 Datasheet 2. FEATURES  CPU: – Fully static design 8-bit high performance 1T 8051-based CMOS microcontroller. – Instruction set fully compatible with MCS-51. – 4-priority-level interrupts capability. – Dual Data Pointers (DPTRs).  Operating: – Wide supply voltage from 2.4V to 5.5V. – Wide operating frequency up to 16 MHz. – Industrial temperature grade: -40℃ to +105℃.  Memory: – Up to 18K Bytes of APROM for User Code. – Configurable 4K/3K/2K/1K/0K Bytes of LDROM, which provides flexibility to user developed Boot Code. – Flash Memory accumulated with pages of 128 Bytes each. – Built-in In-Application-Programmable (IAP). – Code lock for security. – 256 Bytes on-chip RAM. – Additional 768 Bytes on-chip auxiliary RAM (XRAM) accessed by MOVX instruction.  Clock sources: – 16 MHz high-speed internal oscillator trimmed to ±1% when VDD 5.0V, ±2% in all conditions. – 10 kHz low-speed internal oscillator. – External clock input. – On-the-fly clock source switch via software. – Programmable system clock divider up to 1/512.  Peripherals: – Up to 17 general purpose I/O pins and one input-only pin. All output pins have individual 2-level slew rate control. – Standard interrupt pins ̅̅̅̅̅̅̅ and ̅̅̅̅̅̅̅. – Two 16-bit Timers/Counters 0 and 1 compatible with standard 8051. Aug. 03, 2020 Page 7 of 274 Rev. 1.09 N76E003 Datasheet – One 16-bit Timer 2 with three-channel input capture module and 9 input pin can be selected. – One 16-bit auto-reload Timer 3, which can be the baud rate clock source of UARTs. – One 16-bit PWM counter interrupt for timer. – One programmable Watchdog Timer (WDT) clocked by dedicated 10 kHz internal source. – One dedicated Self Wake-up Timer (WKT) for self-timed wake-up for power reduced modes. – Two full-duplex UART ports with frame error detection and automatic address recognition. TXD and RXD pins of UART0 exchangeable via software. – One SPI port with master and slave modes, up to 8 Mbps when system clock is 16 MHz. 2 – One I C bus with master and slave modes, up to 400 kbps data rate. – Three pairs, six channels of pulse width modulator (PWM) output, 10 output pins can be selected., up to 16-bit resolution, with different modes and Fault Brake function for motor control. – Eight channels of pin interrupt, shared for all I/O ports, with variable configuration of edge/level detection. – One 12-bit ADC, up to 500 ksps converting rate, hardware triggered and conversion result compare facilitating motor control.  Power management: – Two power reduced modes: Idle and Power-down mode.  Power monitor: – Brown-out detection (BOD) with low power mode available, 4-level selection, interrupt or reset options. – Power-on reset (POR).  Strong ESD and EFT immunity.  Development Tools: – Nuvoton On-Chip-Debugger (OCD) with KEIL TM development environment. – Nuvoton In-Circuit-Programmer (ICP). – Nuvoton In-System-Programming (ISP) via UART. Aug. 03, 2020 Page 8 of 274 Rev. 1.09 N76E003 Datasheet  Part numbers and packages: Part Number APROM LDROM Package N76E003AT20 18K Bytes shared with LDROM Up to 4K Bytes TSSOP 20 N76E003AS20 18K Bytes shared with LDROM Up to 4K Bytes SOP 20 N76E003AQ20 18K Bytes shared with LDROM Up to 4K Bytes QFN 20* N76E003BQ20 18K Bytes shared with LDROM Up to 4K Bytes QFN 20* N76E003CQ20 18K Bytes shared with LDROM Up to 4K Bytes QFN 20* *The QFN20 package demission between N76E003AQ20 , N76E003BQ20 & N76E003CQ20 is different. For detail please reference Chapter32. PACKAGE DIMENSIONS. Aug. 03, 2020 Page 9 of 274 Rev. 1.09 N76E003 Datasheet 3. BLOCK DIAGRAM Figure 5.1-1 shows the N76E003 functional block diagram and gives the outline of the device. User can find all the peripheral functions of the device in the diagram. Power-on Reset and Brown-out Detection VDD GND RST 1T High Performance 8051 Core [1] Max. 18K Bytes APROM Flash Timer 0/1 Max. 4K Bytes LDROM Flash Timer 2 with Input Capture T0 (P0.5) T1 (P0.0) 9 IC0~IC7 (P1.5, P1[2:0], P0.0, P0.1, P0[5:3]) Timer 3 768 Bytes XRAM (Auxiliary RAM) P0[7:0] P1[7:0] P20 P30 8 Self Wake-up Timer 8-bit Internal Bus 256 Bytes Internal RAM P0 Serial Ports (UARTs) TXD (P0.6 or P0.7) RXD (P0.7 or P0.6) TXD_1 (P1.6) RXD_1 (P0.2) I2C SDA (P1.4 or P1.6) SCL (P1.3 or P0.2) 8 P1 1 SPI 10 [1] P2 PWM 1 MOSI (P0.0) MISO (P0.1) SS (P1.5) SPCLK (P1.0) PWM0~PWM5 (P1.5, P1.4, P1.2, P1.1, P1.0, P0.0, P0.1, P0[3:5]) FB (P1.4) [2] P3 INT0 (P3.0) INT1 (P1.7) External Interrupt Pin Interrupt 8 Any Port Watchdog Timer 8 12-bit ADC AIN0~7 (P1.7, P3.0, P0[7:3], P1.1) STADC (P1.3 or P0.4) System Clock Power Managment XIN [2] Clock Divider 16 MHz/10 kHz Internal RC Oscillator [1] P2.0 is shared with RST. [2] P3.0 is shared with XIN. Figure 5.1-1. Functional Block Diagram Aug. 03, 2020 Page 10 of 274 Rev. 1.09 N76E003 Datasheet 4. PIN CONFIGURATION PWM2/IC6/T0/AIN4/P0.5 1 20 P0.4/AIN5/STADC/PWM3/IC3 TXD/AIN3/P0.6 2 19 P0.3/PWM5/IC5/AIN6 RXD/AIN2/P0.7 3 18 P0.2/ICPCK/OCDCK/RXD_1/[SCL] RST/P2.0 4 17 P0.1/PWM4/IC4/MISO INT0/OSCIN/AIN1/P3.0 5 16 P0.0/PWM3/IC3/MOSI/T1 N76E003AT20 INT1/AIN0/P1.7 6 15 P1.0/PWM2/IC2/SPCLK GND 7 14 P1.1/PWM1/IC1/AIN7/CLO [SDA]/TXD_1/ICPDA/OCDDA/P1.6 8 13 P1.2/PWM0/IC0 VDD 9 12 P1.3/SCL/[STADC] 10 11 P1.4/SDA/FB/PWM1 PWM5/IC7/SS/P1.5 1. [ ] alternate function remapping option (if the same alternate function is shown twice, it indicates an exclusive choice not a duplication of the function). Figure 5.1-1. Pin Assignment of TSSOP-20 Package Aug. 03, 2020 Page 11 of 274 Rev. 1.09 N76E003 Datasheet PWM2/IC6/T0/AIN4/P0.5 1 20 P0.4/AIN5/STADC/PWM3/IC3 TXD/AIN3/P0.6 2 19 P0.3/PWM5/IC5/AIN6 RXD/AIN2/P0.7 3 18 P0.2/ICPCK/OCDCK/RXD_1/[SCL] RST/P2.0 4 17 P0.1/PWM4/IC4/MISO INT0/OSCIN/AIN1/P3.0 5 16 P0.0/PWM3/IC3/MOSI/T1 N76E003AS20 INT1/AIN0/P1.7 6 15 P1.0/PWM2/IC2/SPCLK GND 7 14 P1.1/PWM1/IC1/AIN7/CLO [SDA]/TXD_1/ICPDA/OCDDA/P1.6 8 13 P1.2/PWM0/IC0 VDD 9 12 P1.3/SCL/[STADC] 10 11 P1.4/SDA/FB/PWM1 PWM5/IC7/SS/P1.5 1. [ ] alternate function remapping option (if the same alternate function is shown twice, it indicates an exclusive choice not a duplication of the function). Figure 5.1-2. Pin Assignment of SOP-20 Package Aug. 03, 2020 Page 12 of 274 Rev. 1.09 P1.3/SCL/[STADC] P0.0/PWM3/IC3/MOSI/T1 P0.1/PWM4/IC4/MISO P0.2/ICPCK/OCDCK/RXD_1/[SCL] P0.3/PWM5/IC5/AIN6 N76E003 Datasheet 15 14 13 12 11 AIN5/STADC/PWM3/IC3/P0.4 16 10 P1.4/SDA/FB/PWM1 INT0/OSCIN/AIN1/P3.0 17 9 P1.2/PWM0/IC0 RST/P2.0 18 8 P1.1/PWM1/IC1/AIN7/CLO TXD/AIN3/P0.6 19 7 P1.0/PWM2/IC2/SPCLK PWM2/IC6/T0/AIN4/P0.5 20 6 P1.5/PWM5/IC7/SS 1 2 3 4 5 RXD/AIN2/P0.7 INT1/AIN0/P1.7 GND [SDA]/TXD_1/ICPDA/OCDDA/P1.6 VDD N76E003AQ20 1. [ ] alternate function remapping option (if the same alternate function is shown twice, it indicates an exclusive choice not a duplication of the function). Figure 5.1-3. Pin Assignment of QFN-20 Package for N76E003AQ20 Aug. 03, 2020 Page 13 of 274 Rev. 1.09 P1.1/PWM1/IC1/AIN7/CLO P1.0/PWM2/IC2/SPCLK P0.0/PWM3/IC3/MOSI/T1 P0.1/PWM4/IC4/MISO P0.2/ICPCK/OCDCK/RXD_1/[SCL] N76E003 Datasheet 15 14 13 12 11 PWM5/IC5/AIN6/P0.3 16 10 P1.2/PWM0/IC0 AIN5/STADC/PWM3/IC3/P0.4 17 9 P1.3/SCL/[STADC] PWM2/IC6/T0/AIN4/P0.5 18 8 P1.4/SDA/FB/PWM1 TXD/AIN3/P0.6 19 7 P1.5/PWM5/IC7/SS RXD/AIN2/P0.7 20 6 VDD 1 2 3 4 5 RST/P2.0 INT0/OSCIN/AIN1/P3.0 INT1/AIN0/P1.7 GND [SDA]/TXD_1/ICPDA/OCDDA/P1.6 N76E003BQ20 1. [ ] alternate function remapping option (if the same alternate function is shown twice, it indicates an exclusive choice not a duplication of the function). Figure 5.1-4. Pin Assignment of QFN-20 Package for N76E003BQ20 Aug. 03, 2020 Page 14 of 274 Rev. 1.09 P1.1/PWM1/IC1/AIN7/CLO P1.0/PWM2/IC2/SPCLK P0.0/PWM3/IC3/MOSI/T1 P0.1/PWM4/IC4/MISO P0.2/ICPCK/OCDCK/RXD_1/[SCL] N76E003 Datasheet 15 14 13 12 11 PWM5/IC5/AIN6/P0.3 16 10 P1.2/PWM0/IC0 AIN5/STADC/PWM3/IC3/P0.4 17 9 P1.3/SCL/[STADC] PWM2/IC6/T0/AIN4/P0.5 18 8 P1.4/SDA/FB/PWM1 TXD/AIN3/P0.6 19 7 P1.5/PWM5/IC7/SS RXD/AIN2/P0.7 20 6 VDD 1 2 3 4 5 RST/P2.0 INT0/OSCIN/AIN1/P3.0 INT1/AIN0/P1.7 GND [SDA]/TXD_1/ICPDA/OCDDA/P1.6 N76E003CQ20 1. [ ] alternate function remapping option (if the same alternate function is shown twice, it indicates an exclusive choice not a duplication of the function). Figure 5.1-5. Pin Assignment of QFN-20 Package for N76E003CQ20 Aug. 03, 2020 Page 15 of 274 Rev. 1.09 N76E003 Datasheet Pin Number N76E003AT20 N76E003AQ20 N76E003AS20 Symbol N76E003BQ20 N76E003CQ20 9 5 6 VDD 7 3 4 GND 16 12 13 P0.0/PWM3/IC3/MOSI/T1 17 13 14 P0.1/PWM4/IC4/MISO 18 14 15 P0.2/ICPCK/OCDCK/ RXD_1/[SCL] Multi-Function Description[1] POWER SUPPLY: Supply voltage VDD for operation. GROUND: Ground potential. P0.0: Port 0 bit 0. PWM3: PWM output channel 3. MOSI: SPI master output/slave input. IC3: Input capture channel 3. T1: External count input to Timer/Counter 1 or its toggle output. P0.1: Port 0 bit 1. PWM4: PWM output channel 4. IC4: Input capture channel 4. MISO: SPI master input/slave output. P0.2: Port 0 bit 2. ICPCK: ICP clock input. OCDCK: OCD clock input. RXD_1: Serial port 1 receive input. 2 19 15 16 P0.3/PWM5/IC5/AIN6 20 16 17 P0.4/AIN5/STADC/ PWM3/IC3 1 20 18 P0.5/PWM2/IC6/T0/AIN4 2 19 19 P0.6/TXD/AIN3 3 1 20 P0.7/RXD/AIN2 15 7 12 P1.0/PWM2/IC2/SPCLK 14 8 11 P1.1/PWM1/IC1/AIN7/ CLO 13 9 10 P1.2/PWM0/IC0 12 11 9 P1.3/SCL/[STADC] Aug. 03, 2020 Page 16 of 274 [SCL] [3]: I C clock. P0.3: Port 0 bit 3. PWM5: PWM output channel IC5: Input capture channel 5. AIN6: ADC input channel 6. P0.4: Port 0 bit 4. AIN5: ADC input channel 5. STADC: External start ADC trigger PWM3: PWM output channel 3. IC3: Input capture channel 3. P0.5: Port 0 bit 5. PWM2: PWM output channel 2. IC6: Input capture channel 6. T0: External count input to Timer/Counter 0 or its toggle output. P0.6: Port 0 bit 6. TXD[2]: Serial port 0 transmit data output. AIN3: ADC input channel 3. P0.7: Port 0 bit 7. RXD: Serial port 0 receive input. AIN2: ADC input channel 2. P1.0: Port 1 bit 0. PWM2: PWM output channel 2. IC2: Input capture channel 2. SPCLK: SPI clock. P1.1: Port 1 bit 1 PWM1: PWM output channel 1. IC1: Input capture channel 1. AIN7: ADC input channel 7. CLO: System clock output. P1.2: Port 1 bit 2. PWM0: PWM output channel 0. IC0: Input capture channel 0. P1.3: Port 1 bit 3. Rev. 1.09 N76E003 Datasheet Pin Number N76E003AT20 N76E003AQ20 N76E003AS20 N76E003BQ20 N76E003CQ20 Multi-Function Description[1] Symbol 2 SCL: I C clock. [STADC] [4]: External start ADC trigger P1.4: Port 1 bit 4. 2 11 10 8 P1.4/SDA/FB/PWM1 10 6 7 P1.5/PWM5/IC7/̅̅̅̅ 8 4 5 P1.6/ICPDA/OCDDA/ TXD_1/[SDA] SDA: I C data. FB: Fault Brake input. PWM1: PWM output channel 1. P1.5: Port 1 bit 5. PWM5: PWM output channel 5. IC7: Input capture channel 7. ̅̅̅̅: SPI slave select input. P1.6: Port 1 bit 6. ICPDA: ICP data input or output. OCDAT: OCD data input or output. TXD_1: Serial port 1 transmit data output. 2 [SDA] [3]: I C data. P1.7: Port 1 bit 7. ̅̅̅̅̅̅̅: External interrupt 1 input. 6 2 3 P1.7/̅̅̅̅̅̅̅/AIN0 AIN0: ADC input channel 0. P2.0: Port 2 bit 0 input pin available when RPD (CONFIG0.2) is programmed as 0. ̅̅̅̅̅̅: ̅̅̅̅̅̅ pin is a Schmitt trigger input pin for 4 18 1 P2.0/̅̅̅̅̅̅ hardware device reset. A low on this pin resets the device. ̅̅̅̅̅̅ pin has an internal pull-up resistor allowing power-on reset by simply connecting an external capacitor to GND. P3.0: Port 3 bit 0 available when the internal oscillator is used as the system clock. ̅̅̅̅̅̅̅: External interrupt 0 input. 5 17 12 P3.0/̅̅̅̅̅̅̅/OSCIN/AIN1 XIN: If the ECLK mode is enabled, XIN is the external clock input pin. AIN1: ADC input channel 1. [1] All I/O pins can be configured as a interrupt pin. This feature is not listed in multi-function description. See Section 16. “PIN INTERRUPT”. [2] TXD and RXD pins of UART0 are software exchangeable by UART0PX (AUXR1.2). [3] [I2C] alternate function remapping option. I2C pins is software switched by I2CPX (I2CON.0). [4] [STADC] alternate function remapping option. STADC pin is software switched by STADCPX(ADCCON1.6). [5] PIOx register decides which pins are PWM or GPIO. Aug. 03, 2020 Page 17 of 274 Rev. 1.09 N76E003 Datasheet 5. MEMORY ORGANIZATION A standard 80C51 based microcontroller divides the memory into two different sections, Program Memory and Data Memory. The Program Memory is used to store the instruction codes, whereas the Data Memory is used to store data or variations during the program execution. The Data Memory occupies a separate address space from Program Memory. In N76E003, there are 256 Bytes of internal scratch-pad RAM. For many applications those need more internal RAM, the N76E003 provides another on-chip 768 Bytes of RAM, which is called XRAM, accessed by MOVX instruction. The whole embedded flash, functioning as Program Memory, is divided into three blocks: Application ROM (APROM) normally for User Code, Loader ROM (LDROM) normally for Boot Code, and CONFIG bytes for hardware initialization. Actually, APROM and LDROM function in the same way but have different size. Each block is accumulated page by page and the page size is 128 Bytes. The flash control unit supports Erase, Program, and Read modes. The external writer tools though specific I/O pins, In-Application-Programming (IAP), or In-System-Programming (ISP) can both perform these modes. 5.1 Program Memory The Program Memory stores the program codes to execute as shown in Figure 5.1-1. After any reset, the CPU begins execution from location 0000H. To service the interrupts, the interrupt service locations (called interrupt vectors) should be located in the Program Memory. Each interrupt is assigned with a fixed location in the Program Memory. The interrupt causes the CPU to jump to that location with where it commences execution of the interrupt service routine (ISR). External Interrupt 0, for example, is assigned to location 0003H. If External Interrupt 0 is going to be used, its service routine should begin at location 0003H. If the interrupt is not going to be used, its service location is available as general purpose Program Memory. The interrupt service locations are spaced at an interval of eight Bytes: 0003H for External Interrupt 0, 000BH for Timer 0, 0013H for External Interrupt 1, 001BH for Timer 1, etc. If an interrupt service routine is short enough (as is often the case in control applications), it can reside entirely within the 8-Byte interval. However longer service routines should use a JMP instruction to skip over subsequent interrupt locations if other interrupts are in use. The N76E003 provides two internal Program Memory blocks APROM and LDROM. Although they both behave the same as the standard 8051 Program Memory, they play different rules according to their ROM size. The APROM on N76E003 can be up to 18K Bytes. User Code is normally put inside. CPU fetches instructions here for execution. The MOVC instruction can also read this region. Aug. 03, 2020 Page 18 of 274 Rev. 1.09 N76E003 Datasheet The other individual Program Memory block is called LDROM. The normal function of LDROM is to store the Boot Code for ISP. It can update APROM space and CONFIG bytes. The code in APROM can also re-program LDROM. For ISP details and configuration bit setting related with APROM and LDROM, see Section 21.4 “InSystem-Programming (ISP)” on page 224. Note that APROM and LDROM are hardware individual blocks, consequently if CPU re-boots from LDROM, CPU will automatically re-vector Program Counter 0000H to the LDROM start address. Therefore, CPU accounts the LDROM as an independent Program Memory and all interrupt vectors are independent from APROM. CONFIG1 7 - Bit 2:0 6 - 5 - 4 - 3 - 2 1 0 LDSIZE[2:0] R/W Factory default value: 1111 1111b Name Description LDSIZE[2:0] LDROM size select This field selects the size of LDROM. 111 = No LDROM. APROM is 18K Bytes. 110 = LDROM is 1K Bytes. APROM is 17K Bytes. 101 = LDROM is 2K Bytes. APROM is 16K Bytes. 100 = LDROM is 3K Bytes. APROM is 15K Bytes. 0xx = LDROM is 4K Bytes. APROM is 14K Bytes. 37FFH/ 3BFFH/ 3FFFH/ 43FFH/ 47FFH[1] APROM 0FFFH/ 0BFFH/ 07FFH/ 03FFH/ 0000H[1] LDROM 0000H 0000H BS = 0 BS = 1 [1] The logic boundary addresses of APROM and LDROM are defined by CONFIG1[2:0]. Figure 5.1-1. N76E003 Program Memory Map Aug. 03, 2020 Page 19 of 274 Rev. 1.09 N76E003 Datasheet 5.2 Data Memory Figure 5.2-1 shows the internal Data Memory spaces available on N76E003. Internal Data Memory occupies a separate address space from Program Memory. The internal Data Memory can be divided into three blocks. They are the lower 128 Bytes of RAM, the upper 128 Bytes of RAM, and the 128 Bytes of SFR space. Internal Data Memory addresses are always 8-bit wide, which implies an address space of only 256 Bytes. Direct addressing higher than 7FH will access the special function registers (SFRs) space and indirect addressing higher than 7FH will access the upper 128 Bytes of RAM. Although the SFR space and the upper 128 Bytes of RAM share the same logic address, 80H through FFH, actually they are physically separate entities. Direct addressing to distinguish with the higher 128 Bytes of RAM can only access these SFRs. Sixteen addresses in SFR space are either byte-addressable or bit-addressable. The bit-addressable SFRs are those whose addresses end in 0H or 8H. The lower 128 Bytes of internal RAM are present in all 80C51 devices. The lowest 32 Bytes as general purpose registers are grouped into 4 banks of 8 registers. Program instructions call these registers as R0 to R7. Two bits RS0 and RS1 in the Program Status Word (PSW[3:4]) select which Register Bank is used. It benefits more efficiency of code space, since register instructions are shorter than instructions that use direct addressing. The next 16 Bytes above the general purpose registers (byte-address 20H through 2FH) form a block of bit-addressable memory space (bit-address 00H through 7FH). The 80C51 instruction set includes a wide selection of single-bit instructions, and the 128 bits in this area can be directly addressed by these instructions. The bit addresses in this area are 00H through 7FH. Either direct or indirect addressing can access the lower 128 Bytes space. But the upper 128 Bytes can only be accessed by indirect addressing. Another application implemented with the whole block of internal 256 Bytes RAM is used for the stack. This area is selected by the Stack Pointer (SP), which stores the address of the top of the stack. Whenever a JMP, CALL or interrupt is invoked, the return address is placed on the stack. There is no restriction as to where the stack can begin in the RAM. By default however, the Stack Pointer contains 07H at reset. User can then change this to any value desired. The SP will point to the last used value. Therefore, the SP will be incremented and then address saved onto the stack. Conversely, while popping from the stack the contents will be read first, and then the SP is decreased. Aug. 03, 2020 Page 20 of 274 Rev. 1.09 N76E003 Datasheet FFH 80H 7FH 00H Upper 128 Bytes SFR internal RAM (direct addressing) (indirect addressing) 02FFH Lower 128 Bytes internal RAM (direct or indirect addressing) 768 Bytes XRAM (MOVX addressing) 0000H Figure 5.2-1. Data Memory Map FFH FFH Indirect Accessing RAM 80H 7FH Direct or Indirect Accessing RAM 30H 2FH 2EH 2DH 2CH 2BH 2AH 29H 28H 27H 26H 25H 24H 23H 22H 21H 20H 1FH 18H 17H General Purpose Registers 10H 0FH 08H 07H 7F 77 6F 67 5F 57 4F 47 3F 37 2F 27 1F 17 0F 07 7E 76 6E 66 5E 56 4E 46 3E 36 2E 26 1E 16 0E 06 7D 75 6D 65 5D 55 4D 45 3D 35 2D 25 1D 15 0D 05 7C 74 6C 64 5C 54 4C 44 3C 34 2C 24 1C 14 0C 04 7B 73 6B 63 5B 53 4B 43 3B 33 2B 23 1B 13 0B 03 7A 72 6A 62 5A 52 4A 42 3A 32 2A 22 1A 12 0A 02 79 71 69 61 59 51 49 41 39 31 29 21 19 11 09 01 78 70 68 60 58 50 48 40 38 30 28 20 18 10 08 00 Bit-addressable Register Bank 3 Register Bank 2 General Purpose Registers Register Bank 1 Register Bank 0 00H 00H Figure 5.2-2. Internal 256 Bytes RAM Addressing Aug. 03, 2020 Page 21 of 274 Rev. 1.09 N76E003 Datasheet 5.3 On-Chip XRAM The N76E003 provides additional on-chip 768 bytes auxiliary RAM called XRAM to enlarge the RAM space. It occupies the address space from 00H through 2FFH. The 768 bytes of XRAM are indirectly accessed by move external instruction MOVX @DPTR or MOVX @Ri. (See the demo code below.) Note that the stack pointer cannot be located in any part of XRAM. XRAM demo code: MOV MOV MOVX MOV MOVX MOV MOV MOVX MOV MOVX R0,#23H A,#5AH @R0,A R1,#23H A,@R1 DPTR,#0023H A,#5BH @DPTR,A DPTR,#0023H A,@DPTR ;write #5AH to XRAM with address @23H ;read from XRAM with address @23H ;write #5BH to XRAM with address @0023H ;read from XRAM with address @0023H 5.4 Non-Volatile Data Storage By applying IAP, any page of APROM or LDROM can be used as non-volatile data storage. For IAP details, please see Section 21. “IN-APPLICATION-PROGRAMMING (IAP)” on page 218. Aug. 03, 2020 Page 22 of 274 Rev. 1.09 N76E003 Datasheet 6. SPECIAL FUNCTION REGISTER (SFR) The N76E003 uses Special Function Registers (SFRs) to control and monitor peripherals and their modes. The SFRs reside in the register locations 80 to FFH and are accessed by direct addressing only. SFRs those end their addresses as 0H or 8H are bit-addressable. It is very useful in cases where user would like to modify a particular bit directly without changing other bits via bit-field instructions. All other SFRs are byte-addressable only. The N76E003 contains all the SFRs presenting in the standard 8051. However some additional SFRs are built in. Therefore, some of unused bytes in the original 8051 have been given new functions. The SFRs are listed below. To accommodate more than 128 SFRs in the 0x80 to 0Xff address space, SFR paging has been implemented. By default, all SFR accesses target SFR page 0. During device initialization, some SFRs located on SFR page 1 may need to be accessed. The register SFRS is used to switch SFR addressing page. Note that this register has TA write protection. Most of SFRs are available on both SFR page 0 and 1. SFRS – SFR Page Selection (TA protected) 7 6 5 4 Address: 91H Bit 0 3 - Name Description SFRPAGE SFR page select 0 = Instructions access SFR page 0. 1 = Instructions access SFR page 1. 2 - 1 0 SFRPAGE R/W Reset value: 0000 0000b Switch SFR page demo code: MOV MOV ORL TA,#0AAH TA,#55H SFRS,#01H ;switch to SFR page 1 MOV MOV ANL TA,#0AAH TA,#55H SFRS,#0FEH ;switch to SFR page 0 Aug. 03, 2020 Page 23 of 274 Rev. 1.09 N76E003 Datasheet Table 6-1. SFR Memory Map SFR Page 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 Addr 0/8 1/9 2/A 3/B 4/C 5/D 6/E 7/F F8 SCON_1 PDTEN PDTCNT PMEN PMD PORDIS SPDR - EIP1 AINDIDS PIF C2L C2H EIPH1 EIPH EIP - F0 B CAPCON3 CAPCON4 SPCR SPCR2 SPSR E8 ADCCON0 PICON PINEN PIPEN E0 ACC ADCCON1 ADCCON2 ADCDLY C0L C0H C1L C1H D8 PWMCON0 PWMPL PWM0L PWM1L PWM2L PWM3L PIOCON0 PWMCON1 D0 PSW PWMPH PWM0H PWM1H PWM2H PWM3H PNP FBD C8 T2CON T2MOD RCMP2L RCMP2H ADCMPH I2CON I2ADDR ADCRL ADCRH TH2 PWM5L RL3 PWM5H ADCMPL C0 TL2 PWM4L T3CON PWM4H RH3 PIOCON1 TA B8 IP SADEN SADEN_1 SADDR_1 I2DAT I2STAT I2CLK I2TOC B0 P3 P0M1 P0S P0M2 P0SR P1M1 P1S P2S - IPH PWMINTC A8 IE SADDR WDCON BODCON1 P1M2 P1SR P3M1 P3S P3M2 P3SR IAPFD IAPCN A0 P2 - AUXR1 BODCON0 IAPTRG IAPUEN IAPAL IAPAH 98 SCON SBUF SBUF_1 EIE EIE1 - - CHPCON 90 P1 SFRS CAPCON0 CAPCON1 CAPCON2 CKDIV CKSWT CKEN 88 TCON TMOD TL0 TL1 TH0 TH1 CKCON WKCON 80 P0 SP DPL DPH RCTRIM0 RCTRIM1 RWK PCON - Unoccupied addresses in the SFR space marked in “-“ are reserved for future use. Accessing these areas will have an indeterminate effect and should be avoided. Aug. 03, 2020 Page 24 of 274 Rev. 1.09 N76E003 Datasheet Table 6-2. SFR Definitions and Reset Values Symbol EIPH1 EIP1 PMD PMEN PDTCNT PDTEN [4] [4] SCON_1 Definition Address /(Page) Extensive interrupt priority high 1 FFH/(0) Extensive interrupt priority 1 FEH/(0) PWM mask data FCH PWM mask enable FBH PWM dead-time counter FAH PWM dead-time enable F9H Serial port 1 control F8H SPDR SPSR SPCR SPCR2 CAPCON4 CAPCON3 Extensive interrupt priority high ADC channel digital input disable SPI data SPI status SPI control SPI control 2 Input capture control 4 Input capture control 3 B B register EIPH AINDIDS EIP C2H C2L PIF PIPEN PINEN PICON ADCCON0 C1H C1L C0H C0L ADCDLY ADCCON2 ADCCON1 ACC PWMCON1 PIOCON0 PWM3L PWM2L PWM1L PWM0L PWMPL PWMCON0 FBD PNP PWM3H PWM2H PWM1H PWM0H PWMPH PSW ADCMPH ADCMPL PWM5L TH2 PWM4L Extensive interrupt priority Input capture 2 high byte Input capture 2 low byte Pin interrupt flag Pin interrupt high level/rising edge enable Pin interrupt low level/falling edge enable Pin interrupt control F7H F6H F5H(0) F4H F3H(0) F3H(1) F2H F1H F0H MSB LSB - - - PWKTH - - PWKT PMD4 PMEN4 PMD3 PMEN3 PMD2 PMEN2 PT3H [1] - - PSH_1 0000 0000b - - - - - PMD5 PMEN5 PT3 PS_1 0000 0000b PMD1 PMEN1 PMD0 PMEN0 0000 0000b 0000 0000b 0000 0000b (FF) SM0_1/ FE_1 - - PDTCNT.8 - (FE) SM1_1 (FD) SM2_1 (FC) REN_1 (FB) TB8_1 (FA) RB8_1 (F9) TI_1 (F8) RI_1 0000 0000b PT2H PSPIH PFBH PWDTH PPWMH PCAPH PPIH PI2CH 0000 0000b P11DIDS P03DIDS SPIF SSOE CAP13 (F7) B.7 WCOL SPIEN CAP12 (F6) B.6 SPIOVF LSBFE CAP11 (F5) B.5 PT2 PSPI PFB PDTCNT[7:0] PDT45EN PDT23EN PDT01EN 0 0 0 0 0 0 0 0 b P04DIDS P05DIDS P06DIDS P07DIDS P30DIDS P17DIDS 0 0 0 0 0 0 0 0 b EFH EEH EDH ECH PIF7 PIF6 PIF5 EBH PIPEN7 PIPEN6 PIPEN5 EAH E9H PINEN7 PIT67 (EF) ADCF PINEN6 PIT45 (EE) ADCS SPDR[7:0] MODF DISMODF MSTR CPOL CAP23 CAP10 CAP03 (F4) (F3) B.4 B.3 PWDT PPWM C2H[7:0] C2L[7:0] PIF4 PIF3 PIPEN4 PIPEN3 TXBUF CPHA CAP22 CAP02 (F2) B.2 PCAP - - SPR[1:0] SPIS[1:0] CAP21 CAP20 CAP01 CAP00 (F1) (F0) B.1 B.0 PPI PI2C PIF2 PIF1 PIF0 PIPEN2 PIPEN1 PIPEN0 PINEN5 PINEN4 PINEN3 PINEN2 PINEN1 PINEN0 PIT3 PIT2 PIT1 PIT0 PIPS[1:0] (ED) (EC) (EB) (EA) (E9) (E8) ADC control 0 E8H ETGSEL1 ETGSEL0 ADCHS3 ADCHS2 ADCHS1 ADCHS0 Input capture 1 high byte E7H C1H[7:0] Input capture 1 low byte E6H C1L[7:0] Input capture 0 high byte E5H C0H[7:0] Input capture 0 low byte E4H C0L[7:0] ADC trigger delay E3H ADCDLY[7:0] ADC control 2 E2H ADFBEN ADCMPOP ADCMPEN ADCMPO ADCDLY.8 ADC control 1 E1H STADCPX ETGTYP[1:0] ADCEX ADCEN (E7) (E6) (E5) (E4) (E3) (E2) (E1) (E0) Accumulator E0H ACC.7 ACC.6 ACC.5 ACC.4 ACC.3 ACC.2 ACC.1 ACC.0 PWM control 1 DFH PWMMOD[1:0] GP PWMTYP FBINEN PWMDIV[2:0] PWM I/O switch 0 DEH PIO05 PIO04 PIO03 PIO02 PIO01 PIO00 PWM3 duty low byte DDH PWM3[7:0] PWM2 duty low byte DCH PWM2[7:0] PWM1 duty low byte DBH PWM1[7:0] PWM0 duty low byte DAH PWM0[7:0] PWM period low byte D9H PWMP[7:0] (DF) (DE) (DD) (DC) (DB) (DA) (D9) (D8) PWM control 0 D8H PWMRUN LOAD PWMF CLRPWM Brake data D7H FBF FBINLS FBD5 FBD4 FBD3 FBD2 FBD1 FBD0 PWM negative polarity D6H PNP5 PNP4 PNP3 PNP2 PNP1 PNP0 PWM3 duty high byte D5H PWM3[15:8] PWM2 duty high byte D4H PWM2[15:8] PWM1 duty high byte D3H PWM1[15:8] PWM0 duty high byte D2H PWM0[15:8] PWM period high byte D1H PWMP[15:8] (D7) (D6) (D5) (D4) (D3) (D2) (D1) (D0) Program status word D0H CY AC F0 RS1 RS0 OV P ADC compare high byte CFH ADCMP[11:4] ADC compare low byte CEH ADCMP[3:0] PWM5 duty low byte CDH(1) PWM5[7:0] Timer 2 high byte CDH(0) TH2[7:0] PWM4 duty low byte CCH(1) PWM4[7:0] Aug. 03, 2020 [2] Reset Value Page 25 of 274 0000 0000 0000 0000 0000 0000 0000b 0000b 0000b 0000b 0000b 0000b 0000 0000b 0000 0000b 0000 0000b 0000 0000b 0000 0000b 0000 0000b 0000 0000b 0000 0000b 0000 0000b 0000 0000 0000 0000 0000 0000 0000 0000b 0000b 0000b 0000b 0000b 0000b 0000b 0000 0000b 0000 0000 0000 0000 0000 0000 0000 0000b 0000b 0000b 0000b 0000b 0000b 0000b 0000 0000b 0000 0000 0000 0000 0000 0000 0000 0000b 0000b 0000b 0000b 0000b 0000b 0000b 0000 0000b 0000 0000 0000 0000 0000 0000b 0000b 0000b 0000b 0000b Rev. 1.09 N76E003 Datasheet Table 6-2. SFR Definitions and Reset Values Symbol Definition TL2 Address /(Page) CCH(0) T2MOD Timer 2 low byte Timer 2 compare high byte Timer 2 compare low byte Timer 2 mode T2CON Timer 2 control TA PIOCON1 RH3 PWM5H RL3 PWM4H T3CON ADCRH ADCRL I2ADDR Timed access protection PWM I/O switch 1 Timer 3 reload high byte PWM5 duty high byte Timer 3 reload low byte PWM4 duty high byte Timer 3 control ADC result high byte ADC result low byte 2 I C own slave address I2CON I C control I2TOC I2CLK I2STAT I2DAT SADDR_1 SADEN_1 SADEN I C time-out counter 2 I C clock 2 I C status 2 I C data Slave 1 address Slave 1 address mask Slave 0 address mask BFH BEH BDH BCH BBH BAH B9H IP Interrupt priority B8H PWMINTC IPH P1SR P1M2 P1S P1M1 P0SR P0M2 P0S P0M1 PWM Interrupt Control Interrupt priority high P20 Setting and Timer0/1 Output Enable P1 slew rate P1 mode select 2 P1 Schmitt trigger input P1 mode select 1 P0 slew rate P0 mode select 2 P0 Schmitt trigger input P0 mode select 1 P3 Port 3 IAPCN IAPFD P3SR P3M2 P3S P3M1 IAP control IAP flash data P3 slew rate P3 mode select 2 P3 Schmitt trigger input P3 mode select 1 RCMP2H RCMP2L 2 2 P2S [4] BODCON1 [4] WDCON MSB LSB [2] Reset Value TL2[7:0] 0000 0000b CBH RCMP2H[7:0] 0000 0000b CAH(0) RCMP2L[7:0] 0000 0000b C9H C8H C7H C6H(1) C6H(0) C5H(1) C5H(0) C4H(1) C4H(0) C3H C2H C1H C0H B7H(1) B7H(0) LDEN (CF) TF2 CAPCR (CC) (CB) TA[7:0] PIO15 PIO13 RH3[7:0] PWM5[15:8] RL3[7:0] PWM4[15:8] BRCK TF3 TR3 SMOD_1 SMOD0_1 ADCR[11:4] I2ADDR[7:1] (C7) (C6) (C4) (C4) (C3) I2CEN STA STO SI I2CLK[7:0] I2STAT[7:3] I2DAT[7:0] SADDR_1[7:0] SADEN_1[7:0] SADEN[7:0] (BF) (BE) (BD) (BC) (BB) PADC PBOD PS PT1 INTTYP1 INTTYP0 PADCH PBODH PSH PT1H (CE) - T2DIV[2:0] (CD) - CMPCR (CA) TR2 LDTS[1:0] 0000 (C8) (C9) 0000 ̅̅̅̅̅̅ 0000 PIO12 PIO11 0000 0000 0000 0000 0000 T3PS[2:0] 0000 0000 ADCR[3:0] 0000 GC 0000 (C2) (C1) (C0) 0000 AA I2CPX I2TOCEN DIV I2TOF 0 0 0 0 0000 0 0 0 1111 0000 0000 0000 0000 (BA) (B9) (B8) 0000 PX1 PT0 PX0 INTSEL2 INTSEL1 INTSEL0 0 0 0 0 PX1H PT0H PX0H 0 0 0 0 B5H P20UP - - - T1OE T0OE - P2S.0 B4H/(1) B4H/(0) B3H/(1) B3H/(0) B2H/(1) B2H/(0) B1H/(1) B1H/(0) P1SR.7 P1M2.7 P1S.7 P1M1.7 P0SR.7 P0M2.7 P0S.7 P0M1.7 P1SR.6 P1M2.6 P1S.6 P1M1.6 P0SR.6 P0M2.6 P0S.6 P0M1.6 P1SR.5 P1M2.5 P1S.5 P1M1.5 P0SR.5 P0M2.5 P0S.5 P0M1.5 P1SR.4 P1M2.4 P1S.4 P1M1.4 P0SR.4 P0M2.4 P0S.4 P0M1.4 P1SR.3 P1M2.3 P1S.3 P1M1.3 P0SR.3 P0M2.3 P0S.3 P0M1.3 P1SR.2 P1M2.2 P1S.2 P1M1.2 P0SR.2 P0M2.2 P0S.2 P0M1.2 P1SR.1 P1M2.1 P1S.1 P1M1.1 P0SR.1 P0M2.1 P0S.1 P0M1.1 P1SR.0 P1M2.0 P1S.0 P1M1.0 P0SR.0 P0M2.0 P0S.0 P0M1.0 B0H (B7) 0 (B6) 0 (B5) 0 (B4) 0 (B3) 0 AFH AEH ADH/(1) ADH/(0) ACH/(1) ACH/(0) - - - Brown-out detection control 1 ABH - - - - - Watchdog Timer control AAH WDTR WDCLR WDTF WIDPD WDTRF Aug. 03, 2020 [1] IAPA[17:16] FOEN FCEN IAPFD[7:0] - Page 26 of 274 0000b 0000b 0000b 0000b 0000b 0000b 0000b 0000b 0000b 0000b 0000b 0000b 0000b 0000b 1001b 1000b 0000b 0000b 0000b 0000b 0000b 0000b 0000b 0000 0000b 0000 0000b 0000 0000b 0000 0000b 1111 1111b 0000 0000b 0000 0000b 0000 0000b 1111 1111b Output latch, 0000 0001b (B2) (B1) (B0) Input, 0 0 P3.0 [3] 0000 000Xb FCTRL[3:0] 0011 0000b 0000 0000b P3SR.0 0 0 0 0 0 0 0 0 b P3M2.0 0 0 0 0 0 0 0 0 b P3S.0 0 0 0 0 0 0 0 0 b P3M1.0 0 0 0 0 0 0 0 1 b POR, 0000 0001b LPBOD[1:0] BODFLT Others, 0000 0UUUb POR, 0000 0111b WDT, WDPS[2:0] 0000 1UUUb Others, 0 0 00 U U U U b Rev. 1.09 N76E003 Datasheet Table 6-2. SFR Definitions and Reset Values SADDR Slave 0 address Address /(Page) A9H IE Interrupt enable A8H IAPAH IAPAL [4] IAPUEN [4] IAPTRG IAP address high byte IAP address low byte IAP update enable IAP trigger A7H A6H A5H A4H BODCON0 Brown-out detection control 0 A3H BODEN AUXR1 Auxiliary register 1 A2H SWRF RSTPINF HardF - GF2 UART0PX 0 DPS P2 Port 2 A0H (A7) 0 (A6) 0 (A5) 0 (A4) 0 (A3) 0 (A2) 0 (A1) 0 (A0) P2.0 Chip control 9FH SWRST IAPFF - - - - 9CH - - - - - EWKT ET3 ES_1 0000 0000b 9BH ET2 ESPI EFB EWDT EPWM ECAP EPI EI2C 0000 0000b Symbol Definition [4] CHPCON [4] SBUF_1 SBUF Extensive interrupt enable 1 Extensive interrupt enable Serial port 1 data buffer Serial port 0 data buffer SCON Serial port 0 control 98H Clock enable 97H Clock switch 96H EIE1 EIE CKEN [4] CKSWT CKDIV [4] MSB LSB (AF) EA (AE) EADC - [5] (AD) EBOD - - - BOV[1:0] 9AH 99H (9F) SM0/FE SADDR[7:0] (AC) (AB) ES ET1 IAPA[15:8] IAPA[7:0] - (9E) SM1 (9D) SM2 [5] [6] BOF SBUF_1[7:0] SBUF[7:0] (9C) (9B) REN TB8 EXTEN[1:0] HIRCEN - - - - HIRCST - ECLKST ENF1 ENF0 (A9) ET0 CFUEN - BORST [5] BORF BS (9A) RB8 (99) TI - - - ENF2 CAPCON1 Input capture control 1 93H - - CAPCON0 Input capture control 0 92H - CAPEN2 CAPEN1 CAPEN0 - CAPF2 CAPF1 SFR page selection 91H - - - - - - - Port 1 90H (97) P1.7 (96) P1.6 (95) P1.5 (94) P1.4 (93) P1.3 (92) P1.2 (91) P1.1 8FH - - - WKTF WKTR CKCON TH1 TH0 TL1 TL0 TMOD Self Wake-up Timer control Clock control Timer 1 high byte Timer 0 high byte Timer 1 low byte Timer 0 low byte Timer 0 and 1 mode 8EH 8DH 8CH 8BH 8AH 89H - PWMCKS - TCON Timer 0 and 1control 88H GATE (8F) TF1 (8E) TR1 M1 (8D) TF0 PCON Power control 87H SMOD SMOD0 - RWK RCTRIM1 RCTRIM0 Self Wake-up Timer reload byte Internal RC trim value low byte Internal RC trim value Aug. 03, 2020 84H (98) RI ̅ - - - POF GF1 - 0000 0000b CAP0LS[1:0] 0000 0000b - CAP1LS[1:0] T1M T0M TH1[7:0] TH0[7:0] TL1[7:0] TL0[7:0] M0 GATE (8C) (8B) TR0 IE1 - CAPF0 WKPS[2:0] - 0000 0000b CLOEN - (8A) IT1 M1 (89) IE0 M0 (88) IT0 GF0 PD IDL ̅ 0000 0000b SFRPSEL 0 0 0 0 0 0 0 0 b Output latch, 1111 1111b (90) Input, P1.0 [3] XXXX XXXXb 0000 0000 0000 0000 0000 0000 0000b 0000b 0000b 0000b 0000b 0000b 0000 0000b POR, 0001 0000b Others, 000U 0000b 0000 0000b - HIRCTRIM[8:1] Page 27 of 274 0000 0000b 0000 0000b - RWK[7:0] - 0000 0000b 0000 0000b 0000 0000b 0000 0000b POR, CCCC XC0Xb BOD, UUUU XU1Xb Others, UUUU XUUXb POR, 0000 0000b Software, 1U00 0000b ̅̅̅̅̅̅ pin, U100 0000b Others, UUU0 0000b Output latch, 0000 000Xb Input, [3] 0000 000Xb Software, 0000 00U0b Others, 0000 00C0b CKSWTF 0 0 1 1 0 0 0 0 b 0011 0000b - CKDIV[7:0] 86H 85H IAPEN OSC[1:0] 94H WKCON [7] 0000 0000b 0000 0000b 0000 0000b 95H P1 APUEN IAPGO BOS [5] Input capture control 2 [4] (A8) EX0 LDUEN - Clock divider CAP2LS[1:0] [2] Reset Value 0000 0000b (AA) EX1 CAPCON2 SFRS [1] - - HIRCTRIM[0] 0000 0000b 0000 0000b Rev. 1.09 N76E003 Datasheet Table 6-2. SFR Definitions and Reset Values Symbol Definition Address /(Page) DPH DPL SP high byte Data pointer high byte Data pointer low byte Stack pointer 83H 82H 81H P0 Port 0 80H MSB LSB [1] DPTR[15:8] DPTR[7:0] SP[7:0] (87) P0.7 (86) P0.6 (85) P0.5 (84) P0.4 (83) P0.3 (82) P0.2 (81) P0.1 (80) P0.0 [2] Reset Value 0000 0000b 0000 0000b 0000 0111b Output latch, 1111 1111b Input, [3] XXXX XXXXb [1] ( ) item means the bit address in bit-addressable SFRs. [2] Reset value symbol description. 0: logic 0; 1: logic 1; U: unchanged; C: see [5]; X: see [3], [6], and [7]. [3] All I/O pins are default input-only mode (floating) after reset. Reading back P2.0 is always 0 if RPD (CONFIG0.2) remains un-programmed 1. After reset OCDDA and OCDCK pin will keep quasi mode with pull high resister 600 LIRC clock before change to input mode. [4] These SFRs have TA protected writing. [5] These SFRs have bits those are initialized according to CONFIG values after specified resets. [6] BOF reset value depends on different setting of CONFIG2 and V DD voltage level. Please check Table 24-1. [7] BOS is a read-only flag decided by VDD level while brown-out detection is enabled. Bits marked in “-“ are reserved for future use. They must be kept in their own initial states. Accessing these bits may cause an unpredictable effect. 6.1 ALL SFR DESCRIPTION Following list all SFR description. For each SFR define also list in function IP chapter. P0 – Port 0 (Bit-addressable) 7 6 5 P0.7 P0.6 P0.5 R/W R/W R/W Address: 80H Bit 7:0 Name P0[7:0] SP – Stack Pointer 7 6 4 P0.4 R/W 3 P0.3 R/W 2 P0.2 R/W 1 0 P0.1 P0.0 R/W R/W Reset value: 1111 1111b Description Port 0 Port 0 is an maximum 8-bit general purpose I/O port. 5 4 3 2 1 0 SP[7:0] R/W Address: 81H Bit 7:0 Aug. 03, 2020 Reset value: 0000 0111b Name SP[7:0] Description Stack pointer The Stack Pointer stores the scratch-pad RAM address where the stack begins. It is incremented before data is stored during PUSH or CALL instructions. Note that the default value of SP is 07H. This causes the stack to begin at location 08H. Page 28 of 274 Rev. 1.09 N76E003 Datasheet DPL – Data Pointer Low Byte 7 6 5 4 3 2 1 0 DPL[7:0] R/W Address: 82H Bit 7:0 Reset value: 0000 0000b Name Description DPL[7:0] Data pointer low byte This is the low byte of 16-bit data pointer. DPL combined with DPH serve as a 16bit data pointer DPTR to access indirect addressed RAM or Program Memory. DPS (AUXR1.0) bit decides which data pointer, DPTR or DPTR1, is activated. DPH – Data Pointer High Byte 7 6 5 4 3 2 1 0 DPH[7:0] R/W Address: 83H Bit 7:0 Reset value: 0000 0000b Name Description DPH[7:0] Data pointer high byte This is the high byte of 16-bit data pointer. DPH combined with DPL serve as a 16-bit data pointer DPTR to access indirect addressed RAM or Program Memory. RWK – Self Wake-up Timer Reload Byte 7 6 5 4 3 2 1 0 RWK[7:0] R/W Address: 86H Reset value: 0000 0000b Bit Name 7:0 RWK[7:0] PCON – Power Control 7 6 SMOD SMOD0 R/W R/W Address: 87H Bit Name Description WKT reload byte It holds the 8-bit reload value of WKT. Note that RWK should not be FFH if the pre-scale is 1/1 for implement limitation. 5 - 4 3 2 1 0 POF GF1 GF0 PD IDL R/W R/W R/W R/W R/W Reset value: see Table 6-2. SFR Definitions and Reset Values Description 7 SMOD Serial port 0 double baud rate enable Setting this bit doubles the serial port baud rate when UART0 is in Mode 2 or when Timer 1 overflow is used as the baud rate source of UART0 Mode 1 or 3. See Table 13-1. Serial Port 0 Mode Description for details. 6 SMOD0 Serial port 0 framing error flag access enable 0 = SCON.7 accesses to SM0 bit. 1 = SCON.7 accesses to FE bit. Aug. 03, 2020 Page 29 of 274 Rev. 1.09 N76E003 Datasheet Bit Name Description 4 POF Power-on reset flag This bit will be set as 1 after a power-on reset. It indicates a cold reset, a power-on reset complete. This bit remains its value after any other resets. This flag is recommended to be cleared via software. 3 GF1 General purpose flag 1 The general purpose flag that can be set or cleared by user via software. 2 GF0 General purpose flag 0 The general purpose flag that can be set or cleared by user via software. 1 PD Power-down mode Setting this bit puts CPU into Power-down mode. Under this mode, both CPU and peripheral clocks stop and Program Counter (PC) suspends. It provides the lowest power consumption. After CPU is woken up from Power-down, this bit will be automatically cleared via hardware and the program continue executing the interrupt service routine (ISR) of the very interrupt source that woke the system up before. After return from the ISR, the device continues execution at the instruction, which follows the instruction that put the system into Power-down mode. Note that If IDL bit and PD bit are set simultaneously, CPU will enter Power-down mode. Then it does not go to Idle mode after exiting Power-down. 0 IDL Idle mode Setting this bit puts CPU into Idle mode. Under this mode, the CPU clock stops and Program Counter (PC) suspends but all peripherals keep activated. After CPU is woken up from Idle, this bit will be automatically cleared via hardware and the program continue executing the ISR of the very interrupt source that woke the system up before. After return from the ISR, the device continues execution at the instruction which follows the instruction that put the system into Idle mode. TCON – Timer 0 and 1 Control (Bit-addressable) 7 6 5 4 TF1 TR1 TF0 TR0 R/W R/W R/W Name Description R/W 3 IE1 R (level) R/W (edge) Address: 88H Bit 2 IT1 R/W 1 0 IE0 IT0 R (level) R/W R/W (edge) Reset value: 0000 0000b 7 TF1 Timer 1 overflow flag This bit is set when Timer 1 overflows. It is automatically cleared by hardware when the program executes the Timer 1 interrupt service routine. This bit can be set or cleared by software. 6 TR1 Timer 1 run control 0 = Timer 1 Disabled. Clearing this bit will halt Timer 1 and the current count will be preserved in TH1 and TL1. 1 = Timer 1 Enabled. 5 TF0 Timer 0 overflow flag This bit is set when Timer 0 overflows. It is automatically cleared via hardware when the program executes the Timer 0 interrupt service routine. This bit can be set or cleared by software. 4 TR0 Timer 0 run control 0 = Timer 0 Disabled. Clearing this bit will halt Timer 0 and the current count will be preserved in TH0 and TL0. 1 = Timer 0 Enabled. Aug. 03, 2020 Page 30 of 274 Rev. 1.09 N76E003 Datasheet Bit Name Description 3 IE1 External interrupt 1 edge flag If IT1 = 1 (falling edge trigger), this flag will be set by hardware when a falling edge is detected. It remain set until cleared via software or cleared by hardware in the beginning of its interrupt service routine. If IT1 = 0 (low level trigger), this flag follows the inverse of the ̅̅̅̅̅̅̅ input signal’s logic level. Software cannot control it. 2 IT1 External interrupt 1 type select This bit selects by which type that ̅̅̅̅̅̅̅ is triggered. 0 = ̅̅̅̅̅̅̅ is low level triggered. 1 = ̅̅̅̅̅̅̅ is falling edge triggered. 1 IE0 External interrupt 0 edge flag If IT0 = 1 (falling edge trigger), this flag will be set by hardware when a falling edge is detected. It remain set until cleared via software or cleared by hardware in the beginning of its interrupt service routine. If IT0 = 0 (low level trigger), this flag follows the inverse of the ̅̅̅̅̅̅̅ input signal’s logic level. Software cannot control it. 0 IT0 External interrupt 0 type select This bit selects by which type that ̅̅̅̅̅̅̅ is triggered. 0 = ̅̅̅̅̅̅̅ is low level triggered. 1 = ̅̅̅̅̅̅̅ is falling edge triggered. TMOD – Timer 0 and 1 Mode 7 6 ̅ GATE R/W Address: 89H Bit R/W Name 7 GATE 6 ̅ 5 M1 4 M0 3 GATE 2 ̅ 1 M1 Aug. 03, 2020 5 M1 4 M0 3 GATE 2 ̅ R/W R/W R/W R/W 1 M1 0 M0 R/W R/W Reset value: 0000 0000b Description Timer 1 gate control 0 = Timer 1 will clock when TR1 is 1 regardless of ̅̅̅̅̅̅̅ logic level. 1 = Timer 1 will clock only when TR1 is 1 and ̅̅̅̅̅̅̅ is logic 1. Timer 1 Counter/Timer select 0 = Timer 1 is incremented by internal system clock. 1 = Timer 1 is incremented by the falling edge of the external pin T1. Timer 1 mode select M1 M0 Timer 1 Mode 0 0 Mode 0: 13-bit Timer/Counter 0 1 Mode 1: 16-bit Timer/Counter 1 0 Mode 2: 8-bit Timer/Counter with auto-reload from TH1 1 1 Mode 3: Timer 1 halted Timer 0 gate control 0 = Timer 0 will clock when TR0 is 1 regardless of ̅̅̅̅̅̅̅ logic level. 1 = Timer 0 will clock only when TR0 is 1 and ̅̅̅̅̅̅̅ is logic 1. Timer 0 Counter/Timer select 0 = Timer 0 is incremented by internal system clock. 1 = Timer 0 is incremented by the falling edge of the external pin T0. Timer 0 mode select Page 31 of 274 Rev. 1.09 N76E003 Datasheet Bit Name 0 M0 TL0 – Timer 0 Low Byte 7 6 Description M1 0 0 1 1 5 M0 0 1 0 1 Timer 0 Mode Mode 0: 13-bit Timer/Counter Mode 1: 16-bit Timer/Counter Mode 2: 8-bit Timer/Counter with auto-reload from TH0 Mode 3: TL0 as a 8-bit Timer/Counter and TH0 as a 8-bit Timer 4 3 2 1 0 TL0[7:0] R/W Address: 8AH Bit 7:0 Reset value: 0000 0000b Name TL0[7:0] TL1 – Timer 1 Low Byte 7 6 Description Timer 0 low byte The TL0 register is the low byte of the 16-bit counting register of Timer 0. 5 4 3 2 1 0 TL1[7:0] R/W Address: 8BH Bit 7:0 Reset value: 0000 0000b Name TL1[7:0] TH0 – Timer 0 High Byte 7 6 Description Timer 1 low byte The TL1 register is the low byte of the 16-bit counting register of Timer 1. 5 4 3 2 1 0 TH0[7:0] R/W Address: 8CH Bit 7:0 Reset value: 0000 0000b Name Description TH0[7:0] Timer 0 high byte The TH0 register is the high byte of the 16-bit counting register of Timer 0. TH1 – Timer 1 High Byte 7 6 5 4 3 2 1 0 TH1[7:0] R/W Address: 8DH Bit 7:0 Aug. 03, 2020 Reset value: 0000 0000b Name Description TH1[7:0] Timer 1 high byte The TH1 register is the high byte of the 16-bit counting register of Timer 1. Page 32 of 274 Rev. 1.09 N76E003 Datasheet CKCON – Clock Control 7 6 PWMCKS R/W Address: 8EH Bit 5 - 4 T1M R/W 3 T0M R/W 2 - 1 0 CLOEN R/W Reset value: 0000 0000b Name Description 6 PWMCKS PWM clock source select 0 = The clock source of PWM is the system clock FSYS. 1 = The clock source of PWM is the overflow of Timer 1. 4 T1M Timer 1 clock mode select 0 = The clock source of Timer 1 is the system clock divided by 12. It maintains standard 8051 compatibility. 1 = The clock source of Timer 1 is direct the system clock. 3 T0M Timer 0 clock mode select 0 = The clock source of Timer 0 is the system clock divided by 12. It maintains standard 8051 compatibility. 1 = The clock source of Timer 0 is direct the system clock. 1 CLOEN System clock output enable 0 = System clock output Disabled. 1 = System clock output Enabled from CLO pin (P1.1). WKCON – Self Wake-up Timer Control 7 6 5 Address: 8FH 4 WKTF R/W 3 WKTR R/W 2 1 0 WKPS[2:0] R/W Reset value: 0000 0000b Bit Name 4 WKTF WKT overflow flag This bit is set when WKT overflows. If the WKT interrupt and the global interrupt are enabled, setting this bit will make CPU execute WKT interrupt service routine. This bit is not automatically cleared via hardware and should be cleared via software. 3 WKTR WKT run control 0 = WKT is halted. 1 = WKT starts running. Note that the reload register RWK can only be written when WKT is halted (WKTR bit is 0). If WKT is written while WKTR is 1, result is unpredictable. 2:0 WKPS[2:0] Aug. 03, 2020 Description WKT pre-scalar These bits determine the pre-scale of WKT clock. 000 = 1/1. 001 = 1/4. 010 = 1/16. 011 = 1/64. 100 = 1/256. 101 = 1/512. 110 = 1/1024. 111 = 1/2048. Page 33 of 274 Rev. 1.09 N76E003 Datasheet P1 – Port 1 (Bit-addressable) 7 6 5 P1.7 P1.6 P1.5 R/W R/W R/W Address: 90H Bit Name 7:0 P1[7:0] 4 P1.4 R/W 0 1 0 P1.1 P1.0 R/W R/W Reset value: 1111 1111b Port 1 Port 1 is an maximum 8-bit general purpose I/O port. 3 - Name Description SFRPAGE SFR page select 0 = Instructions access SFR page 0. 1 = Instructions access SFR page 1. CAPCON0 – Input Capture Control 0 7 6 5 CAPEN2 CAPEN1 R/W R/W Address: 92H Bit 2 P1.2 R/W Description SFRS – SFR Page Selection (TA protected) 7 6 5 4 Address: 91H Bit 3 P1.3 R/W 4 CAPEN0 R/W 3 - 2 - 1 0 SFRPAGE R/W Reset value: 0000 0000b 2 CAPF2 R/W 1 0 CAPF1 CAPF0 R/W R/W Reset value: 0000 0000b Name Description 6 CAPEN2 Input capture 2 enable 0 = Input capture channel 2 Disabled. 1 = Input capture channel 2 Enabled. 5 CAPEN1 Input capture 1 enable 0 = Input capture channel 1 Disabled. 1 = Input capture channel 1 Enabled. 4 CAPEN0 Input capture 0 enable 0 = Input capture channel 0 Disabled. 1 = Input capture channel 0 Enabled. 2 CAPF2 Input capture 2 flag This bit is set by hardware if the determined edge of input capture 2 occurs. This bit should cleared by software. 1 CAPF1 Input capture 1 flag This bit is set by hardware if the determined edge of input capture 1 occurs. This bit should cleared by software. 0 CAPF0 Input capture 0 flag This bit is set by hardware if the determined edge of input capture 0 occurs. This bit should cleared by software. Aug. 03, 2020 Page 34 of 274 Rev. 1.09 N76E003 Datasheet CAPCON1 – Input Capture Control 1 7 6 5 4 CAP2LS[1:0] R/W Address: 93H Bit Name 3 2 CAP1LS[1:0] R/W Description 5:4 CAP2LS[1:0] Input capture 2 level select 00 = Falling edge. 01 = Rising edge. 10 = Either Rising or falling edge. 11 = Reserved. 3:2 CAP1LS[1:0] Input capture 1 level select 00 = Falling edge. 01 = Rising edge. 10 = Either Rising or falling edge. 11 = Reserved. 1:0 CAP0LS[1:0] Input capture 0 level select 00 = Falling edge. 01 = Rising edge. 10 = Either Rising or falling edge. 11 = Reserved. CAPCON2 – Input Capture Control 2 7 6 5 ENF2 ENF1 R/W R/W Address: 94H Bit Name 4 ENF0 R/W 3 - 2 - 1 0 Reset value: 0000 0000b Description 6 ENF2 Enable noise filer on input capture 2 0 = Noise filter on input capture channel 2 Disabled. 1 = Noise filter on input capture channel 2 Enabled. 5 ENF1 Enable noise filer on input capture 1 0 = Noise filter on input capture channel 1 Disabled. 1 = Noise filter on input capture channel 1 Enabled. 4 ENF0 Enable noise filer on input capture 0 0 = Noise filter on input capture channel 0 Disabled. 1 = Noise filter on input capture channel 0 Enabled. Aug. 03, 2020 1 0 CAP0LS[1:0] R/W Reset value: 0000 0000b Page 35 of 274 Rev. 1.09 N76E003 Datasheet CKDIV – Clock Divider 7 6 5 4 3 2 1 0 CKDIV[7:0] R/W Address: 95H Bit Reset value: 0000 0000b Name 7:0 CKDIV[7:0] Description Clock divider The system clock frequency FSYS follows the equation below according to CKDIV value. FSYS = FOSC , while CKDIV = 00H, and FSYS = FOSC 2 × CKDIV , while CKDIV = 01H to FFH. CKSWT – Clock Switch (TA protected) 7 6 5 HIRCST R Address: 96H Bit Name 4 LIRCST R 3 ECLKST R 2 1 0 OSC[1:0] W Reset value: 0011 0000b Description 7 - Reserved 6 - Reserved 5 HIRCST - - 3 ECLKST External clock input status 0 = External clock input is not stable or disabled. 1 = External clock input is enabled and stable. 2:1 OSC[1:0] Oscillator selection bits This field selects the system clock source. 00 = Internal 16 MHz oscillator. 01 = External clock source according to EXTEN[1:0] (CKEN[7:6]) setting. 10 = Internal 10 kHz oscillator. 11 = Reserved. Note that this field is write only. The read back value of this field may not correspond to the present system clock source. Aug. 03, 2020 High-speed internal oscillator 16 MHz status 0 = High-speed internal oscillator is not stable or disabled. 1 = High-speed internal oscillator is enabled and stable. Reserved Page 36 of 274 Rev. 1.09 N76E003 Datasheet CKEN – Clock Enable (TA protected) 7 6 5 EXTEN[1:0] HIRCEN R/W R/W Address: 97H Bit 4 - 3 - 2 - 1 0 CKSWTF R Reset value: 0011 0000b Name Description 7:6 EXTEN[1:0] External clock source enable 11 = External clock input via XIN Enabled. Others = external clock input is disable. P30 work as general purpose I/O. 5 HIRCEN 4:1 - 0 CKSWTF High-speed internal oscillator 16 MHz enable 0 = The high-speed internal oscillator Disabled. 1 = The high-speed internal oscillator Enabled. Note that once IAP is enabled by setting IAPEN (CHPCON.0), the high-speed internal 16 MHz oscillator will be enabled automatically. The hardware will also set HIRCEN and HIRCST bits. After IAPEN is cleared, HIRCEN and EHRCST resume the original values. Reserved Clock switch fault flag 0 = The previous system clock source switch was successful. 1 = User tried to switch to an instable or disabled clock source at the previous system clock source switch. If switching to an instable clock source, this bit remains 1 until the clock source is stable and switching is successful. SCON – Serial Port Control (Bit-addressable) 7 6 5 4 SM0/FE SM1 SM2 REN R/W R/W R/W R/W Address: 98H Bit Name 7 SM0/FE 6 SM1 3 TB8 R/W 2 RB8 R/W 1 0 TI RI R/W R/W Reset value: 0000 0000b Description Serial port mode select SMOD0 (PCON.6) = 0: See Table 13-1. Serial Port 0 Mode Description for details. SMOD0 (PCON.6) = 1: SM0/FE bit is used as frame error (FE) status flag. It is cleared by software. 0 = Frame error (FE) did not occur. 1 = Frame error (FE) occurred and detected. Aug. 03, 2020 Page 37 of 274 Rev. 1.09 N76E003 Datasheet Bit Name 5 SM2 Description Multiprocessor communication mode enable The function of this bit is dependent on the serial port 0 mode. Mode 0: This bit select the baud rate between FSYS/12 and FSYS/2. 0 = The clock runs at FSYS/12 baud rate. It maintains standard 8051 compatibility. 1 = The clock runs at FSYS/2 baud rate for faster serial communication. Mode 1: This bit checks valid stop bit. 0 = Reception is always valid no matter the logic level of stop bit. 1 = Reception is valid only when the received stop bit is logic 1 and the received data matches “Given” or “Broadcast” address. Mode 2 or 3: For multiprocessor communication. th 0 = Reception is always valid no matter the logic level of the 9 bit. th 1 = Reception is valid only when the received 9 bit is logic 1 and the received data matches “Given” or “Broadcast” address. 4 REN Receiving enable 0 = Serial port 0 reception Disabled. 1 = Serial port 0 reception Enabled in Mode 1,2, or 3. In Mode 0, reception is initiated by the condition REN = 1 and RI = 0. 3 TB8 9 transmitted bit th This bit defines the state of the 9 transmission bit in serial port 0 Mode 2 or 3. It is not used in Mode 0 or 1. 2 RB8 9 received bit th The bit identifies the logic level of the 9 received bit in serial port 0 Mode 2 or 3. In Mode 1, RB8 is the logic level of the received stop bit. SM2 bit as logic 1 has restriction for exception. RB8 is not used in Mode 0. 1 TI Transmission interrupt flag This flag is set by hardware when a data frame has been transmitted by the serial th port 0 after the 8 bit in Mode 0 or the last data bit in other modes. When the serial port 0 interrupt is enabled, setting this bit causes the CPU to execute the serial port 0 interrupt service routine. This bit should be cleared manually via software. 0 RI Receiving interrupt flag This flag is set via hardware when a data frame has been received by the serial th port 0 after the 8 bit in Mode 0 or after sampling the stop bit in Mode 1, 2, or 3. SM2 bit as logic 1 has restriction for exception. When the serial port 0 interrupt is enabled, setting this bit causes the CPU to execute to the serial port 0 interrupt service routine. This bit should be cleared manually via software. Aug. 03, 2020 th th Page 38 of 274 Rev. 1.09 N76E003 Datasheet SBUF – Serial Port 0 Data Buffer 7 6 5 4 3 2 1 0 SBUF[7:0] R/W Address: 99H Bit 7:0 Reset value: 0000 0000b Name Description SBUF[7:0] Serial port 0 data buffer This byte actually consists two separate registers. One is the receiving resister, and the other is the transmitting buffer. When data is moved to SBUF, it goes to the transmitting buffer and is shifted for serial transmission. When data is moved from SBUF, it comes from the receiving register. The transmission is initiated through giving data to SBUF. SBUF_1 – Serial Port 1 Data Buffer 7 6 5 4 3 SBUF_1[7:0] R/W 2 Address: 9AH Bit 7:0 0 Reset value: 0000 0000b Name Description SBUF_1[7:0] Serial port 1 data buffer This byte actually consists two separate registers. One is the receiving resister, and the other is the transmitting buffer. When data is moved to SBUF_1, it goes to the transmitting buffer and is shifted for serial transmission. When data is moved from SBUF_1, it comes from the receiving register. The transmission is initiated through giving data to SBUF_1. EIE – Extensive Interrupt Enable 7 6 5 ET2 ESPI EFB R/W R/W R/W Address: 9BH Bit 1 Name 4 EWDT R/W 3 EPWM R/W 2 ECAP R/W 1 0 EPI EI2C R/W R/W Reset value: 0000 0000b Description 7 ET2 Enable Timer 2 interrupt 0 = Timer 2 interrupt Disabled. 1 = Interrupt generated by TF2 (T2CON.7) Enabled. 6 ESPI Enable SPI interrupt 0 = SPI interrupt Disabled. 1 = Interrupt generated by SPIF (SPSR.7), SPIOVF (SPSR.5), or MODF (SPSR.4) Enable. 5 EFB Enable Fault Brake interrupt 0 = Fault Brake interrupt Disabled. 1 = Interrupt generated by FBF (FBD.7) Enabled. 4 EWDT Aug. 03, 2020 Enable WDT interrupt 0 = WDT interrupt Disabled. 1 = Interrupt generated by WDTF (WDCON.5) Enabled. Page 39 of 274 Rev. 1.09 N76E003 Datasheet Bit Name Description 3 EPWM Enable PWM interrupt 0 = PWM interrupt Disabled. 1 = Interrupt generated by PWMF (PWMCON0.5) Enabled. 2 ECAP Enable input capture interrupt 0 = Input capture interrupt Disabled. 1 = Interrupt generated by any flags of CAPF[2:0] (CAPCON0[2:0]) Enabled. 1 EPI 0 EI2C Enable pin interrupt 0 = Pin interrupt Disabled. 1 = Interrupt generated by any flags in PIF register Enabled. 2 Enable I C interrupt 2 0 = I C interrupt Disabled. 1 = Interrupt generated by SI (I2CON.3) or I2TOF (I2TOC.0) Enabled. EIE1 – Extensive Interrupt Enable 1 7 6 5 Address: 9CH Bit Name 4 - 3 - 2 EWKT R/W 1 0 ET3 ES_1 R/W R/W Reset value: 0000 0000b Description Enable WKT interrupt 0 = WKT interrupt Disabled. 1 = Interrupt generated by WKTF (WKCON.4) Enabled. 2 EWKT 1 ET3 Enable Timer 3 interrupt 0 = Timer 3 interrupt Disabled. 1 = Interrupt generated by TF3 (T3CON.4) Enabled. 0 ES_1 Enable serial port 1 interrupt 0 = Serial port 1 interrupt Disabled. 1 = Interrupt generated by TI_1 (SCON_1.1) or RI_1 (SCON_1.0) Enabled. CHPCON – Chip Control (TA protected) 7 6 5 SWRST IAPFF W R/W Address: 9FH Bit Name 4 3 2 1 0 BS IAPEN R/W R/W Reset value: see Table 6-2. SFR Definitions and Reset Values Description 6 IAPFF IAP fault flag The hardware will set this bit after IAPGO (ISPTRG.0) is set if any of the following condition is met: (1) The accessing address is oversize. (2) IAPCN command is invalid. (3) IAP erases or programs updating un-enabled block. (4) IAP erasing or programming operates under VBOD while BOIAP (CONFIG2.5) remains un-programmed 1 with BODEN (BODCON0.7) as 1 and BORST (BODCON0.2) as 0. This bit should be cleared via software. 0 IAPEN IAP enable Aug. 03, 2020 Page 40 of 274 Rev. 1.09 N76E003 Datasheet Bit Name Description 0 = IAP function Disabled. 1 = IAP function Enabled. Once enabling IAP function, the HIRC will be turned on for timing control. To clear IAPEN should always be the last instruction after IAP operation to stop internal oscillator if reducing power consumption is concerned. 1 BS 0 IAPEN Boot select This bit defines from which block that MCU re-boots after all resets. 0 = MCU will re-boot from APROM after all resets. 1 = MCU will re-boot from LDROM after all resets. IAP enable 0 = IAP function Disabled. 1 = IAP function Enabled. Once enabling IAP function, the HIRC will be turned on for timing control. To clear IAPEN should always be the last instruction after IAP operation to stop internal oscillator if reducing power consumption is concerned. P2 – Port 2 (Bit-addressable) 7 6 0 0 R R Address: A0H Bit Name 7:1 0 0 P2.0 5 0 R Name 3 0 R 2 0 R 1 0 0 P2.0 R R Reset value: 0000 000Xb Description Reserved The bits are always read as 0. Port 2 bit 0 P2.0 is an input-only pin when RPD (CONFIG0.2) is programmed as 0. When leaving RPD un-programmed, P2.0 is always read as 0. AUXR1 – Auxiliary Register 1 7 6 5 SWRF RSTPINF HardF R/W R/W R/W Address: A2H Bit 4 0 R 4 3 2 1 0 GF2 UART0PX 0 0 R/W R/W R 0 Reset value: see Table 6-2. SFR Definitions and Reset Values Description Software reset flag When the MCU is reset via software reset, this bit will be set via hardware. It is recommended that the flag be cleared via software. 7 SWRF 6 RSTPINF External reset flag When the MCU is reset by the external reset pin, this bit will be set via hardware. It is recommended that the flag be cleared via software. 5 HardF Hard Fault reset flag Once Program Counter (PC) is over flash size, MCU will be reset and this bit will be set via hardware. It is recommended that the flag be cleared via software. Note: If MCU run in OCD debug mode and OCDEN = 0, hard fault reset will be disabled and only HardF flag be asserted. Aug. 03, 2020 Page 41 of 274 Rev. 1.09 N76E003 Datasheet Bit Name Description General purpose flag 2 The general purpose flag that can be set or cleared by the user via software. 3 GF2 2 UART0PX 1 0 Reserved This bit is always read as 0. 0 0 Reserved Always keep this bit as 0 Serial port 0 pin exchange 0 = Assign RXD to P0.7 and TXD to P0.6 by default. 1 = Exchange RXD to P0.6 and TXD to P0.7. Note that TXD and RXD will exchange immediately once setting or clearing this bit. User should take care of not exchanging pins during transmission or receiving. Or it may cause unpredictable situation and no warning alarms. BODCON0 – Brown-out Detection Control 0 (TA protected) 7 6 5 4 3 2 1 0 BODEN[1] BOV[1:0][1] BOF[2] BORST[1] BORF BOS R/W R/W R/W R/W R/W R Address: A3H Reset value: see Table 6-2. SFR Definitions and Reset Values Bit Name Description 7 BODEN Brown-out detection enable 0 = Brown-out detection circuit off. 1 = Brown-out detection circuit on. Note that BOD output is not available until 2~3 LIRC clocks after enabling. 6:4 BOV[1:0] Brown-out voltage select 11 = VBOD is 2.2V. 10 = VBOD is 2.7V. 01 = VBOD is 3.7V. 00 = VBOD is 4.4V. 3 BOF Brown-out interrupt flag This flag will be set as logic 1 via hardware after a V DD dropping below or rising above VBOD event occurs. If both EBOD (EIE.2) and EA (IE.7) are set, a brown-out interrupt requirement will be generated. This bit should be cleared via software. 2 BORST Brown-out reset enable This bit decides whether a brown-out reset is caused by a power drop below VBOD. 0 = Brown-out reset when VDD drops below VBOD Disabled. 1 = Brown-out reset when VDD drops below VBOD Enabled. 1 BORF Brown-out reset flag When the MCU is reset by brown-out event, this bit will be set via hardware. This flag is recommended to be cleared via software. Brown-out status This bit indicates the VDD voltage level comparing with VBOD while BOD circuit is enabled. It keeps 0 if BOD is not enabled. 0 = VDD voltage level is higher than VBOD or BOD is disabled. 1 = VDD voltage level is lower than VBOD. Note that this bit is read-only. [1] BODEN, BOV[1:0], and BORST are initialized by being directly loaded from CONFIG2 bit 7, [6:4], and 2 after all resets. [2] BOF reset value depends on different setting of CONFIG2 and VDD voltage level. Please check Table 24-1. 0 Aug. 03, 2020 BOS Page 42 of 274 Rev. 1.09 N76E003 Datasheet IAPTRG – IAP Trigger (TA protected) 7 6 5 Address: A4H Bit Name 0 IAPGO 4 - 3 - Name 1 0 IAPGO W Reset value: 0000 0000b Description IAP go IAP begins by setting this bit as logic 1. After this instruction, the CPU holds the Program Counter (PC) and the IAP hardware automation takes over to control the progress. After IAP action completed, the Program Counter continues to run the following instruction. The IAPGO bit will be automatically cleared and always read as logic 0. Before triggering an IAP action, interrupts (if enabled) should be temporary disabled for hardware limitation. IAPUEN – IAP Updating Enable (TA protected) 7 6 5 4 Address: A5H Bit 2 - 3 - 2 CFUEN R/W 1 0 LDUEN APUEN R/W R/W Reset value: 0000 0000b Description 2 CFUEN CONFIG bytes updated enable 0 = Inhibit erasing or programming CONFIG bytes by IAP. 1 = Allow erasing or programming CONFIG bytes by IAP. 1 LDUEN LDROM updated enable 0 = Inhibit erasing or programming LDROM by IAP. 1 = Allow erasing or programming LDROM by IAP. 0 APUEN APROM updated enable 0 = Inhibit erasing or programming APROM by IAP. 1 = Allow erasing or programming APROM by IAP. IAPAL – IAP Address Low Byte 7 6 5 4 3 2 1 0 IAPA[7:0] R/W Address: A6H Bit 7:0 Aug. 03, 2020 Reset value: 0000 0000b Name IAPA[7:0] Description IAP address low byte IAPAL contains address IAPA[7:0] for IAP operations. Page 43 of 274 Rev. 1.09 N76E003 Datasheet IAPAH – IAP Address High Byte 7 6 5 4 3 2 1 0 IAPA[15:8] R/W Address: A7H Bit 7:0 Reset value: 0000 0000b Name Description IAPA[15:8] IAP address high byte IAPAH contains address IAPA[15:8] for IAP operations. IE – Interrupt Enable (Bit-addressable) 7 6 5 EA EADC EBOD R/W R/W R/W Address: A8H Bit Name 4 ES R/W 3 ET1 R/W 2 EX1 R/W 1 0 ET0 EX0 R/W R/W Reset value: 0000 0000b Description Enable all interrupt This bit globally enables/disables all interrupts that are individually enabled. 0 = All interrupt sources Disabled. 1 = Each interrupt Enabled depending on its individual mask setting. Individual interrupts will occur if enabled. 7 EA 6 EADC Enable ADC interrupt 0 = ADC interrupt Disabled. 1 = Interrupt generated by ADCF (ADCCON0.7) Enabled. 5 EBOD Enable brown-out interrupt 0 = Brown-out detection interrupt Disabled. 1 = Interrupt generated by BOF (BODCON0.3) Enabled. 4 ES Enable serial port 0 interrupt 0 = Serial port 0 interrupt Disabled. 1 = Interrupt generated by TI (SCON.1) or RI (SCON.0) Enabled. 3 ET1 Enable Timer 1 interrupt 0 = Timer 1 interrupt Disabled. 1 = Interrupt generated by TF1 (TCON.7) Enabled. 2 EX1 Enable external interrupt 1 0 = External interrupt 1 Disabled. 1 = Interrupt generated by ̅̅̅̅̅̅̅ pin (P1.7) Enabled. 1 ET0 Enable Timer 0 interrupt 0 = Timer 0 interrupt Disabled. 1 = Interrupt generated by TF0 (TCON.5) Enabled. 0 EX0 Enable external interrupt 0 0 = External interrupt 0 Disabled. 1 = Interrupt generated by ̅̅̅̅̅̅̅ pin (P3.0) Enabled. Aug. 03, 2020 Page 44 of 274 Rev. 1.09 N76E003 Datasheet SADDR – Slave 0 Address 7 6 5 4 3 2 1 0 SADDR[7:0] R/W Address: A9H Bit 7:0 Reset value: 0000 0000b Name Description SADDR[7:0] Slave 0 address his byte specifies the microcontroller’s own slave address for UA processor communication. multi- WDCON – Watchdog Timer Control (TA protected) 7 6 5 4 3 2 1 0 WDTR WDCLR WDTF WIDPD WDTRF WDPS[2:0] R/W R/W R/W R/W R/W R/W Address: AAH Reset value: see Table 6-2. SFR Definitions and Reset Values Bit Name Description 7 WDTR WDT run This bit is valid only when control bits in WDTEN[3:0] (CONFIG4[7:4]) are all 1. At this time, WDT works as a general purpose timer. 0 = WDT Disabled. 1 = WDT Enabled. The WDT counter starts running. 6 WDCLR WDT clear Setting this bit will reset the WDT count to 00H. It puts the counter in a known state and prohibit the system from unpredictable reset. The meaning of writing and reading WDCLR bit is different. Writing: 0 = No effect. 1 = Clearing WDT counter. Reading: 0 = WDT counter is completely cleared. 1 = WDT counter is not yet cleared. 5 WDTF WDT time-out flag This bit indicates an overflow of WDT counter. This flag should be cleared by software. 4 WIDPD WDT running in Idle or Power-down mode This bit is valid only when control bits in WDTEN[3:0] (CONFIG4[7:4]) are all 1. It decides whether WDT runs in Idle or Power-down mode when WDT works as a general purpose timer. 0 = WDT stops running during Idle or Power-down mode. 1 = WDT keeps running during Idle or Power-down mode. 3 WDTRF WDT reset flag When the MCU is reset by WDT time-out event, this bit will be set via hardware. It is recommended that the flag be cleared via software. Aug. 03, 2020 Page 45 of 274 Rev. 1.09 N76E003 Datasheet Bit Name Description WDT clock pre-scalar select These bits determine the pre-scale of WDT clock from 1/1 through 1/256. See Note: When register CKDIV value is not equal 00H, the system clock frequency will be divided, if under this condition after MCU into power down mode, the WDT Reset will fail. So suggest use WKT to wakeup N76E003 when into power down mode. Table 11-1. The default is the maximum pre-scale value. [1] WDTRF will be cleared after power-on reset, be set after WDT reset, and remains unchanged after any other resets. [2] WDPS[2:0] are all set after power-on reset and keep unchanged after any reset other than power-on reset. 2:0 WDPS[2:0] BODCON1 – Brown-out Detection Control 1 (TA protected) 7 6 5 4 3 2 1 0 LPBOD[1:0] BODFLT R/W R/W Address: ABH Reset value: see Table 6-2. SFR Definitions and Reset Values Bit Name 7:3 - 2:1 LPBOD[1:0] 0 BODFLT Aug. 03, 2020 Description Reserved Low power BOD enable 00 = BOD normal mode. BOD circuit is always enabled. 01 = BOD low power mode 1 by turning on BOD circuit every 1.6 ms periodically. 10 = BOD low power mode 2 by turning on BOD circuit every 6.4 ms periodically. 11 = BOD low power mode 3 by turning on BOD circuit every 25.6 ms periodically. BOD filter control BOD has a filter which counts 32 clocks of FSYS to filter the power noise when MCU runs with HIRC, or ECLK as the system clock and BOD does not operates in its low power mode (LPBOD[1:0] = [0, 0]). In other conditions, the filter counts 2 clocks of LIRC. Note that when CPU is halted in Power-down mode. The BOD output is permanently filtered by 2 clocks of LIRC. The BOD filter avoids the power noise to trigger BOD event. This bit controls BOD filter enabled or disabled. 0 = BOD filter Disabled. 1 = BOD filter Enabled. (Power-on reset default value.) Page 46 of 274 Rev. 1.09 N76E003 Datasheet P3M1 – Port 3 Mode Select 1 7 6 Address: ACH, Page: 0 Bit Name 5 - 4 - 3 - 2 - 1 0 P3M1.0[3] R/W Reset value: 0000 0001b Description Port 3 mode select 1 0 P3M1.0 [3] P3M1 and P3M2 are used in combination to determine the I/O mode of each pin of P3. See Table 7-1. Configuration for Different I/O Modes. P3S – Port 3 Schmitt Triggered Input 7 6 5 Address: ACH, Page: 1 Bit Name 0 P3S.0 Name 3 - 2 - 1 0 P3S.0 R/W Reset value: 0000 0000b 3 - 2 - 1 0 P3M2.0[3] R/W Reset value: 0000 0000b Description P3.0 Schmitt triggered input 0 = TTL level input of P3.0. 1 = Schmitt triggered input of P3.0. P3M2 – Port 3 Mode Select 2 7 6 Address: ADH, Page: 0 Bit 4 - 5 - 4 - Description Port 3 mode select 2 0 P3M2.0 [3] P3M1 and P3M2 are used in combination to determine the I/O mode of each pin of P3. See Table 7-1. Configuration for Different I/O Modes. P3SR – Port 3 Slew Rate 7 6 Address: ADH, Page: 1 Bit Name 0 Aug. 03, 2020 P3SR.0 5 - 4 - 3 - 2 - 1 0 P3SR.0 R/W Reset value: 0000 0000b Description P3.n slew rate 0 = P3.0 normal output slew rate. 1 = P3.0 high-speed output slew rate. Page 47 of 274 Rev. 1.09 N76E003 Datasheet IAPFD – IAP Flash Data 7 6 5 4 3 2 1 0 IAPFD[7:0] R/W Address: AEH Bit 7:0 Reset value: 0000 0000b Name Description IAPFD[7:0] IAP flash data This byte contains flash data, which is read from or is going to be written to the Flash Memory. User should write data into IAPFD for program mode before triggering IAP processing and read data from IAPFD for read/verify mode after IAP processing is finished. IAPCN – IAP Control 7 6 IAPB[1:0] R/W Address: AFH Bit 5 FOEN R/W Name 7:6 IAPB[1:0] 5 FOEN 4 FCEN 3:0 FCTRL[3:0] Name 7:1 0 0 P3.0 Aug. 03, 2020 3 2 1 0 FCTRL[3:0] R/W Reset value: 0011 0000b Description IAP control This byte is used for IAP command. For details, see Table 21-1. IAP Modes and Command Codes. P3 – Port 3 (Bit-addressable) 7 6 0 0 R R Address: B0H Bit 4 FCEN R/W 5 0 R 4 0 R 3 0 R 2 0 R 1 0 0 P3.0 R R/W Reset value: 0000 0001b Description Reserved The bits are always read as 0. Port 3 bit 0 P3.0 is available only when the internal oscillator is used as the system clock. At this moment, P3.0 functions as a general purpose I/O. If the system clock is not selected as the internal oscillator, P3.0 pin functions as OSCIN. A write to P3.0 is invalid and P3.0 is always read as 0. Page 48 of 274 Rev. 1.09 N76E003 Datasheet P0M1 – Port 0 Mode Select 1[1] 7 6 5 P0M1.7 P0M1.6 P0M1.5 R/W R/W R/W Address: B1H, Page: 0 Bit Name 4 P0M1.4 R/W 3 P0M1.3 R/W 2 P0M1.2 R/W 1 0 P0M1.1 P0M1.0 R/W R/W Reset value: 1111 1111b Description 7:0 P0M1[7:0] Port 0 mode select 1 [1] P0M1 and P0M2 are used in combination to determine the I/O mode of each pin of P0. See Table 7-1. Configuration for Different I/O Modes. P0M1.n P0M2.n 0 0 Quasi-bidirectional 0 1 Push-pull 1 0 Input-only (high-impedance) 1 1 Open-drain P0S – Port 0 Schmitt Triggered Input 7 6 5 P0S.7 P0S.6 P0S.5 R/W R/W R/W Address: B1H, Page: 1 Bit Name n P0S.n Name 3 P0S.3 R/W 2 P0S.2 R/W 1 0 P0S.1 P0S.0 R/W R/W Reset value: 0000 0000b 2 P0M2.2 R/W 1 0 P0M2.1 P0M2.0 R/W R/W Reset value: 0000 0000b Description P0.n Schmitt triggered input 0 = TTL level input of P0.n. 1 = Schmitt triggered input of P0.n. P0M2 – Port 0 Mode Select 2[1] 7 6 5 P0M2.7 P0M2.6 P0M2.5 R/W R/W R/W Address: B2H, Page: 0 Bit 4 P0S.4 R/W I/O Type 4 P0M2.4 R/W 3 P0M2.3 R/W Description 7:0 P0M2[7:0] Port 0 mode select 2 [1] P0M1 and P0M2 are used in combination to determine the I/O mode of each pin of P0. See Table 7-1. Configuration for Different I/O Modes. Aug. 03, 2020 Page 49 of 274 Rev. 1.09 N76E003 Datasheet P0SR – Port 0 Slew Rate 7 6 P0SR.7 P0SR.6 R/W R/W Address: B2H, Page: 1 Bit Name n P0SR.n 5 P0SR.5 R/W Name 3 P0SR.3 R/W 2 P0SR.2 R/W 1 0 P0SR.1 P0SR.0 R/W R/W Reset value: 0000 0000b 2 P1M1.2 R/W 1 0 P1M1.1 P1M1.0 R/W R/W Reset value: 1111 1111b Description P0.n slew rate 0 = P0.n normal output slew rate. 1 = P0.n high-speed output slew rate. P1M1 – Port 1 Mode Select 1[2] 7 6 5 P1M1.7 P1M1.6 P1M1.5 R/W R/W R/W Address: B3H, Page: 0 Bit 4 P0SR.4 R/W 4 P1M1.4 R/W 3 P1M1.3 R/W Description 7:0 P1M1[7:0] Port 1 mode select 1 [2] P1M1 and P1M2 are used in combination to determine the I/O mode of each pin of P1. See Table 7-1. Configuration for Different I/O Modes. P1S – Port 1 Schmitt Triggered Input 7 6 5 P1S.7 P1S.6 P1S.5 R/W R/W R/W Address: B3H, Page: 1 Bit Name n P1S.n Name 3 P1S.3 R/W 2 P1S.2 R/W 1 0 P1S.1 P1S.0 R/W R/W Reset value: 0000 0000b 2 P1M2.2 R/W 1 0 P1M2.1 P1M2.0 R/W R/W Reset value: 0000 0000b Description P1.n Schmitt triggered input 0 = TTL level input of P1.n. 1 = Schmitt triggered input of P1.n. P1M2 – Port 1 Mode Select 2[2] 7 6 5 P1M2.7 P1M2.6 P1M2.5 R/W R/W R/W Address: B4H, Page: 0 Bit 4 P1S.4 R/W 4 P1M2.4 R/W 3 P1M2.3 R/W Description 7:0 P1M2[7:0] Port 1 mode select 2. [2] P1M1 and P1M2 are used in combination to determine the I/O mode of each pin of P1. See Table 7-1. Configuration for Different I/O Modes. Aug. 03, 2020 Page 50 of 274 Rev. 1.09 N76E003 Datasheet P1SR – Port 1 Slew Rate 7 6 P1SR.7 P1SR.6 R/W R/W Address: B4H, Page: 1 Bit Name n P1SR.n 5 P1SR.5 R/W 4 P1SR.4 R/W Name 2 P1SR.2 R/W 1 0 P1SR.1 P1SR.0 R/W R/W Reset value: 0000 0000b 2 T0OE R/W 1 0 P2S.0 R/W Reset value: 0000 0000b Description P1.n slew rate 0 = P1.n normal output slew rate. 1 = P1.n high-speed output slew rate. P2S – P20 Setting and Timer01 Output Enable 7 6 5 4 P20UP R/W Address: B5H Bit 3 P1SR.3 R/W 3 T1OE R/W Description 7 P20UP P2.0 pull-up enable 0 = P2.0 pull-up Disabled. 1 = P2.0 pull-up Enabled. This bit is valid only when RPD (CONFIG0.2) is programmed as 0. When selecting as a ̅̅̅̅̅̅ pin, the pull-up is always enabled. 3 T1OE Timer 1 output enable 0 = Timer 1 output Disabled. 1 = Timer 1 output Enabled from T1 pin. ote that imer output should be enabled only when operating in its “ imer” mode. 2 T0OE Timer 0 output enable 0 = Timer 0 output Disabled. 1 = Timer 0 output Enabled from T0 pin. ote that imer output should be enabled only when operating in its “ imer” mode. 0 P2S.0 P2.0 Schmitt triggered input 0 = TTL level input of P2.0. 1 = Schmitt triggered input of P2.0. IPH – Interrupt Priority High[2] 7 6 5 PADCH PBODH R/W R/W Address: B7H, Page0 Bit Name 4 PSH R/W 3 PT1H R/W 1 0 PT0H PX0H R/W R/W Reset value: 0000 0000b Description 6 PADC ADC interrupt priority high bit 5 PBOD Brown-out detection interrupt priority high bit 4 PSH Aug. 03, 2020 2 PX1H R/W Serial port 0 interrupt priority high bit Page 51 of 274 Rev. 1.09 N76E003 Datasheet Bit Name Description 3 PT1H Timer 1 interrupt priority high bit 2 PX1H External interrupt 1 priority high bit 1 PT0H Timer 0 interrupt priority high bit External interrupt 0 priority high bit 0 PX0H [2] IPH is used in combination with the IP respectively to determine the priority of each interrupt source. See Table 20-2. Interrupt Priority Level Setting for correct interrupt priority configuration. PWMINTC – PWM Interrupt Control 7 6 5 INTTYP1 R/W Address: B7H, Page:1 Bit Name 4 INTTYP0 R/W 3 - 2 INTSEL2 R/W 1 0 INTSEL1 INTSEL0 R/W R/W Reset value: 0000 0000b Description 5:4 INTTYP[1:0] PWM interrupt type select These bit select PWM interrupt type. 00 = Falling edge on PWM0/1/2/3/4/5 pin. 01 = Rising edge on PWM0/1/2/3/4/5 pin. 10 = Central point of a PWM period. 11 = End point of a PWM period. Note that the central point interrupt or the end point interrupt is only available while PWM operates in center-aligned type. 2:0 INTSEL[2:0] PWM interrupt pair select These bits select which PWM channel asserts PWM interrupt when PWM interrupt type is selected as falling or rising edge on PWM0/1/2/3/4/5 pin.. 000 = PWM0. 001 = PWM1. 010 = PWM2. 011 = PWM3. 100 = PWM4. 101 = PWM5. Others = PWM0. IP – Interrupt Priority (Bit-addressable)[1] 7 6 5 PADC PBOD R/W R/W Address: B8H Bit Name 4 PS R/W 3 PT1 R/W 1 0 PT0 PX0 R/W R/W Reset value: 0000 0000b Description 6 PADC ADC interrupt priority low bit 5 PBOD Brown-out detection interrupt priority low bit 4 PS Serial port 0 interrupt priority low bit 3 PT1 Timer 1 interrupt priority low bit 2 PX1 External interrupt 1 priority low bit 1 PT0 Timer 0 interrupt priority low bit 0 PX0 External interrupt 0 priority low bit Aug. 03, 2020 2 PX1 R/W Page 52 of 274 Rev. 1.09 N76E003 Datasheet [1] IP is used in combination with the IPH to determine the priority of each interrupt source. See Table 20-2. Interrupt Priority Level Setting for correct interrupt priority configuration. SADEN – Slave 0 Address Mask 7 6 5 4 3 2 1 0 SADEN[7:0] R/W Address: B9H Bit 7:0 Reset value: 0000 0000b Name Description SADEN[7:0] Slave 0 address mask This byte is a mask byte of UART0 that contains “don’t-care” bits (defined by zeros) to form the device’s “Given” address. The don’t-care bits provide the flexibility to address one or more slaves at a time. SADEN_1 – Slave 1 Address Mask 7 6 5 4 3 SADEN_1[7:0] R/W 2 Address: BAH Bit 7:0 Name Description SADEN_1[7:0] Slave 1 address mask This byte is a mask byte of UART1 that contains “don’t-care” bits (defined by zeros) to form the device’s “Given” address. The don’t-care bits provide the flexibility to address one or more slaves at a time. 5 4 3 SADDR_1[7:0] R/W Address: BBH 7:0 Aug. 03, 2020 0 Reset value: 0000 0000b SADDR_1 – Slave 1 Address 7 6 Bit 1 2 1 0 Reset value: 0000 0000b Name Description SADDR_1[7:0] Slave 1 address his byte specifies the microcontroller’s own slave address for UART1 multiprocessor communication. Page 53 of 274 Rev. 1.09 N76E003 Datasheet 2 I2DAT – I C Data 7 6 5 4 3 2 1 0 I2DAT[7:0] R/W Address: BCH Bit Reset value: 0000 0000b Name 7:0 I2DAT[7:0] Description 2 I C data 2 I2DAT contains a byte of the I C data to be transmitted or a byte, which has just received. Data in I2DAT remains as long as SI is logic 1. The result of reading 2 or writing I2DAT during I C transceiving progress is unpredicted. While data in I2DAT is shifted out, data on the bus is simultaneously being shifted in to update I2DAT. I2DAT always shows the last byte that presented on 2 the I C bus. Thus the event of lost arbitration, the original value of I2DAT changes after the transaction. 2 I2STAT – I C Status 7 6 5 I2STAT[7:3] R 4 3 Address: BDH Bit 2 0 R 1 0 0 0 R R Reset value: 1111 1000b Name Description 7:3 I2STAT[7:3] I C status code The MSB five bits of I2STAT contains the status code. There are 27 possible status codes. When I2STAT is F8H, no relevant state information is available 2 and SI flag keeps 0. All other 26 status codes correspond to the I C states. When each of these status is entered, SI will be set as logic 1 and a interrupt is requested. 2:0 0 Aug. 03, 2020 2 Reserved The least significant three bits of I2STAT are always read as 0. Page 54 of 274 Rev. 1.09 N76E003 Datasheet 2 I2CLK – I C Clock 7 6 5 4 3 2 1 0 I2CLK[7:0] R/W Address: BEH Bit 7:0 Reset value: 0000 1001b Name Description I2CLK[7:0] I C clock setting In master mode: 2 This register determines the clock rate of I C bus when the device is in a master mode. The clock rate follows the equation, 2 FSYS 4 × (I2CLK + 1) . 2 The default value will make the clock rate of I C bus 400k bps if the peripheral clock is 16 MHz. Note that the I2CLK value of 00H and 01H are not valid. This is an implement limitation. In slave mode: 2 This byte has no effect. In slave mode, the I C device will automatically synchronize with any given clock rate up to 400k bps. 2 I2TOC – I C Time-out Counter 7 6 Address: BFH Bit 5 - 4 - Name Description 2 I2TOCEN I C time-out counter enable 2 0 = I C time-out counter Disabled. 2 1 = I C time-out counter Enabled. 1 DIV 0 I2TOF Aug. 03, 2020 3 - 2 I2TOCEN R/W 1 0 DIV I2TOF R/W R/W Reset value: 0000 0000b 2 2 I C time-out counter clock divider 2 0 = The clock of I C time-out counter is FSYS/1. 2 1 = The clock of I C time-out counter is FSYS/4. 2 I C time-out flag 2 This flag is set by hardware if 14-bit I C time-out counter overflows. It is cleared by software. Page 55 of 274 Rev. 1.09 N76E003 Datasheet 2 I2CON – I C Control (Bit-addressable) 7 6 5 I2CEN STA R/W R/W Address: C0H Bit Name 4 STO R/W 3 SI R/W 2 AA R/W 1 0 I2CPX R/W Reset value: 0000 0000b Description 2 6 I2CEN 5 STA START flag 2 When STA is set, the I C generates a START condition if the bus is free. If the bus 2 is busy, the I C waits for a STOP condition and generates a START condition following. 2 If STA is set while the I C is already in the master mode and one or more bytes 2 have been transmitted or received, the I C generates a repeated START condition. Note that STA can be set anytime even in a slave mode, but STA is not hardware automatically cleared after START or repeated START condition has been detected. User should take care of it by clearing STA manually. 4 STO STOP flag 2 When STO is set if the I C is in the master mode, a STOP condition is transmitted to the bus. STO is automatically cleared by hardware once the STOP condition has been detected on the bus. 2 The STO flag setting is also used to recover the I C device from the bus error 2 state (I2STAT as 00H). In this case, no STOP condition is transmitted to the I C bus. If the STA and STO bits are both set and the device is original in the master 2 mode, the I C bus will generate a STOP condition and immediately follow a START condition. If the device is in slave mode, STA and STO simultaneous 2 setting should be avoid from issuing illegal I C frames. 3 SI I C interrupt flag 2 SI flag is set by hardware when one of 26 possible I C status (besides F8H status) is entered. After SI is set, the software should read I2STAT register to determine which step has been passed and take actions for next step. SI is cleared by software. Before the SI is cleared, the low period of SCL line is stretched. The transaction is suspended. It is useful for the slave device to deal with previous data bytes until ready for receiving the next byte. The serial transaction is suspended until SI is cleared by software. After SI is 2 cleared, I C bus will continue to generate START or repeated START condition, STOP condition, 8-bit data, or so on depending on the software configuration of controlling byte or bits. Therefore, user should take care of it by preparing suitable setting of registers before SI is software cleared. Aug. 03, 2020 I C bus enable 2 0 = I C bus Disabled. 2 1 = I C bus Enabled. 2 Before enabling the I C, SCL and SDA port latches should be set to logic 1. 2 Page 56 of 274 Rev. 1.09 N76E003 Datasheet Bit Name 2 AA 0 I2CPX Description Acknowledge assert flag If the AA flag is set, an ACK (low level on SDA) will be returned during the 2 acknowledge clock pulse of the SCL line while the I C device is a receiver or an own-address-matching slave. If the AA flag is cleared, a NACK (high level on SDA) will be returned during the 2 acknowledge clock pulse of the SCL line while the I C device is a receiver or an own-address-matching slave. A device with its own AA flag cleared will ignore its own salve address and the General Call. Consequently, SI will note be asserted and no interrupt is requested. Note that if an addressed slave does not return an ACK under slave receiver mode or not receive an ACK under slave transmitter mode, the slave device will become a not addressed slave. It cannot receive any data until its AA flag is set and a master addresses it again. There is a special case of I2STAT value C8H occurs under slave transmitter mode. Before the slave device transmit the last data byte to the master, AA flag can be cleared as 0. Then after the last data byte transmitted, the slave device will actively switch to not addressed slave mode of disconnecting with the master. The further reading by the master will be all FFH. I2C pins select 0 = Assign SCL to P1.3 and SDA to P1.4. 1 = Assign SCL to P0.2 and SDA to P1.6. Note that I2C pins will exchange immediately once setting or clearing this bit. 2 I2ADDR – I C Own Slave Address 7 6 5 4 I2ADDR[7:1] R/W 3 Address: C1H Bit Name 7:1 I2ADDR[7:1] 2 1 0 GC R/W Reset value: 0000 0000b Description 2 I C device’s own slave address In master mode: These bits have no effect. In slave mode: 2 These 7 bits define the slave address of this I C device by user. The master 2 should address I C device by sending the same address in the first byte data 2 after a START or a repeated START condition. If the AA flag is set, this I C device will acknowledge the master after receiving its own address and become an addressed slave. Otherwise, the addressing from the master will be ignored. Note that I2ADDR[7:1] should not remain its default value of all 0, because address 0x00 is reserved for General Call. 6 GC General Call bit In master mode: This bit has no effect. In slave mode: 0 = The General Call is always ignored. 1 = The General Call is recognized if AA flag is 1; otherwise, it is ignored if AA is 0. Aug. 03, 2020 Page 57 of 274 Rev. 1.09 N76E003 Datasheet ADCRL – ADC Result Low Byte 7 6 5 Address: C2H Bit Name 3:0 ADCR[3:0] 4 - 3 2 1 0 ADCR[3:0] R Reset value: 0000 0000b Description ADC result low byte The least significant 4 bits of the ADC result stored in this register. ADCRH – ADC Result High Byte 7 6 5 4 3 2 1 0 ADCR[11:4] R Address: C3H Bit 7:0 Reset value: 0000 0000b Name Description ADCR[11:4] ADC result high byte The most significant 8 bits of the ADC result stored in this register. T3CON – Timer 3 Control 7 6 _ SMOD 1 SMOD0_1 R/W R/W Address: C4H, Page:0 5 BRCK R/W 4 TF3 R/W 3 TR3 R/W 2 1 0 T3PS[2:0] R/W Reset value: 0000 0000b Bit Name Description 7 SMOD_1 Serial port 1 double baud rate enable Setting this bit doubles the serial port baud rate when UART1 is in Mode 2. See Table 13-2. Serial Port 1 Mode Description for details. 6 SMOD0_1 Serial port 1 framing error access enable 0 = SCON_1.7 accesses to SM0_1 bit. 1 = SCON_1.7 accesses to FE_1 bit. 5 BRCK 4 TF3 Timer 3 overflow flag This bit is set when Timer 3 overflows. It is automatically cleared by hardware when the program executes the Timer 3 interrupt service routine. This bit can be set or cleared by software. 3 TR3 Timer 3 run control 0 = Timer 3 is halted. 1 = Timer 3 starts running. Note that the reload registers RH3 and RL3 can only be written when Timer 3 is halted (TR3 bit is 0). If any of RH3 or RL3 is written if TR3 is 1, result is unpredictable. Aug. 03, 2020 Serial port 0 baud rate clock source This bit selects which Timer is used as the baud rate clock source when serial port 0 is in Mode 1 or 3. 0 = Timer 1. 1 = Timer 3. Page 58 of 274 Rev. 1.09 N76E003 Datasheet Bit Name 2:0 T3PS[2:0] Description Timer 3 pre-scalar These bits determine the scale of the clock divider for Timer 3. 000 = 1/1. 001 = 1/2. 010 = 1/4. 011 = 1/8. 100 = 1/16. 101 = 1/32. 110 = 1/64. 111 = 1/128. PWM4H – PWM4 Duty High Byte 7 6 5 4 3 2 1 0 PWM4[15:8] R/W Address: C4H, Page:1 Bit 7:0 reset value: 0000 0000b Name Description PWM4[15:8] PWM4 duty high byte This byte with PWM4L controls the duty of the output signal PG4 from PWM generator. RL3 – Timer 3 Reload Low Byte 7 6 5 4 3 2 1 0 RL3[7:0] R/W Address: C5H, Page:0 Bit Name 7:0 RL3[7:0] Reset value: 0000 0000b Description Timer 3 reload low byte It holds the low byte of the reload value of Timer 3. PWM5H – PWM5 Duty High Byte 7 6 5 4 3 2 1 0 PWM5[15:8] R/W Address: C5H, Page:1 Bit 7:0 Aug. 03, 2020 Name PWM5[15:8] reset value: 0000 0000b Description PWM5 duty high byte This byte with PWM5L controls the duty of the output signal PG5 from PWM generator. Page 59 of 274 Rev. 1.09 N76E003 Datasheet RH3 – Timer 3 Reload High Byte 7 6 5 4 3 2 1 0 RH3[7:0] R/W Address: C6H, Page:0 Bit Name 7:0 RH3[7:0] Reset value: 0000 0000b Description Timer 3 reload high byte It holds the high byte of the reload value of Time 3. PIOCON1 – PWM or I/O Select 7 6 5 PIO15 R/W Address: C6H, Page:1 Bit Name 4 - 3 PIO13 R/W 1 0 PIO11 R/W Reset value: 0000 0000b Description 5 PIO15 P1.5/PWM5 pin function select 0 = P1.5/PWM5 pin functions as P1.5. 1 = P1.5/PWM5 pin functions as PWM5 output. 3 PIO13 P0.4/PWM3 pin function select 0 = P0.4/PWM3 pin functions as P0.4. 1 = P0.4/PWM3 pin functions as PWM3 output. 2 PIO12 P0.5/PWM2 pin function select 0 = P0.5/PWM2 pin functions as P0.5. 1 = P0.5/PWM2 pin functions as PWM2 output. 1 PIO11 P1.4/PWM1 pin function select 0 = P1.4/PWM1 pin functions as P1.4. 1 = P1.4/PWM1 pin functions as PWM1 output. TA – Timed Access 7 6 2 PIO12 R/W 5 4 3 2 1 0 TA[7:0] W Address: C7H Bit 7:0 Aug. 03, 2020 Reset value: 0000 0000b Name TA[7:0] Description Timed access The timed access register controls the access to protected SFRs. To access protected bits, user should first write AAH to the TA and immediately followed by a write of 55H to TA. After these two steps, a writing permission window is opened for 4 clock cycles during this period that user may write to protected SFRs. Page 60 of 274 Rev. 1.09 N76E003 Datasheet T2CON – Timer 2 Control 7 6 TF2 R/W Address: C8H Bit Name 5 - 4 - 3 - 2 TR2 R/W 1 0 ̅̅̅̅̅̅ R/W Reset value: 0000 0000b Description 7 TF2 Timer 2 overflow flag This bit is set when Timer 2 overflows or a compare match occurs. If the Timer 2 interrupt and the global interrupt are enable, setting this bit will make CPU execute Timer 2 interrupt service routine. This bit is not automatically cleared via hardware and should be cleared via software. 2 TR2 Timer 2 run control 0 = Timer 2 Disabled. Clearing this bit will halt Timer 2 and the current count will be preserved in TH2 and TL2. 1 = Timer 2 Enabled. 0 ̅̅̅̅̅̅ T2MOD – Timer 2 Mode 7 6 LDEN R/W Address: C9H Bit Name Timer 2 compare or auto-reload mode select This bit selects Timer 2 functioning mode. 0 = Auto-reload mode. 1 = Compare mode. 5 T2DIV[2:0] R/W 4 3 CAPCR R/W 2 CMPCR R/W 1 0 LDTS[1:0] R/W Reset value: 0000 0000b Description Enable auto-reload 0 = Reloading RCMP2H and RCMP2L to TH2 and TL2 Disabled. 1 = Reloading RCMP2H and RCMP2L to TH2 and TL2 Enabled. 7 LDEN 6:4 T2DIV[2:0] 3 CAPCR Capture auto-clear This bit is valid only under Timer 2 auto-reload mode. It enables hardware autoclearing TH2 and TL2 counter registers after they have been transferred in to RCMP2H and RCMP2L while a capture event occurs. 0 = Timer 2 continues counting when a capture event occurs. 1 = Timer 2 value is auto-cleared as 0000H when a capture event occurs. 2 CMPCR Compare match auto-clear This bit is valid only under Timer 2 compare mode. It enables hardware autoclearing TH2 and TL2 counter registers after a compare match occurs. 0 = Timer 2 continues counting when a compare match occurs. 1 = Timer 2 value is auto-cleared as 0000H when a compare match occurs. Aug. 03, 2020 Timer 2 clock divider 000 = Timer 2 clock divider is 1/1. 001 = Timer 2 clock divider is 1/4. 010 = Timer 2 clock divider is 1/16. 011 = Timer 2 clock divider is 1/32. 100 = Timer 2 clock divider is 1/64. 101 = Timer 2 clock divider is 1/128. 110 = Timer 2 clock divider is 1/256. 111 = Timer 2 clock divider is 1/512. Page 61 of 274 Rev. 1.09 N76E003 Datasheet Bit 1:0 Name Description LDTS[1:0] Auto-reload trigger select These bits select the reload trigger event. 00 = Reload when Timer 2 overflows. 01 = Reload when input capture 0 event occurs. 10 = Reload when input capture 1 event occurs. 11 = Reload when input capture 2 event occurs. RCMP2L – Timer 2 Reload/Compare Low Byte 7 6 5 4 3 RCMP2L[7:0] R/W Address: CAH Bit 7:0 Name 7:0 RCMP2L[7:0] Name 0 Reset value: 0000 0000b Timer 2 reload/compare low byte This register stores the low byte of compare value when Timer 2 is configured in compare mode. Also it holds the low byte of the reload value in auto-reload mode. 2 1 0 Reset value: 0000 0000b Description RCMP2H[7:0] TL2 – Timer 2 Low Byte 7 6 1 Description RCMP2H – Timer 2 Reload/Compare High Byte 7 6 5 4 3 RCMP2H[7:0] R/W Address: CBH Bit 2 Timer 2 reload/compare high byte This register stores the high byte of compare value when Timer 2 is configured in compare mode. Also it holds the high byte of the reload value in auto-reload mode. 5 4 3 2 1 0 TL2[7:0] R/W Address: CCH, Page:0 Bit 7:0 Aug. 03, 2020 Name TL2[7:0] Reset value: 0000 0000b Description Timer 2 low byte The TL2 register is the low byte of the 16-bit counting register of Timer 2. Page 62 of 274 Rev. 1.09 N76E003 Datasheet PWM4L – PWM4 Duty Low Byte 7 6 5 4 3 2 1 0 PWM4[7:0] R/W Address: CCH, Page:1 Bit 7:0 reset value: 0000 0000b Name Description PWM4 duty low byte This byte with PWM4H controls the duty of the output signal PG4 from PWM generator. PWM4[7:0] TH2 – Timer 2 High Byte 7 6 5 4 3 2 1 0 TH2[7:0] R/W Address: CDH, Page:0 Bit 7:0 Reset value: 0000 0000b Name Description TH2[7:0] Timer 2 high byte The TH2 register is the high byte of the 16-bit counting register of Timer 2. PWM5L – PWM5 Duty Low Byte 7 6 5 4 3 2 1 0 PWM5[7:0] R/W Address: CDH, Page:1 Bit 7:0 Name PWM5[7:0] reset value: 0000 0000b Description PWM5 duty low byte This byte with PWM5H controls the duty of the output signal PG5 from PWM generator. ADCMPL – ADC Compare Low Byte 7 6 5 Address: CEH Bit 3:0 Aug. 03, 2020 4 - 3 2 1 0 ADCMP[3:0] W/R Reset value: 0000 0000b Name Description ADCMP[3:0] ADC compare low byte The least significant 4 bits of the ADC compare value stores in this register. Page 63 of 274 Rev. 1.09 N76E003 Datasheet ADCMPH – ADC Compare High Byte 7 6 5 4 3 ADCMP[11:4] W/R 2 Address: CFH Bit 7:0 0 Reset value: 0000 0000b Name Description ADCMP[11:4] ADC compare high byte The most significant 8 bits of the ADC compare value stores in this register. PSW – Program Status Word (Bit-addressable) 7 6 5 4 CY AC F0 RS1 R/W R/W R/W R/W Address: D0H Bit 1 Name 3 RS0 R/W 2 OV R/W 1 0 F1 P R/W R Reset value: 0000 0000b Description 7 CY Carry flag For a adding or subtracting operation, CY will be set when the previous operation resulted in a carry-out from or a borrow-in to the Most Significant bit, otherwise cleared. If the previous operation is MUL or DIV, CY is always 0. CY is affected by DA A instruction, which indicates that if the original BCD sum is greater than 100. For a CJNE branch, CY will be set if the first unsigned integer value is less than the second one. Otherwise, CY will be cleared. 6 AC Auxiliary carry Set when the previous operation resulted in a carry-out from or a borrow-in to the th 4 bit of the low order nibble, otherwise cleared. 5 F0 User flag 0 The general purpose flag that can be set or cleared by user. 4 RS1 3 RS0 2 OV Aug. 03, 2020 Register bank selection bits These two bits select one of four banks in which R0 to R7 locate. RS1 RS0 Register Bank RAM Address 0 0 0 00H to 07H 0 1 1 08H to 0FH 1 0 2 10H to 17H 1 1 3 18H to 1FH Overflow flag OV is used for a signed character operands. For a ADD or ADDC instruction, OV will be set if there is a carry out of bit 6 but not out of bit 7, or a carry out of bit 7 but not bit 6. Otherwise, OV is cleared. OV indicates a negative number produced as the sum of two positive operands or a positive sum from two negative operands. For a SUBB, OV is set if a borrow is needed into bit6 but not into bit 7, or into bit7 but not bit 6. Otherwise, OV is cleared. OV indicates a negative number produced when a negative value is subtracted from a positive value, or a positive result when a positive number is subtracted from a negative number. For a MUL, if the product is greater than 255 (00FFH), OV will be set. Otherwise, it is cleared. For a DIV, it is normally 0. However, if B had originally contained 00H, the values returned in A and B will be undefined. Meanwhile, the OV will be set. Page 64 of 274 Rev. 1.09 N76E003 Datasheet Bit Name Description 1 F1 User flag 1 The general purpose flag that can be set or cleared by user via software. 0 P Parity flag Set to 1 to indicate an odd number of ones in the accumulator. Cleared for an even number of ones. It performs even parity check. Table 6-3. Instructions That Affect Flag Settings Instruction CY [1] ADD X OV AC Instruction CY X X CLR C 0 ADDC X X X CPL C X SUBB X X X ANL C, bit X MUL 0 X ANL C, /bit X DIV 0 X ORL C, bit X DA A X ORL C, /bit X RRC A X MOV C, bit X RLC A X CJNE X SETB C 1 OV AC [1] X indicates the modification depends on the result of the instruction. PWMPH – PWM Period High Byte 7 6 5 4 3 PWMP[15:8] R/W 2 Address: D1H Bit 7:0 1 0 reset value: 0000 0000b Name Description PWMP[15:8] PWM period high byte This byte with PWMPL controls the period of the PWM generator signal. PWM0H – PWM0 Duty High Byte 7 6 5 4 3 2 1 0 PWM0[15:8] R/W Address: D2H Bit 7:0 Aug. 03, 2020 reset value: 0000 0000b Name PWM0[15:8] Description PWM0 duty high byte This byte with PWM0L controls the duty of the output signal PG0 from PWM generator. Page 65 of 274 Rev. 1.09 N76E003 Datasheet PWM1H – PWM1 Duty High Byte 7 6 5 4 3 2 1 0 PWM1[15:8] R/W Address: D3H Bit reset value: 0000 0000b Name 7:0 Description PWM1[15:8] PWM1 duty high byte This byte with PWM1L controls the duty of the output signal PG1 from PWM generator. PWM2H – PWM2 Duty High Byte 7 6 5 4 3 2 1 0 PWM2[15:8] R/W Address: D4H Bit reset value: 0000 0000b Name 7:0 Description PWM2[15:8] PWM2 duty high byte This byte with PWM2L controls the duty of the output signal PG2 from PWM generator. PWM3H – PWM3 Duty High Byte 7 6 5 4 3 2 1 0 PWM3[15:8] R/W Address: D5H Bit reset value: 0000 0000b Name 7:0 Description PWM3[15:8] PWM3 duty high byte This byte with PWM3L controls the duty of the output signal PG3 from PWM generator. PNP – PWM Negative Polarity 7 6 5 PNP5 R/W Address: D6H Bit Name n Aug. 03, 2020 PNPn 4 PNP4 R/W 3 PNP3 R/W 2 PNP2 R/W 1 0 PNP1 PNP0 R/W R/W Reset value: 0000 0000b Description PWMn negative polarity output enable 0 = PWMn signal outputs directly on PWMn pin. 1 = PWMn signal outputs inversely on PWMn pin. Page 66 of 274 Rev. 1.09 N76E003 Datasheet FBD – PWM Fault Brake Data 7 6 5 FBF FBINLS FBD5 R/W R/W R/W Address: D7H Bit Name 7 FBF 6 FBINLS N FBDn 4 FBD4 R/W 2 FBD2 R/W 1 0 FBD1 FBD0 R/W R/W Reset value: 0000 0000b Description Fault Brake flag This flag is set when FBINEN is set as 1 and FB pin detects an edge, which matches FBINLS (FBD.6) selection. This bit is cleared by software. After FBF is cleared, Fault Brake data output will not be released until PWMRUN (PWMCON0.7) is set. FB pin input level selection 0 = Falling edge. 1 = Rising edge. PWMn Fault Brake data 0 = PWMn signal is overwritten by 0 once Fault Brake asserted. 1 = PWMn signal is overwritten by 1 once Fault Brake asserted. PWMCON0 – PWM Control 0 (Bit-addressable) 7 6 5 4 PWMRUN LOAD PWMF CLRPWM R/W R/W R/W R/W Address: D8H Bit 3 FBD3 R/W Name 7 PWMRUN 6 LOAD 3 - 2 - 1 0 Reset value: 0000 0000b Description PWM run enable 0 = PWM stays in idle. 1 = PWM starts running. PWM new period and duty load This bit is used to load period and duty control registers in their buffer if new period or duty value needs to be updated. The loading will act while a PWM period is completed. The new period and duty affected on the next PWM cycle. After the loading is complete, LOAD will be automatically cleared via hardware. The meaning of writing and reading LOAD bit is different. Writing: 0 = No effect. 1 = Load new period and duty in their buffers while a PWM period is completed. Reading: 0 = A loading of new period and duty is finished. 1 = A loading of new period and duty is not yet finished. 5 Aug. 03, 2020 PWMF PWM flag This flag is set according to definitions of INTSEL[2:0] and INTTYP[1:0] in PWMINTC. This bit is cleared by software. Page 67 of 274 Rev. 1.09 N76E003 Datasheet Bit Name 4 CLRPWM Description Clear PWM counter Setting this bit clears the value of PWM 16-bit counter for resetting to 0000H. After the counter value is cleared, CLRPWM will be automatically cleared via hardware. The meaning of writing and reading CLRPWM bit is different. Writing: 0 = No effect. 1 = Clearing PWM 16-bit counter. Reading: 0 = PWM 16-bit counter is completely cleared. 1 = PWM 16-bit counter is not yet cleared. PWMPL – PWM Period Low Byte 7 6 5 4 3 2 1 0 PWMP[7:0] R/W Address: D9H Bit 7:0 reset value: 0000 0000b Name PWMP[7:0] Description PWM period low byte This byte with PWMPH controls the period of the PWM generator signal. PWM0L – PWM0 Duty Low Byte 7 6 5 4 3 2 1 0 PWM0[7:0] R/W Address: DAH Bit 7:0 reset value: 0000 0000b Name PWM0[7:0] Description PWM0 duty low byte This byte with PWM0H controls the duty of the output signal PG0 from PWM generator. PWM1L – PWM/1 Duty Low Byte 7 6 5 4 3 2 1 0 PWM1[7:0] R/W Address: DBH Bit 7:0 Aug. 03, 2020 reset value: 0000 0000b Name PWM1[7:0] Description PWM1 duty low byte This byte with PWM1H controls the duty of the output signal PG1 from PWM generator. Page 68 of 274 Rev. 1.09 N76E003 Datasheet PWM2L – PWM2 Duty Low Byte 7 6 5 4 3 2 1 0 PWM2[7:0] R/W Address: DCH Bit reset value: 0000 0000b Name 7:0 PWM2[7:0] Description PWM2 duty low byte This byte with PWM2H controls the duty of the output signal PG2 from PWM generator. PWM3L – PWM3 Duty Low Byte 7 6 5 4 3 2 1 0 PWM3[7:0] R/W Address: DDH Bit reset value: 0000 0000b Name 7:0 PWM3[7:0] Description PWM3 duty low byte This byte with PWM3H controls the duty of the output signal PG3 from PWM generator. PIOCON0 – PWM or I/O Select 7 6 5 PIO05 R/W Address: DEH Bit Name 4 PIO04 R/W 3 PIO03 R/W 1 0 PIO01 PIO00 R/W R/W Reset value: 0000 0000b Description 5 PIO05 P0.3/PWM5 pin function select 0 = P0.3/PWM5 pin functions as P0.3. 1 = P0.3/PWM5 pin functions as PWM5 output. 4 PIO04 P0.1/PWM4 pin function select 0 = P0.1/PWM4 pin functions as P0.1. 1 = P0.1/PWM4 pin functions as PWM4 output. 3 PIO03 P0.0/PWM3 pin function select 0 = P0.0/PWM3 pin functions as P0.0. 1 = P0.0/PWM3 pin functions as PWM3 output. 2 PIO02 P1.0/PWM2 pin function select 0 = P1.0/PWM2 pin functions as P1.0. 1 = P1.0/PWM2 pin functions as PWM2 output. 1 PIO01 P1.1/PWM1 pin function select 0 = P1.1/PWM1 pin functions as P1.1. 1 = P1.1/PWM1 pin functions as PWM1 output. 0 PIO00 P1.2/PWM0 pin function select 0 = P1.2/PWM0 pin functions as P1.2. 1 = P1.2/PWM0 pin functions as PWM0 output. Aug. 03, 2020 2 PIO02 R/W Page 69 of 274 Rev. 1.09 N76E003 Datasheet PWMCON1 – PWM Control 1 7 6 5 PWMMOD[1:0] GP R/W R/W Address: DFH Bit Name 4 PWMTYP R/W 2:0 PWMDIV[2:0] PWM clock divider This field decides the pre-scale of PWM clock source. 000 = 1/1. 001 = 1/2 010 = 1/4. 011 = 1/8. 100 = 1/16. 101 = 1/32. 110 = 1/64. 111 = 1/128. A or ACC – Accumulator (Bit-addressable) 7 6 5 4 ACC.7 ACC.6 ACC.5 ACC.4 R/W R/W R/W R/W Address: E0H Aug. 03, 2020 2 ACC.2 R/W 1 0 ACC.1 ACC.0 R/W R/W Reset value: 0000 0000b Description ACC[7:0] Accumulator The A or ACC register is the standard 80C51 accumulator for arithmetic operation. Name 6 3 ACC.3 R/W Name ADCCON1 – ADC Control 1 7 6 STADCPX R/W Address: E1H Bit 1 0 PWMDIV[2:0] R/W Reset value: 0000 0000b Group mode enable This bit enables the group mode. If enabled, the duty of first three pairs of PWM are decided by PWM01H and PWM01L rather than their original duty control registers. 0 = Group mode Disabled. 1 = Group mode Enabled. GP 7:0 2 Description 5 Bit 3 FBINEN R/W STADCPX 5 - 4 - 3 2 ETGTYP[1:0] R/W 1 0 ADCEX ADCEN R/W R/W Reset value: 0000 0000b Description External start ADC trigger pin select 0 = Assign STADC to P0.4. 1 = Assign STADC to P1.3. Note that STADC will exchange immediately once setting or clearing this bit. Page 70 of 274 Rev. 1.09 N76E003 Datasheet Bit Name Description 3:2 ETGTYP[1:0] External trigger type select When ADCEX (ADCCON1.1) is set, these bits select which condition triggers ADC conversion. 00 = Falling edge on PWM0/2/4 or STADC pin. 01 = Rising edge on PWM0/2/4 or STADC pin. 10 = Central point of a PWM period. 11 = End point of a PWM period. Note that the central point interrupt or the period point interrupt is only available for PWM center-aligned type. 1 ADCEX ADC external conversion trigger select This bit select the methods of triggering an A/D conversion. 0 = A/D conversion is started only via setting ADCS bit. 1 = A/D conversion is started via setting ADCS bit or by external trigger source depending on ETGSEL[1:0] and ETGTYP[1:0]. Note that while ADCS is 1 (busy in converting), the ADC will ignore the following external trigger until ADCS is hardware cleared. 0 ADCEN ADC enable 0 = ADC circuit off. 1 = ADC circuit on. ADCCON2 – ADC Control 2 7 6 5 ADFBEN ADCMPOP ADCMPEN R/W R/W R/W Address: E2H Bit Name 4 ADCMPO R 3 - 2 - 1 0 ADCDLY.8 R/W Reset value: 0000 0000b Description ADC compare result asserting Fault Brake enable 0 = ADC asserting Fault Brake Disabled. 1 = ADC asserting Fault Brake Enabled. Fault Brake is asserted once its compare result ADCMPO is 1. Meanwhile, PWM channels output Fault Brake data. PWMRUN (PWMCON0.7) will also be automatically cleared by hardware. The PWM output resumes when PWMRUN is set again. 7 ADFBEN 6 ADCMPOP ADC comparator output polarity 0 = ADCMPO is 1 if ADCR[11:0] is greater than or equal to ADCMP[11:0]. 1 = ADCMPO is 1 if ADCR[11:0] is less than ADCMP[11:0]. 5 ADCMPEN ADC result comparator enable 0 = ADC result comparator Disabled. 1 = ADC result comparator Enabled. 4 ADCMPO ADC comparator output value This bit is the output value of ADC result comparator based on the setting of ACMPOP. This bit updates after every A/D conversion complete. 0 ADCDLY.8 ADC external trigger delay counter bit 8 See ADCDLY register. Aug. 03, 2020 Page 71 of 274 Rev. 1.09 N76E003 Datasheet ADCDLY – ADC Trigger Delay Counter 7 6 5 4 3 ADCDLY[7:0] R/W 2 Address: E3H Bit 7:0 1 0 Reset value: 0000 0000b Name Description ADCDLY[7:0] ADC external trigger delay counter low byte This 8-bit field combined with ADCCON2.0 forms a 9-bit counter. This counter inserts a delay after detecting the external trigger. An A/D converting starts after this period of delay. ADCDLY External trigger delay time = . FADC Note that this field is valid only when ADCEX (ADCCON1.1) is set. User should not modify ADCDLY during PWM run time if selecting PWM output as the external ADC trigger source. C0L – Capture 0 Low Byte 7 6 5 4 3 2 1 0 C0L[7:0] R/W Address: E4H Bit 7:0 Reset value: 0000 0000b Name C0L[7:0] Description Input capture 0 result low byte The C0L register is the low byte of the 16-bit result captured by input capture 0. C0H – Capture 0 High Byte 7 6 5 4 3 2 1 0 C0H[7:0] R/W Address: E5H Bit 7:0 Reset value: 0000 0000b Name Description C0H[7:0] Input capture 0 result high byte The C0H register is the high byte of the 16-bit result captured by input capture 0. C1L – Capture 1 Low Byte 7 6 5 4 3 2 1 0 C1L[7:0] R/W Address: E6H Bit 7:0 Aug. 03, 2020 Reset value: 0000 0000b Name C1L[7:0] Description Input capture 1 result low byte The C1L register is the low byte of the 16-bit result captured by input capture 1. Page 72 of 274 Rev. 1.09 N76E003 Datasheet C1H – Capture 1 High Byte 7 6 5 4 3 2 1 0 C1H[7:0] R/W Address: E7H Bit 7:0 Reset value: 0000 0000b Name Description C1H[7:0] Input capture 1 result high byte The C1H register is the high byte of the 16-bit result captured by input capture 1. ADCCON0 – ADC Control 0 (Bit-addressable) 7 6 5 4 ADCF ADCS ETGSEL1 ETGSEL0 R/W R/W R/W R/W Address: E8H Bit Name 3 ADCHS3 R/W 2 ADCHS2 R/W 1 0 ADCHS1 ADCHS0 R/W R/W Reset value: 0000 0000b Description 7 ADCF ADC flag This flag is set when an A/D conversion is completed. The ADC result can be read. While this flag is 1, ADC cannot start a new converting. This bit is cleared by software. 6 ADCS A/D converting software start trigger Setting this bit 1 triggers an A/D conversion. This bit remains logic 1 during A/D converting time and is automatically cleared via hardware right after conversion complete. The meaning of writing and reading ADCS bit is different. Writing: 0 = No effect. 1 = Start an A/D converting. Reading: 0 = ADC is in idle state. 1 = ADC is busy in converting. 5:4 Aug. 03, 2020 ETGSEL[1:0] External trigger source select When ADCEX (ADCCON1.1) is set, these bits select which pin output triggers ADC conversion. 00 = PWM0. 01 = PWM2. 10 = PWM4. 11 = STADC pin. Page 73 of 274 Rev. 1.09 N76E003 Datasheet Bit Name 3:0 Description ADCHS[3:0] A/D converting channel select This filed selects the activating analog input source of ADC. If ADCEN is 0, all inputs are disconnected. 0000 = AIN0. 0001 = AIN1. 0010 = AIN2. 0011 = AIN3. 0100 = AIN4. 0101 = AIN5. 0110 = AIN6. 0111 = AIN7 1000 = Internal band-gap voltage. Others = Reserved. PICON – Pin Interrupt Control 7 6 5 PIT67 PIT45 PIT3 R/W R/W R/W Address: E9H Bit Name 4 PIT2 R/W 3 PIT1 R/W 2 PIT0 R/W 1 0 PIPS[1:0] R/W Reset value: 0000 0000b Description 7 PIT67 Pin interrupt channel 6 and 7 type select This bit selects which type that pin interrupt channel 6 and 7 is triggered. 0 = Level triggered. 1 = Edge triggered. 6 PIT45 Pin interrupt channel 4 and 5 type select This bit selects which type that pin interrupt channel 4 and 5 is triggered. 0 = Level triggered. 1 = Edge triggered. 5 PIT3 Pin interrupt channel 3 type select This bit selects which type that pin interrupt channel 3 is triggered. 0 = Level triggered. 1 = Edge triggered. 4 PIT2 Pin interrupt channel 2 type select This bit selects which type that pin interrupt channel 2 is triggered. 0 = Level triggered. 1 = Edge triggered. 3 PIT1 Pin interrupt channel 1 type select This bit selects which type that pin interrupt channel 1 is triggered. 0 = Level triggered. 1 = Edge triggered. 2 PIT0 Pin interrupt channel 0 type select This bit selects which type that pin interrupt channel 0 is triggered. 0 = Level triggered. 1 = Edge triggered. 1:0 PIPS[:0] Aug. 03, 2020 Pin interrupt port select This field selects which port is active as the 8-channel of pin interrupt. 00 = Port 0. 01 = Port 1. 10 = Port 2. 11 = Port 3. Page 74 of 274 Rev. 1.09 N76E003 Datasheet PINEN – Pin Interrupt Negative Polarity Enable. 7 6 5 4 PINEN7 PINEN6 PINEN5 PINEN4 R/W R/W R/W R/W Address: EAH Bit Name n PINENn Name n PIPENn PIF – Pin Interrupt Flags 7 6 PIF7 PIF6 R (level) R (level) R/W (edge) R/W (edge) Address: ECH Bit Name n Aug. 03, 2020 PIFn 2 PINEN2 R/W 1 0 PINEN1 PINEN0 R/W R/W Reset value: 0000 0000b Description Pin interrupt channel n negative polarity enable This bit enables low-level/falling edge triggering pin interrupt channel n. The level or edge triggered selection depends on each control bit PITn in PICON. 0 = Low-level/falling edge detect Disabled. 1 = Low-level/falling edge detect Enabled. PIPEN – Pin Interrupt Positive Polarity Enable. 7 6 5 4 PIPEN7 PIPEN6 PIPEN5 PIPEN4 R/W R/W R/W R/W Address: EBH Bit 3 PINEN3 R/W 3 PIPEN3 R/W 2 PIPEN2 R/W 1 0 PIPEN1 PIPEN0 R/W R/W Reset value: 0000 0000b Description Pin interrupt channel n positive polarity enable This bit enables high-level/rising edge triggering pin interrupt channel n. The level or edge triggered selection depends on each control bit PITn in PICON. 0 = High-level/rising edge detect Disabled. 1 = High-level/rising edge detect Enabled. 5 PIF5 R (level) R/W (edge) 4 PIF4 R (level) R/W (edge) 3 PIF3 R (level) R/W (edge) 2 PIF2 R (level) R/W (edge) 1 0 PIF1 PIF0 R (level) R (level) R/W (edge) R/W (edge) Reset value: 0000 0000b Description Pin interrupt channel n flag If the edge trigger is selected, this flag will be set by hardware if the channel n of pin interrupt detects an enabled edge trigger. This flag should be cleared by software. f the level trigger is selected, this flag follows the inverse of the input signal’s logic level on the channel n of pin interrupt. Software cannot control it. Page 75 of 274 Rev. 1.09 N76E003 Datasheet C2L – Capture 2 Low Byte 7 6 5 4 3 2 1 0 C2L[7:0] R/W Address: EDH Bit Reset value: 0000 0000b Name 7:0 C2L[7:0] Description Input capture 2 result low byte The C2L register is the low byte of the 16-bit result captured by input capture 2. C2H – Capture 2 High Byte 7 6 5 4 3 2 1 0 C2H[7:0] R/W Address: EEH Bit 7:0 Reset value: 0000 0000b Name Description C2H[7:0] Input capture 2 result high byte The C2H register is the high byte of the 16-bit result captured by input capture 2. EIP – Extensive Interrupt Priority[3] 7 6 5 PT2 PSPI PFB R/W R/W R/W Address: EFH Bit Name 4 PWDT R/W 3 PPWM R/W 2 PCAP R/W 1 0 PPI PI2C R/W R/W Reset value: 0000 0000b Description 7 PT2 Timer 2 interrupt priority low bit 6 PSPI SPI interrupt priority low bit 5 PFB Fault Brake interrupt priority low bit 4 PWDT WDT interrupt priority low bit 3 PPWM PWM interrupt priority low bit 2 PCAP Input capture interrupt priority low bit 1 PPI 0 PI2C Pin interrupt priority low bit 2 I C interrupt priority low bit [3] EIP is used in combination with the EIPH to determine the priority of each interrupt source. See Table 20-2. Interrupt Priority Level Setting for correct interrupt priority configuration. Aug. 03, 2020 Page 76 of 274 Rev. 1.09 N76E003 Datasheet B – B Register (Bit-addressable) 7 6 5 B.7 B.6 B.5 R/W R/W R/W Address: F0H Bit 7:0 Name B[7:0] 3 B.3 R/W 1 0 B.1 B.0 R/W R/W Reset value: 0000 0000b B register The B register is the other accumulator of the standard 80C51 .It is used mainly for MUL and DIV instructions. 4 CAP10 R/W 3 CAP03 R/W Name Description [7:4] CAP1[3:0] Input capture channel 1 input pin select 0000 = P1.2/IC0 0001 = P1.1/IC1 0010 = P1.0/IC2 0011 = P0.0/IC3 0100 = P0.4/IC3 0101 = P0.1/IC4 0110 = P0.3/IC5 0111 = P0.5/IC6 1000 = P1.5/IC7 others = P1.2/IC0 [3:0] CAP0[3:0] Input capture channel 0 input pin select 0000 = P1.2/IC0 0001 = P1.1/IC1 0010 = P1.0/IC2 0011 = P0.0/IC3 0100 = P0.4/IC3 0101 = P0.1/IC4 0110 = P0.3/IC5 0111 = P0.5/IC6 1000 = P1.5/IC7 others = P1.2/IC0 Aug. 03, 2020 2 B.2 R/W Description CAPCON3 – Input Capture Control 3 7 6 5 CAP13 CAP12 CAP11 R/W R/W R/W Address: F1H Bit 4 B.4 R/W Page 77 of 274 2 CAP02 R/W 1 0 CAP01 CAP00 R/W R/W Reset value: 0000 0000b Rev. 1.09 N76E003 Datasheet CAPCON4 – Input Capture Control 4 7 6 5 Address: F2H Bit [3:0] 4 - Name Description CAP2[3:0] Input capture channel 0 input pin select 0000 = P1.2/IC0 0001 = P1.1/IC1 0010 = P1.0/IC2 0011 = P0.0/IC3 0100 = P0.4/IC3 0101 = P0.1/IC4 0110 = P0.3/IC5 0111 = P0.5/IC6 1000 = P1.5/IC7 others = P1.2/IC0 SPCR – Serial Peripheral Control Register 7 6 5 4 SSOE SPIEN LSBFE MSTR R/W R/W R/W R/W Address: F3H, page 0 Bit 3 CAP23 R/W Name 3 CPOL R/W 2 CAP22 R/W 1 0 CAP21 CAP20 R/W R/W Reset value: 0000 0000b 2 CPHA R/W 1 0 SPR1 SPR0 R/W R/W Reset value: 0000 0000b Description 7 SSOE Slave select output enable This bit is used in combination with the DISMODF (SPSR.3) bit to determine the feature of ̅̅̅̅ pin as shown in Table 14-1. Slave Select Pin Configurations. This bit takes effect only under MSTR = 1 and DISMODF = 1 condition. 0 = ̅̅̅̅ functions as a general purpose I/O pin. 1 = ̅̅̅̅ automatically goes low for each transmission when selecting external Slave device and goes high during each idle state to de-select the Slave device. 6 SPIEN SPI enable 0 = SPI function Disabled. 1 = SPI function Enabled. 5 LSBFE LSB first enable 0 = The SPI data is transferred MSB first. 1 = The SPI data is transferred LSB first. 4 MSTR Master mode enable This bit switches the SPI operating between Master and Slave modes. 0 = The SPI is configured as Slave mode. 1 = The SPI is configured as Master mode. 3 CPOL SPI clock polarity select CPOL bit determines the idle state level of the SPI clock. See Figure 14.3-1. SPI Clock Formats. 0 = The SPI clock is low in idle state. 1 = The SPI clock is high in idle state. Aug. 03, 2020 Page 78 of 274 Rev. 1.09 N76E003 Datasheet Bit Name 2 CPHA Description SPI clock phase select CPHA bit determines the data sampling edge of the SPI clock. See Figure 14.3-1. SPI Clock Formats. 0 = The data is sampled on the first edge of the SPI clock. 1 = The data is sampled on the second edge of the SPI clock. SPCR2 – Serial Peripheral Control Register 2 7 6 5 4 Address: F3H, page 1 Bit Name 7:2 - 1:0 SPIS[1:0] 3 - 2 - 1 0 SPIS1 SPIS0 R/W R/W Reset value: 0000 0000b Description Reserved SPI Interval time selection between adjacent bytes SPIS[1:0] and CPHA select eight grades of SPI interval time selection between adjacent bytes. As below table: CPHA 0 0 0 0 1 1 1 1 SPIS1 0 0 1 1 0 0 1 1 SPIS0 0 1 0 1 0 1 0 1 SPI clock 0.5 1.0 1.5 2.0 1.0 1.5 2.0 2.5 SPIS[1:0] are valid only under Master mode (MSTR = 1). SPSR – Serial Peripheral Status Register 7 6 5 4 SPIF WCOL SPIOVF MODF R/W R/W R/W R/W Address: F4H Bit Name 3 DISMODF R/W 2 TXBUF R 1 0 Reset value: 0000 0000b Description 7 SPIF SPI complete flag This bit is set to logic 1 via hardware while an SPI data transfer is complete or an receiving data has been moved into the SPI read buffer. If ESPI (EIE .0) and EA are enabled, an SPI interrupt will be required. This bit should be cleared via software. Attempting to write to SPDR is inhibited if SPIF is set. 6 WCOL Write collision error flag This bit indicates a write collision event. Once a write collision event occurs, this bit will be set. It should be cleared via software. 5 SPIOVF SPI overrun error flag This bit indicates an overrun event. Once an overrun event occurs, this bit will be set. If ESPI and EA are enabled, an SPI interrupt will be required. This bit should be cleared via software. Aug. 03, 2020 Page 79 of 274 Rev. 1.09 N76E003 Datasheet Bit Name 4 MODF 3 DISMODF 2 TXBUF Description Mode Fault error flag This bit indicates a Mode Fault error event. If ̅̅̅̅ pin is configured as Mode Fault input (MSTR = 1 and DISMODF = 0) and ̅̅̅̅ is pulled low by external devices, a Mode Fault error occurs. Instantly MODF will be set as logic 1. If ESPI and EA are enabled, an SPI interrupt will be required. This bit should be cleared via software. Disable Mode Fault error detection This bit is used in combination with the SSOE (SPCR.7) bit to determine the feature of ̅̅̅̅ pin as shown in Table 14-1. Slave Select Pin Configurations. DISMODF is valid only in Master mode (MSTR = 1). 0 = Mode Fault detection Enabled. ̅̅̅̅ serves as input pin for Mode Fault detection disregard of SSOE. 1 = Mode Fault detection Disabled. The feature of ̅̅̅̅ follows SSOE bit. SPI writer data buffer status This bit indicates the SPI transmit buffer status. 0 = SPI writer data buffer is empty 1 = SPI writer data buffer is full. SPDR – Serial Peripheral Data Register 7 6 5 4 3 2 1 0 SPDR[7:0] R/W Address: F5H Bit 7:0 Reset value: 0000 0000b Name Description SPDR[7:0] Serial peripheral data This byte is used for transmitting or receiving data on SPI bus. A write of this byte is a write to the shift register. A read of this byte is actually a read of the read data buffer. In Master mode, a write to this register initiates transmission and reception of a byte simultaneously. AINDIDS – ADC Channel Digital Input Disconnect 7 6 5 4 P11DIDS P03DIDS P04DIDS P05DIDS R/W R/W R/W R/W Address: F6H Bit Name n Aug. 03, 2020 PnnDIDS 3 P06DIDS R/W 2 P07DIDS R/W 1 0 P30DIDS P17DIDS R/W R/W Reset value: 0000 0000b Description ADC Channel digital input disable 0 = ADC channel n digital input Enabled. 1 = ADC channel n digital input Disabled. ADC channel n is read always 0. Page 80 of 274 Rev. 1.09 N76E003 Datasheet EIPH – Extensive Interrupt Priority High[4] 7 6 5 4 PT2H PSPIH PFBH PWDTH R/W R/W R/W R/W Address: F7H Bit Name 3 PPWMH R/W 2 PCAPH R/W 1 0 PPIH PI2CH R/W R/W Reset value: 0000 0000b Description 7 PT2H Timer 2 interrupt priority high bit 6 PSPIH SPI interrupt priority high bit 5 PFBH Fault Brake interrupt priority high bit 4 PWDTH WDT interrupt priority high bit 3 PPWMH PWM interrupt priority high bit 2 PCAPH Input capture interrupt priority high bit 1 PPIH 0 PI2CH Pin interrupt priority high bit 2 I C interrupt priority high bit [4] EIPH is used in combination with the EIP to determine the priority of each interrupt source. See Table 20-2. Interrupt Priority Level Setting for correct interrupt priority configuration. Aug. 03, 2020 Page 81 of 274 Rev. 1.09 N76E003 Datasheet SCON_1 – Serial Port 1 Control (bit-addressable) 7 6 5 4 SM0_1/FE_1 SM1_1 SM2_1 REN_1 R/W R/W R/W R/W Address: F8H Bit Name 7 SM0_1/FE_1 6 SM1_1 3 TB8_1 R/W 2 RB8_1 R/W 1 0 TI_1 RI_1 R/W R/W Reset value: 0000 0000b Description Serial port 1 mode select SMOD0_1 (T3CON.6) = 0: See Table 13-2. Serial Port 1 Mode Description for details. SMOD0_1 (T3CON.6) = 1: SM0_1/FE_1 bit is used as frame error (FE) status flag. It is cleared by software. 0 = Frame error (FE) did not occur. 1 = Frame error (FE) occurred and detected. 5 SM2_1 Multiprocessor communication mode enable The function of this bit is dependent on the serial port 1 mode. Mode 0: No effect. Mode 1: This bit checks valid stop bit. 0 = Reception is always valid no matter the logic level of stop bit. 1 = Reception is valid only when the received stop bit is logic 1 and the received data matches “Given” or “Broadcast” address. Mode 2 or 3: For multiprocessor communication. th 0 = Reception is always valid no matter the logic level of the 9 bit. th 1 = Reception is valid only when the received 9 bit is logic 1 and the received data matches “Given” or “Broadcast” address. 4 REN_1 Receiving enable 0 = Serial port 1 reception Disabled. 1 = Serial port 1 reception Enabled in Mode 1,2, or 3. In Mode 0, reception is initiated by the condition REN_1 = 1 and RI_1 = 0. 3 TB8_1 9 transmitted bit th This bit defines the state of the 9 transmission bit in serial port 1 Mode 2 or 3. It is not used in Mode 0 or 1. 2 RB8_1 9 received bit th The bit identifies the logic level of the 9 received bit in serial port 1 Mode 2 or 3. In Mode 1, RB8_1 is the logic level of the received stop bit. SM2 _1 bit as logic 1 has restriction for exception. RB8_1 is not used in Mode 0. 1 TI_1 Transmission interrupt flag This flag is set by hardware when a data frame has been transmitted by the th serial port 1 after the 8 bit in Mode 0 or the last data bit in other modes. When the serial port 1 interrupt is enabled, setting this bit causes the CPU to execute the serial port 1 interrupt service routine. This bit must be cleared manually via software. Aug. 03, 2020 th th Page 82 of 274 Rev. 1.09 N76E003 Datasheet Bit Name Description 0 RI_1 Receiving interrupt flag This flag is set via hardware when a data frame has been received by the serial th port 1 after the 8 bit in Mode 0 or after sampling the stop bit in Mode 1, 2, or _ 3. SM2 1 bit as logic 1 has restriction for exception. When the serial port 1 interrupt is enabled, setting this bit causes the CPU to execute to the serial port 1 interrupt service routine. This bit must be cleared manually via software. PDTEN – PWM Dead-time Enable (TA protected) 7 6 5 4 PDTCNT.8 R/W Address: F9H Bit 3 - 2 PDT45EN R/W 1 0 PDT23EN PDT01EN R/W R/W Reset value: 0000 0000b Name Description 4 PDTCNT.8 PWM dead-time counter bit 8 See PDTCNT register. 2 PDT45EN PWM4/5 pair dead-time insertion enable This bit is valid only when PWM4/5 is under complementary mode. 0 = No delay on GP4/GP5 pair signals. 1 = Insert dead-time delay on the rising edge of GP4/GP5 pair signals. 1 PDT23EN PWM2/3 pair dead-time insertion enable This bit is valid only when PWM2/3 is under complementary mode. 0 = No delay on GP2/GP3 pair signals. 1 = Insert dead-time delay on the rising edge of GP2/GP3 pair signals. 0 PDT01EN PWM0/1 pair dead-time insertion enable This bit is valid only when PWM0/1 is under complementary mode. 0 = No delay on GP0/GP1 pair signals. 1 = Insert dead-time delay on the rising edge of GP0/GP1 pair signals. PDTCNT – PWM Dead-time Counter (TA protected) 7 6 5 4 3 PDTCNT[7:0] R/W Address: FAH Bit 7:0 2 1 0 Reset value: 0000 0000b Name Description PDTCNT[7:0] PWM dead-time counter low byte This 8-bit field combined with PDTEN.4 forms a 9-bit PWM dead-time counter PDTCNT. This counter is valid only when PWM is under complementary mode and the correspond PDTEN bit for PWM pair is set. PWM dead-time = PDTCNT  1 . FSYS Note that user should not modify PDTCNT during PWM run time. Aug. 03, 2020 Page 83 of 274 Rev. 1.09 N76E003 Datasheet PMEN – PWM Mask Enable 7 6 5 PMEN5 R/W Address: FBH Bit Name n PMENn Name n PMDn 3 PMEN3 R/W 2 PMEN2 R/W PWMn mask enable 0 = PWMn signal outputs from its PWM generator. 1 = PWMn signal is masked by PMDn. 5 PMD5 R/W 4 PMD4 R/W 3 PMD3 R/W 2 PMD2 R/W PWMn mask data The PWMn signal outputs mask data once its corresponding PMENn is set. 0 = PWMn signal is masked by 0. 1 = PWMn signal is masked by 1. 4 3 PORDIS[7:0] W 2 Address: FDH, Page: 0 1 0 Reset value: 0000 0000b Name 7:0 1 0 PMD1 PMD0 R/W R/W Reset value: 0000 0000b Description PORDIS – POR disable (TA protected) 7 6 5 Bit 1 0 PMEN1 PMEN0 R/W R/W Reset value: 0000 0000b Description PMD – PWM Mask Data 7 6 Address: FCH Bit 4 PMEN4 R/W Description PORDIS[7:0] POR disable To first writing 5AH to the PORDIS and immediately followed by a writing of A5H will disable POR. Notice: Strongly suggests that disable POR function after power-on reset at the initial part of Customer code. Please reference 24.1 Power-On Reset (POR) for more detail information. EIP1 – Extensive Interrupt Priority 1[5] 7 6 5 Address: FEH, Page: 0 Bit Name 2 PWKT 1 PT3 Aug. 03, 2020 4 - 3 - 2 PWKT R/W 1 0 PT3 PS_1 R/W R/W Reset value: 0000 0000b Description WKT interrupt priority low bit Timer 3 interrupt priority low bit Page 84 of 274 Rev. 1.09 N76E003 Datasheet Bit Name Description Serial port 1 interrupt priority low bit PS_1 [5] EIP1 is used in combination with the EIPH1 to determine the priority of each interrupt source. See Table 20-2. Interrupt Priority Level Setting for correct interrupt priority configuration. 0 EIPH1 – Extensive Interrupt Priority High 1[6] 7 6 5 4 Address: FFH, Page: 0 Bit Name 2 PWKTH 1 PT3H 3 - 2 PWKTH R/W 1 0 PT3H PSH_1 R/W R/W Reset value: 0000 0000b Description WKT interrupt priority high bit Timer 3 interrupt priority high bit Serial port 1 interrupt priority high bit PSH_1 [6] EIPH1 is used in combination with the EIP1 to determine the priority of each interrupt source. See Table 20-2. Interrupt Priority Level Setting for correct interrupt priority configuration. 0 Aug. 03, 2020 Page 85 of 274 Rev. 1.09 N76E003 Datasheet 7. I/O PORT STRUCTURE AND OPERATION The N76E003 has a maximum of 26 bit-addressable general I/O pins grouped as 4 ports, P0 to P3. Each port has its port control register (Px register). The writing and reading of a port control register have different meanings. A write to port control register sets the port output latch logic value, whereas a read gets the port pin logic state. All I/O pins except P2.0 can be configured individually as one of four I/O modes by software. These four modes are quasi-bidirectional (standard 8051 port structure), push-pull, input-only, and open-drain modes. Each port spends two special function registers PxM1 and PxM2 to select the I/O mode of port Px. The list below illustrates how to select the I/O mode of Px.n. Note that the default configuration of is input-only (highimpedance) after any reset except the OCDDA and OCDCK pin, this two pins keep quasi mode with pull high resister about 600 LIRC clock before change to input mode after reset Table 7-1. Configuration for Different I/O Modes PxM1.n PxM2.n I/O Type 0 0 Quasi-bidirectional 0 1 Push-pull 1 0 Input-only (high-impedance) 1 1 Open-drain All I/O pins can be selected as TTL level inputs or Schmitt triggered inputs by selecting corresponding bit in PxS register. Schmitt triggered input has better glitch suppression capability. All I/O pins also have bitcontrollable, slew rate select ability via software. The control registers are PxSR. By default, the slew rate is slow. If user would like to increase the I/O output speed, setting the corresponding bit in PxSR, the slew rate is selected in a faster level. P2.0 is configured as an input-only pin when programming RPD (CONFIG0.2) as 0. Meanwhile, P2.0 is permanent in input-only mode and Schmitt triggered type. P2.0 also has an internal pull-up enabled by P20UP (P2S.7). If RPD remains un-programmed, P2.0 pin functions as an external reset pin and P2.0 is not available. A read of P2.0 bit is always 0. Meanwhile, the internal pull-up is always enabled. 7.1 Quasi-Bidirectional Mode The quasi-bidirectional mode, as the standard 8051 I/O structure, can rule as both input and output. When the port outputs a logic high, it is weakly driven, allowing an external device to pull the pin low. When the pin is pulled low, it is driven strongly and able to sink a large current. In the quasi-bidirectional I/O structure, there are three pull-high transistors. Each of them serves different purposes. One of these pull-highs, called the “very weak” pull-high, is turned on whenever the port latch contains logic . he “very weak” pull-high sources a very small current that will pull the pin high if it is left floating. Aug. 03, 2020 Page 86 of 274 Rev. 1.09 N76E003 Datasheet A second pull-high, called the “weak” pull-high, is turned on when the outside port pin itself is at logic 1 level. This pull-high provides the primary source current for a quasi-bidirectional pin that is outputting 1. If a pin which has logic on it is pulled low by an external device, the “weak” pull-high turns off, and only the “very weak” pull-high remains on. To pull the pin low under these conditions, the external device has to sink enough current (larger than ITL) to overcome the “weak” pull-high and make the voltage on the port pin below its input threshold (lower than VIL). The third pull-high is the “strong” pull-high. This pull-high is used to speed up 0-to-1 transitions on a quasibidirectional port pin when the port latch changes from logic 0 to logic 1. When this occurs, the strong pull-high turns on for two-CPU-clock time to pull the port pin high quickly. hen it turns off and “weak” and “very weak” pull-highs continue remaining the port pin high. The quasi-bidirectional port structure is shown below. VDD 2-CPU-clock delay P Strong P Very Weak P Weak Port Pin Port Latch N Input Figure 7.1-1. Quasi-Bidirectional Mode Structure 7.2 Push-Pull Mode The push-pull mode has the same pull-low structure as the quasi-bidirectional mode, but provides a continuous strong pull-high when the port latch is written by logic 1. The push-pull mode is generally used as output pin when more source current is needed for an output driving. Aug. 03, 2020 Page 87 of 274 Rev. 1.09 N76E003 Datasheet VDD P Strong Port Pin Port Latch N Input Figure 7.2-1. Push-Pull Mode Structure 7.3 Input-Only Mode Input-only mode provides true high-impedance input path. Although a quasi-bidirectional mode I/O can also be an input pin, but it requires relative strong input source. Input-only mode also benefits to power consumption reduction for logic 0 input always consumes current from VDD if in quasi-bidirectional mode. User needs to take care that an input-only mode pin should be given with a determined voltage level by external devices or resistors. A floating pin will induce leakage current especially in Power-down mode. Input Port Pin Figure 7.3-1. Input-Only Mode Structure 7.4 Open-Drain Mode The open-drain mode turns off all pull-high transistors and only drives the pull-low of the port pin when the port latch is given by logic 0. If the port latch is logic 1, it behaves as if in input-only mode. To be used as an output 2 pin generally as I C lines, an open-drain pin should add an external pull-high, typically a resistor tied to VDD. User needs to take care that an open-drain pin with its port latch as logic 1 should be given with a determined voltage level by external devices or resistors. A floating pin will induce leakage current especially in Powerdown mode. Aug. 03, 2020 Page 88 of 274 Rev. 1.09 N76E003 Datasheet Port Pin N Port Latch Input Figure 7.4-1. Open-Drain Mode Structure 7.5 Read-Modify-Write Instructions nstructions that read a byte from F or internal A , modify it, and rewrite it back, are called “ ead-Modify- Write” instructions. When the destination is an I/O port or a port bit, these instructions read the internal output latch rather than the external pin state. This kind of instructions read the port SFR value, modify it and write back to the port F . All “ ead-Modify-Write” instructions are listed as follows. Instruction Description ANL Logical AND. (ANL direct, A and ANL direct, #data) ORL Logical OR. (ORL direct, A and ORL direct, #data) XRL Logical exclusive OR. (XRL direct, A and XRL direct, #data) JBC Jump if bit = 1 and clear it. (JBC bit, rel) CPL Complement bit. (CPL bit) INC Increment. (INC direct) DEC Decrement. (DEC direct) DJNZ Decrement and jump if not zero. (DJNZ direct, rel) MOV bit, C Move carry to bit. (MOV bit, C) CLR bit Clear bit. (CLR bit) SETB bit Set bit. (SETB bit) he last three seem not obviously “ ead-Modify-Write” instructions but actually they are. hey read the entire port latch value, modify the changed bit, and then write the new value back to the port latch. 7.6 Control Registers of I/O Ports The N76E003 has a lot of I/O control registers to provide flexibility in all kinds of applications. The SFRs related with I/O ports can be categorized into four groups: input and output control, output mode control, input type and sink current control, and output slew rate control. All of SFRs are listed as follows. Aug. 03, 2020 Page 89 of 274 Rev. 1.09 N76E003 Datasheet 7.6.1 Input and Output Data Control These registers are I/O input and output data buffers. Reading gets the I/O input data. Writing forces the data output. All of these registers are bit-addressable. P0 – Port 0 (Bit-addressable) 7 6 5 P0.7 P0.6 P0.5 R/W R/W R/W Address: 80H Bit Name 7:0 P0[7:0] Name 7:0 P1[7:0] Name 7:1 0 0 P2.0 Aug. 03, 2020 2 P0.2 R/W 1 0 P0.1 P0.0 R/W R/W Reset value: 1111 1111b Port 0 Port 0 is an maximum 8-bit general purpose I/O port. 4 P1.4 R/W 3 P1.3 R/W 2 P1.2 R/W 1 0 P1.1 P1.0 R/W R/W Reset value: 1111 1111b Description Port 1 Port 1 is an maximum 8-bit general purpose I/O port. P2 – Port 2 (Bit-addressable) 7 6 0 0 R R Address: A0H Bit 3 P0.3 R/W Description P1 – Port 1 (Bit-addressable) 7 6 5 P1.7 P1.6 P1.5 R/W R/W R/W Address: 90H Bit 4 P0.4 R/W 5 0 R 4 0 R 3 0 R 2 0 R 1 0 0 P2.0 R R Reset value: 0000 000Xb Description Reserved The bits are always read as 0. Port 2 bit 0 P2.0 is an input-only pin when RPD (CONFIG0.2) is programmed as 0. When leaving RPD un-programmed, P2.0 is always read as 0. Page 90 of 274 Rev. 1.09 N76E003 Datasheet P3 – Port 3 (Bit-addressable) 7 6 0 0 R R Address: B0H Bit Name 7:1 0 0 P3.0 5 0 R 4 0 R 3 0 R 2 0 R 1 0 0 P3.0 R R/W Reset value: 0000 0001b Description Reserved The bits are always read as 0. Port 3 bit 0 P3.0 is available only when the internal oscillator is used as the system clock. At this moment, P3.0 functions as a general purpose I/O. If the system clock is not selected as the internal oscillator, P3.0 pin functions as OSCIN. A write to P3.0 is invalid and P3.0 is always read as 0. 7.6.2 Output Mode Control These registers control output mode which is configurable among four modes: input-only, quasi-bidirectional, push-pull, or open-drain. Each pin can be configured individually. There is also a pull-up control for P2.0 in P2S.7. P0M1 – Port 0 Mode Select 1[1] 7 6 5 P0M1.7 P0M1.6 P0M1.5 R/W R/W R/W Address: B1H, Page: 0 Bit 7:0 Name Description P0M1[7:0] Port 0 mode select 1 P0M2 – Port 0 Mode Select 2[1] 7 6 5 P0M2.7 P0M2.6 P0M2.5 R/W R/W R/W Address: B2H, Page: 0 Bit 4 P0M1.4 R/W Name 4 P0M2.4 R/W 3 P0M1.3 R/W 2 P0M1.2 R/W 1 0 P0M1.1 P0M1.0 R/W R/W Reset value: 1111 1111b 3 P0M2.3 R/W 2 P0M2.2 R/W 1 0 P0M2.1 P0M2.0 R/W R/W Reset value: 0000 0000b Description 7:0 P0M2[7:0] Port 0 mode select 2 [1] P0M1 and P0M2 are used in combination to determine the I/O mode of each pin of P0. See Table 7-1. Configuration for Different I/O Modes. Aug. 03, 2020 Page 91 of 274 Rev. 1.09 N76E003 Datasheet P1M1 – Port 1 Mode Select 1[2] 7 6 5 P1M1.7 P1M1.6 P1M1.5 R/W R/W R/W Address: B3H, Page: 0 Bit 7:0 Name Description P1M1[7:0] Port 1 mode select 1 P1M2 – Port 1 Mode Select 2[2] 7 6 5 P1M2.7 P1M2.6 P1M2.5 R/W R/W R/W Address: B4H, Page: 0 Bit 4 P1M1.4 R/W Name 4 P1M2.4 R/W 3 P1M1.3 R/W 2 P1M1.2 R/W 1 0 P1M1.1 P1M1.0 R/W R/W Reset value: 1111 1111b 3 P1M2.3 R/W 2 P1M2.2 R/W 1 0 P1M2.1 P1M2.0 R/W R/W Reset value: 0000 0000b Description 7:0 P1M2[7:0] Port 1 mode select 2. [2] P1M1 and P1M2 are used in combination to determine the I/O mode of each pin of P1. See Table 7-1. Configuration for Different I/O Modes. P1M1.n P1M2.n 0 0 Quasi-bidirectional 0 1 Push-pull 1 0 Input-only (high-impedance) 1 1 Open-drain P2S – P20 Setting and Timer01 Output Enable 7 6 5 4 P20UP R/W Address: B5H Bit Name 7 Aug. 03, 2020 P20UP I/O Type 3 T1OE R/W 2 T0OE R/W 1 0 P2S.0 R/W Reset value: 0000 0000b Description P2.0 pull-up enable 0 = P2.0 pull-up Disabled. 1 = P2.0 pull-up Enabled. This bit is valid only when RPD (CONFIG0.2) is programmed as 0. When selecting as a ̅̅̅̅̅̅ pin, the pull-up is always enabled. Page 92 of 274 Rev. 1.09 N76E003 Datasheet P3M1 – Port 3 Mode Select 1 7 6 Address: ACH, Page: 0 Bit Name 0 P3M1.0 Name 4 - 3 - 2 - 1 0 P3M1.0[3] R/W Reset value: 0000 0001b 3 - 2 - 1 0 P3M2.0[3] R/W Reset value: 0000 0000b Description Port 3 mode select 1 P3M2 – Port 3 Mode Select 2 7 6 Address: ADH, Page: 0 Bit 5 - 5 - 4 - Description Port 3 mode select 2 0 P3M2.0 [3] P3M1 and P3M2 are used in combination to determine the I/O mode of each pin of P3. See Table 7-1. Configuration for Different I/O Modes. P3M1.n P3M2.n I/O Type 0 0 Quasi-bidirectional 0 1 Push-pull 1 0 Input-only (high-impedance) 1 1 Open-drain 7.6.3 Input Type Each I/O pin can be configured individually as TTL input or Schmitt triggered input. Note that all of PxS registers are accessible by switching SFR page to page 1. P0S – Port 0 Schmitt Triggered Input 7 6 5 P0S.7 P0S.6 P0S.5 R/W R/W R/W Address: B1H, Page: 1 Bit Name n Aug. 03, 2020 P0S.n 4 P0S.4 R/W 3 P0S.3 R/W 2 P0S.2 R/W 1 0 P0S.1 P0S.0 R/W R/W Reset value: 0000 0000b Description P0.n Schmitt triggered input 0 = TTL level input of P0.n. 1 = Schmitt triggered input of P0.n. Page 93 of 274 Rev. 1.09 N76E003 Datasheet P1S – Port 1 Schmitt Triggered Input 7 6 5 P1S.7 P1S.6 P1S.5 R/W R/W R/W Address: B3H, Page: 1 Bit Name 4 P1S.4 R/W 3 P1S.3 R/W P1S.7 P1.7 Schmitt triggered input 0 = TTL level input of P1.7. 1 = Schmitt triggered input of P1.7. 6 P1S.6 P1.6 Schmitt triggered input 0 = TTL level input of P1.6. 1 = Schmitt triggered input of P1.6. 5 P1S.5 P1.5 Schmitt triggered input 0 = TTL level input of P1.5. 1 = Schmitt triggered input of P1.5. 4 P1S.4 P1.4 Schmitt triggered input 0 = TTL level input of P1.4. 1 = Schmitt triggered input of P1.4. 3 P1S.3 P1.3 Schmitt triggered input 0 = TTL level input of P1.3. 1 = Schmitt triggered input of P1.3. 2 P1S.2 P1.2 Schmitt triggered input 0 = TTL level input of P1.2. 1 = Schmitt triggered input of P1.2. 1 P1S.1 P1.1 Schmitt triggered input 0 = TTL level input of P1.1. 1 = Schmitt triggered input of P1.1. 0 P1S.0 P1.0 Schmitt triggered input 0 = TTL level input of P1.0. 1 = Schmitt triggered input of P1.0. P2S – P20 Setting and Timer01 Output Enable 7 6 5 4 P20UP R/W Address: B5H Name 0 Aug. 03, 2020 P2S.0 1 0 P1S.1 P1S.0 R/W R/W Reset value: 0000 0000b 2 T0OE R/W 1 0 P2S.0 R/W Reset value: 0000 0000b Description 7 Bit 2 P1S.2 R/W 3 T1OE R/W Description P2.0 Schmitt triggered input 0 = TTL level input of P2.0. 1 = Schmitt triggered input of P2.0. Page 94 of 274 Rev. 1.09 N76E003 Datasheet P3S – Port 3 Schmitt Triggered Input 7 6 5 Address: ACH, Page: 1 Bit Name 0 P3S.0 4 - 3 - 2 - 1 0 P3S.0 R/W Reset value: 0000 0000b Description P3.0 Schmitt triggered input 0 = TTL level input of P3.0. 1 = Schmitt triggered input of P3.0. 7.6.4 Output Slew Rate Control Slew rate for each I/O pin is configurable individually. By default, each pin is in normal slew rate mode. User can set each control register bit to enable high-speed slew rate for the corresponding I/O pin. Note that all PxSR registers are accessible by switching SFR page to page 1. P0SR – Port 0 Slew Rate 7 6 P0SR.7 P0SR.6 R/W R/W Address: B2H, Page: 1 Bit Name n P0SR.n P1SR – Port 1 Slew Rate 7 6 P1SR.7 P1SR.6 R/W R/W Address: B4H, Page: 1 Bit Name n Aug. 03, 2020 P1SR.n 5 P0SR.5 R/W 4 P0SR.4 R/W 3 P0SR.3 R/W 2 P0SR.2 R/W 1 0 P0SR.1 P0SR.0 R/W R/W Reset value: 0000 0000b 2 P1SR.2 R/W 1 0 P1SR.1 P1SR.0 R/W R/W Reset value: 0000 0000b Description P0.n slew rate 0 = P0.n normal output slew rate. 1 = P0.n high-speed output slew rate. 5 P1SR.5 R/W 4 P1SR.4 R/W 3 P1SR.3 R/W Description P1.n slew rate 0 = P1.n normal output slew rate. 1 = P1.n high-speed output slew rate. Page 95 of 274 Rev. 1.09 N76E003 Datasheet P3SR – Port 3 Slew Rate 7 6 Address: ADH, Page: 1 Bit Name 0 Aug. 03, 2020 P3SR.0 5 - 4 - 3 - 2 - 1 0 P3SR.0 R/W Reset value: 0000 0000b Description P3.n slew rate 0 = P3.0 normal output slew rate. 1 = P3.0 high-speed output slew rate. Page 96 of 274 Rev. 1.09 N76E003 Datasheet 8. TIMER/COUNTER 0 AND 1 Timer/Counter 0 and 1 on N76E003 are two 16-bit Timers/Counters. Each of them has two 8-bit registers those form the 16-bit counting register. For Timer/Counter 0 they are TH0, the upper 8-bit register, and TL0, the lower 8-bit register. Similarly Timer/Counter 1 has two 8-bit registers, TH1 and TL1. TCON and TMOD can configure modes of Timer/Counter 0 and 1. The Timer or Counter function is selected by the ̅ bit in TMOD. Each Timer/Counter has its own selection bit. TMOD.2 selects the function for Timer/Counter 0 and TMOD.6 selects the function for Timer/Counter 1 When configured as a “ imer”, the timer counts the system clock cycles. he timer clock is of the system clock (FSYS) for standard 8051 capability or direct the system clock for enhancement, which is selected by T0M ( K O .3) bit for imer and ( K O .4) bit for imer . n the “ ounter” mode, the countering register increases on the falling edge of the external input pin T0. If the sampled value is high in one clock cycle and low in the next, a valid 1-to-0 transition is recognized on T0 or T1 pin. The Timers 0 and 1 can be configured to automatically toggle a port output whenever a timer overflow occurs. The same device pins that are used for the T0 and T1 count inputs are also used for the timer toggle outputs. This function is enabled by control bits T0OE and T1OE in the P2S register, and apply to Timer 0 and Timer 1 respectively. The port outputs will be logic 1 prior to the first timer overflow when this mode is turned on. In order for this mode to function, the ̅ bit should be cleared selecting the system clock as the clock source for the timer. Note that the TH0 (TH1) and TL0 (TL1) are accessed separately. It is strongly recommended that in mode 0 or 1, user should stop Timer temporally by clearing TR0 (TR1) bit before reading from or writing to TH0 (TH1) and TL0 (TL1). The free-running reading or writing may cause unpredictable result. TMOD – Timer 0 and 1 Mode 7 6 ̅ GATE R/W Address: 89H Bit R/W Name 7 GATE 6 ̅ 5 M1 Aug. 03, 2020 5 M1 4 M0 3 GATE 2 ̅ R/W R/W R/W R/W 1 M1 0 M0 R/W R/W Reset value: 0000 0000b Description Timer 1 gate control 0 = Timer 1 will clock when TR1 is 1 regardless of ̅̅̅̅̅̅̅ logic level. 1 = Timer 1 will clock only when TR1 is 1 and ̅̅̅̅̅̅̅ is logic 1. Timer 1 Counter/Timer select 0 = Timer 1 is incremented by internal system clock. 1 = Timer 1 is incremented by the falling edge of the external pin T1. Timer 1 mode select Page 97 of 274 Rev. 1.09 N76E003 Datasheet Bit Name 4 M0 3 GATE 2 ̅ 1 M1 0 M0 Description M1 0 0 1 1 M0 0 1 0 1 Timer 1 Mode Mode 0: 13-bit Timer/Counter Mode 1: 16-bit Timer/Counter Mode 2: 8-bit Timer/Counter with auto-reload from TH1 Mode 3: Timer 1 halted Timer 0 gate control 0 = Timer 0 will clock when TR0 is 1 regardless of ̅̅̅̅̅̅̅ logic level. 1 = Timer 0 will clock only when TR0 is 1 and ̅̅̅̅̅̅̅ is logic 1. Timer 0 Counter/Timer select 0 = Timer 0 is incremented by internal system clock. 1 = Timer 0 is incremented by the falling edge of the external pin T0. Timer 0 mode select M1 M0 Timer 0 Mode 0 0 Mode 0: 13-bit Timer/Counter 0 1 Mode 1: 16-bit Timer/Counter 1 0 Mode 2: 8-bit Timer/Counter with auto-reload from TH0 1 1 Mode 3: TL0 as a 8-bit Timer/Counter and TH0 as a 8-bit Timer TCON – Timer 0 and 1 Control (Bit-addressable) 7 6 5 4 TF1 TR1 TF0 TR0 R/W R/W R/W Name Description R/W 3 IE1 R (level) R/W (edge) Address: 88H Bit 2 IT1 R/W 1 0 IE0 IT0 R (level) R/W R/W (edge) Reset value: 0000 0000b 7 TF1 Timer 1 overflow flag This bit is set when Timer 1 overflows. It is automatically cleared by hardware when the program executes the Timer 1 interrupt service routine. This bit can be set or cleared by software. 6 TR1 Timer 1 run control 0 = Timer 1 Disabled. Clearing this bit will halt Timer 1 and the current count will be preserved in TH1 and TL1. 1 = Timer 1 Enabled. 5 TF0 Timer 0 overflow flag This bit is set when Timer 0 overflows. It is automatically cleared via hardware when the program executes the Timer 0 interrupt service routine. This bit can be set or cleared by software. 4 TR0 Timer 0 run control 0 = Timer 0 Disabled. Clearing this bit will halt Timer 0 and the current count will be preserved in TH0 and TL0. 1 = Timer 0 Enabled. Aug. 03, 2020 Page 98 of 274 Rev. 1.09 N76E003 Datasheet TL0 – Timer 0 Low Byte 7 6 5 4 3 2 1 0 TL0[7:0] R/W Address: 8AH Bit 7:0 Reset value: 0000 0000b Name TL0[7:0] TH0 – Timer 0 High Byte 7 6 Description Timer 0 low byte The TL0 register is the low byte of the 16-bit counting register of Timer 0. 5 4 3 2 1 0 TH0[7:0] R/W Address: 8CH Bit 7:0 Reset value: 0000 0000b Name Description TH0[7:0] Timer 0 high byte The TH0 register is the high byte of the 16-bit counting register of Timer 0. TL1 – Timer 1 Low Byte 7 6 5 4 3 2 1 0 TL1[7:0] R/W Address: 8BH Bit 7:0 Reset value: 0000 0000b Name TL1[7:0] TH1 – Timer 1 High Byte 7 6 Description Timer 1 low byte The TL1 register is the low byte of the 16-bit counting register of Timer 1. 5 4 3 2 1 0 TH1[7:0] R/W Address: 8DH Bit 7:0 Aug. 03, 2020 Reset value: 0000 0000b Name Description TH1[7:0] Timer 1 high byte The TH1 register is the high byte of the 16-bit counting register of Timer 1. Page 99 of 274 Rev. 1.09 N76E003 Datasheet CKCON – Clock Control 7 6 PWMCKS R/W Address: 8EH Bit Name 5 - 4 T1M R/W 3 T0M R/W 2 - 1 0 CLOEN R/W Reset value: 0000 0000b Description 4 T1M Timer 1 clock mode select 0 = The clock source of Timer 1 is the system clock divided by 12. It maintains standard 8051 compatibility. 1 = The clock source of Timer 1 is direct the system clock. 3 T0M Timer 0 clock mode select 0 = The clock source of Timer 0 is the system clock divided by 12. It maintains standard 8051 compatibility. 1 = The clock source of Timer 0 is direct the system clock. P2S – P20 Setting and Timer01 Output Enable 7 6 5 4 P20UP R/W Address: B5H Bit Name 3 T1OE R/W 2 T0OE R/W 1 0 P2S.0 R/W Reset value: 0000 0000b Description 3 T1OE Timer 1 output enable 0 = Timer 1 output Disabled. 1 = Timer 1 output Enabled from T1 pin. ote that imer output should be enabled only when operating in its “ imer” mode. 2 T0OE Timer 0 output enable 0 = Timer 0 output Disabled. 1 = Timer 0 output Enabled from T0 pin. ote that imer output should be enabled only when operating in its “ imer” mode. 8.1 Mode 0 (13-Bit Timer) In Mode 0, the Timer/Counter is a 13-bit counter. The 13-bit counter consists of TH0 (TH1) and the five lower bits of TL0 (TL1). The upper three bits of TL0 (TL1) are ignored. The Timer/Counter is enabled when TR0 (TR1) is set and either GATE is 0 or ̅̅̅̅̅̅̅ (̅̅̅̅̅̅̅) is 1. Gate setting as 1 allows the Timer to calculate the pulse width on external input pin ̅̅̅̅̅̅̅ ( ̅̅̅̅̅̅̅ ). When the 13-bit value moves from 1FFFH to 0000H, the Timer overflow flag TF0 (TF1) is set and an interrupt occurs if enabled. Aug. 03, 2020 Page 100 of 274 Rev. 1.09 N76E003 Datasheet 1/12 T0M (CKCON.3) (T1M (CKCON.4)) 0 FSYS 1 C/T 0 1 T0 (T1) pin 0 TL0 (TL1) 4 0 TR0 (TR1) 7 TF0 (TF1) 7 TH0 (TH1) Timer Interrupt T0 (T1) pin GATE T0OE (P2S.2) (T1OE(P2S.3)) INT0 (INT1) pin Figure 8.1-1. Timer/Counters 0 and 1 in Mode 0 8.2 Mode 1 (16-Bit Timer) Mode 1 is similar to Mode 0 except that the counting registers are fully used as a 16-bit counter. Roll-over occurs when a count moves FFFFH to 0000H. The Timer overflow flag TF0 (TF1) of the relevant Timer/Counter is set and an interrupt will occurs if enabled. 1/12 T0M (CKCON.3) (T1M (CKCON.4)) 0 FSYS 1 C/T 0 1 TL0 (TL1) T0 (T1) pin TR0 (TR1) 0 7 0 7 TF0 (TF1) TH0 (TH1) Timer Interrupt T0 (T1) pin GATE T0OE (P2S.2) (T1OE(P2S.3)) INT0 (INT1) pin Figure 8.2-1. Timer/Counters 0 and 1 in Mode 1 8.3 Mode 2 (8-Bit Auto-Reload Timer) In Mode 2, the Timer/Counter is in auto-reload mode. In this mode, TL0 (TL1) acts as an 8-bit count register whereas TH0 (TH1) holds the reload value. When the TL0 (TL1) register overflow, the TF0 (TF1) bit in TCON is set and TL0 (TL1) is reloaded with the contents of TH0 (TH1) and the counting process continues from here. The reload operation leaves the contents of the TH0 (TH1) register unchanged. This feature is best suitable for UART baud rate generator for it runs without continuous software intervention. Note that only Timer1 can be Aug. 03, 2020 Page 101 of 274 Rev. 1.09 N76E003 Datasheet the baud rate source for UART. Counting is enabled by setting the TR0 (TR1) bit as 1 and proper setting of GATE and ̅̅̅̅̅̅̅ (̅̅̅̅̅̅̅) pins. The functions of GATE and ̅̅̅̅̅̅̅ (̅̅̅̅̅̅̅) pins are just the same as Mode 0 and 1. 1/12 T0M (CKCON.3) (T1M (CKCON.4)) 0 FSYS 1 C/T 0 1 TL0 (TL1) T0 (T1) pin 0 TF0 (TF1) 7 Timer Interrupt T0 (T1) pin TR0 (TR1) 0 GATE 7 T0OE (P2S.2) (T1OE(P2S.3)) TH0 (TH1) INT0 (INT1) pin Figure 8.3-1. Timer/Counters 0 and 1 in Mode 2 8.4 Mode 3 (Two Separate 8-Bit Timers) Mode 3 has different operating methods for Timer 0 and Timer 1. For Timer/Counter 1, Mode 3 simply freezes the counter. Timer/Counter 0, however, configures TL0 and TH0 as two separate 8 bit count registers in this mode. TL0 uses the Timer/Counter 0 control bits ̅, GATE, TR0, ̅̅̅̅̅̅̅, and TF0. The TL0 also can be used as a 1-to-0 transition counter on pin T0 as determined by ̅ (TMOD.2). TH0 is forced as a clock cycle counter and takes over the usage of TR1 and TF1 from Timer/Counter 1. Mode 3 is used in case that an extra 8 bit timer is needed. If Timer/Counter 0 is configured in Mode 3, Timer/Counter 1 can be turned on or off by switching it out of or into its own Mode 3. It can still be used in Modes 0, 1 and 2 although its flexibility is restricted. It no longer has control over its overflow flag TF1 and the enable bit TR1. However Timer 1 can still be used as a Timer/Counter and retains the use of GATE, ̅̅̅̅̅̅̅ pin and T1M. It can be used as a baud rate generator for the serial port or other application not requiring an interrupt. Aug. 03, 2020 Page 102 of 274 Rev. 1.09 N76E003 Datasheet 1/12 T0M (CKCON.3) 0 FSYS 1 C/T 0 1 T0 pin TL0 0 7 TF0 Timer 0 Interrupt T0 pin T0OE (P2S.2) TR0 GATE TH0 INT0 pin TR1 0 7 TF1 Timer 1 Interrupt T1 pin T1OE(P2S.3) Figure 8.4-1. Timer/Counter 0 in Mode 3 Aug. 03, 2020 Page 103 of 274 Rev. 1.09 N76E003 Datasheet 9. TIMER 2 AND INPUT CAPTURE Timer 2 is a 16-bit up counter cascaded with TH2, the upper 8 bits register, and TL2, the lower 8 bit register. Equipped with RCMP2H and RCMP2L, Timer 2 can operate under compare mode and auto-reload mode selected by ̅̅̅̅̅̅ (T2CON.0). An 3-channel input capture module makes Timer 2 detect and measure the width or period of input pulses. The results of 3 input captures are stores in C0H and C0L, C1H and C1L, C2H and C2L individually. The clock source of Timer 2 is from the system clock pre-scaled by a clock divider with 8 different scales for wide field application. The clock is enabled when TR2 (T2CON.2) is 1, and disabled when TR2 is 0. The following registers are related to Timer 2 function. C0L P1.5/IC7 P0.5/IC6 P0.3/IC5 P0.1/IC4 P0.4/IC3 P0.0/IC3 P1.0/IC2 P1.1/IC1 P1.2/IC0 1000 0111 0110 0101 0100 0011 0010 0001 0000 CAP1 CAP2 CAPF0 CAPF0 [00] CAP0 C0H CAPF1 Noise Filter Input Capture Interrupt [01] CAPF2 ENF0 (CAPCON2.4) [10] or CAPEN0 (CAPCON0.4) CAP0LS[1:0] (CAPCON1[1:0]) Input Capture 0 Module Input Capture 1 Module Input Capture 2 Module Input Capture Flags (CAPF[2:0]) CAPF0 CAPF1 CAPF2 Clear Timer 2 CAPCR[1] (T2MOD.3) CMPCR (T2MOD.2) Clear Counter Clear Timer 2 FSYS Pre-scalar TL2 TH2 TF2 Timer 2 Interrupt TR2 (T2CON.2) T2DIV[2:0] (T2MOD[6:4]) CAPF0 CAPF1 CAPF2 LDTS[1:0] (T2MOD[1:0]) 00 01 10 11 = LDEN[1] (T2MOD.7) RCMP2L RCMP2H Timer 2 Module [1] Once CAPCR and LDEN are both set, an input capture event only clears TH2 and TL2 without reloading RCMP2H and RCMP2L contents. Figure 8.4-1. Timer 2 Block Diagram Aug. 03, 2020 Page 104 of 274 Rev. 1.09 N76E003 Datasheet T2CON – Timer 2 Control 7 6 TF2 R/W Address: C8H Bit Name 5 - 4 - 3 - 2 TR2 R/W 1 0 ̅̅̅̅̅̅ R/W Reset value: 0000 0000b Description 7 TF2 Timer 2 overflow flag This bit is set when Timer 2 overflows or a compare match occurs. If the Timer 2 interrupt and the global interrupt are enable, setting this bit will make CPU execute Timer 2 interrupt service routine. This bit is not automatically cleared via hardware and should be cleared via software. 2 TR2 Timer 2 run control 0 = Timer 2 Disabled. Clearing this bit will halt Timer 2 and the current count will be preserved in TH2 and TL2. 1 = Timer 2 Enabled. 0 ̅̅̅̅̅̅ T2MOD – Timer 2 Mode 7 6 LDEN R/W Address: C9H Bit Name Timer 2 compare or auto-reload mode select This bit selects Timer 2 functioning mode. 0 = Auto-reload mode. 1 = Compare mode. 5 T2DIV[2:0] R/W 4 3 CAPCR R/W 2 CMPCR R/W 1 0 LDTS[1:0] R/W Reset value: 0000 0000b Description Enable auto-reload 0 = Reloading RCMP2H and RCMP2L to TH2 and TL2 Disabled. 1 = Reloading RCMP2H and RCMP2L to TH2 and TL2 Enabled. 7 LDEN 6:4 T2DIV[2:0] 3 CAPCR Capture auto-clear This bit is valid only under Timer 2 auto-reload mode. It enables hardware autoclearing TH2 and TL2 counter registers after they have been transferred in to RCMP2H and RCMP2L while a capture event occurs. 0 = Timer 2 continues counting when a capture event occurs. 1 = Timer 2 value is auto-cleared as 0000H when a capture event occurs. 2 CMPCR Compare match auto-clear This bit is valid only under Timer 2 compare mode. It enables hardware autoclearing TH2 and TL2 counter registers after a compare match occurs. 0 = Timer 2 continues counting when a compare match occurs. 1 = Timer 2 value is auto-cleared as 0000H when a compare match occurs. Aug. 03, 2020 Timer 2 clock divider 000 = Timer 2 clock divider is 1/1. 001 = Timer 2 clock divider is 1/4. 010 = Timer 2 clock divider is 1/16. 011 = Timer 2 clock divider is 1/32. 100 = Timer 2 clock divider is 1/64. 101 = Timer 2 clock divider is 1/128. 110 = Timer 2 clock divider is 1/256. 111 = Timer 2 clock divider is 1/512. Page 105 of 274 Rev. 1.09 N76E003 Datasheet Bit 1:0 Name Description LDTS[1:0] Auto-reload trigger select These bits select the reload trigger event. 00 = Reload when Timer 2 overflows. 01 = Reload when input capture 0 event occurs. 10 = Reload when input capture 1 event occurs. 11 = Reload when input capture 2 event occurs. RCMP2L – Timer 2 Reload/Compare Low Byte 7 6 5 4 3 RCMP2L[7:0] R/W Address: CAH Bit 7:0 Name 7:0 RCMP2L[7:0] Name 0 Reset value: 0000 0000b Timer 2 reload/compare low byte This register stores the low byte of compare value when Timer 2 is configured in compare mode. Also it holds the low byte of the reload value in auto-reload mode. 2 1 0 Reset value: 0000 0000b Description RCMP2H[7:0] TL2 – Timer 2 Low Byte 7 6 1 Description RCMP2H – Timer 2 Reload/Compare High Byte 7 6 5 4 3 RCMP2H[7:0] R/W Address: CBH Bit 2 Timer 2 reload/compare high byte This register stores the high byte of compare value when Timer 2 is configured in compare mode. Also it holds the high byte of the reload value in auto-reload mode. 5 4 3 2 1 0 TL2[7:0] R/W Address: CCH, Page:0 Bit 7:0 Aug. 03, 2020 Name TL2[7:0] Reset value: 0000 0000b Description Timer 2 low byte The TL2 register is the low byte of the 16-bit counting register of Timer 2. Page 106 of 274 Rev. 1.09 N76E003 Datasheet TH2 – Timer 2 High Byte 7 6 5 4 3 2 1 0 TH2[7:0] R/W Address: CDH, Page:0 Bit 7:0 Reset value: 0000 0000b Name Description TH2[7:0] Timer 2 high byte The TH2 register is the high byte of the 16-bit counting register of Timer 2. Note that the TH2 and TL2 are accessed separately. It is strongly recommended that user stops Timer 2 temporally by clearing TR2 bit before reading from or writing to TH2 and TL2. The free-running reading or writing may cause unpredictable result. Aug. 03, 2020 Page 107 of 274 Rev. 1.09 N76E003 Datasheet 9.1 Auto-Reload Mode ̅̅̅̅̅̅. In this mode RCMP2H and RCMP2L The Timer 2 is configured as auto-reload mode by clearing registers store the reload value. The contents in RCMP2H and RCMP2L transfer into TH2 and TL2 once the auto-reload event occurs if setting LDEN bit. The event can be the Timer 2 overflow or one of the triggering event on any of enabled input capture channel depending on the LDTS[1:0] (T2MOD[1:0]) selection. Note that once CAPCR (T2MOD.3) is set, an input capture event only clears TH2 and TL2 without reloading RCMP2H and RCMP2L contents. C0L P1.5/IC7 P0.5/IC6 P0.3/IC5 P0.1/IC4 P0.4/IC3 P0.0/IC3 P1.0/IC2 P1.1/IC1 P1.2/IC0 1000 0111 0110 0101 0100 0011 0010 0001 0000 Noise Filter CAP1 CAPF1 [10] Input Capture Interrupt CAPF2 [01] ENF0 (CAPCON2.4) CAP2 CAPF0 CAPF0 [00] CAP0 C0H or CAPEN0 (CAPCON0.4) CAP0LS[1:0] (CAPCON1[1:0]) Input Capture 0 Module Input Capture 1 Module Input Capture Flags CAPF[2:0] Input Capture 2 Module CAPF0 CAPF1 CAPF2 Clear Timer 2 FSYS Pre-scalar T2DIV[2:0] (T2MOD[6:4]) TL2 TH2 RCMP2L RCMP2H CAPCR[1] (T2MOD.3) TF2 Timer 2 Interrupt TR2 (T2CON.2) CAPF0 CAPF1 CAPF2 LDTS[1:0] (T2MOD[1:0]) 00 01 10 11 LDEN[1] (T2MOD.7) Timer 2 Module [1] Once CAPCR and LDEN are both set, an input capture event only clears TH2 and TL2 without reloading RCMP2H and RCMP2L contents. Figure 9.1-1. Timer 2 Auto-Reload Mode and Input Capture Module Functional Block Diagram Aug. 03, 2020 Page 108 of 274 Rev. 1.09 N76E003 Datasheet 9.2 Compare Mode Timer 2 can also be configured as the compare mode by setting ̅̅̅̅̅̅. In this mode RCMP2H and RCMP2L registers serve as the compare value registers. As Timer 2 up counting, TH2 and TL2 match RCMP2H and RCMP2L, TF2 (T2CON.7) will be set by hardware to indicate a compare match event. Setting CMPCR (T2MOD.2) makes the hardware to clear Timer 2 counter as 0000H automatically after a compare match has occurred. C0L P1.5/IC7 P0.5/IC6 P0.3/IC5 P0.1/IC4 P0.4/IC3 P0.0/IC3 P1.0/IC2 P1.1/IC1 P1.2/IC0 1000 0111 0110 0101 0100 0011 0010 0001 0000 Noise Filter CAP1 CAPF1 [10] Input Capture Interrupt CAPF2 [01] ENF0 (CAPCON2.4) CAP2 CAPF0 CAPF0 [00] CAP0 C0H or CAPEN0 (CAPCON0.4) CAP0LS[1:0] (CAPCON1[1:0]) Input Capture 0 Module Input Capture 1 Module Input Capture 2 Module CMPCR (T2MOD.2) Clear Timer 2 FSYS Pre-scalar T2DIV[2:0] (T2MOD[6:4]) TL2 TR2 (T2CON.2) TH2 = RCMP2L TF2 Timer 2 Interrupt RCMP2H Timer 2 Module Figure 9.2-1. Timer 2 Compare Mode and Input Capture Module Functional Block Diagram 9.3 Input Capture Module The input capture module along with Timer 2 implements the input capture function. The input capture module is configured through CAPCON0~2 registers. The input capture module supports 3-channel inputs (CAP0, CAP1, and CAP2) that share 9 I/O pins (P1.5, P1[2:0], P0.0, P0.1 and P0[5:3]). The pin mux select through CAPCON3 and CAPCON4. Each input channel consists its own noise filter, which is enabled via setting ENF0~2 (CAPCON2[6:4]). It filters input glitches smaller than four system clock cycles. Input capture channels has their own independent edge detector but share the unique Timer 2. Each trigger edge detector is selected individually by setting corresponding bits in CAPCON1. It supports positive edge capture, negative edge Aug. 03, 2020 Page 109 of 274 Rev. 1.09 N76E003 Datasheet capture, or any edge capture. Each input capture channel has to set its own enabling bit CAPEN0~2 (CAPCON0[6:4]) before use. While input capture channel is enabled and the selected edge trigger occurs, the content of the free running Timer 2 counter, TH2 and TL2, will be captured, transferred, and stored into the capture registers CnH and CnL. The edge triggering also causes CAPFn (CAPCON0.n) set by hardware. The interrupt will also generate if the ECAP (EIE.2) and EA bit are both set. For three input capture flags share the same interrupt vector, user should check CAPFn to confirm which channel comes the input capture edge. These flags should be cleared by software. The bit CAPCR (CAPCON2.3) benefits the implement of period calculation. Setting CAPCR makes the hardware clear Timer 2 as 0000H automatically after the value of TH2 and TL2 have been captured after an input capture edge event occurs. It eliminates the routine software overhead of writing 16-bit counter or an arithmetic subtraction. CAPCON0 – Input Capture Control 0 7 6 5 CAPEN2 CAPEN1 R/W R/W Address: 92H Bit 4 CAPEN0 R/W 3 - 2 CAPF2 R/W 1 0 CAPF1 CAPF0 R/W R/W Reset value: 0000 0000b Name Description 6 CAPEN2 Input capture 2 enable 0 = Input capture channel 2 Disabled. 1 = Input capture channel 2 Enabled. 5 CAPEN1 Input capture 1 enable 0 = Input capture channel 1 Disabled. 1 = Input capture channel 1 Enabled. 4 CAPEN0 Input capture 0 enable 0 = Input capture channel 0 Disabled. 1 = Input capture channel 0 Enabled. 2 CAPF2 Input capture 2 flag This bit is set by hardware if the determined edge of input capture 2 occurs. This bit should cleared by software. 1 CAPF1 Input capture 1 flag This bit is set by hardware if the determined edge of input capture 1 occurs. This bit should cleared by software. 0 CAPF0 Input capture 0 flag This bit is set by hardware if the determined edge of input capture 0 occurs. This bit should cleared by software. Aug. 03, 2020 Page 110 of 274 Rev. 1.09 N76E003 Datasheet CAPCON1 – Input Capture Control 1 7 6 5 4 CAP2LS[1:0] R/W Address: 93H Bit Name 3 2 CAP1LS[1:0] R/W Description 5:4 CAP2LS[1:0] Input capture 2 level select 00 = Falling edge. 01 = Rising edge. 10 = Either Rising or falling edge. 11 = Reserved. 3:2 CAP1LS[1:0] Input capture 1 level select 00 = Falling edge. 01 = Rising edge. 10 = Either Rising or falling edge. 11 = Reserved. 1:0 CAP0LS[1:0] Input capture 0 level select 00 = Falling edge. 01 = Rising edge. 10 = Either Rising or falling edge. 11 = Reserved. CAPCON2 – Input Capture Control 2 7 6 5 ENF2 ENF1 R/W R/W Address: 94H Bit Name 4 ENF0 R/W 3 - 2 - 1 0 Reset value: 0000 0000b Description 6 ENF2 Enable noise filer on input capture 2 0 = Noise filter on input capture channel 2 Disabled. 1 = Noise filter on input capture channel 2 Enabled. 5 ENF1 Enable noise filer on input capture 1 0 = Noise filter on input capture channel 1 Disabled. 1 = Noise filter on input capture channel 1 Enabled. 4 ENF0 Enable noise filer on input capture 0 0 = Noise filter on input capture channel 0 Disabled. 1 = Noise filter on input capture channel 0 Enabled. C0L – Capture 0 Low Byte 7 6 1 0 CAP0LS[1:0] R/W Reset value: 0000 0000b 5 4 3 2 1 0 C0L[7:0] R/W Address: E4H Bit 7:0 Aug. 03, 2020 Reset value: 0000 0000b Name C0L[7:0] Description Input capture 0 result low byte The C0L register is the low byte of the 16-bit result captured by input capture 0. Page 111 of 274 Rev. 1.09 N76E003 Datasheet C0H – Capture 0 High Byte 7 6 5 4 3 2 1 0 C0H[7:0] R/W Address: E5H Bit 7:0 Reset value: 0000 0000b Name Description C0H[7:0] Input capture 0 result high byte The C0H register is the high byte of the 16-bit result captured by input capture 0. C1L – Capture 1 Low Byte 7 6 5 4 3 2 1 0 C1L[7:0] R/W Address: E6H Bit 7:0 Reset value: 0000 0000b Name C1L[7:0] Description Input capture 1 result low byte The C1L register is the low byte of the 16-bit result captured by input capture 1. C1H – Capture 1 High Byte 7 6 5 4 3 2 1 0 C1H[7:0] R/W Address: E7H Bit 7:0 Reset value: 0000 0000b Name Description C1H[7:0] Input capture 1 result high byte The C1H register is the high byte of the 16-bit result captured by input capture 1. C2L – Capture 2 Low Byte 7 6 5 4 3 2 1 0 C2L[7:0] R/W Address: EDH Bit 7:0 Aug. 03, 2020 Reset value: 0000 0000b Name C2L[7:0] Description Input capture 2 result low byte The C2L register is the low byte of the 16-bit result captured by input capture 2. Page 112 of 274 Rev. 1.09 N76E003 Datasheet C2H – Capture 2 High Byte 7 6 5 4 3 2 1 0 C2H[7:0] R/W Address: EEH Bit 7:0 Reset value: 0000 0000b Name Description C2H[7:0] Input capture 2 result high byte The C2H register is the high byte of the 16-bit result captured by input capture 2. CAPCON3 – Input Capture Control 3 7 6 5 CAP13 CAP12 CAP11 R/W R/W R/W Address: F1H Bit 4 CAP10 R/W 3 CAP03 R/W Name Description [7:4] CAP1[3:0] Input capture channel 1 input pin select 0000 = P1.2/IC0 0001 = P1.1/IC1 0010 = P1.0/IC2 0011 = P0.0/IC3 0100 = P0.4/IC3 0101 = P0.1/IC4 0110 = P0.3/IC5 0111 = P0.5/IC6 1000 = P1.5/IC7 others = P1.2/IC0 [3:0] CAP0[3:0] Input capture channel 0 input pin select 0000 = P1.2/IC0 0001 = P1.1/IC1 0010 = P1.0/IC2 0011 = P0.0/IC3 0100 = P0.4/IC3 0101 = P0.1/IC4 0110 = P0.3/IC5 0111 = P0.5/IC6 1000 = P1.5/IC7 others = P1.2/IC0 Aug. 03, 2020 Page 113 of 274 2 CAP02 R/W 1 0 CAP01 CAP00 R/W R/W Reset value: 0000 0000b Rev. 1.09 N76E003 Datasheet CAPCON4 – Input Capture Control 4 7 6 5 Address: F2H Bit [3:0] Aug. 03, 2020 4 - 3 CAP23 R/W Name Description CAP2[3:0] Input capture channel 2 input pin select 0000 = P1.2/IC0 0001 = P1.1/IC1 0010 = P1.0/IC2 0011 = P0.0/IC3 0100 = P0.4/IC3 0101 = P0.1/IC4 0110 = P0.3/IC5 0111 = P0.5/IC6 1000 = P1.5/IC7 others = P1.2/IC0 Page 114 of 274 2 CAP22 R/W 1 0 CAP21 CAP20 R/W R/W Reset value: 0000 0000b Rev. 1.09 N76E003 Datasheet 10. TIMER 3 Timer 3 is implemented simply as a 16-bit auto-reload, up-counting timer. The user can select the pre-scale with T3PS[2:0] (T3CON[2:0]) and fill the reload value into RH3 and RL3 registers to determine its overflow rate. User then can set TR3 (T3CON.3) to start counting. When the counter rolls over FFFFH, TF3 (T3CON.4) is set as 1 and a reload is generated and causes the contents of the RH3 and RL3 registers to be reloaded into the internal 16-bit counter. If ET3 (EIE1.1) is set as 1, Timer 3 interrupt service routine will be served. TF3 is autocleared by hardware after entering its interrupt service routine. Timer 3 can also be the baud rate clock source of both UARTs. For details, please see Section 13.5 “Baud Rate” on page 132. FSYS Pre-scalar (1/1~1/128) TR3 (T3CON.3) T3PS[2:0] (T3CON[2:0]) Timer 3 Overflow Internal 16-bit Counter 0 7 0 RL3 TF3 (T3CON.4) Timer 3 Interrupt 7 RH3 Figure 9.3-1. Timer 3 Block Diagram T3CON – Timer 3 Control 7 6 SMOD_1 SMOD0_1 R/W R/W Address: C4H, Page:0 5 BRCK R/W 4 TF3 R/W 3 TR3 R/W 2 1 0 T3PS[2:0] R/W Reset value: 0000 0000b Bit Name 4 TF3 Timer 3 overflow flag This bit is set when Timer 3 overflows. It is automatically cleared by hardware when the program executes the Timer 3 interrupt service routine. This bit can be set or cleared by software. 3 TR3 Timer 3 run control 0 = Timer 3 is halted. 1 = Timer 3 starts running. Note that the reload registers RH3 and RL3 can only be written when Timer 3 is halted (TR3 bit is 0). If any of RH3 or RL3 is written if TR3 is 1, result is unpredictable. 2:0 T3PS[2:0] Aug. 03, 2020 Description Timer 3 pre-scalar These bits determine the scale of the clock divider for Timer 3. 000 = 1/1. 001 = 1/2. 010 = 1/4. 011 = 1/8. 100 = 1/16. 101 = 1/32. 110 = 1/64. 111 = 1/128. Page 115 of 274 Rev. 1.09 N76E003 Datasheet RL3 – Timer 3 Reload Low Byte 7 6 5 4 3 2 1 0 RL3[7:0] R/W Address: C5H, Page:0 Bit Name 7:0 RL3[7:0] Reset value: 0000 0000b Description Timer 3 reload low byte It holds the low byte of the reload value of Timer 3. RH3 – Timer 3 Reload High Byte 7 6 5 4 3 2 1 0 RH3[7:0] R/W Address: C6H, Page:0 Bit Name 7:0 RH3[7:0] Aug. 03, 2020 Reset value: 0000 0000b Description Timer 3 reload high byte It holds the high byte of the reload value of Time 3. Page 116 of 274 Rev. 1.09 N76E003 Datasheet 11. WATCHDOG TIMER (WDT) The N76E003 provides one Watchdog Timer (WDT). It can be configured as a time-out reset timer to reset whole device. Once the device runs in an abnormal status or hangs up by outward interference, a WDT reset recover the system. It provides a system monitor, which improves the reliability of the system. Therefore, WDT is especially useful for system that is susceptible to noise, power glitches, or electrostatic discharge. The WDT also can be configured as a general purpose timer, of which the periodic interrupt serves as an event timer or a durational system supervisor in a monitoring system, which is able to operate during Idle or Power-down mode. WDTEN[3:0] (CONFIG4[7:4]) initialize the WDT to operate as a time-out reset timer or a general purpose timer. CONFIG4 7 6 5 WDTEN[3:0] R/W Bit 7:4 4 3 - 2 1 0 Factory default value: 1111 1111b Name Description WDTEN[3:0] WDT enable This field configures the WDT behavior after MCU execution. 1111 = WDT is Disabled. WDT can be used as a general purpose timer via software control. 0101 = WDT is Enabled as a time-out reset timer and it stops running during Idle or Power-down mode. Others = WDT is Enabled as a time-out reset timer and it keeps running during Idle or Power-down mode. The WDT is implemented with a set of divider that divides the low-speed internal oscillator clock nominal 10 kHz. The divider output is selectable and determines the time-out interval. When the time-out interval is fulfilled, it will wake the system up from Idle or Power-down mode and an interrupt event will occur if WDT interrupt is enabled. If WDT is initialized as a time-out reset timer, a system reset will occur after a period of delay if without any software action. WDCON – Watchdog Timer Control (TA protected) 7 6 5 4 3 2 1 0 WDTR WDCLR WDTF WIDPD WDTRF[1] WDPS[2:0][2] R/W R/W R/W R/W R/W R/W Address: AAH Reset value: see Table 6-2. SFR Definitions and Reset Values Bit Name 7 Aug. 03, 2020 WDTR Description WDT run This bit is valid only when control bits in WDTEN[3:0] (CONFIG4[7:4]) are all 1. At this time, WDT works as a general purpose timer. 0 = WDT Disabled. 1 = WDT Enabled. The WDT counter starts running. Page 117 of 274 Rev. 1.09 N76E003 Datasheet Bit Name Description 6 WDCLR WDT clear Setting this bit will reset the WDT count to 00H. It puts the counter in a known state and prohibit the system from unpredictable reset. The meaning of writing and reading WDCLR bit is different. Writing: 0 = No effect. 1 = Clearing WDT counter. Reading: 0 = WDT counter is completely cleared. 1 = WDT counter is not yet cleared. 5 WDTF WDT time-out flag This bit indicates an overflow of WDT counter. This flag should be cleared by software. 4 WIDPD WDT running in Idle or Power-down mode This bit is valid only when control bits in WDTEN[3:0] (CONFIG4[7:4]) are all 1. It decides whether WDT runs in Idle or Power-down mode when WDT works as a general purpose timer. 0 = WDT stops running during Idle or Power-down mode. 1 = WDT keeps running during Idle or Power-down mode. 3 WDTRF WDT reset flag When the CPU is reset by WDT time-out event, this bit will be set via hardware. This flag is recommended to be cleared via software after reset. WDT clock pre-scalar select These bits determine the pre-scale of WDT clock from 1/1 through 1/256. See Note: When register CKDIV value is not equal 00H, the system clock frequency will be divided, if under this condition after MCU into power down mode, the WDT Reset will fail. So suggest use WKT to wakeup N76E003 when into power down mode. Table 11-1. The default is the maximum pre-scale value. [1] WDTRF will be cleared after power-on reset, be set after WDT reset, and remains unchanged after any other resets. [2] WDPS[2:0] are all set after power-on reset and keep unchanged after any reset other than power-on reset. 2:0 WDPS[2:0] The Watchdog time-out interval is determined by the formula 1 × 64 , where FLIRC is FLIRC × clock dividerscalar the frequency of internal 10 kHz oscillator. The following table shows an example of the Watchdog time-out interval with different pre-scales. Note: When register CKDIV value is not equal 00H, the system clock frequency will be divided, if under this condition after MCU into power down mode, the WDT Reset will fail. So suggest use WKT to wakeup N76E003 when into power down mode. Aug. 03, 2020 Page 118 of 274 Rev. 1.09 N76E003 Datasheet Table 11-1. Watchdog Timer-out Interval Under Different Pre-scalars Clock Divider Scale Watchdog Time-out Interval (FLIRC ~= 10 kHz) WDPS.2 WDPS.1 WDPS.0 0 0 0 1/1 6.40 ms 0 0 1 1/4 25.60 ms 0 1 0 1/8 51.20 ms 0 1 1 1/16 102.40 ms 1 0 0 1/32 204.80 ms 1 0 1 1/64 409.60 ms 1 1 0 1/128 819.20 ms 1 1 1 1/256 1.638 s 11.1 Time-Out Reset Timer When the CONFIG bits WDTEN[3:0] (CONFIG4[7:4]) is not FH, the WDT is initialized as a time-out reset timer. If WDTEN[3:0] is not 5H, the WDT is allowed to continue running after the system enters Idle or Power-down mode. Note that when WDT is initialized as a time-out reset timer, WDTR and WIDPD has no function. 10 kHz Internal Oscillator FLIRC Pre-scalar (1/1~1/256) WDT counter (6-bit) overflow 512-clock Delay clear WDPS[2:0] WDTRF WDT Reset clear WDCLR WDTF WDT Interrupt Figure 11.1-1. WDT as A Time-Out Reset Timer After the device is powered and it starts to execute software code, the WDT starts counting simultaneously. The time-out interval is selected by the three bits WDPS[2:0] (WDCON[2:0]). When the selected time-out occurs, the WDT will set the interrupt flag WDTF (WDCON.5). If the WDT interrupt enable bit EWDT (EIE.4) and global interrupt enable EA are both set, the WDT interrupt routine will be executed. Meanwhile, an additional 512 clocks of the low-speed internal oscillator delays to expect a counter clearing by setting WDCLR to avoid the system reset by WDT if the device operates normally. If no counter reset by writing 1 to WDCLR during this 512-clock period, a WDT reset will happen. Setting WDCLR bit is used to clear the counter of the WDT. This bit is self-cleared for user monitoring it. Once a reset due to WDT occurs, the WDT reset flag WDTRF (WDCON.3) will be set. This bit keeps unchanged after any reset other than a power-on reset. User may clear WDTRF via software. Note that all bits in WDCON require timed access writing. Aug. 03, 2020 Page 119 of 274 Rev. 1.09 N76E003 Datasheet NOTICE: WDT counter has been specially taken care. The hardware automatically clears WDT counter and pre-scalar value after : (1) Entering into or being woken-up from Idle or Power Down mode (2) Any resets. It prevents unconscious system reset. The main application of the WDT with time-out reset enabling is for the system monitor. This is important in real-time control applications. In case of some power glitches or electro-magnetic interference, CPU may begin to execute erroneous codes and operate in an unpredictable state. If this is left unchecked the entire system may crash. Using the WD during software development requires user to select proper “Feeding Dog” time by clearing the WDT counter. By inserting the instruction of setting WDCLR, it allows the code to run without any WDT reset. However If any erroneous code executes by any interference, the instructions to clear the WDT counter will not be executed at the required instants. Thus the WDT reset will occur to reset the system state from an erroneously executing condition and recover the system. 11.2 General Purpose Timer There is another application of the WDT, which is used as a simple, long period timer. When the CONFIG bits WDTEN[3:0] (CONFIG4[7:4]) is FH, the WDT is initialized as a general purpose timer. In this mode, WDTR and WIDPD are fully accessed via software. 10 kHz Internal Oscillator Pre-scalar (1/1~1/256) WDT counter (6-bit) overflow WDTF WDT Interrupt clear IDL (PCON.0) PD (PCON.1) WIDPD FLIRC WDPS[2:0] WDCLR WDTR Figure 11.2-1. Watchdog Timer Block Diagram The WDT starts running by setting WDTR as 1 and halts by clearing WDTR as 0. The WDTF flag will be set while the WDT completes the selected time interval. The software polls the WDTF flag to detect a time-out. An interrupt will occur if the individual interrupt EWDT (EIE.4) and global interrupt enable EA is set. WDT will continue counting. User should clear WDTF and wait for the next overflow by polling WDTF flag or waiting for the interrupt occurrence. In some application of low power consumption, the CPU usually stays in Idle mode when nothing needs to be served to save power consumption. After a while the CPU will be woken up to check if anything needs to be served at an interval of programmed period implemented by Timer 0~3. However, the current consumption of dle mode still keeps at a “ mA” level. o further reducing the current consumption to “mA” level, the PU should stay in Power-down mode when nothing needs to be served, and has the ability of waking up at a programmable interval. The N76E003 is equipped with this useful function by WDT waking up. It provides a Aug. 03, 2020 Page 120 of 274 Rev. 1.09 N76E003 Datasheet very low power internal oscillator 10 kHz as the clock source of the WDT. It is also able to count under Powerdown mode and wake CPU up. The demo code to accomplish this feature is shown below. For Example: ORG LJMP 0000H START ORG LJMP 0053H WDT_ISR ORG 0100H ;******************************************************************** ;WDT interrupt service routine ;******************************************************************** WDT_ISR: CLR EA MOV TA,#0AAH MOV TA,#55H ANL WDCON,#11011111B ;clear WDT interrupt flag SETB EA RETI ;******************************************************************** ;Start here ;******************************************************************** START: MOV TA,#0AAH MOV TA,#55H ORL WDCON,#00010111B ;choose interval length and enable WDT running during ;Power-down SETB EWDT ;enable WDT interrupt SETB EA MOV MOV ORL TA,#0AAH TA,#55H WDCON,#10000000B ; WDT run ;******************************************************************** ;Enter Power-down mode ;******************************************************************** LOOP: ORL PCON,#02H LJMP LOOP Aug. 03, 2020 Page 121 of 274 Rev. 1.09 N76E003 Datasheet 12. SELF WAKE-UP TIMER (WKT) The N76E003 has a dedicated Self Wake-up Timer (WKT), which serves for a periodic wake-up timer in low power mode or for general purpose timer. WKT remains counting in Idle or Power-down mode. When WKT is being used as a wake-up timer, a start of WKT can occur just prior to entering a power management mode. WKT has one clock source, internal 10 kHz. Note that the system clock frequency must be twice over WKT clock. If WKT starts counting, the selected clock source will remain active once the device enters Idle or Power-down mode. Note that the selected clock source of WKT will not automatically enabled along with WKT configuration. User should manually enable the selected clock source and waiting for stability to ensure a proper operation. The WKT is implemented simply as a 8-bit auto-reload, up-counting timer with pre-scale 1/1 to 1/2048 selected by WKPS[2:0] (WKCON[2:0]). User fills the reload value into RWK register to determine its overflow rate. The WKTR (WKCON.3) can be set to start counting. When the counter rolls over FFH, WKTF (WKCON.4) is set as 1 and a reload is generated and causes the contents of the RWK register to be reloaded into the internal 8-bit counter. If EWKT (EIE1.2) is set as 1, WKT interrupt service routine will be served. 10 kHz Internal Oscillator FLIRC Pre-scalar (1/1~1/2048) WKTCK (WKCON.5) WKTR (WKCON.3) Internal 8-bit Counter WKPS[2:0] (WKCON[2:0]) 0 WKT Overflow WKTF (WKCON.4) WKT Interrupt 7 RWK Figure 11.2-1. Self Wake Up Timer Block Diagram WKCON – Self Wake-up Timer Control 7 6 5 Address: 8FH Bit Name 5 - 4 WKTF Aug. 03, 2020 4 WKTF R/W 3 WKTR R/W 2 1 0 WKPS[2:0] R/W Reset value: 0000 0000b Description Reserved WKT overflow flag This bit is set when WKT overflows. If the WKT interrupt and the global interrupt are enabled, setting this bit will make CPU execute WKT interrupt service routine. This bit is not automatically cleared via hardware and should be cleared via software. Page 122 of 274 Rev. 1.09 N76E003 Datasheet Bit Name 3 WKTR 2:0 WKPS[2:0] Description WKT run control 0 = WKT is halted. 1 = WKT starts running. Note that the reload register RWK can only be written when WKT is halted (WKTR bit is 0). If WKT is written while WKTR is 1, result is unpredictable. WKT pre-scalar These bits determine the pre-scale of WKT clock. 000 = 1/1. 001 = 1/4. 010 = 1/16. 011 = 1/64. 100 = 1/256. 101 = 1/512. 110 = 1/1024. 111 = 1/2048. RWK – Self Wake-up Timer Reload Byte 7 6 5 4 3 2 1 0 RWK[7:0] R/W Address: 86H Reset value: 0000 0000b Bit Name 7:0 RWK[7:0] Aug. 03, 2020 Description WKT reload byte It holds the 8-bit reload value of WKT. Note that RWK should not be FFH if the pre-scale is 1/1 for implement limitation. Page 123 of 274 Rev. 1.09 N76E003 Datasheet 13. SERIAL PORT (UART) The N76E003 includes two enhanced full duplex serial ports enhanced with automatic address recognition and framing error detection. As control bits of these two serial ports are implemented the same, the bit names (including interrupt enabling or priority setting bits) end with “ _ ” (e.g. O _1) to indicate serial port 1 control bits for making a distinction between these two serial ports. Generally speaking, in the following contents, there will not be any reference to serial port 1, but only to serial port 0. Each serial port supports one synchronous communication mode, Mode 0, and three modes of full duplex UART (Universal Asynchronous Receiver and Transmitter), Mode 1, 2, and 3. This means it can transmit and receive simultaneously. The serial port is also receiving-buffered, meaning it can commence reception of a second byte before a previously received byte has been read from the register. The receiving and transmitting registers are both accessed at SBUF. Writing to SBUF loads the transmitting register, and reading SBUF accesses a physically separate receiving register. There are four operation modes in serial port. In all four modes, transmission initiates by any instruction that uses SBUF as a destination register. Note that before serial port function works, the port latch bits of P0.7 and P0.6 (for RXD and TXD pins) or P0.2 and P1.6 (for RXD_1 and TXD_1 pins) have to be set to 1. For application flexibility, TXD and RXD pins of serial port 0 can be exchanged by UART0PX (AUXR1.2). SCON – Serial Port Control (Bit-addressable) 7 6 5 4 SM0/FE SM1 SM2 REN R/W R/W R/W R/W Address: 98H Bit Name 7 SM0/FE 6 SM1 3 TB8 R/W 2 RB8 R/W 1 0 TI RI R/W R/W Reset value: 0000 0000b Description Serial port mode select SMOD0 (PCON.6) = 0: See Table 13-1. Serial Port 0 Mode Description for details. SMOD0 (PCON.6) = 1: SM0/FE bit is used as frame error (FE) status flag. It is cleared by software. 0 = Frame error (FE) did not occur. 1 = Frame error (FE) occurred and detected. Aug. 03, 2020 Page 124 of 274 Rev. 1.09 N76E003 Datasheet Bit Name 5 SM2 Description Multiprocessor communication mode enable The function of this bit is dependent on the serial port 0 mode. Mode 0: This bit select the baud rate between FSYS/12 and FSYS/2. 0 = The clock runs at FSYS/12 baud rate. It maintains standard 8051 compatibility. 1 = The clock runs at FSYS/2 baud rate for faster serial communication. Mode 1: This bit checks valid stop bit. 0 = Reception is always valid no matter the logic level of stop bit. 1 = Reception is valid only when the received stop bit is logic 1 and the received data matches “Given” or “Broadcast” address. Mode 2 or 3: For multiprocessor communication. th 0 = Reception is always valid no matter the logic level of the 9 bit. th 1 = Reception is valid only when the received 9 bit is logic 1 and the received data matches “Given” or “Broadcast” address. 4 REN Receiving enable 0 = Serial port 0 reception Disabled. 1 = Serial port 0 reception Enabled in Mode 1,2, or 3. In Mode 0, reception is initiated by the condition REN = 1 and RI = 0. 3 TB8 9 transmitted bit th This bit defines the state of the 9 transmission bit in serial port 0 Mode 2 or 3. It is not used in Mode 0 or 1. 2 RB8 9 received bit th The bit identifies the logic level of the 9 received bit in serial port 0 Mode 2 or 3. In Mode 1, RB8 is the logic level of the received stop bit. SM2 bit as logic 1 has restriction for exception. RB8 is not used in Mode 0. 1 TI Transmission interrupt flag This flag is set by hardware when a data frame has been transmitted by the serial th port 0 after the 8 bit in Mode 0 or the last data bit in other modes. When the serial port 0 interrupt is enabled, setting this bit causes the CPU to execute the serial port 0 interrupt service routine. This bit should be cleared manually via software. 0 RI Receiving interrupt flag This flag is set via hardware when a data frame has been received by the serial th port 0 after the 8 bit in Mode 0 or after sampling the stop bit in Mode 1, 2, or 3. SM2 bit as logic 1 has restriction for exception. When the serial port 0 interrupt is enabled, setting this bit causes the CPU to execute to the serial port 0 interrupt service routine. This bit should be cleared manually via software. Aug. 03, 2020 th th Page 125 of 274 Rev. 1.09 N76E003 Datasheet SCON_1 – Serial Port 1 Control (bit-addressable) 7 6 5 4 SM0_1/FE_1 SM1_1 SM2_1 REN_1 R/W R/W R/W R/W Address: F8H Bit Name 7 SM0_1/FE_1 6 SM1_1 3 TB8_1 R/W 2 RB8_1 R/W 1 0 TI_1 RI_1 R/W R/W Reset value: 0000 0000b Description Serial port 1 mode select SMOD0_1 (T3CON.6) = 0: See Table 13-2. Serial Port 1 Mode Description for details. SMOD0_1 (T3CON.6) = 1: SM0_1/FE_1 bit is used as frame error (FE) status flag. It is cleared by software. 0 = Frame error (FE) did not occur. 1 = Frame error (FE) occurred and detected. 5 SM2_1 Multiprocessor communication mode enable The function of this bit is dependent on the serial port 1 mode. Mode 0: No effect. Mode 1: This bit checks valid stop bit. 0 = Reception is always valid no matter the logic level of stop bit. 1 = Reception is valid only when the received stop bit is logic 1 and the received data matches “Given” or “Broadcast” address. Mode 2 or 3: For multiprocessor communication. th 0 = Reception is always valid no matter the logic level of the 9 bit. th 1 = Reception is valid only when the received 9 bit is logic 1 and the received data matches “Given” or “Broadcast” address. 4 REN_1 Receiving enable 0 = Serial port 1 reception Disabled. 1 = Serial port 1 reception Enabled in Mode 1,2, or 3. In Mode 0, reception is initiated by the condition REN_1 = 1 and RI_1 = 0. 3 TB8_1 9 transmitted bit th This bit defines the state of the 9 transmission bit in serial port 1 Mode 2 or 3. It is not used in Mode 0 or 1. 2 RB8_1 9 received bit th The bit identifies the logic level of the 9 received bit in serial port 1 Mode 2 or 3. In Mode 1, RB8_1 is the logic level of the received stop bit. SM2 _1 bit as logic 1 has restriction for exception. RB8_1 is not used in Mode 0. 1 TI_1 Transmission interrupt flag This flag is set by hardware when a data frame has been transmitted by the th serial port 1 after the 8 bit in Mode 0 or the last data bit in other modes. When the serial port 1 interrupt is enabled, setting this bit causes the CPU to execute the serial port 1 interrupt service routine. This bit must be cleared manually via software. Aug. 03, 2020 th th Page 126 of 274 Rev. 1.09 N76E003 Datasheet Bit Name Description 0 RI_1 Receiving interrupt flag This flag is set via hardware when a data frame has been received by the serial th port 1 after the 8 bit in Mode 0 or after sampling the stop bit in Mode 1, 2, or _ 3. SM2 1 bit as logic 1 has restriction for exception. When the serial port 1 interrupt is enabled, setting this bit causes the CPU to execute to the serial port 1 interrupt service routine. This bit must be cleared manually via software. PCON – Power Control 7 6 SMOD SMOD0 R/W R/W Address: 87H Bit Name 5 - 4 3 2 1 0 POF GF1 GF0 PD IDL R/W R/W R/W R/W R/W Reset value: see Table 6-2. SFR Definitions and Reset Values Description 7 SMOD Serial port 0 double baud rate enable Setting this bit doubles the serial port baud rate when UART0 is in Mode 2 or when Timer 1 overflow is used as the baud rate source of UART0 Mode 1 or 3. See Table 13-1. Serial Port 0 Mode Description for details. 6 SMOD0 Serial port 0 framing error flag access enable 0 = SCON.7 accesses to SM0 bit. 1 = SCON.7 accesses to FE bit. T3CON – Timer 3 Control 7 6 SMOD_1 SMOD0_1 R/W R/W Address: C4H, Page:0 5 BRCK R/W 4 TF3 R/W 3 TR3 R/W 2 1 0 T3PS[2:0] R/W Reset value: 0000 0000b Bit Name Description 7 SMOD_1 Serial port 1 double baud rate enable Setting this bit doubles the serial port baud rate when UART1 is in Mode 2. See Table 13-2. Serial Port 1 Mode Description for details. 6 SMOD0_1 Serial port 1 framing error access enable 0 = SCON_1.7 accesses to SM0_1 bit. 1 = SCON_1.7 accesses to FE_1 bit. Table 13-1. Serial Port 0 Mode Description Mode SM0 SM1 Description Frame Bits Baud Rate 0 0 0 Synchronous 8 FSYS divided by 12 or by 2[1] 1 0 1 Asynchronous 10 Timer 1/Timer 3 overflow rate divided by 32 or 16[2] 2 1 0 Asynchronous 11 FSYS divided by 32 or 64[2] 3 1 1 Asynchronous 11 Timer 1/Timer 3 overflow rate divided by 32 or 16[2] [1] While SM2 (SCON.5) is logic 1. [2] While SMOD (PCON.7) is logic 1. Aug. 03, 2020 Page 127 of 274 Rev. 1.09 N76E003 Datasheet Table 13-2. Serial Port 1 Mode Description Mode SM0 SM1 Description Frame Bits Baud Rate 0 0 0 Synchronous 8 FSYS divided by 12 or by 2[1] 1 0 1 Asynchronous 10 Timer 3 overflow rate divided by 16 2 1 0 Asynchronous 11 FSYS divided by 32 or 64[2] 3 1 1 Asynchronous 11 Timer 3 overflow rate divided by 16 [1] While SM2_1 (SCON_1.5) is logic 1. [2] While SMOD_1 (T3CON.7) is logic 1. SBUF – Serial Port 0 Data Buffer 7 6 5 4 3 2 1 0 SBUF[7:0] R/W Address: 99H Bit 7:0 Reset value: 0000 0000b Name Description SBUF[7:0] Serial port 0 data buffer This byte actually consists two separate registers. One is the receiving resister, and the other is the transmitting buffer. When data is moved to SBUF, it goes to the transmitting buffer and is shifted for serial transmission. When data is moved from SBUF, it comes from the receiving register. The transmission is initiated through giving data to SBUF. SBUF_1 – Serial Port 1 Data Buffer 7 6 5 4 3 _ SBUF 1[7:0] R/W Address: 9AH Bit 7:0 Aug. 03, 2020 2 1 0 Reset value: 0000 0000b Name Description SBUF_1[7:0] Serial port 1 data buffer This byte actually consists two separate registers. One is the receiving resister, and the other is the transmitting buffer. When data is moved to SBUF_1, it goes to the transmitting buffer and is shifted for serial transmission. When data is moved from SBUF_1, it comes from the receiving register. The transmission is initiated through giving data to SBUF_1. Page 128 of 274 Rev. 1.09 N76E003 Datasheet AUXR1 – Auxiliary Register 1 7 6 5 SWRF RSTPINF HardF R/W R/W R/W Address: A2H Bit 2 4 3 2 1 0 GF2 UART0PX 0 DPS R/W R/W R R/W Reset value: see Table 6-2. SFR Definitions and Reset Values Name Description UART0PX Serial port 0 pin exchange 0 = Assign RXD to P0.7 and TXD to P0.6 by default. 1 = Exchange RXD to P0.6 and TXD to P0.7. Note that TXD and RXD will exchange immediately once setting or clearing this bit. User should take care of not exchanging pins during transmission or receiving. Or it may cause unpredictable situation and no warning alarms. 13.1 Mode 0 Mode 0 provides synchronous communication with external devices. Serial data enters and exits through RXD pin. TXD outputs the shift clocks. 8-bit frame of data are transmitted or received. Mode 0 therefore provides half-duplex communication because the transmitting or receiving data is via the same data line RXD. The baud rate is enhanced to be selected as FSYS/12 if SM2 (SCON.5) is 0 or as FSYS/2 if SM2 is 1. Note that whenever transmitting or receiving, the serial clock is always generated by the MCU. Thus any device on the serial port in Mode 0 should accept the MCU as the master. Figure 13.1-1 shows the associated timing of the serial port in Mode 0. Figure 13.1-1. Serial Port Mode 0 Timing Diagram Aug. 03, 2020 Page 129 of 274 Rev. 1.09 N76E003 Datasheet As shown there is one bi-directional data line (RXD) and one shift clock line (TXD). The shift clocks are used to shift data in or out of the serial port controller bit by bit for a serial communication. Data bits enter or emit LSB first. The band rate is equal to the shift clock frequency. Transmission is initiated by any instruction writes to SBUF. The control block will then shift out the clocks and begin to transfer data until all 8 bits are complete. Then the transmitted flag TI (SCON.1) will be set 1 to indicate one byte transmitting complete. Reception is initiated by the condition REN (SCON.4) = 1 and RI (SCON.0) = 0. This condition tells the serial port controller that there is data to be shifted in. This process will continue until 8 bits have been received. Then the received flag RI will be set as 1. User can clear RI to triggering the next byte reception. 13.2 Mode 1 Mode 1 supports asynchronous, full duplex serial communication. The asynchronous mode is commonly used for communication with PCs, modems or other similar interfaces. In Mode 1, 10 bits are transmitted through TXD or received through RXD including a start bit (logic 0), 8 data bits (LSB first) and a stop bit (logic 1). The baud rate is determined by the Timer 1. SMOD (PCON.7) setting 1 makes the baud rate double. Figure 13.2-1 shows the associated timings of the serial port in Mode 1 for transmitting and receiving. Figure 13.2-1. Serial Port Mode 1 Timing Diagram Transmission is initiated by any writing instructions to SBUF. Transmission takes place on TXD pin. First the start bit comes out, the 8-bit data follows to be shifted out and then ends with a stop bit. After the stop bit appears, TI (SCON.1) will be set to indicate one byte transmission complete. All bits are shifted out depending on the rate determined by the baud rate generator. Aug. 03, 2020 Page 130 of 274 Rev. 1.09 N76E003 Datasheet Once the baud rate generator is activated and REN (SCON.4) is 1, the reception can begin at any time. Reception is initiated by a detected 1-to-0 transition at RXD. Data will be sampled and shifted in at the selected baud rate. In the midst of the stop bit, certain conditions should be met to load SBUF with the received data: 1. RI (SCON.0) = 0, and 2. Either SM2 (SCON.5) = 0, or the received stop bit = while = and the received data matches “Given” or “Broadcast” address. (For enhancement function, see 13.7 “Multiprocessor Communication” and 13.8 “Automatic Address Recognition”.) If these conditions are met, then the SBUF will be loaded with the received data, the RB8 (SCON.2) with stop bit, and RI will be set. If these conditions fail, there will be no data loaded and RI will remain 0. After above receiving progress, the serial control will look forward another 1-to-0 transition on RXD pin to start next data reception. 13.3 Mode 2 Mode 2 supports asynchronous, full duplex serial communication. Different from Mode1, there are 11 bits to be th transmitted or received. They are a start bit (logic 0), 8 data bits (LSB first), a programmable 9 bit TB8 or RB8 th bit and a stop bit (logic 1). The most common use of 9 bit is to put the parity bit in it or to label address or data frame for multiprocessor communication. The baud rate is fixed as 1/32 or 1/64 the system clock frequency depending on SMOD (PCON.7) bit. Figure 13.3-1 shows the associated timings of the serial port in Mode 2 for transmitting and receiving. Figure 13.3-1. Serial Port Mode 2 and 3 Timing Diagram Aug. 03, 2020 Page 131 of 274 Rev. 1.09 N76E003 Datasheet Transmission is initiated by any writing instructions to SBUF. Transmission takes place on TXD pin. First the start bit comes out, the 8-bit data and bit TB8 (SCON.3) follows to be shifted out and then ends with a stop bit. After the stop bit appears, TI will be set to indicate the transmission complete. While REN is set, the reception is allowed at any time. A falling edge of a start bit on RXD will initiate the reception progress. Data will be sampled and shifted in at the selected baud rate. In the midst of the stop bit, certain conditions should be met to load SBUF with the received data: 1. RI (SCON.0) = 0, and th 2. Either SM2 (SCON.5) = 0, or the received 9 bit = while = and the received data matches “Given” or “Broadcast” address. (For enhancement function, see 13.7 “Multiprocessor Communication” and 13.8 “Automatic Address Recognition”.) If these conditions are met, the SBUF will be loaded with the received data, the RB8(SCON.2) with the th received 9 bit and RI will be set. If these conditions fail, there will be no data loaded and RI will remain 0. After above receiving progress, the serial control will look forward another 1-to-0 transition on RXD pin to start next data reception. 13.4 Mode 3 Mode 3 has the same operation as Mode 2, except its baud rate clock source uses Timer 1 overflows as its baud rate clocks. See Figure 13.3-1 for timing diagram of Mode 3. It has no difference from Mode 2. 13.5 Baud Rate The baud rate source and speed for different modes of serial port is quite different from one another. All cases are listed in Table 13-3. The user should calculate the baud rate according to their system configuration. In Mode 1 or 3, the baud rate clock source of UART0 can be selected from Timer 1 or Timer 3. User can select the baud rate clock source by BRCK (T3CON.5). For UART1, its baud rate clock comes only from Timer 3 as its unique clock source. Aug. 03, 2020 Page 132 of 274 Rev. 1.09 N76E003 Datasheet T3CON – Timer 3 Control 7 6 SMOD_1 SMOD0_1 R/W R/W Address: C4H, Page:0 Bit Name 5 BRCK 5 BRCK R/W 4 TF3 R/W 3 TR3 R/W 2 1 0 T3PS[2:0] R/W Reset value: 0000 0000b Description Serial port 0 baud rate clock source This bit selects which Timer is used as the baud rate clock source when serial port 0 is in Mode 1 or 3. 0 = Timer 1. 1 = Timer 3. When using Timer 1 as the baud rate clock source, note that the Timer 1 interrupt should be disabled. Timer 1 itself can be configured for either “ imer” or “ ounter” operation. t can be in any of its three running modes. However, in the most typical applications, it is configured for “ imer” operation, in the auto-reload mode (Mode 2). If using Timer 3 as the baud rate generator, its interrupt should also be disabled. Aug. 03, 2020 Page 133 of 274 Rev. 1.09 N76E003 Datasheet Table 13-3. UART Baud Rate Formulas UART Mode Baud Rate Clock Source Formula Number Baud Rate 0 System clock FSYS / 12 or FSYS / 2 [1] 1 2 System clock FSYS / 64 or FSYS / 32 [2] 2 F 2SMOD FSYS 2SMOD  SYS [4] or  32 256 - TH1 32 12  256 - TH1 3 Timer 3 (for UART0) FSYS 2SMOD  32 Pre - scale  65536 - {RH3,RL3}  [5] 4 Timer 3 (for UART1) FSYS 1 [5]  16 Pre - scale  65536 - {RH3,RL3}  5 Timer 1 (only for UART0) 1 or 3 [3] [1] SM2 (SCON.5) or SM2_1(SCON_1.5) is set as logic 1. [2] SMOD (PCON.7) or SMOD_1(T3CON.7) is set as logic 1. [3] Timer 1 is configured as a timer in auto-reload mode (Mode 2). [4] T1M (CKCON.4) is set as logic 1. While SMOD is 1, TH1 should not be FFH. [5] {RH3,RL3} in the formula means 256 × RH3 + RL3 . While SMOD is 1 and pre-scale is 1/1, {RH3,RL3} should not be FFFFH. Important: Since the limitation of baud rate generator, Suggest setting baud rate under 38400 when system timer base 16MHz HIRC value. Following show the baud rate value table show the deviation upper 38400 baud rate. HIRC Target Baud Rate 2400 RHx RLx 0x5F RHx + RLx DEC Value 65119 Actual Baud Rate 2398.081535 0Xfe 4800 0Xff 0x30 65328 4807.692308 -0.160% 9600 0Xff 0x98 65432 9615.384615 -0.160% 19200 0Xff 0Xcc 65484 19230.76923 -0.160% 38400 0Xff 0Xe6 65510 38461.53846 -0.160% 57600 0Xff 0Xef 65519 58823.52941 -2.124% 115200 0Xff 0Xf7 65527 111111.1111 3.549% 16MHz Error % 0.079% NOTE: RHx and RLx setting value base on baud rate formula 4 (SMOD =1) or 5 . But In most application the baud rate 115200 is a common setting value. So we provide a special function to modify HIRC to 16.6MHz. then the deviation of baud rate will be reasonable. Following table shows the error value when HIRC and timer base modified. HIRC Target Baud Rate Aug. 03, 2020 RHx RLx RHx + RLx DEC Value Page 134 of 274 Actual Baud Rate Error % Rev. 1.09 N76E003 Datasheet 2400 0Xfe 0x50 65104 2401.62037 -0.067% 4800 0Xff 0x28 65320 4803.240741 -0.067% 9600 0Xff 0x94 65428 9606.481481 -0.067% 19200 0Xff 0Xca 65482 19212.96296 -0.067% 38400 0Xff 0Xe5 65509 38425.92593 -0.067% 57600 0Xff 0Xee 65518 57638.88889 -0.067% 115200 0Xff 0Xf7 65527 115277.7778 -0.067% 16.6MHz NOTE: RHx and RLx setting value base on baud rate formula 4 (SMOD =1) or 5 N76E003 provide two bytes SFR to user trim HIRC value, default after reset the value is trim to 16MHz, once modify this SFR, the HIRC value will change. Suggest decrease reset value 15(dec.) will trim HIRC to 16.6MHz. Following two Byte combine the 9 bit internal RC trim value. Each bit deviation is 0.25% of 16MHz that means about 40KHz / bit. RCTRIM0 –High Speed Internal Oscillator 16 MHz Trim 0 7 6 5 4 3 HIRCTRIM[8:1] R/W Address: 84H RCTRIM1 –High Speed Internal Oscillator 16 MHz Trim 1 7 6 5 4 3 Address: 85H 2 1 0 Reset value: 16MHz HIRC value 2 - 1 0 HIRCTRIM.0 R/W Reset value: 16MHz HIRC value Following is the demo code to modify HIRC to 16.6MHz, sfr RCTRIM0 sfr RCTRIM1 = 0x84; = 0x85; void MODIFY_HIRC_166(void) { unsigned char hircmap0,hircmap1; unsigned int trimvalue16bit; /* Since only power on will reload RCTRIM0 and RCTRIM1 value, check power on flag*/ if ((PCON&SET_BIT4)==SET_BIT4) { hircmap0 = RCTRIM0; hircmap1 = RCTRIM1; trimvalue16bit = ((hircmap01; TA=0XAA; Aug. 03, 2020 Page 135 of 274 Rev. 1.09 N76E003 Datasheet TA=0X55; RCTRIM0 = hircmap0; TA=0XAA; TA=0X55; RCTRIM1 = hircmap1; /* After modify HIRC value, clear power on flag */ PCON &= CLR_BIT4; } } 13.6 Framing Error Detection Framing error detection is provided for asynchronous modes. (Mode 1, 2, or 3.) The framing error occurs when a valid stop bit is not detected due to the bus noise or contention. The UART can detect a framing error and notify the software. The framing error bit, FE, is located in SCON.7. This bit normally serves as SM0. While the framing error accessing enable bit SMOD0 (PCON.6) is set 1, it serves as FE flag. Actually, SM0 and FE locate in different registers. The FE bit will be set 1 via hardware while a framing error occurs. FE can be checked in UART interrupt service routine if necessary. Note that SMOD0 should be 1 while reading or writing to FE. If FE is set, any following frames received without frame error will not clear the FE flag. The clearing has to be done via software. 13.7 Multiprocessor Communication The N76E003 multiprocessor communication feature lets a master device send a multiple frame serial message to a slave device in a multi-slave configuration. It does this without interrupting other slave devices that may be on the same serial line. This feature can be used only in UART Mode 2 or 3. User can enable this function by setting SM2 (SCON.5) as logic 1 so that when a byte of frame is received, the serial interrupt will th th be generated only if the 9 bit is 1. (For Mode 2, the 9 bit is the stop bit.) When the SM2 bit is 1, serial data frames that are received with the 9 th bit as 0 do not generate an interrupt. In this case, the 9 th bit simply separates the slave address from the serial data. When the master device wants to transmit a block of data to one of several slaves on a serial line, it first sends out an address byte to identify the target slave. Note that in this case, an address byte differs from a data byte. th In an address byte, the 9 bit is 1 and in a data byte, it is 0. The address byte interrupts all slaves so that each slave can examine the received byte and see if it is addressed by its own slave address. The addressed slave then clears its SM2 bit and prepares to receive incoming data bytes. The SM2 bits of slaves that were not addressed remain set, and they continue operating normally while ignoring the incoming data bytes. Aug. 03, 2020 Page 136 of 274 Rev. 1.09 N76E003 Datasheet Follow the steps below to configure multiprocessor communications: 1. Set all devices (masters and slaves) to UART Mode 2 or 3. 2. Write the SM2 bit of all the slave devices to 1. 3. he master device’s transmission protocol is: th – First byte: the address, identifying the target slave device, (9 bit = 1). th – Next bytes: data, (9 bit = 0). th 4. When the target slave receives the first byte, all of the slaves are interrupted because the 9 data bit is 1. The targeted slave compares the address byte to its own address and then clears its SM2 bit to receiving incoming data. The other slaves continue operating normally. 5. After all data bytes have been received, set SM2 back to 1 to wait for next address. SM2 has no effect in Mode 0, and in Mode 1 can be used to check the validity of the stop bit. For Mode 1 reception, if SM2 is 1, the receiving interrupt will not be issue unless a valid stop bit is received. 13.8 Automatic Address Recognition The automatic address recognition is a feature, which enhances the multiprocessor communication feature by allowing the UART to recognize certain addresses in the serial bit stream by using hardware to make the comparisons. This feature saves a great deal of software overhead by eliminating the need for the software to examine every serial address, which passes by the serial port. Only when the serial port recognizes its own address, the receiver sets RI bit to request an interrupt. The automatic address recognition feature is enabled when the multiprocessor communication feature is enabled, SM2 is set. If desired, user may enable the automatic address recognition feature in Mode 1. In this configuration, the stop bit takes the place of the ninth data bit. RI is set only when the received command frame address matches the device’s address and is terminated by a valid stop bit. Using the automatic address recognition feature allows a master to selectively communicate with one or more slaves by invoking the “Given” slave address or addresses. All of the slaves may be contacted by using the “Broadcast” address. Two SFRs are used to define the slave address, SADDR, and the slave address mask, ADE . ADE is used to define which bits in the ADD are to be used and which bits are “don’t care”. he SADEN mask can be logically ANDed with the SADDR to create the “Given” address, which the master will use for addressing each of the slaves. Use of the “Given” address allows multiple slaves to be recognized while excluding others. Aug. 03, 2020 Page 137 of 274 Rev. 1.09 N76E003 Datasheet SADDR – Slave 0 Address 7 6 5 4 3 2 1 0 SADDR[7:0] R/W Address: A9H Bit 7:0 Reset value: 0000 0000b Name Description SADDR[7:0] Slave 0 address his byte specifies the microcontroller’s own slave address for UA processor communication. SADEN – Slave 0 Address Mask 7 6 5 4 3 2 multi- 1 0 SADEN[7:0] R/W Address: B9H Bit 7:0 Reset value: 0000 0000b Name Description SADEN[7:0] Slave 0 address mask This byte is a mask byte of UART0 that contains “don’t-care” bits (defined by zeros) to form the device’s “Given” address. The don’t-care bits provide the flexibility to address one or more slaves at a time. SADDR_1 – Slave 1 Address 7 6 5 4 3 SADDR_1[7:0] R/W 2 Address: BBH Bit 7:0 Name Description SADDR_1[7:0] Slave 1 address his byte specifies the microcontroller’s own slave address for UART1 multiprocessor communication. 4 3 SADEN_1[7:0] R/W Address: BAH 7:0 0 Reset value: 0000 0000b SADEN_1 – Slave 1 Address Mask 7 6 5 Bit 1 2 1 0 Reset value: 0000 0000b Name Description SADEN_1[7:0] Slave 1 address mask This byte is a mask byte of UART1 that contains “don’t-care” bits (defined by zeros) to form the device’s “Given” address. The don’t-care bits provide the flexibility to address one or more slaves at a time. The following examples will help to show the versatility of this scheme. Aug. 03, 2020 Page 138 of 274 Rev. 1.09 N76E003 Datasheet Example 1, slave 0: SADDR = 11000000b SADEN = 11111101b Given = 110000X0b Example 2, slave 1: SADDR = 11000000b SADEN = 11111110b Given = 1100000Xb In the above example SADDR is the same and the SADEN data is used to differentiate between the two slaves. Slave 0 requires 0 in bit 0 and it ignores bit 1. Slave 1 requires 0 in bit 1 and bit 0 is ignored. A unique address for Slave 0 would be 1100 0010 since slave 1 requires 0 in bit 1. A unique address for slave 1 would be 11000001b since 1 in bit 0 will exclude slave 0. Both slaves can be selected at the same time by an address, which has bit 0 = 0 (for slave 0) and bit 1 = 0 (for slave 1). Thus, both could be addressed with b as their “Broadcast” address. In a more complex system the following could be used to select slaves 1 and 2 while excluding slave 0: Example 1, slave 0: SADDR = 11000000b SADEN = 11111001b Given = 11000XX0b Example 2, slave 1: SADDR = 11100000b SADEN = 11111010b Given = 11100X0Xb Example 3, slave 2: SADDR = 11000000b SADEN = 11111100b Given = 110000XXb In the above example the differentiation among the 3 slaves is in the lower 3 address bits. Slave 0 requires that bit 0 = 0 and it can be uniquely addressed by 11100110b. Slave 1 requires that bit 1 = 0 and it can be uniquely addressed by 11100101b. Slave 2 requires that bit 2 = 0 and its unique address is 11100011b. To select Slaves 0 and 1 and exclude Slave 2 use address 11100100b, since it is necessary to make bit 2 = 1 to exclude slave 2. he “Broadcast” address for each slave is created by taking the logical OR of SADDR and SADEN. Zeros in this result are treated as “don’t-cares”, e.g.: Aug. 03, 2020 Page 139 of 274 Rev. 1.09 N76E003 Datasheet SADDR = 01010110b SADEN = 11111100b Broadcast = 1111111Xb he use of don’t-care bits provides flexibility in defining the Broadcast address, however in most applications, interpreting the “don’t-cares” as all ones, the broadcast address will be FFH. On reset, ADD and ADE are initialized to H. his produces a “Given” address of all “don’t cares” as well as a “Broadcast” address of all XXXXXXXXb (all “don’t care” bits). his ensures that the serial port will reply to any address, and so that it is backwards compatible with the standard 80C51 microcontrollers that do not support automatic address recognition. Aug. 03, 2020 Page 140 of 274 Rev. 1.09 N76E003 Datasheet 14. SERIAL PERIPHERAL INTERFACE (SPI) The N76E003 provides a Serial Peripheral Interface (SPI) block to support high-speed serial communication. SPI is a full-duplex, high-speed, synchronous communication bus between microcontrollers or other peripheral devices such as serial EEPROM, LCD driver, or D/A converter. It provides either Master or Slave mode, highspeed rate up to FSYS/2, transfer complete and write collision flag. For a multi-master system, SPI supports Master Mode Fault to protect a multi-master conflict. 14.1 Functional Description FSYS S M MSB MOSI CLOCK SPR0 SPR1 M S Write Data Buffer 8-bit Shift Register Read Data Buffer Select MISO LSB Pin Contorl Logic Divider /2, /4, /8, /16 Clock Logic SPCLK SSOE DISMODF MSTR SPIEN SS MSTR SPI Status Register SPI Interrupt SPR0 SPR1 CPOL CPHA LSBFE MSTR SSOE SPIEN DISMODF SPIOVF MODF WCOL SPIF SPI Status Control Logic SPIEN SPI Control Register Internal Data Bus Figure 14.1-1. SPI Block Diagram Figure 14.1-1. SPI Block Diagram shows SPI block diagram. It provides an overview of SPI architecture in this device. The main blocks of SPI are the SPI control register logic, SPI status logic, clock rate control logic, and pin control logic. For a serial data transfer or receiving, The SPI block exists a write data buffer, a shift out register and a read data buffer. It is double buffered in the receiving and transmit directions. Transmit data can Aug. 03, 2020 Page 141 of 274 Rev. 1.09 N76E003 Datasheet be written to the shifter until when the previous transfer is not complete. Receiving logic consists of parallel read data buffer so the shift register is free to accept a second data, as the first received data will be transferred to the read data buffer. The four pins of SPI interface are Master-In/Slave-Out (MISO), Master-Out/Slave-In (MOSI), Shift Clock (SPCLK), and Slave Select (̅̅̅̅). The MOSI pin is used to transfer a 8-bit data in series from the Master to the Slave. Therefore, MOSI is an output pin for Master device and an input for Slave. Respectively, the MISO is used to receive a serial data from the Slave to the Master. The SPCLK pin is the clock output in Master mode, but is the clock input in Slave mode. The shift clock is used to synchronize the data movement both in and out of the devices through their MOSI and MISO pins. The shift clock is driven by the Master mode device for eight clock cycles. Eight clocks exchange one byte data on the serial lines. For the shift clock is always produced out of the Master device, the system should never exist more than one device in Master mode for avoiding device conflict. Each Slave peripheral is selected by one Slave Select pin ( ̅̅̅̅). The signal should stay low for any Slave access. When ̅̅̅̅ is driven high, the Slave device will be inactivated. If the system is multi-slave, there should be only one Slave device selected at the same time. In the Master mode MCU, the ̅̅̅̅ pin does not function and it can be configured as a general purpose I/O. However, ̅̅̅̅ can be used as Master Mode Fault detection (see Section 14.5 “Mode Fault Detection” on page 150) via software setting if multi-master environment exists. The N76E003 also provides auto-activating function to toggle ̅̅̅̅ between each byte-transfer. Master/Slave MCU1 Master/Slave MCU2 MISO MISO MOSI MOSI SPCLK Slave device 1 Slave device 2 I/O PORT SO SI SCK SS SO SI SCK SS 0 1 2 3 SO 0 1 2 3 SI SS SCK SS SS I/O PORT SPCLK Slave device 3 Figure 14.1-2. SPI Multi-Master, Multi-Slave Interconnection Figure 14.1-2 shows a typical interconnection of SPI devices. The bus generally connects devices together through three signal wires, MOSI to MOSI, MISO to MISO, and SPCLK to SPCLK. The Master devices select Aug. 03, 2020 Page 142 of 274 Rev. 1.09 N76E003 Datasheet the individual Slave devices by using four pins of a parallel port to control the four ̅̅̅̅ pins. MCU1 and MCU2 play either Master or Slave mode. The ̅̅̅̅ should be configured as Master Mode Fault detection to avoid multimaster conflict. MOSI MOSI MISO MISO SPI shift register 7 6 5 4 3 2 1 0 SPI shift register 7 6 5 4 3 2 1 0 SPCLK SPCLK SPI clock generator SS Master MCU * SS GND Slave MCU * SS configuration follows DISMODF and SSOE bits. Figure 14.1-3. SPI Single-Master, Single-Slave Interconnection Figure 14.1-3 shows the simplest SPI system interconnection, single-master and signal-slave. During a transfer, the Master shifts data out to the Slave via MOSI line. While simultaneously, the Master shifts data in from the Slave via MISO line. The two shift registers in the Master MCU and the Slave MCU can be considered as one 16-bit circular shift register. Therefore, while a transfer data pushed from Master into Slave, the data in Slave will also be pulled in Master device respectively. The transfer effectively exchanges the data, which was in the SPI shift registers of the two MCUs. By default, SPI data is transferred MSB first. If the LSBFE (SPCR.5) is set, SPI data shifts LSB first. This bit does not affect the position of the MSB and LSB in the data register. Note that all the following description and figures are under the condition of LSBFE logic 0. MSB is transmitted and received first. There are three SPI registers to support its operations, including SPI control register (SPCR), SPI status register (SPSR), and SPI data register (SPDR). These registers provide control, status, data storage functions, and clock rate selection. The following registers relate to SPI function. Aug. 03, 2020 Page 143 of 274 Rev. 1.09 N76E003 Datasheet SPCR – Serial Peripheral Control Register 7 6 5 4 SSOE SPIEN LSBFE MSTR R/W R/W R/W R/W Address: F3H, page 0 Bit Name 3 CPOL R/W 2 CPHA R/W 1 0 SPR1 SPR0 R/W R/W Reset value: 0000 0000b Description 7 SSOE Slave select output enable This bit is used in combination with the DISMODF (SPSR.3) bit to determine the feature of ̅̅̅̅ pin as shown in Table 14-1. Slave Select Pin Configurations. This bit takes effect only under MSTR = 1 and DISMODF = 1 condition. 0 = ̅̅̅̅ functions as a general purpose I/O pin. 1 = ̅̅̅̅ automatically goes low for each transmission when selecting external Slave device and goes high during each idle state to de-select the Slave device. 6 SPIEN SPI enable 0 = SPI function Disabled. 1 = SPI function Enabled. 5 LSBFE LSB first enable 0 = The SPI data is transferred MSB first. 1 = The SPI data is transferred LSB first. 4 MSTR Master mode enable This bit switches the SPI operating between Master and Slave modes. 0 = The SPI is configured as Slave mode. 1 = The SPI is configured as Master mode. 3 CPOL SPI clock polarity select CPOL bit determines the idle state level of the SPI clock. See Figure 14.3-1. SPI Clock Formats. 0 = The SPI clock is low in idle state. 1 = The SPI clock is high in idle state. 2 CPHA SPI clock phase select CPHA bit determines the data sampling edge of the SPI clock. See Figure 14.3-1. SPI Clock Formats. 0 = The data is sampled on the first edge of the SPI clock. 1 = The data is sampled on the second edge of the SPI clock. Aug. 03, 2020 Page 144 of 274 Rev. 1.09 N76E003 Datasheet Bit 1:0 Name Description SPR[1:0] SPI clock rate select These two bits select four grades of SPI clock divider. The clock rates below are illustrated under FSYS = 16 MHz condition. SPR1 0 0 1 1 SPR0 0 1 0 1 Divider 2 4 8 16 SPI clock rate 8M bit/s 4M bit/s 2M bit/s 1M bit/s SPR[1:0] are valid only under Master mode (MSTR = 1). If under Slave mode, the clock will automatically synchronize with the external clock on SPICLK pin from Master device up to FSYS/2 communication speed. SPCR2 – Serial Peripheral Control Register 2 7 6 5 4 Address: F3H, page 1 Bit Name 7:2 - 1:0 SPIS[1:0] 3 - 2 - 1 0 SPIS1 SPIS0 R/W R/W Reset value: 0000 0000b Description Reserved SPI Interval time selection between adjacent bytes SPIS[1:0] and CPHA select eight grades of SPI interval time selection between adjacent bytes. As below table: CPHA 0 0 0 0 1 1 1 1 SPIS1 0 0 1 1 0 0 1 1 SPIS0 0 1 0 1 0 1 0 1 SPI clock 0.5 1.0 1.5 2.0 1.0 1.5 2.0 2.5 SPIS[1:0] are valid only under Master mode (MSTR = 1). Aug. 03, 2020 Page 145 of 274 Rev. 1.09 N76E003 Datasheet Table 14-1. Slave Select Pin Configurations DISMODF SSOE Master Mode (MSTR = 1) 0 X ̅̅̅̅ input for Mode Fault 1 0 General purpose I/O 1 1 Automatic ̅̅̅̅ output Slave Mode (MSTR = 0) ̅̅̅̅ Input for Slave select SPSR – Serial Peripheral Status Register 7 6 5 4 SPIF WCOL SPIOVF MODF R/W R/W R/W R/W Address: F4H Bit Name 3 DISMODF R/W 2 TXBUF R 1 0 Reset value: 0000 0000b Description 7 SPIF SPI complete flag This bit is set to logic 1 via hardware while an SPI data transfer is complete or an receiving data has been moved into the SPI read buffer. If ESPI (EIE .0) and EA are enabled, an SPI interrupt will be required. This bit should be cleared via software. Attempting to write to SPDR is inhibited if SPIF is set. 6 WCOL Write collision error flag This bit indicates a write collision event. Once a write collision event occurs, this bit will be set. It should be cleared via software. 5 SPIOVF SPI overrun error flag This bit indicates an overrun event. Once an overrun event occurs, this bit will be set. If ESPI and EA are enabled, an SPI interrupt will be required. This bit should be cleared via software. 4 MODF Mode Fault error flag This bit indicates a Mode Fault error event. If ̅̅̅̅ pin is configured as Mode Fault input (MSTR = 1 and DISMODF = 0) and ̅̅̅̅ is pulled low by external devices, a Mode Fault error occurs. Instantly MODF will be set as logic 1. If ESPI and EA are enabled, an SPI interrupt will be required. This bit should be cleared via software. 3 DISMODF 2 TXBUF Aug. 03, 2020 Disable Mode Fault error detection This bit is used in combination with the SSOE (SPCR.7) bit to determine the feature of ̅̅̅̅ pin as shown in Table 14-1. Slave Select Pin Configurations. DISMODF is valid only in Master mode (MSTR = 1). 0 = Mode Fault detection Enabled. ̅̅̅̅ serves as input pin for Mode Fault detection disregard of SSOE. 1 = Mode Fault detection Disabled. The feature of ̅̅̅̅ follows SSOE bit. SPI writer data buffer status This bit indicates the SPI transmit buffer status. 0 = SPI writer data buffer is empty 1 = SPI writer data buffer is full. Page 146 of 274 Rev. 1.09 N76E003 Datasheet SPDR – Serial Peripheral Data Register 7 6 5 4 3 2 1 0 SPDR[7:0] R/W Address: F5H Bit 7:0 Reset value: 0000 0000b Name Description SPDR[7:0] Serial peripheral data This byte is used for transmitting or receiving data on SPI bus. A write of this byte is a write to the shift register. A read of this byte is actually a read of the read data buffer. In Master mode, a write to this register initiates transmission and reception of a byte simultaneously. 14.2 Operating Modes 14.2.1 Master Mode The SPI can operate in Master mode while MSTR (SPCR.4) is set as 1. Only one Master SPI device can initiate transmissions. A transmission always begins by Master through writing to SPDR. The byte written to SPDR begins shifting out on MOSI pin under the control of SPCLK. Simultaneously, another byte shifts in from the Slave on the MISO pin. After 8-bit data transfer complete, SPIF (SPSR.7) will automatically set via hardware to indicate one byte data transfer complete. At the same time, the data received from the Slave is also transferred in SPDR. User can clear SPIF and read data out of SPDR. 14.2.2 Slave Mode When MSTR is 0, the SPI operates in Slave mode. The SPCLK pin becomes input and it will be clocked by another Master SPI device. The ̅̅̅̅̅ pin also becomes input. The Master device cannot exchange data with the Slave device until the ̅̅̅̅̅ pin of the Slave device is externally pulled low. Before data transmissions occurs, the ̅̅̅̅̅ of the Slave device should be pulled and remain low until the transmission is complete. If ̅̅̅̅̅ goes high, the SPI is forced into idle state. If the ̅̅̅̅̅ is forced to high at the middle of transmission, the transmission will be aborted and the rest bits of the receiving shifter buffer will be high and goes into idle state. In Slave mode, data flows from the Master to the Slave on MOSI pin and flows from the Slave to the Master on MISO pin. The data enters the shift register under the control of the SPCLK from the Master device. After one byte is received in the shift register, it is immediately moved into the read data buffer and the SPIF bit is set. A read of the SPDR is actually a read of the read data buffer. To prevent an overrun and the loss of the byte that caused by the overrun, the Slave should read SPDR out and the first SPIF should be cleared before a second transfer of data from the Master device comes in the read data buffer. Aug. 03, 2020 Page 147 of 274 Rev. 1.09 N76E003 Datasheet 14.3 Clock Formats and Data Transfer To accommodate a wide variety of synchronous serial peripherals, the SPI has a clock polarity bit CPOL (SPCR.3) and a clock phase bit CPHA (SPCR.2). Figure 14.3-1. SPI Clock Formats shows that CPOL and CPHA compose four different clock formats. The CPOL bit denotes the SPCLK line level in its idle state. The CPHA bit defines the edge on which the MOSI and MISO lines are sampled. The CPOL and CPHA should be identical for the Master and Slave devices on the same system. To Communicate in different data formats with one another will result undetermined result. Clock Phase (CPHA) CPOL = 0 CPHA = 1 sample sample sample sample CPOL = 1 Clock Polarity (CPOH) CPHA = 0 Figure 14.3-1. SPI Clock Formats In SPI, a Master device always initiates the transfer. If SPI is selected as Master mode (MSTR = 1) and enabled (SPIEN = 1), writing to the SPI data register (SPDR) by the Master device starts the SPI clock and data transfer. After shifting one byte out and receiving one byte in, the SPI clock stops and SPIF (SPSR.7) is set in both Master and Slave. If SPI interrupt enable bit ESPI (EIE.0) is set 1 and global interrupt is enabled (EA = 1), the interrupt service routine (ISR) of SPI will be executed. Concerning the Slave mode, the ̅̅̅̅̅ signal needs to be taken care. As shown in Figure 14.3-1. SPI Clock Formats, when CPHA = 0, the first SPCLK edge is the sampling strobe of MSB (for an example of LSBFE = 0, MSB first). Therefore, the Slave should shift its MSB data before the first SPCLK edge. The falling edge of ̅̅̅̅̅ is used for preparing the MSB on MISO line. The ̅̅̅̅̅ pin therefore should toggle high and then low between each successive serial byte. Furthermore, if the slave writes data to the SPI data register (SPDR) while ̅̅̅̅̅ is low, a write collision error occurs. When CPHA = 1, the sampling edge thus locates on the second edge of SPCLK clock. The Slave uses the first SPCLK clock to shift MSB out rather than the ̅̅̅̅̅ falling edge. Therefore, the ̅̅̅̅̅ line can remain low between successive transfers. This format may be preferred in systems having single fixed Master and single fixed Aug. 03, 2020 Page 148 of 274 Rev. 1.09 N76E003 Datasheet Slave. The ̅̅̅̅̅ line of the unique Slave device can be tied to GND as long as only CPHA = 1 clock mode is used. The SPI should be configured before it is enabled (SPIEN = 1), or a change of LSBFE, MSTR, CPOL, CPHA and SPR[1:0] will abort a transmission in progress and force the SPI system into idle state. Prior to any configuration bit changed, SPIEN must be disabled first. SPCLK Cycles 1 SPCLK Cycles 2 3 4 5 6 7 8 SPCLK (CPOL=0) SPCLK (CPOL=1) Transfer Progress[1] (internal signal) MOSI MISO MSB MSB 6 5 4 3 2 1 6 5 4 3 2 1 LSB LSB Input to Slave SS SS output of Master[2] SPIF (Master) SPIF (Slave) [1] Transfer progress starts by a writing SPDR of Master MCU. [2] SS automatic output affects when MSTR = DISMODF = SSOE = 1. Figure 14.3-2. SPI Clock and Data Format with CPHA = 0 Aug. 03, 2020 Page 149 of 274 Rev. 1.09 N76E003 Datasheet SPCLK Cycles SPCLK Cycles 1 2 3 4 5 6 7 8 MSB 6 5 4 3 2 1 LSB 6 5 4 3 2 1 SPCLK (CPOL=0) SPCLK (CPOL=1) Transfer Progress[1] (internal signal) MOSI MSB MISO LSB [3] [4] Input to Slave SS SS output of Master[2] SPIF (Master) SPIF (Slave) [1] Transfer progress starts by a writing SPDR of Master MCU. [2] SS automatic output affects when DISMODF = SSOE = MSTR = 1. [3] If SS of Slave is low, the MISO will be the LSB of previous data. Otherwise, MISO will be high. [4] While SS stays low, the LSB will last its state. Once SS is released to high, MISO will switch to high level. Figure 14.3-3. SPI Clock and Data Format with CPHA = 1 14.4 Slave Select Pin Configuration The N76E003 SPI gives a flexible ̅̅̅̅̅ pin feature for different system requirements. When the SPI operates as a Slave, ̅̅̅̅̅ pin always rules as Slave select input. When the Master mode is enabled, ̅̅̅̅̅ has three different functions according to DISMODF (SPSR.3) and SSOE (SPCR.7). By default, DISMODF is 0. It means that the Mode Fault detection activates. ̅̅̅̅̅ is configured as a input pin to check if the Mode Fault appears. On the contrary, if DISMODF is 1, Mode Fault is inactivated and the SSOE bit takes over to control the function of the ̅̅̅̅̅ pin. While SSOE is 1, it means the Slave select signal will generate automatically to select a Slave device. The ̅̅̅̅̅ as output pin of the Master usually connects with the ̅̅̅̅̅ input pin of the Slave device. The ̅̅̅̅̅ output automatically goes low for each transmission when selecting external Slave device and goes high during each idle state to de-select the Slave device. While SSOE is 0 and DISMODF is 1, ̅̅̅̅̅ is no more used by the SPI and reverts to be a general purpose I/O pin. 14.5 Mode Fault Detection The Mode Fault detection is useful in a system where more than one SPI devices might become Masters at the same time. It may induce data contention. When the SPI device is configured as a Master and the ̅̅̅̅̅ input line Aug. 03, 2020 Page 150 of 274 Rev. 1.09 N76E003 Datasheet is configured for Mode Fault input depending on Table 14-1. Slave Select Pin Configurations, a Mode Fault error occurs once the ̅̅̅̅̅ is pulled low by others. It indicates that some other SPI device is trying to address this Master as if it is a Slave. Instantly the MSTR and SPIEN control bits in the SPCR are cleared via hardware to disable SPI, Mode Fault flag MODF (SPSR.4) is set and an interrupt is generated if ESPI (EIE .0) and EA are enabled. 14.6 Write Collision Error The SPI is signal buffered in the transfer direction and double buffered in the receiving and transmit direction. New data for transmission cannot be written to the shift register until the previous transaction is complete. Write collision occurs while SPDR be written more than once while a transfer was in progress. SPDR is double buffered in the transmit direction. Any writing to SPDR cause data to be written directly into the SPI shift register. Once a write collision error is generated, WCOL (SPSR.6) will be set as 1 via hardware to indicate a write collision. In this case, the current transferring data continues its transmission. However the new data that caused the collision will be lost. Although the SPI logic can detect write collisions in both Master and Slave modes, a write collision is normally a Slave error because a Slave has no indicator when a Master initiates a transfer. During the receiving of Slave, a write to SPDR causes a write collision in Slave mode. WCOL flag needs to be cleared via software. 14.7 Overrun Error For receiving data, the SPI is double buffered in the receiving direction. The received data is transferred into a parallel read data buffer so the shifter is free to accept a second serial byte. However, the received data should be read from SPDR before the next data has been completely shifted in. As long as the first byte is read out of the read data buffer and SPIF is cleared before the next byte is ready to be transferred, no overrun error condition occurs. Otherwise the overrun error occurs. In this condition, the second byte data will not be successfully received into the read data register and the previous data will remains. If overrun occur, SPIOVF (SPSR.5) will be set via hardware. An SPIOVF setting will also require an interrupt if enabled. Figure 14.7-1. SPI Overrun Waveform shows the relationship between the data receiving and the overrun error. Aug. 03, 2020 Page 151 of 274 Rev. 1.09 N76E003 Datasheet Data[n] Receiving Begins Shift Register SPIF Data[n+1] Receiving Begins Shifting Data[n] in Data[n+2] Receiveing Begins Shifting Data[n+1] in Shifting Data[n+2] in [1] [3] Read Data Buffer Data[n] SPIOVF [4] Data[n] [2] Data[n+2] [3] [1] When Data[n] is received, the SPIF will be set. [2] If SPIF is not clear before Data[n+1] progress done, the SPIOVF will be set. Data[n] will be kept in read data buffer but Data [n+1] will be lost. [3] SPIF and SPIOVF must be cleared by software. [4] When Data[n+2] is received, the SPIF will be set again. Figure 14.7-1. SPI Overrun Waveform 14.8 SPI Interrupt Three SPI status flags, SPIF, MODF, and SPIOVF, can generate an SPI event interrupt requests. All of them locate in SPSR. SPIF will be set after completion of data transfer with external device or a new data have been received and copied to SPDR. MODF becomes set to indicate a low level on ̅̅̅̅̅ causing the Mode Fault state. SPIOVF denotes a receiving overrun error. If SPI interrupt mask is enabled via setting ESPI (EIE.6) and EA is 1, CPU will executes the SPI interrupt service routine once any of these three flags is set. User needs to check flags to determine what event caused the interrupt. These three flags are software cleared. SPIF SPIOVF SS MSTR DISMODF Mode MODF Fault Detection SPI Interrupt ESPI (EIE.6) EA Figure 14.8-1. SPI Interrupt Request Aug. 03, 2020 Page 152 of 274 Rev. 1.09 N76E003 Datasheet 2 15. INTER-INTEGRATED CIRCUIT (I C) 2 2 The Inter-Integrated Circuit (I C) bus serves as an serial interface between the microcontrollers and the I C 2 devices such as EEPROM, LCD module, temperature sensor, and so on. The I C bus used two wires design (a serial data line SDA and a serial clock line SCL) to transfer information between devices. 2 The I C bus uses bi-directional data transfer between masters and slaves. There is no central master and the multi-master system is allowed by arbitration between simultaneously transmitting masters. The serial clock 2 synchronization allows devices with different bit rates to communicate via one serial bus. The I C bus supports four transfer modes including master transmitter, master receiver, slave receiver, and slave transmitter. The 2 2 I C interface only supports 7-bit addressing mode. A special mode General Call is also available. The I C can meet both standard (up to 100kbps) and fast (up to 400k bps) speeds. 15.1 Functional Description For a bi-directional transfer operation, the SDA and SCL pins should be open-drain pads. This implements a 2 wired-AND function, which is essential to the operation of the interface. A low level on a I C bus line is 2 2 generated when one or more I C devices output a “ ”. A high level is generated when all I C devices output “ ”, allowing the pull-up resistors to pull the line high. In N76E003, user should set output latches of SCL and 2 SDA. As logic 1 before enabling the I C function by setting I2CEN (I2CON.6). VDD RUP RUP SDA SCL SDA SDA SCL SCL Other MCU N76E003 SDA SCL Slave Device 2 Figure 15.1-1. I C Bus Interconnection 2 The I C is considered free when both lines are high. Meanwhile, any device, which can operate as a master can occupy the bus and generate one transfer after generating a START condition. The bus now is considered busy before the transfer ends by sending a STOP condition. The master generates all of the serial clock pulses and the START and STOP condition. However if there is no START condition on the bus, all devices serve as not addressed slave. The hardware looks for its own slave address or a General Call address. (The General Aug. 03, 2020 Page 153 of 274 Rev. 1.09 N76E003 Datasheet Call address detection may be enabled or disabled by GC (I2ADDR.0).) If the matched address is received, an interrupt is requested. 2 Every transaction on the I C bus is 9 bits long, consisting of 8 data bits (MSB first) and a single acknowledge bit. The number of bytes per transfer (defined as the time between a valid START and STOP condition) is unrestricted but each byte has to be followed by an acknowledge bit. The master device generates 8 clock th pulse to send the 8-bit data. After the 8 falling edge of the SCL line, the device outputting data on the SDA th th changes that pin to an input and reads in an acknowledge value on the 9 clock pulse. After 9 clock pulse, the data receiving device can hold SCL line stretched low if next receiving is not prepared ready. It forces the next byte transaction suspended. The data transaction continues when the receiver releases the SCL line. SDA MSB LSB ACK 8 9 SCL 1 2 START condition STOP condition 2 Figure 15.1-2. I C Bus Protocol 15.1.1 START and STOP Condition 2 The protocol of the I C bus defines two states to begin and end a transfer, START (S) and STOP (P) conditions. A START condition is defined as a high-to-low transition on the SDA line while SCL line is high. The STOP condition is defined as a low-to-high transition on the SDA line while SCL line is high. A START or a 2 STOP condition is always generated by the master and I C bus is considered busy after a START condition and free after a STOP condition. After issuing the STOP condition successful, the original master device will release the control authority and turn back as a not addressed slave. Consequently, the original addressed 2 slave will become a not addressed slave. The I C bus is free and listens to next START condition of next transfer. A data transfer is always terminated by a STOP condition generated by the master. However, if a master still wishes to communicate on the bus, it can generate a repeated START (Sr) condition and address the pervious or another slave without first generating a STOP condition. Various combinations of read/write formats are then possible within such a transfer. Aug. 03, 2020 Page 154 of 274 Rev. 1.09 N76E003 Datasheet SDA SCL START STOP Repeated START START STOP Figure 15.1-3. START, Repeated START, and STOP Conditions 15.1.2 7-Bit Address with Data Format Following the START condition is generated, one byte of special data should be transmitted by the master. It th includes a 7-bit long slave address (SLA) following by an 8 bit, which is a data direction bit (R/W), to address the target slave device and determine the direction of data flow. If R/W bit is 0, it indicates that the master will write information to a selected slave. Also, if R/W bit is 1, it indicates that the master will read information from the addressed slave. An address packet consisting of a slave address and a read I or a write (W) bit is called SLA+R or SLA+W, respectively. A transmission basically consists of a START condition, a SLA+W/R, one or more data packets and a STOP condition. After the specified slave is addressed by SLA+W/R, the second and following 8-bit data bytes issue by the master or the slave devices according to the R/W bit configuration. There is an exception called “General all” address, which can address all devices by giving the first byte of data all 0. A General Call is used when a master wishes to transmit the same message to several slaves in the system. When this address is used, other devices may respond with an acknowledge or ignore it according to individual software configuration. If a device response the General Call, it operates as like in the slave-receiver mode. Note that the address 0x00 is reserved for General Call and cannot be used as a slave address, 2 therefore, in theory, a 7-bit addressing I C bus accepts 127 devices with their slave addresses 1 to 127. SDA SCL S 1-7 8 9 ADDRESS W/R ACK 1-7 8 DATA 1-7 9 ACK 8 DATA 9 ACK P 2 Figure 15.1-4. Data Format of One I C Transfer During the data transaction period, the data on the SDA line should be stable during the high period of the clock, and the data line can only change when SCL is low. Aug. 03, 2020 Page 155 of 274 Rev. 1.09 N76E003 Datasheet 15.1.3 Acknowledge e th Th 9 SCL pulse for any transferred byte is dedicated as an Acknowledge (ACK). It allows receiving devices (which can be the master or slave) to respond back to the transmitter (which also can be the master or slave) by pulling the SDA line low. The acknowledge-related clock pulse is generated by the master. The transmitter should release control of SDA line during the acknowledge clock pulse. The ACK is an active-low signal, pulling the SDA line low during the clock pulse high duty, indicates to the transmitter that the device has received the transmitted data. Commonly, a receiver, which has been addressed is requested to generate an ACK after each byte has been received. When a slave receiver does not acknowledge (NACK) the slave address, the SDA line should be left high by the slave so that the mater can generate a STOP or a repeated START condition. If a slave-receiver does acknowledge the slave address, it switches itself to not addressed slave mode and cannot receive any more data bytes. This slave leaves the SDA line high. The master should generate a STOP or a repeated START condition. If a master-receiver is involved in a transfer, because the master controls the number of bytes in the transfer, it should signal the end of data to the slave-transmitter by not generating an acknowledge on the last byte. The slave-transmitter then switches to not addressed mode and releases the SDA line to allow the master to generate a STOP or a repeated START condition. SDA output by transmitter SDA output by receiver SDA = 0, acknowledge (ACK) SDA = 1, not acknowledge (NACK) SCL from master 1 2 8 9 Clock pulse for acknowledge bit START condition Figure 15.1-5. Acknowledge Bit 15.1.4 Arbitration A master may start a transfer only if the bus is free. It is possible for two or more masters to generate a START condition. In these situations, an arbitration scheme takes place on the SDA line, while SCL is high. During arbitration, the first of the competing master devices to place‘a’’ ’ (high) on DA while another master transmits‘a’’ ’ (low) switches off its data output stage because the level on the bus does not match its own level. The arbitration lost master switches to the not addressed slave immediately to detect its own slave Aug. 03, 2020 Page 156 of 274 Rev. 1.09 N76E003 Datasheet address in the same serial transfer whether it is being addressed by the winning master. It also releases SDA line to high level for not affecting the data transfer continued by the winning master. However, the arbitration lost master continues generating clock pulses on SCL line until the end of the byte in which it loses the arbitration. Arbitration is carried out by all masters continuously monitoring the SDA line after outputting data. If the value read from the SDA line does not match the value that the master has to output, it has lost the arbitration. Note that a master can only lose arbitration when it outputs a high SDA value while another master outputs a low value. Arbitration will continue until only one master remains, and this may take many bits. Its first stage is a comparison of address bits, and if both masters are trying to address the same device, arbitration continues on to the comparison of data bits or acknowledge bit. DATA 1 from master 1 Master 1 loses arbitration for DATA 1 ≠ SDA It immediately switches to not addressed slave and outputs high level DATA 2 from master 2 SDA line SCL line START condition Figure 15.1-6. Arbitration Procedure of Two Masters 2 Since control of the I C bus is decided solely on the address or master code and data sent by competing masters, there is no central master, nor any order of priority on the bus. Slaves are not involved in the arbitration procedure. 2 15.2 Control Registers of I C 2 There are five control registers to interface the I C bus including I2CON, I2STAT, I2DAT, I2ADDR, and I2CLK. These registers provide protocol control, status, data transmitting and receiving functions, and clock rate configuration. For application flexibility, SDA and SCL pins can be exchanged by I2CPX (I2CON.0). The 2 following registers relate to I C function. Aug. 03, 2020 Page 157 of 274 Rev. 1.09 N76E003 Datasheet 2 I2CON – I C Control (Bit-addressable) 7 6 5 I2CEN STA R/W R/W Address: C0H Bit Name 4 STO R/W 3 SI R/W 2 AA R/W 1 0 I2CPX R/W Reset value: 0000 0000b Description 7 - 6 I2CEN 5 STA START flag 2 When STA is set, the I C generates a START condition if the bus is free. If the bus 2 is busy, the I C waits for a STOP condition and generates a START condition following. 2 If STA is set while the I C is already in the master mode and one or more bytes 2 have been transmitted or received, the I C generates a repeated START condition. Note that STA can be set anytime even in a slave mode, but STA is not hardware automatically cleared after START or repeated START condition has been detected. User should take care of it by clearing STA manually. 4 STO STOP flag 2 When STO is set if the I C is in the master mode, a STOP condition is transmitted to the bus. STO is automatically cleared by hardware once the STOP condition has been detected on the bus. 2 The STO flag setting is also used to recover the I C device from the bus error 2 state (I2STAT as 00H). In this case, no STOP condition is transmitted to the I C bus. If the STA and STO bits are both set and the device is original in the master 2 mode, the I C bus will generate a STOP condition and immediately follow a START condition. If the device is in slave mode, STA and STO simultaneous 2 setting should be avoid from issuing illegal I C frames. 3 SI I C interrupt flag 2 SI flag is set by hardware when one of 26 possible I C status (besides F8H status) is entered. After SI is set, the software should read I2STAT register to determine which step has been passed and take actions for next step. SI is cleared by software. Before the SI is cleared, the low period of SCL line is stretched. The transaction is suspended. It is useful for the slave device to deal with previous data bytes until ready for receiving the next byte. The serial transaction is suspended until SI is cleared by software. After SI is 2 cleared, I C bus will continue to generate START or repeated START condition, STOP condition, 8-bit data, or so on depending on the software configuration of controlling byte or bits. Therefore, user should take care of it by preparing suitable setting of registers before SI is software cleared. Aug. 03, 2020 Reserved 2 I C bus enable 2 0 = I C bus Disabled. 2 1 = I C bus Enabled. 2 Before enabling the I C, SCL and SDA port latches should be set to logic 1. 2 Page 158 of 274 Rev. 1.09 N76E003 Datasheet Bit Name 2 AA 1 - 0 I2CPX Description Acknowledge assert flag If the AA flag is set, an ACK (low level on SDA) will be returned during the 2 acknowledge clock pulse of the SCL line while the I C device is a receiver or an own-address-matching slave. If the AA flag is cleared, a NACK (high level on SDA) will be returned during the 2 acknowledge clock pulse of the SCL line while the I C device is a receiver or an own-address-matching slave. A device with its own AA flag cleared will ignore its own salve address and the General Call. Consequently, SI will note be asserted and no interrupt is requested. Note that if an addressed slave does not return an ACK under slave receiver mode or not receive an ACK under slave transmitter mode, the slave device will become a not addressed slave. It cannot receive any data until its AA flag is set and a master addresses it again. There is a special case of I2STAT value C8H occurs under slave transmitter mode. Before the slave device transmit the last data byte to the master, AA flag can be cleared as 0. Then after the last data byte transmitted, the slave device will actively switch to not addressed slave mode of disconnecting with the master. The further reading by the master will be all FFH. Reserved I2C pins select 0 = Assign SCL to P1.3 and SDA to P1.4. 1 = Assign SCL to P0.2 and SDA to P1.6. Note that I2C pins will exchange immediately once setting or clearing this bit. 2 I2STAT – I C Status 7 6 5 I2STAT[7:3] R 4 3 Address: BDH Bit 2 0 R 1 0 0 0 R R Reset value: 1111 1000b Name Description 7:3 I2STAT[7:3] I C status code The MSB five bits of I2STAT contains the status code. There are 27 possible status codes. When I2STAT is F8H, no relevant state information is available 2 and SI flag keeps 0. All other 26 status codes correspond to the I C states. When each of these status is entered, SI will be set as logic 1 and a interrupt is requested. 2:0 0 Aug. 03, 2020 2 Reserved The least significant three bits of I2STAT are always read as 0. Page 159 of 274 Rev. 1.09 N76E003 Datasheet 2 I2DAT – I C Data 7 6 5 4 3 2 1 0 I2DAT[7:0] R/W Address: BCH Bit Reset value: 0000 0000b Name 7:0 I2DAT[7:0] Description 2 I C data 2 I2DAT contains a byte of the I C data to be transmitted or a byte, which has just received. Data in I2DAT remains as long as SI is logic 1. The result of reading 2 or writing I2DAT during I C transceiving progress is unpredicted. While data in I2DAT is shifted out, data on the bus is simultaneously being shifted in to update I2DAT. I2DAT always shows the last byte that presented on 2 the I C bus. Thus the event of lost arbitration, the original value of I2DAT changes after the transaction. 2 I2ADDR – I C Own Slave Address 7 6 5 4 I2ADDR[7:1] R/W 3 Address: C1H Bit Name 7:1 I2ADDR[7:1] 2 1 0 GC R/W Reset value: 0000 0000b Description 2 I C device’s own slave address In master mode: These bits have no effect. In slave mode: 2 These 7 bits define the slave address of this I C device by user. The master 2 should address I C device by sending the same address in the first byte data 2 after a START or a repeated START condition. If the AA flag is set, this I C device will acknowledge the master after receiving its own address and become an addressed slave. Otherwise, the addressing from the master will be ignored. Note that I2ADDR[7:1] should not remain its default value of all 0, because address 0x00 is reserved for General Call. 6 GC General Call bit In master mode: This bit has no effect. In slave mode: 0 = The General Call is always ignored. 1 = The General Call is recognized if AA flag is 1; otherwise, it is ignored if AA is 0. Aug. 03, 2020 Page 160 of 274 Rev. 1.09 N76E003 Datasheet 2 I2CLK – I C Clock 7 6 5 4 3 2 1 0 I2CLK[7:0] R/W Address: BEH Bit 7:0 Reset value: 0000 1001b Name Description I2CLK[7:0] I C clock setting In master mode: 2 This register determines the clock rate of I C bus when the device is in a master mode. The clock rate follows the equation, 2 FSYS 4 × (I2CLK + 1) . 2 The default value will make the clock rate of I C bus 400k bps if the peripheral clock is 16 MHz. Note that the I2CLK value of 00H and 01H are not valid. This is an implement limitation. In slave mode: 2 This byte has no effect. In slave mode, the I C device will automatically synchronize with any given clock rate up to 400k bps. 15.3 Operating Modes 2 In I C protocol definition, there are four operating modes including master transmitter, master receiver, slave receiver, and slave transmitter. There is also a special mode called General Call. Its operating is similar to master transmitter mode. 15.3.1 Master Transmitter Mode In the master transmitter mode, several bytes of data are transmitted to a slave receiver. The master should prepare by setting desired clock rate in I2CLK. The master transmitter mode may now be entered by setting STA (I2CON.5) bit as 1. The hardware will test the bus and generate a START condition as soon as the bus becomes free. After a START condition is successfully produced, the SI flag (I2CON.3) will be set and the status code in I2STAT show 08H. The progress is continued by loading I2DAT with the target slave address and the data direction bit “write” ( A+W). he bit should then be cleared to commence A+W transaction. After the SLA+W byte has been transmitted and an acknowledge (ACK) has been returned by the addressed slave device, the SI flag is set again and I2STAT is read as 18H. The appropriate action to be taken follows user defined communication protocol by sending data continuously. After all data is transmitted, the master can send a STOP condition by setting STO (I2CON.4) and then clearing SI to terminate the transmission. A repeated START condition can also be generated without sending STOP condition to immediately initial another transmission. Aug. 03, 2020 Page 161 of 274 Rev. 1.09 N76E003 Datasheet (STA,STO,SI,AA) = (1,0,0,X) A START will be transmitted Normal Arbitration lost 08H A START has been transmitted (STA,STO,SI,AA) = (X,0,0,X) I2DAT = SLA+W SLA+W will be transmitted (STA,STO,SI,AA) = (X,0,0,1) I2DAT = SLA+W SLA+W will be transmitted MT 68H 18H 78H or Arbitration lost and addressed as slave receiver ACK has been transmitted OR SLA+W has been transmitted ACK has been received OR 20H B0H SLA+W has been transmitted NACK has been received Arbitration lost and addressed as slave transmitter ACK has been transmitted to corresponding slave mode (STA,STO,SI,AA)=(0,0,0,X) I2DAT = Data Byte Data byte will be transmitted (STA,STO,SI,AA)=(0,1,0,X) A STOP will be transmitted (STA,STO,SI,AA)=(1,1,0,X) A STOP followed by a START will be transmitted A STOP has been transmitted A STOP has been transmitted (STA,STO,SI,AA)=(1,0,0,X) A repeated START will be transmitted 28H 10H Data byte has been transmitted ACK has been received or A repeated START has been transmitted 30H Data byte has been transmitted NACK has been received 38H Arbitration lost in SLA+W or Data byte (STA,STO,SI,AA) =(0,0,0,X) I2DAT = SLA+R SLA+R will be transmitted (STA,STO,SI,AA)=(0,0,0,X) Not addressed slave will be entered (STA,STO,SI,AA)=(1,0,0,X) A START will be transmitted when the bus becomes free MR to master receiver Figure 15.3-1. Flow and Status of Master Transmitter Mode 15.3.2 Master Receiver Mode In the master receiver mode, several bytes of data are received from a slave transmitter. The transaction is initialized just as the master transmitter mode. Following the START condition, I2DAT should be loaded with the target slave address and the data direction bit “read” ( A+ ). After the A+ byte is transmitted and an acknowledge bit has been returned, the SI flag is set again and I2STAT is read as 40H. SI flag then should be cleared to receive data from the slave transmitter. If AA flag (I2CON.2) is set, the master receiver will acknowledge the slave transmitter. If AA is cleared, the master receiver will not acknowledge the slave and Aug. 03, 2020 Page 162 of 274 Rev. 1.09 N76E003 Datasheet release the slave transmitter as a not addressed slave. After that, the master can generate a STOP condition or a repeated START condition to terminate the transmission or initial another one. (STA,STO,SI,AA) = (1,0,0,X) A START will be transmitted Normal Arbitration lost 08H A START has been transmitted (STA,STO,SI,AA) = (X,0,0,X) I2DAT = SLA+R SLA+R will be transmitted (STA,STO,SI,AA) = (X,0,0,1) I2DAT = SLA+R SLA+R will be transmitted 40H or Arbitration lost and addressed as slave receiver ACK has been transmitted OR MR 68H SLA+R has been transmitted ACK has been received OR 48H 78H B0H SLA+R has been transmitted NACK has been received Arbitration lost and addressed as slave transmitter ACK has been transmitted to corresponding slave mode (STA,STO,SI,AA)=(0,0,0,0) Data byte will be received NACK will be transmitted (STA,STO,SI,AA)=(0,0,0,1) Data byte will be received ACK will be transmitted (STA,STO,SI,AA)=(1,0,0,X) A repeated START will be transmitted 58H 50H 10H Data byte has been received NACK has been transmitted I2DAT = Data Byte Data byte has been received ACK has been transmitted I2DAT = Data Byte A repeated START has been transmitted (STA,STO,SI,AA)=(0,1,0,X) A STOP will be transmitted (STA,STO,SI,AA)=(1,1,0,X) A STOP followed by a START will be transmitted A STOP has been transmitted A STOP has been transmitted 38H Arbitration lost in NACK bit (STA,STO,SI,AA) =(0,0,0,X) I2DAT = SLA+W SLA+W will be transmitted (STA,STO,SI,AA)=(0,0,0,X) Not addressed slave will be entered (STA,STO,SI,AA)=(1,0,0,X) A START will be transmitted when the bus becomes free MT to master transmitter Figure 15.3-2. Flow and Status of Master Receiver Mode 15.3.3 Slave Receiver Mode In the slave receiver mode, several bytes of data are received form a master transmitter. Before a transmission is commenced, I2ADDR should be loaded with the address to which the device will respond when addressed by a master. I2CLK does not affect in slave mode. The AA bit should be set to enable acknowledging its own Aug. 03, 2020 Page 163 of 274 Rev. 1.09 N76E003 Datasheet 2 slave address. After the initialization above, the I C idles until it is addressed by its own address with the data direction bit “write” ( A+W). he slave receiver mode may also be entered if arbitration is lost. After the slave is addressed by SLA+W, it should clear its SI flag to receive the data from the master transmitter. If the AA bit is 0 during a transaction, the slave will return a non-acknowledge after the next received data byte. The slave will also become not addressed and isolate with the master. It cannot receive any byte of data with I2DAT remaining the previous byte of data, which is just received. (STA,STO,SI,AA) = (0,0,0,1) If own SLA+W is received, ACK will be transmitted 60H Own SLA+W has been received ACK has been transmitted I2DAT = own SLA+W OR 68H Arbitration lost and own SLA+W has been received ACK has been transmitted I2DAT = own SLA+W (STA,STO,SI,AA)=(X,0,0,1) Data byte will be received ACK will be transmitted (STA,STO,SI,AA)=(X,0,0,0) Data byte will be received NACK will be transmitted (STA,STO,SI,AA)=(X,0,0,X) A STOP or repeated START will be received 80H 88H A0H Data byte has been received ACK has been transmitted I2DAT = Data Byte Data byte has been received NACK has been transmitted I2DAT = Data Byte A STOP or repeated START has been received (STA,STO,SI,AA)=(0,0,0,1) Not addressed slave will be entered; own SLA will be recognized; General Call will be recognized if GC = 1 (STA,STO,SI,AA)=(1,0,0,0) Not addressed slave will be entered; no recognition of own SLA or General Call; A START will be transmitted when the bus becomes free (STA,STO,SI,AA)=(0,0,0,0) Not addressed slave will be entered; no recognition of own SLA or General Call (STA,STO,SI,AA)=(1,0,0,1) Not addressed slave will be entered; own SLA will be recognized; General Call will be recognized if GC = 1; A START will be transmitted when the bus becomes free Figure 15.3-3. Flow and Status of Slave Receiver Mode 15.3.4 Slave Transmitter Mode In the slave transmitter mode, several bytes of data are transmitted to a master receiver. After I2ADDR and 2 I2CON values are given, the I C wait until it is addressed by its own address with the data direction bit “read” (SLA+R). The slave transmitter mode may also be entered if arbitration is lost. After the slave is addressed by SLA+R, it should clear its SI flag to transmit the data to the master receiver. Normally the master receiver will return an acknowledge after every byte of data is transmitted by the slave. If the acknowledge is not received, it will transmit all “ ” data if it continues the transaction. t becomes a not Aug. 03, 2020 Page 164 of 274 Rev. 1.09 N76E003 Datasheet addressed slave. If the AA flag is cleared during a transaction, the slave transmits the last byte of data. The next transmitting data will be all “ ” and the slave becomes not addressed. (STA,STO,SI,AA) = (0,0,0,1) If own SLA+R is received, ACK will be transmitted A8H Own SLA+R has been received ACK has been transmitted I2DAT = own SLA+R OR B0H Arbitration lost and own SLA+R has been received ACK has been transmitted I2DAT = own SLA+R (STA,STO,SI,AA)=(X,0,0,1) I2DAT = Data Byte Data byte will be transmitted ACK will be received (STA,STO,SI,AA)=(X,0,0,X) I2DAT = Data Byte Data byte will be transmitted NACK will be received (STA,STO,SI,AA)=(X,0,0,0) I2DAT = Last Data Byte Last data byte will be transmitted ACK will be received (STA,STO,SI,AA)=(X,0,0,X) A STOP or repeated START will be received B8H C0H C8H A0H Data byte has been transmitted ACK has been received Data byte has been transmitted NACK has been received Last Data byte has been transmitted ACK has been received A STOP or repeated START has been received * (STA,STO,SI,AA)=(0,0,0,0) Not addressed slave will be entered; no recognition of own SLA or General Call (STA,STO,SI,AA)=(0,0,0,1) Not addressed slave will be entered; own SLA will be recognized; General Call will be recognized if GC = 1 (STA,STO,SI,AA)=(1,0,0,0) Not addressed slave will be entered; no recognition of own SLA or General Call; A START will be transmitted when the bus becomes free flow is not recommended. If the MSB of next byte which the Slave is going to transmit is 0, it * This will hold SDA line. The STOP or repeated START cannot be successfully generated by Master. (STA,STO,SI,AA)=(1,0,0,1) Not addressed slave will be entered; own SLA will be recognized; General Call will be recognized if GC = 1; A START will be transmitted when the bus becomes free Figure 15.3-4. Flow and Status of Slave Transmitter Mode 15.3.5 General Call he General all is a special condition of slave receiver mode by been addressed with all “ ” data in slave address with data direction bit. Both GC (I2ADDR.0) bit and AA bit should be set as 1 to enable acknowledging General Calls. The slave addressed by a General Call has different status code in I2STAT with normal slave receiver mode. The General Call may also be produced if arbitration is lost. Aug. 03, 2020 Page 165 of 274 Rev. 1.09 N76E003 Datasheet (STA,STO,SI,AA) = (0,0,0,1) GC = 1 If General Call is received, ACK will be transmitted 70H General Call has been received ACK has been transmitted I2DAT = 00H OR 78H Arbitration lost and General Call has been received ACK has been transmitted I2DAT = 00H (STA,STO,SI,AA)=(X,0,0,1) Data byte will be received ACK will be transmitted (STA,STO,SI,AA)=(X,0,0,0) Data byte will be received NACK will be transmitted (STA,STO,SI,AA)=(X,0,0,X) A STOP or repeated START will be received 90H 98H A0H Data byte has been received ACK has been transmitted I2DAT = Data Byte Data byte has been received NACK has been transmitted I2DAT = Data Byte A STOP or repeated START has been received (STA,STO,SI,AA)=(0,0,0,1) Not addressed slave will be entered; own SLA will be recognized; General Call will be recognized if GC = 1 (STA,STO,SI,AA)=(1,0,0,0) Not addressed slave will be entered; no recognition of own SLA or General Call; A START will be transmitted when the bus becomes free (STA,STO,SI,AA)=(0,0,0,0) Not addressed slave will be entered; no recognition of own SLA or General Call (STA,STO,SI,AA)=(1,0,0,1) Not addressed slave will be entered; own SLA will be recognized; General Call will be recognized if GC = 1; A START will be transmitted when the bus becomes free Figure 15.3-5. Flow and Status of General Call Mode 15.3.6 Miscellaneous States There are two I2STAT status codes that do not correspond to the 25 defined states, which are mentioned in previous sections. These are F8H and 00H states. The first status code F8H indicates that no relevant information is available during each transaction. 2 Meanwhile, the SI flag is 0 and no I C interrupt is required. The other status code 00H means a bus error has occurred during a transaction. A bus error is caused by a START or STOP condition appearing temporally at an illegal position such as the second through eighth bits of an address or a data byte, and the acknowledge bit. When a bus error occurs, the SI flag is set immediately. 2 When a bus error is detected on the I C bus, the operating device immediately switches to the not addressed salve mode, releases SDA and SCL lines, sets the SI flag, and loads I2STAT as 00H. To recover from a bus error, the STO bit should be set and then SI should be cleared. After that, STO is cleared by hardware and 2 2 release the I C bus without issuing a real STOP condition waveform on I C bus. Aug. 03, 2020 Page 166 of 274 Rev. 1.09 N76E003 Datasheet 2 There is a special case if a START or a repeated START condition is not successfully generated for I C bus is obstructed by a low level on SDA line e.g. a slave device out of bit synchronization, the problem can be solved 2 by transmitting additional clock pulses on the SCL line. The I C hardware transmits additional clock pulses when the STA bit is set, but no START condition can be generated because the SDA line is pulled low. When the SDA line is eventually released, a normal START condition is transmitted, state 08H is entered, and the 2 serial transaction continues. If a repeated START condition is transmitted while SDA is obstructed low, the I C hardware also performs the same action as above. In this case, state 08H is entered instead of 10H after a successful START condition is transmitted. Note that the software is not involved in solving these bus problems. 2 The following table is show the status display in I2STAT register of I C number and description: Master Mode Slave Mode STATUS Description STATUS Description 0x08 Start 0Xa0 Slave Transmit Repeat Start or Stop 0x10 Master Repeat Start 0Xa8 Slave Transmit Address ACK 0x18 Master Transmit Address ACK 0Xb0 Slave Transmit Arbitration Lost 0x20 Master Transmit Address NACK 0Xb8 Slave Transmit Data ACK 0x28 Master Transmit Data ACK 0Xc0 Slave Transmit Data NACK 0x30 Master Transmit Data NACK 0Xc8 Slave Transmit Last Data ACK 0x38 Master Arbitration Lost 0x60 Slave Receive Address ACK 0x40 Master Receive Address ACK 0x68 Slave Receive Arbitration Lost 0x48 Master Receive Address NACK 0x80 Slave Receive Data ACK 0x50 Master Receive Data ACK 0x88 Slave Receive Data NACK 0x58 Master Receive Data NACK 0x70 GC mode Address ACK 0x00 Bus error 0x78 GC mode Arbitration Lost 0x90 GC mode Data ACK 0x98 GC mode Data NACK 0Xf8 Bus Released Note: tatus “ Xf8” exists in both master slave modes, and it won’t raise interrupt. Note: When I2C is enabled and I2C status is entered bus error state, SI flag is set by hardware. Until the I2C bus error is handled, SI flag will maintain its value at 1 and cannot be cleared by software. That is to clear SI flag Aug. 03, 2020 Page 167 of 274 Rev. 1.09 N76E003 Datasheet does not clear I2C bus error as well. When using SI flag to determine I2C status and flow, use following steps to enhance the reliability of the system. Solution: – Send a STOP condition to I2C bus – If the STOP condition is invalid, disable the I2C bus and then restart the communication. For example: while(SI != 0) { if (I2STAT == 0x00) { STO = 1; } SI = 0; if(SI!=0) { I2CEN = 0; I2CEN = 1 ; SI = 0; I2CEN = 0; } } // Check bus status if bus error,first send stop // If SI still keep 1 // please first disable I2C. // Then enable I2C for clear SI. // At last disable I2C for next a new transfer 2 15.4 Typical Structure of I C Interrupt Service Routine The following software example in C language for KEIL TM 2 C51 compiler shows the typical structure of the I C interrupt service routine including the 26 state service routines and may be used as a base for user applications. User can follow or modify it for their own application. If one or more of the five modes are not used, the associated state service routines may be removed, but care should be taken that a deleted routine can never be invoked. Void I2C_ISR (void) interrupt 6 { switch (I2STAT) { //=============================================== //Bus Error, always put in ISR for noise handling //=============================================== case 0x00: /*00H, bus error occurs*/ STO = 1; //recover from bus error break; //=========== //Master Mode //=========== Aug. 03, 2020 Page 168 of 274 Rev. 1.09 N76E003 Datasheet case 0x08: STA = 0; I2DAT = SLA_ADDR1; break; case 0x10: STA = 0; I2DAT = SLA_ADDR2; break; //======================= //Master Transmitter Mode //======================= case 0x18: I2DAT = NEXT_SEND_DATA1; break; case 0x20: STO = 1; AA = 1; break; case 0x28: if (Conti_TX_Data) I2DAT = NEXT_SEND_DATA2; else { STO = 1; AA = 1; } break; case 0x30: STO = 1; AA = 1; break; //=========== //Master Mode //=========== case 0x38: STA = 1; break; //==================== //Master Receiver Mode //==================== case 0x40: AA = 1; break; case 0x48: STO = 1; AA = 1; break; case 0x50: DATA_RECEIVED1 = I2DAT; if (To_RX_Last_Data1) AA = 0; else Aug. 03, 2020 /*08H, a START transmitted*/ //STA bit should be cleared by software //load SLA+W/R /*10H, a repeated START transmitted*/ /*18H, SLA+W transmitted, ACK received*/ //load DATA /*20H, SLA+W transmitted, NACK received*/ //transmit STOP //ready for ACK own SLA+W/R or General Call /*28H, DATA transmitted, ACK received*/ //if continuing to send DATA //if no DATA to be sent /*30H, DATA transmitted, NACK received*/ /*38H, arbitration lost*/ //retry to transmit START if bus free /*40H, SLA+R transmitted, ACK received*/ //ACK next received DATA /*48H, SLA+R transmitted, NACK received*/ /*50H, DATA received, ACK transmitted*/ //store received DATA //if last DATA will be received //not ACK next received DATA //if continuing receiving DATA Page 169 of 274 Rev. 1.09 N76E003 Datasheet AA = 1; break; case 0x58: /*58H, DATA received, NACK transmitted*/ DATA_RECEIVED_LAST1 = I2DAT; STO = 1; AA = 1; break; //==================================== //Slave Receiver and General Call Mode //==================================== case 0x60: /*60H, own SLA+W received, ACK returned*/ AA = 1; break; case 0x68: /*68H, arbitration lost in SLA+W/R own SLA+W received, ACK returned */ AA = 0; //not ACK next received DATA after //arbitration lost STA = 1; //retry to transmit START if bus free break; case 0x70: //*70H, General Call received, ACK returned AA = 1; break; case 0x78: /*78H, arbitration lost in SLA+W/R General Call received, ACK returned*/ AA = 0; STA = 1; break; case 0x80: /*80H, previous own SLA+W, DATA received, ACK returned*/ DATA_RECEIVED2 = I2DAT; if (To_RX_Last_Data2) AA = 0; else AA = 1; break; case 0x88: /*88H, previous own SLA+W, DATA received, NACK returned, not addressed SLAVE mode entered*/ DATA_RECEIVED_LAST2 = I2DAT; AA = 1; //wait for ACK next Master addressing break; case 0x90: /*90H, previous General Call, DATA received, ACK returned*/ DATA_RECEIVED3 = I2DAT; if (To_RX_Last_Data3) AA = 0; else AA = 1; break; case 0x98: /*98H, previous General Call, DATA received, NACK returned, not addressed SLAVE mode entered*/ Aug. 03, 2020 Page 170 of 274 Rev. 1.09 N76E003 Datasheet DATA_RECEIVED_LAST3 = I2DAT; AA = 1; break; //========== //Slave Mode //========== case 0Xa0: /*A0H, STOP or repeated START received while still addressed SLAVE mode*/ AA = 1; break; //====================== //Slave Transmitter Mode //====================== case 0Xa8: /*A8H, own SLA+R received, ACK returned*/ I2DAT = NEXT_SEND_DATA3; AA = 1; //when AA is “1”, not last data to be //transmitted break; case 0Xb0: /*B0H, arbitration lost in SLA+W/R own SLA+R received, ACK returned */ I2DAT = DUMMY_DATA; AA = 0; //when AA is “0”, last data to be //transmitted STA = 1; //retry to transmit START if bus free break; case 0Xb8: /*B8H, previous own SLA+R, DATA transmitted, ACK received*/ I2DAT = NEXT_SEND_DATA4; if (To_TX_Last_Data) //if last DATA will be transmitted AA = 0; else AA = 1; break; case 0Xc0: /*C0H, previous own SLA+R, DATA transmitted, NACK received, not addressed SLAVE mode entered*/ AA = 1; break; case 0Xc8: /*C8H, previous own SLA+R, last DATA transmitted, ACK received, not addressed SLAVE AA = 1; mode entered*/ break; }//end of switch (I2STAT) SI = 0; while(STO); //SI should be the last command of I2C ISR //wait for STOP transmitted or bus error //free, STO is cleared by hardware }//end of I2C_ISR Aug. 03, 2020 Page 171 of 274 Rev. 1.09 N76E003 Datasheet 2 15.5 I C Time-Out 2 There is a 14-bit time-out counter, which can be used to deal with the I C bus hang-up. If the time-out counter is enabled, the counter starts up counting until it overflows. Meanwhile I2TOF will be set by hardware and 2 requests I C interrupt. When time-out counter is enabled, setting flag SI to high will reset counter and restart 2 counting up after SI is cleared. If the I C bus hangs up, it causes the SI flag not set for a period. The 14-bit time-out counter will overflow and require the interrupt service. 0 FSYS 1/4 14-bit I2C Time-out Counter 1 I2TOF Clear Counter DIV I2CEN I2TOCEN SI 2 Figure 15.5-1. I C Time-Out Counter 2 I2TOC – I C Time-out Counter 7 6 Address: BFH Bit 5 - 4 - 3 - 2 I2TOCEN R/W 1 0 DIV I2TOF R/W R/W Reset value: 0000 0000b Name Description 2 I2TOCEN I C time-out counter enable 2 0 = I C time-out counter Disabled. 2 1 = I C time-out counter Enabled. 2 2 Note: please always enable I C interrupt when enable I C time-out counter function 1 DIV 0 I2TOF 2 2 I C time-out counter clock divider 2 0 = The clock of I C time-out counter is FSYS/1. 2 1 = The clock of I C time-out counter is FSYS/4. 2 I C time-out flag 2 This flag is set by hardware if 14-bit I C time-out counter overflows. It is cleared by software. 2 15.6 I C Interrupt 2 2 2 There are two I C flags, SI and I2TOF. Both of them can generate an I C event interrupt requests. If I C 2 interrupt mask is enabled via setting EI2C (EIE.0) and EA as 1, CPU will execute the I C interrupt service Aug. 03, 2020 Page 172 of 274 Rev. 1.09 N76E003 Datasheet routine once any of these two flags is set. User needs to check flags to determine what event caused the 2 interrupt. Both of I C flags are cleared by software. Aug. 03, 2020 Page 173 of 274 Rev. 1.09 N76E003 Datasheet 16. PIN INTERRUPT The N76E003 provides pin interrupt input for each I/O pin to detect pin state if button or keypad set is used. A maximum 8-channel pin interrupt detection can be assigned by I/O port sharing. The pin interrupt is generated when any key is pressed on a keyboard or keypad, which produces an edge or level triggering event. Pin interrupt may be used to wake the CPU up from Idle or Power-down mode. Each channel of pin interrupt can be enabled and polarity controlled independently by PIPEN and PINEN register. PICON selects which port that the pin interrupt is active. It also defines which type of pin interrupt is us– d – level detect or edge detect. Each channel also has its own interrupt flag. There are total eight pin interrupt flags located in PIF register. The respective flags for each pin interrupt channel allow the interrupt service routine to poll on which channel on which the interrupt event occurs. All flags in PIF register are set by hardware and should be cleared by software. PIPS[1:0] (PICON[1:0]) P0.0 P1.0 P2.0 P3.0 00 01 0 PIF0 10 11 PIT0 1 PINEN0 Pin Interrupt Channel 0 P0.1 P1.1 Reserved Reserved PIPEN0 00 01 0 PIF1 10 11 PIT1 1 PINEN1 Pin Interrupt Channel 1 PIPEN1 Pin Interrupt P0.7 P1.7 Reserved Reserved 00 01 0 PIF7 10 11 PIT67 1 PINEN7 Pin Interrupt Channel 7 PIPEN7 Figure 15.6-1. Pin Interface Block Diagram Aug. 03, 2020 Page 174 of 274 Rev. 1.09 N76E003 Datasheet Pin interrupt is generally used to detect an edge transient from peripheral devices like keyboard or keypad. During idle state, the system prefers to enter Power-down mode to minimize power consumption and waits for event trigger. Pin interrupt can wake up the device from Power-down mode. PICON – Pin Interrupt Control 7 6 5 PIT67 PIT45 PIT3 R/W R/W R/W Address: E9H Bit Name 4 PIT2 R/W 3 PIT1 R/W 2 PIT0 R/W 1 0 PIPS[1:0] R/W Reset value: 0000 0000b Description 7 PIT67 Pin interrupt channel 6 and 7 type select This bit selects which type that pin interrupt channel 6 and 7 is triggered. 0 = Level triggered. 1 = Edge triggered. 6 PIT45 Pin interrupt channel 4 and 5 type select This bit selects which type that pin interrupt channel 4 and 5 is triggered. 0 = Level triggered. 1 = Edge triggered. 5 PIT3 Pin interrupt channel 3 type select This bit selects which type that pin interrupt channel 3 is triggered. 0 = Level triggered. 1 = Edge triggered. 4 PIT2 Pin interrupt channel 2 type select This bit selects which type that pin interrupt channel 2 is triggered. 0 = Level triggered. 1 = Edge triggered. 3 PIT1 Pin interrupt channel 1 type select This bit selects which type that pin interrupt channel 1 is triggered. 0 = Level triggered. 1 = Edge triggered. 2 PIT0 Pin interrupt channel 0 type select This bit selects which type that pin interrupt channel 0 is triggered. 0 = Level triggered. 1 = Edge triggered. 1:0 PIPS[:0] Aug. 03, 2020 Pin interrupt port select This field selects which port is active as the 8-channel of pin interrupt. 00 = Port 0. 01 = Port 1. 10 = Port 2. 11 = Port 3. Page 175 of 274 Rev. 1.09 N76E003 Datasheet PINEN – Pin Interrupt Negative Polarity Enable. 7 6 5 4 PINEN7 PINEN6 PINEN5 PINEN4 R/W R/W R/W R/W Address: EAH Bit Name n PINENn Name n PIPENn PIF – Pin Interrupt Flags 7 6 PIF7 PIF6 R (level) R (level) R/W (edge) R/W (edge) Address: ECH Bit Name n Aug. 03, 2020 PIFn 2 PINEN2 R/W 1 0 PINEN1 PINEN0 R/W R/W Reset value: 0000 0000b Description Pin interrupt channel n negative polarity enable This bit enables low-level/falling edge triggering pin interrupt channel n. The level or edge triggered selection depends on each control bit PITn in PICON. 0 = Low-level/falling edge detect Disabled. 1 = Low-level/falling edge detect Enabled. PIPEN – Pin Interrupt Positive Polarity Enable. 7 6 5 4 PIPEN7 PIPEN6 PIPEN5 PIPEN4 R/W R/W R/W R/W Address: EBH Bit 3 PINEN3 R/W 3 PIPEN3 R/W 2 PIPEN2 R/W 1 0 PIPEN1 PIPEN0 R/W R/W Reset value: 0000 0000b Description Pin interrupt channel n positive polarity enable This bit enables high-level/rising edge triggering pin interrupt channel n. The level or edge triggered selection depends on each control bit PITn in PICON. 0 = High-level/rising edge detect Disabled. 1 = High-level/rising edge detect Enabled. 5 PIF5 R (level) R/W (edge) 4 PIF4 R (level) R/W (edge) 3 PIF3 R (level) R/W (edge) 2 PIF2 R (level) R/W (edge) 1 0 PIF1 PIF0 R (level) R (level) R/W (edge) R/W (edge) Reset value: 0000 0000b Description Pin interrupt channel n flag If the edge trigger is selected, this flag will be set by hardware if the channel n of pin interrupt detects an enabled edge trigger. This flag should be cleared by software. If the level trigger is selected, this flag follows the inverse of the input signal’s logic level on the channel n of pin interrupt. Software cannot control it. Page 176 of 274 Rev. 1.09 N76E003 Datasheet 17. PULSE WIDTH MODULATED (PWM) The PWM (Pulse Width Modulation) signal is a useful control solution in wide application field. It can used on motor driving, fan control, backlight brightness tuning, LED light dimming, or simulating as a simple digital to analog converter output through a low pass filter circuit. The N76E003 PWM is especially designed for motor control by providing three pairs, maximum 16-bit resolution of PWM output with programmable period and duty. The architecture makes user easy to drive the one-phase or three-phase brushless DC motor (BLDC), or three-phase AC induction motor. Each of six PWM can be configured as one of independent mode, complementary mode, or synchronous mode. If the complementary mode is used, a programmable dead-time insertion is available to protect MOS turn-on simultaneously. The PWM waveform can be edge-aligned or center-aligned with variable interrupt points. 17.1 Functional Description 17.1.1 PWM Generator The PWM generator is clocked by the system clock or Timer 1 overflow divided by a PWM clock pre-scalar selectable from 1/1~1/128. The PWM period is defined by effective 16-bit period registers, {PWMPH, PWMPL}. The period is the same for all PWM channels for they share the same 16-bit period counter. The duty of each PWM is determined independently by the value of duty registers {PWM0H, PWM0L}, {PWM1H, PWM1L}, {PWM2H, PWM2L}, {PWM3H, PWM3L}, {PWM4H, PWM4L}, and {PWM5H, PWM5L}. With six duty registers, six PWM output can be generated independently with different duty cycles. The interval and duty of PWM signal is generated by a 16-bit counter comparing with the period and duty registers. To facilitate the three-phase motor control, a group mode can be used by setting GP (PWMCON1.5), which makes {PWM0H, PWM0L} and {PWM1H, PWM1L} duty register decide duties of the PWM outputs. In a threephase motor control application, two-group PWM outputs generally are given the same duty cycle. When the group mode is enabled, {PWM2H, PWM2L}, {PWM3H, PWM3L}, {PWM4H, PWM4L} and {PWM5H, PWM5L} registers have no effect. This mean is {PWM2H, PWM2L} and {PWM4H, PWM4L} both as same as {PWM0H, PWM0L}. Also {PWM3H, PWM3L} and {PWM5H, PWM5L} are same as {PWM1H, PWM1L}. Note that enabling PWM does not configure the I/O pins into their output mode automatically. User should configure I/O output mode via software manually. Aug. 03, 2020 Page 177 of 274 Rev. 1.09 N76E003 Datasheet (PWMPH, PWMPL) PWMP registers 0-to-1 LOAD (PWMCON0.6) PWMP buffer Counter Matching(edgealigned)/ underflow(venter aligned) = PWMRUN (PWMCON0.7) FSYS Timer 1 overflow 0 1 PWMCKS (CKCON.6) Pre-scalar PWMDIV0[2:0] (PWMCON1[2:0]) FPWM edge/center 16-bit up/down counter clear counter PWMTYP (PWMCON1.4) CLRPWM (PWMCON0.4) PWMF (PWMCON0.5) Interrupt select/type PG0 = PWM interrupt INTSEL[1:0], INTTYP[1:0] (PWMCON0[3:0]) PWM0/P1.2 PWM0 buffer (PWM0H, PWM0L) PWM0 Register PG1 = PWM1/P1.1/P1.4 PWM1 buffer (PWM1H, PWM1L) PWM1 Register = 0 PWM2/P0.5/P1.0 PG2 1 PWM2 buffer (PWM2H, PWM2L) PWM and Fault Brake output control PWM2 Register = 0 PG3 PWM3/P0.0/P0.4 PG4 PWM4/P0.1 PG5 PWM5/P0.3/P1.5 1 PWM3 buffer (PWM3H, PWM3L) PWM3 Register = 0 1 PWM4 buffer (PWM4H, PWM4L) PWM4 Register = 0 1 PWM5 buffer GP (PWMCON1.5) (PWM5H, PWM5L) PWM5 Register Brake event (P1.4/FB) Figure 17.1-1. PWM Block Diagram The PWM counter generates six PWM signals called PG0, PG1, PG2, PG3, PG4, and PG5. These signals will go through the PWM and Fault Brake output control circuit. It generates real PWM outputs on I/O pins. The Aug. 03, 2020 Page 178 of 274 Rev. 1.09 N76E003 Datasheet output control circuit determines the PWM mode, dead-time insertion, mask output, Fault Brake control, and PWM polarity. The last stage is a multiplexer of PWM output or I/O function. User should set the PIOn bit to make the corresponding pin function as PWM output. Meanwhile, the general purpose I/O function can be used. PWM and Fault Brake output control PWM mode select Dead time insertion Mask output Brake control PWM polarity PIO00 PMEN0 P1.2 PNP0 PG0_DT PG0 0 PMD0 PWM0/1 mode PG1 PWM & I/O switch PWM0/1 dead time 1 FBD0 0 1 0 0 1 1 P1.1 0 1 PG1_DT 0 PMD1 1 P1.4 0 FBD1 0 0 1 1 1 PMEN1 PWM0/P1.2 PIO01 PWM1/P1.1 PWM1/P1.4 PIO11 PNP1 PIO02 P0.5 PMEN2 PG2_DT PG2 0 PMD2 PWM2/3 mode PWM2/3 dead time PG3 P1.0 0 1 FBD2 0 1 PNP2 0 0 1 1 1 PWM2/P0.5 PWM2/P1.0 PIO12 PIO03 PG3_DT 0 PMD3 P0.0 0 1 FBD3 PMEN3 0 0 1 1 1 P0.4 PNP3 0 1 PWM3/P0.0 PWM3/P0.4 PIO13 PMEN4 PIO04 PNP4 PG4_DT PG4 0 PMD4 PWM4/5 mode PWM4/5 dead time PG5 1 P0.1 0 FBD4 0 0 1 1 1 P0.3 0 PG5_DT 0 PMD5 1 1 0 FBD5 0 1 P1.5 1 PNP5 PDTEN, PDTCNT PMEN, PMD FBD FBINEN (PWMCON1.3) PWM5/P0.3 PWM5/P1.5 PIO15 BRK PWMMOD[1:0] (PWMCON1[7:6]) 0 1 PMEN5 PWM4/P0.1 PIO05 PNP PIOCON1,PIOCON0 Brake event (P1.4/FB) Figure 17.1-2. PWM and Fault Brake Output Control Block Diagram User should follow the initialization steps below to start generating the PWM signal output. In the first step by setting CLRPWM (PWMCON0.4), it ensures the 16-bit up counter reset for the accuracy of the first duration. After initialization and setting {PWMPH, PWMPL} and all {PWMnH, PWMnL} registers, PWMRUN (PWMCON0.7) can be set as logic 1 to trigger the 16-bit counter running. PWM starts to generate waveform on its output pins. The hardware for all period and duty control registers are double buffered designed. Therefore, {PWMPH, PWMPL} and all {PWMnH, PWMnL} registers can be written to at any time, but the period and duty Aug. 03, 2020 Page 179 of 274 Rev. 1.09 N76E003 Datasheet cycle of PWM will not be updated immediately until the LOAD (PWMCON0.6) is set and previous period is complete. This prevents glitches when updating the PWM period or duty. A loading of new period and duty by setting LOAD should be ensured complete by monitoring it and waiting for a hardware automatic clearing LOAD bit. Any updating of PWM control registers during LOAD bit as logic 1 will cause unpredictable output. PWMCON0 – PWM Control 0 (Bit-addressable) 7 6 5 4 PWMRUN LOAD PWMF CLRPWM R/W R/W R/W R/W Address: D8H Bit Name 7 PWMRUN 6 LOAD 3 - 2 - 1 0 Reset value: 0000 0000b Description PWM run enable 0 = PWM stays in idle. 1 = PWM starts running. PWM new period and duty load This bit is used to load period and duty control registers in their buffer if new period or duty value needs to be updated. The loading will act while a PWM period is completed. The new period and duty affected on the next PWM cycle. After the loading is complete, LOAD will be automatically cleared via hardware. The meaning of writing and reading LOAD bit is different. Writing: 0 = No effect. 1 = Load new period and duty in their buffers while a PWM period is completed. Reading: 0 = A loading of new period and duty is finished. 1 = A loading of new period and duty is not yet finished. 5 PWMF 4 CLRPWM PWM flag This flag is set according to definitions of INTSEL[2:0] and INTTYP[1:0] in PWMINTC. This bit is cleared by software. Clear PWM counter Setting this bit clears the value of PWM 16-bit counter for resetting to 0000H. After the counter value is cleared, CLRPWM will be automatically cleared via hardware. The meaning of writing and reading CLRPWM bit is different. Writing: 0 = No effect. 1 = Clearing PWM 16-bit counter. Reading: 0 = PWM 16-bit counter is completely cleared. 1 = PWM 16-bit counter is not yet cleared. Aug. 03, 2020 Page 180 of 274 Rev. 1.09 N76E003 Datasheet PWMCON1 – PWM Control 1 7 6 5 PWMMOD[1:0] GP R/W R/W Address: DFH Bit Name 2:0 PWMDIV[2:0] 6 2 1 0 PWMDIV[2:0] R/W Reset value: 0000 0000b Group mode enable This bit enables the group mode. If enabled, the duty of first three pairs of PWM are decided by PWM01H and PWM01L rather than their original duty control registers. 0 = Group mode Disabled. 1 = Group mode Enabled. GP Bit 3 FBINEN R/W Description 5 CKCON – Clock Control 7 6 PWMCKS R/W Address: 8EH 4 PWMTYP R/W PWM clock divider This field decides the pre-scale of PWM clock source. 000 = 1/1. 001 = 1/2 010 = 1/4. 011 = 1/8. 100 = 1/16. 101 = 1/32. 110 = 1/64. 111 = 1/128. 5 - 4 T1M R/W 3 T0M R/W 2 - Name Description PWMCKS PWM clock source select 0 = The clock source of PWM is the system clock FSYS. 1 = The clock source of PWM is the overflow of Timer 1. PWMPL – PWM Period Low Byte 7 6 5 4 3 2 1 0 CLOEN R/W Reset value: 0000 0000b 1 0 PWMP[7:0] R/W Address: D9H Bit 7:0 Aug. 03, 2020 reset value: 0000 0000b Name PWMP[7:0] Description PWM period low byte This byte with PWMPH controls the period of the PWM generator signal. Page 181 of 274 Rev. 1.09 N76E003 Datasheet PWMPH – PWM Period High Byte 7 6 5 4 3 PWMP[15:8] R/W 2 Address: D1H Bit 7:0 1 0 reset value: 0000 0000b Name Description PWMP[15:8] PWM period high byte This byte with PWMPL controls the period of the PWM generator signal. PWM0L – PWM0 Duty Low Byte 7 6 5 4 3 2 1 0 PWM0[7:0] R/W Address: DAH Bit 7:0 reset value: 0000 0000b Name PWM0[7:0] Description PWM0 duty low byte This byte with PWM0H controls the duty of the output signal PG0 from PWM generator. PWM0H – PWM0 Duty High Byte 7 6 5 4 3 2 1 0 PWM0[15:8] R/W Address: D2H Bit 7:0 reset value: 0000 0000b Name PWM0[15:8] Description PWM0 duty high byte This byte with PWM0L controls the duty of the output signal PG0 from PWM generator. PWM1L – PWM/1 Duty Low Byte 7 6 5 4 3 2 1 0 PWM1[7:0] R/W Address: DBH Bit 7:0 Aug. 03, 2020 reset value: 0000 0000b Name PWM1[7:0] Description PWM1 duty low byte This byte with PWM1H controls the duty of the output signal PG1 from PWM generator. Page 182 of 274 Rev. 1.09 N76E003 Datasheet PWM1H – PWM1 Duty High Byte 7 6 5 4 3 2 1 0 PWM1[15:8] R/W Address: D3H Bit 7:0 reset value: 0000 0000b Name PWM1[15:8] Description PWM1 duty high byte This byte with PWM1L controls the duty of the output signal PG1 from PWM generator. PWM2L – PWM2 Duty Low Byte 7 6 5 4 3 2 1 0 PWM2[7:0] R/W Address: DCH Bit 7:0 reset value: 0000 0000b Name PWM2[7:0] Description PWM2 duty low byte This byte with PWM2H controls the duty of the output signal PG2 from PWM generator. PWM2H – PWM2 Duty High Byte 7 6 5 4 3 2 1 0 PWM2[15:8] R/W Address: D4H Bit 7:0 reset value: 0000 0000b Name PWM2[15:8] Description PWM2 duty high byte This byte with PWM2L controls the duty of the output signal PG2 from PWM generator. PWM3L – PWM3 Duty Low Byte 7 6 5 4 3 2 1 0 PWM3[7:0] R/W Address: DDH Bit 7:0 Aug. 03, 2020 reset value: 0000 0000b Name PWM3[7:0] Description PWM3 duty low byte This byte with PWM3H controls the duty of the output signal PG3 from PWM generator. Page 183 of 274 Rev. 1.09 N76E003 Datasheet PWM3H – PWM3 Duty High Byte 7 6 5 4 3 2 1 0 PWM3[15:8] R/W Address: D5H Bit 7:0 reset value: 0000 0000b Name PWM3[15:8] Description PWM3 duty high byte This byte with PWM3L controls the duty of the output signal PG3 from PWM generator. PWM4L – PWM4 Duty Low Byte 7 6 5 4 3 2 1 0 PWM4[7:0] R/W Address: CCH, Page:1 Bit 7:0 Name PWM4[7:0] reset value: 0000 0000b Description PWM4 duty low byte This byte with PWM4H controls the duty of the output signal PG4 from PWM generator. PWM4H – PWM4 Duty High Byte 7 6 5 4 3 2 1 0 PWM4[15:8] R/W Address: C4H, Page:1 Bit 7:0 Name PWM4[15:8] reset value: 0000 0000b Description PWM4 duty high byte This byte with PWM4L controls the duty of the output signal PG4 from PWM generator. PWM5L – PWM5 Duty Low Byte 7 6 5 4 3 2 1 0 PWM5[7:0] R/W Address: CDH, Page:1 Bit 7:0 Aug. 03, 2020 Name PWM5[7:0] reset value: 0000 0000b Description PWM5 duty low byte This byte with PWM5H controls the duty of the output signal PG5 from PWM generator. Page 184 of 274 Rev. 1.09 N76E003 Datasheet PWM5H – PWM5 Duty High Byte 7 6 5 4 3 2 1 0 PWM5[15:8] R/W Address: C5H, Page:1 Bit reset value: 0000 0000b Name 7:0 Description PWM5[15:8] PWM5 duty high byte This byte with PWM5L controls the duty of the output signal PG5 from PWM generator. PIOCON0 – PWM or I/O Select 7 6 5 PIO05 R/W Address: DEH Bit Name 4 PIO04 R/W 3 PIO03 R/W PIO05 P0.3/PWM5 pin function select 0 = P0.3/PWM5 pin functions as P0.3. 1 = P0.3/PWM5 pin functions as PWM5 output. 4 PIO04 P0.1/PWM4 pin function select 0 = P0.1/PWM4 pin functions as P0.1. 1 = P0.1/PWM4 pin functions as PWM4 output. 3 PIO03 P0.0/PWM3 pin function select 0 = P0.0/PWM3 pin functions as P0.0. 1 = P0.0/PWM3 pin functions as PWM3 output. 2 PIO02 P1.0/PWM2 pin function select 0 = P1.0/PWM2 pin functions as P1.0. 1 = P1.0/PWM2 pin functions as PWM2 output. 1 PIO01 P1.1/PWM1 pin function select 0 = P1.1/PWM1 pin functions as P1.1. 1 = P1.1/PWM1 pin functions as PWM1 output. 0 PIO00 P1.2/PWM0 pin function select 0 = P1.2/PWM0 pin functions as P1.2. 1 = P1.2/PWM0 pin functions as PWM0 output. PIOCON1 – PWM or I/O Select 7 6 5 PIO15 R/W Address: C6H, Page:1 Name 5 Aug. 03, 2020 PIO15 1 0 PIO01 PIO00 R/W R/W Reset value: 0000 0000b 2 PIO12 R/W 1 0 PIO11 R/W Reset value: 0000 0000b Description 5 Bit 2 PIO02 R/W 4 - 3 PIO13 R/W Description P1.5/PWM5 pin function select 0 = P1.5/PWM5 pin functions as P1.5. 1 = P1.5/PWM5 pin functions as PWM5 output. Page 185 of 274 Rev. 1.09 N76E003 Datasheet Bit Name Description 3 PIO13 P0.4/PWM3 pin function select 0 = P0.4/PWM3 pin functions as P0.4. 1 = P0.4/PWM3 pin functions as PWM3 output. 2 PIO12 P0.5/PWM2 pin function select 0 = P0.5/PWM2 pin functions as P0.5. 1 = P0.5/PWM2 pin functions as PWM2 output. 1 PIO11 P1.4/PWM1 pin function select 0 = P1.4/PWM1 pin functions as P1.4. 1 = P1.4/PWM1 pin functions as PWM1 output. 17.1.2 PWM Types The PWM generator provides two PWM types: edge-aligned or center-aligned. PWM type is selected by PWMTYP (PWMCON1.4). PWMCON1 – PWM Control 1 7 6 5 PWMMOD[1:0] GP R/W R/W Address: DFH Bit Name 4 PWMTYP 4 PWMTYP R/W 3 FBINEN R/W 2 1 0 PWMDIV[2:0] R/W Reset value: 0000 0000b Description PWM type select 0 = Edge-aligned PWM. 1 = Center-aligned PWM. 17.1.2.1 Edge-Aligned Type In edge-aligned mode, the 16-bit counter uses single slop operation by counting up from 0000H to {PWMPH, PWMPL} and then starting from 0000H. The PWM generator signal (PGn before PWM and Fault Brake output control) is cleared on the compare match of 16-bit counter and the duty register {PWMnH, PWMnL} and set at the 16-bit counter is 0000H. The result PWM output waveform is left-edge aligned. Aug. 03, 2020 Page 186 of 274 Rev. 1.09 N76E003 Datasheet PWMP (2nd) PWMP (1st) 12-bit counter PWM01 (2nd) PWM01 (1st) PWM01 (2nd) duty valid PG01 output PWMP (2nd) period valid Load PWM01 (2nd) Load PWMP (2nd) Figure 17.1-3. PWM Edge-aligned Type Waveform The output frequency and duty cycle for edge-aligned PWM are given by following equations: PWM frequency = FPWM (FPWM is the PWM clock source frequency divided by PWMDIV). {PWMPH,PWMPL}  1 PWM high level duty = {PWMnH,PWMnL} . {PWMPH,PWMPL}  1 17.1.2.2 Center-Aligned Type In center-aligned mode, the 16-bit counter use dual slop operation by counting up from 0000H to {PWMPH, PWMPL} and then counting down from {PWMPH, PWMPL} to 0000H. The PGn signal is cleared on the upcount compare match of 16-bit counter and the duty register {PWMnH, PWMnL} and set on the down-count compare match. Center-aligned PWM may be used to generate non-overlapping waveforms. Aug. 03, 2020 Page 187 of 274 Rev. 1.09 N76E003 Datasheet PWMP (2nd) PWMP (1st) 12-bit counter PWM01 (2nd) PWM01 (1st) PWM01 (2nd) duty valid PG01 output PWMP (2nd) period valid Load PWM01 (2nd) Load PWMP (2nd) Figure 17.1-4. PWM Center-aligned Type Waveform The output frequency and duty cycle for center-aligned PWM are given by following equations: PWM frequency = FPWM (FPWM is the PWM clock source frequency divided by PWMDIV). 2 × {PWMPH,PWMPL} PWM high level duty = {PWMnH,PWMnL} . {PWMPH,PWMPL} 17.1.3 Operation Modes After PGn signals pass through the first stage of the PWM and Fault Brake output control circuit. The PWM mode selection circuit generates different kind of PWM output modes with six-channel, three-pair signal PG0~PG5 . It supports independent mode, complementary mode, and synchronous mode. PWMCON1 – PWM Control 1 7 6 5 PWMMOD[1:0] GP R/W R/W Address: DFH Bit 7:6 Aug. 03, 2020 4 PWMTYP R/W 3 FBINEN R/W Name Description PWMMOD[1:0] PWM mode select 00 = Independent mode. 01 = Complementary mode. 10 = Synchronized mode. 11 = Reserved. Page 188 of 274 2 1 0 PWMDIV[2:0] R/W Reset value: 0000 0000b Rev. 1.09 N76E003 Datasheet 17.1.3.1 Independent Mode Independent mode is enabled when PWMMOD[1:0] (PWMCON1[7:6]) is [0:0]. It is the default mode of PWM. PG0, PG1, PG2, PG3, PG4 and PG5 output PWM signals independently. 17.1.3.2 Complementary Mode with Dead-Time Insertion Complementary mode is enabled when PWMMOD[1:0] = [0:1]. In this mode, PG0/2/4 output PWM signals the same as the independent mode. However, PG1/3/5 output the out-phase PWM signals of PG0/2/4 correspondingly, and ignore PG1/3/5 Duty register {PWMnH, PWMnL} (n:1/3/5). This mode makes PG0/PG1 a PWM complementary pair and so on PG2/PG3 and PG4/PG5. n a real motor application, a complementary PW output always has a need of “dead-time” insertion to prevent damage of the power switching device like GPIBs due to being active on simultaneously of the upper and lower switches of the half bridge, even in a “μs” duration. For a power switch device physically cannot switch on/off instantly. For the N76E003 PWM, each PWM pair share a 9-bit dead-time down-counter PDTCNT used to produce the off time between two PWM signals in the same pair. On implementation, a 0-to-1 signal edge delays after PDTCNT timer underflows. The timing diagram illustrates the complementary mode with dead-time insertion of PG0/PG1 pair. Pairs of PG2/PG3 and PG4/PG5 have the same dead-time circuit. Each pair has its own dead-time enabling bit in the field of PDTEN[3:0]. Note that the PDTCNT and PDTEN registers are all TA write protection. The dead-time control are also valid only when the PWM is configured in its complementary mode. PG0 PG1 PG0_DT PG1_DT Figure 17.1-5. PWM Complementary Mode with Dead-time Insertion Aug. 03, 2020 Page 189 of 274 Rev. 1.09 N76E003 Datasheet PDTEN – PWM Dead-time Enable (TA protected) 7 6 5 4 PDTCNT.8 R/W Address: F9H Bit 3 - 2 PDT45EN R/W 1 0 PDT23EN PDT01EN R/W R/W Reset value: 0000 0000b Name Description 4 PDTCNT.8 PWM dead-time counter bit 8 See PDTCNT register. 2 PDT45EN PWM4/5 pair dead-time insertion enable This bit is valid only when PWM4/5 is under complementary mode. 0 = No delay on GP4/GP5 pair signals. 1 = Insert dead-time delay on the rising edge of GP4/GP5 pair signals. 1 PDT23EN PWM2/3 pair dead-time insertion enable This bit is valid only when PWM2/3 is under complementary mode. 0 = No delay on GP2/GP3 pair signals. 1 = Insert dead-time delay on the rising edge of GP2/GP3 pair signals. 0 PDT01EN PWM0/1 pair dead-time insertion enable This bit is valid only when PWM0/1 is under complementary mode. 0 = No delay on GP0/GP1 pair signals. 1 = Insert dead-time delay on the rising edge of GP0/GP1 pair signals. PDTCNT – PWM Dead-time Counter (TA protected) 7 6 5 4 3 PDTCNT[7:0] R/W Address: FAH Bit 7:0 2 1 0 Reset value: 0000 0000b Name Description PDTCNT[7:0] PWM dead-time counter low byte This 8-bit field combined with PDTEN.4 forms a 9-bit PWM dead-time counter PDTCNT. This counter is valid only when PWM is under complementary mode and the correspond PDTEN bit for PWM pair is set. PWM dead-time = PDTCNT  1 . FSYS Note that user should not modify PDTCNT during PWM run time. 17.1.3.3 Synchronous Mode Synchronous mode is enabled when PWMMOD[1:0] = [1:0]. In this mode, PG0/2/4 output PWM signals the same as the independent mode. PG1/3/5 output just the same in-phase PWM signals of PG02/4 correspondingly. 17.1.4 Mask Output Control Each PWM signal can be software masked by driving a specified level of PWM signal. The PWM mask output function is quite useful when controlling Electrical Commutation Motor like a BLDC. PMEN contains six bits, Aug. 03, 2020 Page 190 of 274 Rev. 1.09 N76E003 Datasheet those determine which channel of PWM signal will be masked. PMD set the individual mask level of each PWM channel. The default value of PMEN is 00H, which makes all outputs of PWM channels follow signals from PWM generator. Note that the masked level is reversed or not by PNP setting on PWM output pins. PMEN – PWM Mask Enable 7 6 5 PMEN5 R/W Address: FBH Bit Name n PMENn PMD – PWM Mask Data 7 6 Address: FCH Bit Name n PMDn 4 PMEN4 R/W 3 PMEN3 R/W 2 PMEN2 R/W 1 0 PMEN1 PMEN0 R/W R/W Reset value: 0000 0000b Description PWMn mask enable 0 = PWMn signal outputs from its PWM generator. 1 = PWMn signal is masked by PMDn. 5 PMD5 R/W 4 PMD4 R/W 3 PMD3 R/W 2 PMD2 R/W 1 0 PMD1 PMD0 R/W R/W Reset value: 0000 0000b Description PWMn mask data The PWMn signal outputs mask data once its corresponding PMENn is set. 0 = PWMn signal is masked by 0. 1 = PWMn signal is masked by 1. 17.1.5 Fault Brake The Fault Brake function is usually implemented in conjunction with an enhanced PWM circuit. It rules as a fault detection input to protect the motor system from damage. Fault Brake pin input (FB) is valid when FBINEN (PWMCON1.3) is set. When Fault Brake is asserted PWM signals will be individually overwritten by FBD corresponding bits. PWMRUN (PWMCON0.7) will also be automatically cleared by hardware to stop PWM generating. The PWM 16-bit counter will also be reset as 0000H. A indicating flag FBF will be set by hardware to assert a Fault Brake interrupt if enabled. FBD data output remains even after the FBF is cleared by software. User should resume the PWM output only by setting PWMRUN again. Meanwhile the Fault Brake state will be released and PWM waveform outputs on pins as usual. Fault Brake input has a polarity selection by FBINLS (FBD.6) bit. Note that the Fault Brake signal feed in FB pin should be longer than eight-systemclock time for FB pin input has a permanent 8/FSYS de-bouncing, which avoids fake Fault Brake event by input noise. The other path to trigger a Fault Brake event is the ADC compare event. It asserts the Fault Brake behavior just the same as FB pin input. See Sector 18.1.3 “ADC Conversion Result Comparator” on page 197. Aug. 03, 2020 Page 191 of 274 Rev. 1.09 N76E003 Datasheet 0 FB (P1.4) De-bounce 1 FBINLS FBINEN ADC comparator Fault Brake event FBF Fault Brake interrupt ADC compare event Figure 17.1-6. Fault Brake Function Block Diagram PWMCON1 – PWM Control 1 7 6 5 PWMMOD[1:0] GP R/W R/W Address: DFH Bit Name 3 FBINEN Name 7 FBF 6 FBINLS N FBDn 3 FBINEN R/W 2 1 0 PWMDIV[2:0] R/W Reset value: 0000 0000b Description FB pin input enable 0 = PWM output Fault Braked by FB pin input Disabled. 1 = PWM output Fault Braked by FB pin input Enabled. Once an edge, which matches FBINLS (FBD.6) selection, occurs on FB pin, PWM0~5 output Fault Brake data in FBD register and PWM6/7 remains their states. PWMRUN (PWMCON0.7) will also be automatically cleared by hardware. The PWM output resumes when PWMRUN is set again. FBD – PWM Fault Brake Data 7 6 5 FBF FBINLS FBD5 R/W R/W R/W Address: D7H Bit 4 PWMTYP R/W 4 FBD4 R/W 3 FBD3 R/W 2 FBD2 R/W 1 0 FBD1 FBD0 R/W R/W Reset value: 0000 0000b Description Fault Brake flag This flag is set when FBINEN is set as 1 and FB pin detects an edge, which matches FBINLS (FBD.6) selection. This bit is cleared by software. After FBF is cleared, Fault Brake data output will not be released until PWMRUN (PWMCON0.7) is set. FB pin input level selection 0 = Falling edge. 1 = Rising edge. PWMn Fault Brake data 0 = PWMn signal is overwritten by 0 once Fault Brake asserted. 1 = PWMn signal is overwritten by 1 once Fault Brake asserted. 17.1.6 Polarity Control Each PWM output channel has its independent polarity control bit, PNP0~PNP5. The default is high active level on all control fields implemented with positive logic. It means the power switch is ON when PWM outputs Aug. 03, 2020 Page 192 of 274 Rev. 1.09 N76E003 Datasheet high level and OFF when low level. User can easily configure all setting with positive logic and then set PNP bit to make PWM actually outputs according to the negative logic. PNP – PWM Negative Polarity 7 6 5 PNP5 R/W Address: D6H Bit Name n PNPn 4 PNP4 R/W 3 PNP3 R/W 2 PNP2 R/W 1 0 PNP1 PNP0 R/W R/W Reset value: 0000 0000b Description PWMn negative polarity output enable 0 = PWMn signal outputs directly on PWMn pin. 1 = PWMn signal outputs inversely on PWMn pin. 17.2 PWM Interrupt The PWM module has a flag PWMF (PWMCON0.5) to indicate certain point of each complete PWM period. The indicating PWM channel and point can be selected by INTSEL[2:0] and INTTYP[1:0] (PWMINTC[2:0] and [5:4]). Note that the center point and the end point interrupts are only available when PWM operates in its center-aligned type. PWMF is cleared by software. PWMINTC – PWM Interrupt Control 7 6 5 INTTYP1 R/W Address: B7H, Page:1 Bit Name 4 INTTYP0 R/W 3 - 2 INTSEL2 R/W 1 0 INTSEL1 INTSEL0 R/W R/W Reset value: 0000 0000b Description 5:4 INTTYP[1:0] PWM interrupt type select These bit select PWM interrupt type. 00 = Falling edge on PWM0/1/2/3/4/5 pin. 01 = Rising edge on PWM0/1/2/3/4/5 pin. 10 = Central point of a PWM period. 11 = End point of a PWM period. Note that the central point interrupt or the end point interrupt is only available while PWM operates in center-aligned type. 2:0 INTSEL[2:0] PWM interrupt pair select These bits select which PWM channel asserts PWM interrupt when PWM interrupt type is selected as falling or rising edge on PWM0/1/2/3/4/5 pin.. 000 = PWM0. 001 = PWM1. 010 = PWM2. 011 = PWM3. 100 = PWM4. 101 = PWM5. Others = PWM0. The PWM interrupt related with PWM waveform is shown as figure below. Aug. 03, 2020 Page 193 of 274 Rev. 1.09 N76E003 Datasheet Edge-aligned PWM Center-aligned PWM Central point 12-bit PWM counter End point Dead time PWM0/2/4 pin output PWMF (falling edge) (INTTYP[1:0] = [0:0]) Software clear PWMF (rising edge) (INTTYP[1:0] = [0:1]) PWMF (central point) (INTTYP[1:0] = [1:0]) Reserved PWMF (end point) (INTTYP[1:0] = [1:1]) Reserved Figure 17.2-1. PWM Interrupt Type Fault Brake event requests another interrupt, Fault Brake interrupt. It has different interrupt vector from PWM interrupt. When either Fault Brake pin input event or ADC compare event occurs, FBF (FBD.7) will be set by hardware. It generates Fault Brake interrupt if enabled. The Fault Brake interrupt enable bit is EFB (EIE.5). FBF Is cleared via software. Aug. 03, 2020 Page 194 of 274 Rev. 1.09 N76E003 Datasheet 18. 12-BIT ANALOG-TO-DIGITAL CONVERTER (ADC) The N76E003 is embedded with a 12-bit SAR ADC. The ADC (analog-to-digital converter) allows conversion of an analog input signal to a 12-bit binary representation of that signal. The N76E003 is selected as 8-channel inputs in single end mode. The internal band-gap voltage also can be the internal ADC input. The analog input, multiplexed into one sample and hold circuit, charges a sample and hold capacitor. The output of the sample and hold capacitor is the input into the converter. The converter then generates a digital result of this analog level via successive approximation and stores the result in the result registers. 18.1 Functional Description 18.1.1 ADC Operation AIN0 AIN1 AIN2 AIN3 AIN4 AIN5 AIN6 AIN7 Internal band-gap VREF VDD 0000 0001 0010 ADCF 0011 12-bit SAR ADC 0100 0101 0110 ADC interrupt 12 0111 A/D convertion start 1000 ADCEN ADCHS[3:0] ADCRH ADCRL ADC result comparator ADCS External Trigger [00] P0.4 P1.3 0 1 PWM0 PWM2 PWM4 STADC 00 [01] 01 ADCDLY 10 11 [10] ADCEX [11] STADCPX ETGSEL[1:0] (ADCCON0[5:4]) ETGTYP[1:0] (ADCCON1[3:2]) Figure 18.1-1. 12-bit ADC Block Diagram Aug. 03, 2020 Page 195 of 274 Rev. 1.09 N76E003 Datasheet Before ADC operation, the ADC circuit should be enabled by setting ADCEN (ADCCON1.0). This makes ADC circuit active. It consume extra power. Once ADC is not used, clearing ADCEN to turn off ADC circuit saves power. The ADC analog input pin should be specially considered. ADCHS[2:0] are channel selection bits that control which channel is connected to the sample and hold circuit. User needs to configure selected ADC input pins as input-only (high impedance) mode via respective bits in PxMn registers. This configuration disconnects the digital output circuit of each selected ADC input pin. But the digital input circuit still works. Digital input may cause the input buffer to induce leakage current. To disable the digital input buffer, the respective bits in AINDIDS should be set. Configuration above makes selected ADC analog input pins pure analog inputs to allow external feeding of the analog voltage signals. Also, the ADC clock rate needs to be considered carefully. The ADC maximum clock frequency is listed in Table 31-9. ADC Electrical Characteristics Clock above the maximum clock frequency degrades ADC performance unpredictably. An A/D conversion is initiated by setting the ADCS bit (ADCCON0.6). When the conversion is complete, the hardware will clear ADCS automatically, set ADCF (ADCCON0.7) and generate an interrupt if enabled. The new conversion result will also be stored in ADCRH (most significant 8 bits) and ADCRL (least significant 4 4095× bits). The 12-bit ADC result value is VAIN VREF . By the way, digital circuitry inside and outside the device generates noise which might affect the accuracy of ADC measurements. If conversion accuracy is critical, the noise level can be reduced by applying the following techniques: 1. Keep analog signal paths as short as possible. Make sure to run analog signals tracks well away from highspeed digital tracks. 2. Place the device in Idle mode during a conversion. 3. If any AIN pins are used as digital outputs, it is essential that these do not switch while a conversion is in progress. 18.1.2 ADC Conversion Triggered by External Source Besides setting ADCS via software, the N76E003 is enhanced by supporting hardware triggering method to start an A/D conversion. If ADCEX (ADCCON1.1) is set, edges or period points on selected PWM channel or edges of STADC pin will automatically trigger an A/D conversion. (The hardware trigger also sets ADCS by hardware.) For application flexibility, STADC pin can be exchanged by STADCPX (ADCCON1.6). Aug. 03, 2020 Page 196 of 274 Rev. 1.09 N76E003 Datasheet The effective condition is selected by ETGSEL (ADCCON0[5:4]) and ETGTYP (ADCCON1[3:2]). A trigger delay can also be inserted between external trigger point and A/D conversion. The external trigging ADC hardware with controllable trigger delay makes the N76E003 feasible for high performance motor control. Note that during ADC is busy in converting (ADCS = 1), any conversion triggered by software or hardware will be ignored and there is no warning presented. [00] PWM0 PWM2 PWM4 STADC 00 [01] 01 ADCDLY 10 External Trigger [10] 11 [11] ETGSEL[1:0] (ADCCON0[5:4]) ETGTYP[1:0] (ADCCON1[3:2]) Figure 18.1-2. External Triggering ADC Circuit 18.1.3 ADC Conversion Result Comparator The N76E003 ADC has a digital comparator, which compares the A/D conversion result with a 12-bit constant value given in ACMPH and ACMPL registers. The ADC comparator is enabled by setting ADCMPEN (ADCCON2.5) and each compare will be done on every A/D conversion complete moment. ADCMPO (ADCCON2.4) shows the compare result according to its output polarity setting bit ADCMPOP (ADCCON2.6). The ADC comparing result can trigger a PWM Fault Brake output directly. This function is enabled when ADFBEN (ADCCON2.7). When ADCMPO is set, it generates a ADC compare event and asserts Fault Brake. Please also see ector 8. .5“Fault Brake” on page ADCR[11:0] + ADCMP[11:0] - ADCMPEN (ADCCON2.5) 0 9. ADCMPO (ADCCON2.4) 1 ADFBEN (ADCCON2.7) ADC compare event ADCMPOP (ADCCON2.6) Figure 18.1-3. ADC Result Comparator Aug. 03, 2020 Page 197 of 274 Rev. 1.09 N76E003 Datasheet 18.1.4 Internal Band-gap At room temperature, all N76E003 band-gap voltage values will be calibrated within the range of 1.17V to 1.30V. If you want to get the actual band-gap value for N76E003, read the 2 bytes value after the UID address and the actually valid bit is 12. The first byte is the upper 8 bits, and the lower 4 bits of the second byte are the lower 4 bits of the 12 bit. Reading and calculation steps: 1. Read a bad-gap value with IAP by reading UID; 2. Merge the upper 8 bits and the lower 4 bits; 3. Use the following formula to convert to an actual voltage value. Formula as following For example: Read the 2 bytes value after the UID address, wherein the first byte value is 0x64, and the second byte value is 0x0E, merged as 0x64E = 1614. The conversion result is as follows: #define set_IAPEN BIT_TMP=EA;EA=0;TA=0Xaa;TA=0x55;CHPCON|=SET_BIT0 ;EA=BIT_TMP #define set_IAPGO BIT_TMP=EA;EA=0;TA=0Xaa;TA=0x55;IAPTRG|=SET_BIT0 ;EA=BIT_TMP #define clr_IAPEN BIT_TMP=EA;EA=0;TA=0Xaa;TA=0x55;CHPCON&=~SET_BIT0;EA=BIT_TMP void READ_BANDGAP() { UINT8 BandgapHigh,BandgapLow; Set_IAPEN; // Enable IAPEN IAPAL = 0x0C; IAPAH = 0x00; IAPCN = 0x04; set_IAPGO; // Trig set IAPGO BandgapHigh = IAPFD; IAPAL = 0x0d; IAPAH = 0x00; Aug. 03, 2020 Page 198 of 274 Rev. 1.09 N76E003 Datasheet IAPCN = 0x04; set_IAPGO; // Trig set IAPGO BandgapLow = IAPFD; BandgapLow = BandgapLow&0x0F; Clr_IAPEN; // Disable IAPEN Bandgap_Value = (BandgapHigh
N76E003AS20 价格&库存
很抱歉,暂时无法提供与“N76E003AS20”相匹配的价格&库存,您可以联系我们找货
N76E003AS20
  • 1+7.298981+0.94852
  • 10+6.2562710+0.81302
  • 38+5.6265538+0.73119
  • 114+5.13870114+0.66779
  • 266+4.80192266+0.62403
  • 532+4.55680532+0.59217
  • 1026+4.350981026+0.56542
  • 2508+4.112162508+0.53439
  • 5016+3.957865016+0.51434
库存:12610
