LP5305AQVF
LP5305AQVF
    LPSEMI(微源)
    DFN-8-EP(2x2)
    过压和过流保护集成电路
LP5305AQVF 数据手册
LP5305A Preliminary Datasheet Over Voltage and Over Current Protection IC General Description Features The LP5305A is a highly integrated circuits, it used to protect low voltage system from abnormal high input voltage. The IC continuously check the input voltage, the input current, and the battery voltage. When the protection status is occur, the power MOS will turn off at the same time. The LP5305A is safety devices to ensure worked against accidents.             In case of the input voltage exceeds a OVP threshold voltage level, the power MOS will turn off within 1μs. The current limit can is adjustable by external resistor between ISET and GND. And the current is also limited to prevent charging the battery with an excessive current. The LP5305A also monitors the Li-ion battery voltage, when the battery voltage exceeds 4.35V, the IC will turn off the MOS. Other features include over temperature protection and under-voltage lockout (UVLO). The LP5305A is available in a space saving DFN-8 package. LP5305A F: Green Package Type QV: DFN-8 Version 0.3 JUL.-2019 Applications    Cell Phones Digital Cameras Portable Instruments Marking Information Order Information LP5305A □□□ Withstand High Input Voltage Up to 26V Adjustable Over Current Protection Input Over Voltage Protection Battery Over Voltage Protection High Accuracy Protection Thresholds Fault Signal Output Enable Control Under Voltage Lockout Output Short-Circuit Protection Over-Temperature Protection Available in DFN-8 RoHS Compliant and Halogen Free Device Marking Package Shipping LP5305A LPS DFN-8 4K/REEL P5305A YWX Y: Y is year code. W: W is week code. X: X is series number. Email: marketing@lowpowersemi.com www.lowpowersemi.com Page 1 of 7 LP5305A Preliminary Datasheet Typical Application Circuit VBUS VIN VOUT LP5305A Cin Fault BAT EN H/L ISET GND VOUT VDD COUT RPU Fault RBAT RSET Battery Figure 1. Typical Application Circuit of LP5305A . Pin Configuration VIN 1 GND 2 NC 3 Fault 4 Exposed Pad 8 VOUT 7 ISET 6 BAT 5 EN Figure 2. Package Top View LP5305A Version 0.3 JUL.-2019 Email: marketing@lowpowersemi.com www.lowpowersemi.com Page 2 of 7 LP5305A Preliminary Datasheet Function Block Diagram VOUT VIN Driver OCP ISET Switch BAT EN UVLO OTP OVP OSC Control Logic Fault GND Fault Figure 3. Function Block Diagram Functional Pin Description Pin NO. DFN8 VIN 1 Power source input. Connect a ceramic capacitor between VIN and GND. GND 2 Ground. NC 3 No connect. Fault 4 Fault output pin. Open-drain output, device status. EN 5 Enable pin. BAT 6 Battery voltage detector input. ISET 7 OCP level setting by an external resistor to GND. VOUT 8 Output through the power MOSFET. EP LP5305A Description Exposed pad. Connect EP to GND is suggested. Version 0.3 JUL.-2019 Email: marketing@lowpowersemi.com www.lowpowersemi.com Page 3 of 7 LP5305A Preliminary Datasheet Absolute Maximum Ratings Note1  VIN to GND -------------------------------------------------------------------------------------------------------- -0.3V to +30V  VOUT to GND ---------------------------------------------------------------------------------------------------- -0.3V to +7V  All Other Pin to GND -------------------------------------------------------------------------------------------- -0.3V to +7V  Operating Junction Temperature Range (TJ)  Operation Ambient Temperature Range ------------------------------------------------------------- -40°C to +105°C  Storage Temperature Range  Maximum Soldering Temperature (at leads, 10sec) -------------------------------------------------------- -40℃ to 150℃ ---------------------------------------------------------------------------- -65°C to +150°C ----------------------------------------------- +260°C Note1. Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Thermal Information  Thermal Resistance DFN-8, θJA ----------------------------------------------------------------------------------------------------- 76.11 °C/W DFN-8, θJC ---------------------------------------------------------------------------------------------------- 68.46 °C/W Recommended Operating Conditions  Input Voltage, VIN ------------------------------------------------------------------------------------------------- 3.3V to 5V  Output Current, IOUT --------------------------------------------------------------------------------------------- 0.3A to 1.5A  OCP Set Resistance, RSET ------------------------------------------------------------------------------------ 15kΩ to 90kΩ  Junction Temperature, TJ -------------------------------------------------------------------------------------- -40°C to 125°C LP5305A Version 0.3 JUL.-2019 Email: marketing@lowpowersemi.com www.lowpowersemi.com Page 4 of 7 LP5305A Preliminary Datasheet Electrical Characteristics (VIN = 5V, TA = 25°C, Unless Otherwise Specified) Parameter Symbol Test Conditions Min Typ Max Units General Function Power Source Voltage VIN TJ= +25 °C 3.3 5 26 V Input UVLO Threshold VUVLO V IN Rising 2.5 2.7 2.9 V UVLO Threshold Hysteresis ΔVUVLO Power On Deglitch Time Soft Start Time Falling Hysteresis 200 mV TDeglitch 8 ms TSS 8.2 ms Power Source Current IIN VIN=5V, EN=L 400 µA Shutdown Current ISD VIN=5V, EN=H 55 uA Thermal Shutdown Threshold TSD 140 °C Thermal Shutdown Threshold Hysteresis ΔTSD 20 °C Logic Function EN Threshold Voltage EN Input Resistance to GND VENH 1.4 V VENL IEN 0.4 V EN=2V 15 uA FAULT Output Logic Low Sink 5mA 0.2 V FAULT Logic High Leakage Current Fault=5V 10 uA 250 mΩ Power MOS Switch On Resistance RDS(ON) IOUT=1A 160 VLDO VIN=5.7V 5.1 V VIOVP VIN from 5V to 10V 6.8 V Input OVP threshold Hysteresis ΔVIOVP VIN from 10V to 5V 100 mV Input OVP Recovery Delay Time TOVPR 8.2 ms 1 A Regulation Function Output Voltage Regulation Protection Functions Input Over Voltage Protect threshold RSET = 24.9K, 3.3V
LP5305AQVF 价格&库存
很抱歉,暂时无法提供与“LP5305AQVF”相匹配的价格&库存,您可以联系我们找货
