CZHR-11V-S
CZHR-11V-S
    JST
    P=1.5mm
CZHR-11V-S 数据手册
CZ FAMILY SERIES/CZ・CZW・CZH・CZHW・TZ・TZW 1.5mm pitch/Disconnectable Insulation displacement connectors CZ connector • Distortion resistant construction • Compact and low profileCZW connector CZW connector • Low insertion force • Locking construction CZH connector • Housing lance • Intarchangeability TZ/TZW connector • The TZ connector is applicable to single-row connection, while the TZW connector is for dual-row connection. • Applicable to wide range of panel thickness • The design of the panel lock part does not allow the wires to be caught there before mounting on the panel. CZ connector: Side entry type header CZ connector: Top entry type TZ connector RPZ connector: Receptacle TZW connector RPZ connector: Plug CZW connector: Socket holder Standards –––––––––––––––––––––– CZW connector: Header 0 1 Certified LR20812 CZ connector: Socket Recognized E60389 Specifications ––––––––––––––––––– Item Serise Current rating Voltage rating Temperature rise Contact resistance ※ CZ connector used for the harness shown in the abovementioned figure can be replaced to CZH connector. Insulation resistance Withstanding voltage CZ / CZW connector TZ / TZW CZH / CZHW connector connector 2 A AC, DC (AWG #26) 100 V AC, DC -25°C to +85°C (including temperature rise) Initial value / 20 mΩ max. Initial value / 10 mΩ max. After environmental After environmental tests tests / 40 mΩ max. / 20 mΩ max. 500 MΩ min. 500 VAC/minute UL10272 (Contact JST for other UL style wires.) AWG #28, #26 Applicable wire Conductor / 7-strands, tincoated annealed copper Insulation O.D. / 0.7 to 0.83 mm Based upon the 1.5 mm pitch CZ connectors, the CZ family connectors have been expanded to meet the requirements of high density packaging. The CZW connector holder allows dualrow wire-to-board connection using the CZ sockets, while the TZ (single-row) or TZW (dual-row) allows wire-to-wire connection, also using the CZ sockets. Applicable PC board thickness Applicable panel thickness AWG #28 to #26 - 1.6 mm - - 0.5 to 2 mm * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. * Compliant with RoHS. PC board layout and Assembly layout Top entry type Side entry type ±0.05 4.4 1.5 4.4 φ0.7+0.1 0 when mating with CZH Circuit No.1 4.4 3.4 ±0.05 when mating with CZ 3.4 3.4 Connector outline 9.8 4.4 ±0.05 3 7.3 6.7 ±0.05 1.5 ±0.05 2 ±0.05 0.7 Circuit No.1 9.2 φ0.8+0.1 0 φ0.8+0.1 0 3.4 ±0.05 1.5 Connector outline ±0.05 2 ±0.05 1.5 ±0.1 A 1.5 ±0.1 A φ0.7+0.1 0 when mating with CZ when mating with CZH Note: 1. The above figure is the figure viewed from the connector mounting side. 2. Tolerances are non-cumulative: ± 0.05 mm for all centers. 3. Hole dimensions differ according to the type of PC board and piercing method. The dimensions above should serve as a guideline. Contact JST for details. 1 CZ FAMILY SERIES/CZ・CZW・CZH・CZHW・TZ・TZW PC board layout and Assembly layout 4.9 Top entry type 7.2 ±0.1 ±0.05 1.5 A ±0.1 ±0.1 1.2 1.25 Connector outline 4.9 ±0.05 1.35 7.2 ±0.1 A Side entry type MIN +0.1 0 φ0.8 2.2 0.9 MIN 4.15 1.5 2.75 when mating with CZ ±0.1 ±0.1 ±0.05 2.7 7.8 Connector outline +0.1 0 ±0.05 MIN φ0.8 1.35 0.9 4.9 ±0.1 1.25 7.8 0.2 ±0.1 1.2 3.7 ±0.1 4.9 4.35 ±0.1 3.7 2.55 ±0.1 2.7 ±0.1 MIN when mating with CZ when mating with CZH when mating with CZH Top entry type Side entry type A±0.1 +0.1 φ1.2 0 ±0.1 A 1.5±0.05 +0.1 0 φ0.7 ±0.05 1.5 9 1 ±0.05 +0.1 φ0.7 0 2 ±0.05 ±0.05 10.6 10.8 8.3 ±0.05 ±0.05 3.4 (3) ±0.05 2 3.4 Line B / Circuit No.1 (when Line B is of odd numbers) 5.8 3.3 ±0.05 8.3 2.5±0.05 2.5±0.05 2.5±0.05 Line A / Circuit No.1 Line B / Circuit No.1 (when Line B is of even numbers) 14.3 ±0.05 0.8 Connector outline Connector outline ±0.05 2.8 when mating with CZW/CZHW when mating with CZW/CZHW +0.1 ±0.05 10 ±0.1 8.1 0.8 ±0.05 MIN φ1.2  0 2.7 2 8.6 A ±0.1 Connector outline when mating with CZHW 0.9 MIN 1.5 ±0.05 Note: 1. The above figure is the figure viewed from the connector mounting side. 2. Tolerances are non-cumulative: ± 0.05 mm for all centers. 3. Hole dimensions differ according to the type of PC board and piercing method. The dimensions above should serve as a guideline. Contact JST for details. ±0.05 5.4 +0.1 5.9 D 0 +0.1 when mating with CZ 11.8 11 0 ±0.05 5.2 4 ±0.05 3.9 14.5 +0.1 D 0 ±0.1 5.4 E 3.9 E ±0.1 4.95 16.7 15 when mating with CZH D,E dimensions: Refer to TZ connector (Until for wire-to-wire connection). when mating with CZ/CZH D,E dimensions: Refer to TZ connector (Dual-row until for wire-to-wire connection). 2 CZ FAMILY SERIES/CZ・CZW・CZH・CZHW・TZ・TZW CZ connector socket 3 4 5 6 4.4 7 8 A 9 10 2.7 4.1 HJST 11 12 13 14 4.1 15 16 Circuit No.1(Triangle-mark indicates.) Yellow 02CZ-6Y 03CZ-6Y 04CZ-6Y 05CZ-6Y 06CZ-6Y 07CZ-6Y 08CZ-6Y 09CZ-6Y 10CZ-6Y 11CZ-6Y 12CZ-6Y 13CZ-6Y 14CZ-6Y 15CZ-6Y 16CZ-6Y 17CZ-6Y 18CZ-6Y 19CZ-6Y 20CZ-6Y Gray 02CZ-6H 03CZ-6H 04CZ-6H 05CZ-6H 06CZ-6H 07CZ-6H 08CZ-6H 09CZ-6H 10CZ-6H 11CZ-6H 12CZ-6H 13CZ-6H 14CZ-6H 15CZ-6H 16CZ-6H 17CZ-6H 18CZ-6H 19CZ-6H 20CZ-6H 2 B Dimensions (mm) Model No. Circuits 17 18 19 20 Q'ty/box A B 1.5 4.5 2,000 3.0 6.0 2,000 4.5 7.5 2,000 6.0 9.0 2,000 7.5 10.5 2,000 9.0 12.0 2,000 10.5 13.5 2,000 12.0 15.0 1,000 13.5 16.5 1,000 15.0 18.0 1,000 16.5 19.5 1,000 18.0 21.0 1,000 19.5 22.5 1,000 21.0 24.0 1,000 22.5 25.5 1,000 24.0 27.0 1,000 25.5 28.5 1,000 27.0 30.0 1,000 28.5 31.5 1,000 Material and Finish Contact: Phosphor bronze, tin-plated (reflow treatment) Housing: Glass-filled PA 66, UL94V-0 RoHS compliance As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. 02CZ-6HY…yellow H…natural (grayish color) CZH connector contact Applicable wire mm2 AWG # Model No. SCZH-002T-P0.5 4.05 2.2 0.08∼0.13 1.1 Insulation O.D. (mm) Q'ty/ reel 0.8∼1.1 13,000 28∼26 Material and Finish Phosphor bronze, tin-plated (reflow treatment) 1.5 RoHS compliance Contact Applicator Dies Crimping machine Crimp applicator 1.1 MKS-L SCZH-002T-P0.5 AP-K2N Crimp applicator with dies MK/SCZH-002-05 APLMK SCZH002-05 −− − − CZH connector housing B A 3.7 1.5 Circuits Model No. 2 CZHR-02V-S CZHR-03V-S CZHR-04V-S CZHR-05V-S CZHR-06V-S CZHR-07V-S CZHR-08V-S CZHR-09V-S CZHR-10V-S CZHR-11V-S CZHR-12V-S CZHR-13V-S CZHR-14V-S CZHR-15V-S CZHR-16V-S CZHR-17V-S CZHR-19V-S CZHR-20V-S 3 4 5 6 1 7 2 3 4 5 8 9 10 11 C 2.7 12 13 14 15 RoHS compliance 16 As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. 17 ex. 3 CZHR-02V-SS…natural (white) K…black H…gray Y…yellow 19 20 Dimensions(mm) A B C Q'ty/ box 1.5 4.5 3.5 1,000 3.0 6.0 5.0 1,000 4.5 7.5 6.5 1,000 6.0 9.0 8.0 1,000 7.5 10.5 9.5 1,000 9.0 12.0 11.0 1,000 10.5 13.5 12.5 1,000 12.0 15.0 14.0 1,000 13.5 16.5 15.5 1,000 15.0 18.0 17.0 1,000 16.5 19.5 18.5 1,000 18.0 21.0 20.0 1,000 19.5 22.5 21.5 1,000 21.0 24.0 23.0 1,000 22.5 25.5 24.5 1,000 24.0 27.0 26.0 1,000 27.0 30.0 29.0 1,000 28.5 31.5 30.5 1,000 Material PBT, UL94V-0, natural (white) CZ FAMILY SERIES/CZ・CZW・CZH・CZHW・TZ・TZW CZW connector holder 0.8 A 0.8 Dimensions (mm) Circuits Model No. 16 CZWH-16-S CZWH-18-S CZWH-20-S CZWH-22-S CZWH-24-S CZWH-26-S CZWH-28-S CZWH-30-S CZWH-32-S CZWH-34-S CZWH-36-S CZWH-38-S CZWH-40-S B 18 Line A / Circuit No.1 20 22 24 26 H JST 28 30 Line B / Circuit No.1 32 8.1 34 36 38 5.7 40 A B Q'ty/ box 14.9 13.5 1,000 16.4 15.0 1,000 17.9 16.5 1,000 19.4 18.0 1,000 20.9 19.5 1,000 22.4 21.0 1,000 23.9 22.5 1,000 25.4 24.0 1,000 26.9 25.5 1,000 28.4 27.0 1,000 29.9 28.5 1,000 31.4 30.0 1,000 32.9 31.5 1,000 Material PBT, UL94V-0, natural (white) RoHS compliance CZ connector through-hole type shrouded header B Top entry type 4.2 Circuits A 2 3 6.6 4 5 6 7 3.4 8 9 10 1.5 1.5 Circuit No.1 11 2 Circuit No.1 12 Side entry type 13 B A 4.2 14 15 1.5 16 17 JST 3 18 19 20 2 9.1 H Model No. Top entry type B02B-CZHK-B-1 B03B-CZHK-B-1 B04B-CZHK-B-1 B05B-CZHK-B-1 B06B-CZHK-B-1 B07B-CZHK-B-1 B08B-CZHK-B-1 B09B-CZHK-B-1 B10B-CZHK-B-1 B11B-CZHK-B-1 B12B-CZHK-B-1 B13B-CZHK-B-1 B14B-CZHK-B-1 B15B-CZHK-B-1 B16B-CZHK-B-1 B17B-CZHK-B-1 B18B-CZHK-B-1 B19B-CZHK-B-1 B20B-CZHK-B-1 Side entry type S02B-CZHK-B-1 S03B-CZHK-B-1 S04B-CZHK-B-1 S05B-CZHK-B-1 S06B-CZHK-B-1 S07B-CZHK-B-1 S08B-CZHK-B-1 S09B-CZHK-B-1 S10B-CZHK-B-1 S11B-CZHK-B-1 S12B-CZHK-B-1 S13B-CZHK-B-1 S14B-CZHK-B-1 S15B-CZHK-B-1 S16B-CZHK-B-1 S17B-CZHK-B-1 S18B-CZHK-B-1 S19B-CZHK-B-1 S20B-CZHK-B-1 Dimensions (mm) Q'ty/box A B 1.5 6.0 2,072 1,480 3.0 7.5 1,624 1,160 4.5 9.0 1,344 960 6.0 10.5 1,176 840 7.5 12.0 1,008 720 9.0 13.5 896 640 10.5 15.0 784 560 12.0 16.5 728 520 13.5 18.0 672 480 15.0 19.5 616 440 16.5 21.0 560 400 18.0 22.5 504 360 19.5 24.0 504 360 21.0 25.5 448 320 22.5 27.0 448 320 24.0 28.5 392 280 25.5 30.0 392 280 27.0 31.5 392 280 28.5 33.0 336 240 Top entry type Side entry type Material and Finish Circuit No.1 3.4 Circuit No.1 As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. Pin: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: Glass-filled PA 66, UL94V-0, natural (grayish color) Note: Models B( )B-CZHK-B are the headers without the boss. Note: Models S( )B-CZHK-B are the headers without the boss. RoHS compliance This product displays (LF)(SN) on a label. B02B-CZHK-B-1 H…natural (grayish color) Y…yellow K…black CZ connector SMT type shrouded header Top entry type 4.7 B 1 A Circuits 2 4 JST 5 6 7.1 H 5 8 10 13 14 15 1.5 1.5 1.35 16 17 Side entry type 20 Model No. Top entry type BM02B-CZSS-1-TF BM04B-CZSS-1-TF BM05B-CZSS-1-TF BM06B-CZSS-1-TF BM08B-CZSS-1-TF BM10B-CZSS-1-TF BM13B-CZSS-1-TF BM14B-CZSS-1-TF BM15B-CZSS-1-TF BM16B-CZSS-1-TF BM17B-CZSS-1-TF BM20B-CZSS-1-TF Side entry type SM02B-CZSS-1-TB SM04B-CZSS-1-TB SM05B-CZSS-1-TB SM06B-CZSS-1-TB SM08B-CZSS-1-TB SM10B-CZSS-1-TB SM13B-CZSS-1-TB − − SM16B-CZSS-1-TB − − Dimensions( mm) Q’ty/reel A B 1.5 6.0 800 1,250 4.5 9.0 800 1,250 6.0 10.5 800 1,250 7.5 12.0 800 1,250 10.5 15.0 800 1,250 13.5 18.0 800 1,250 18.0 22.5 800 1,250 19.5 24.0 800 21.0 25.5 800 − − 22.5 27.0 800 1,250 24.0 28.5 800 28.5 33.0 800 − − Top entry type Side entry type 4.7 B Material and Finish A Pin: Copper alloy, copper-undercoated, tin-plated (reflow treatment) JST Wafer: PA, UL94V-0, natural (ivory) Solder tab: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Note: Models BM( )B-CZSS-TF are the headers without the boss. Note: Models SM( )B-CZSS-TF are the headers without the boss. 5 7.1 H RoHS compliance This product displays (LF)(SN) on a label. 1.5 1.5 1.35 As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. B02B-CZSS-1-TF- S…natural (ivory) H…gray 4 CZ FAMILY SERIES/CZ・CZW・CZH・CZHW・TZ・TZW CZW connector through-hole type shrouded header Top entry type Circuits 16 B 18 Line A / Circuit No.1 A 20 22 B1 HJST A1 24 26 28 30 Line B / Circuit No.1 32 1.5 9 34 36 38 8.3 40 Model No. Top entry type B16B-CZWHK-B-1 B18B-CZWHK-B-1 B20B-CZWHK-B-1 B22B-CZWHK-B-1 B24B-CZWHK-B-1 B26B-CZWHK-B-1 B28B-CZWHK-B-1 B30B-CZWHK-B-1 B32B-CZWHK-B-1 B34B-CZWHK-B-1 B36B-CZWHK-B-1 B38B-CZWHK-B-1 B40B-CZWHK-B-1 Side entry type − − S20B-CZWHS-B-1 − − S26B-CZWHS-B-1 − − − − − − S40B-CZWHS-B-1 Dimensions (mm) Q'ty/box A B 10.5 18.0 420 12.0 19.5 385 − 13.5 21.0 350 280 15.0 22.5 315 16.5 24.0 315 − − 18.0 25.5 280 224 19.5 27.0 280 21.0 28.5 245 22.5 30.0 245 24.0 31.5 245 25.5 33.0 210 27.0 34.5 210 − − − − − − 28.5 36.0 210 168 Top entry type Side entry type − Material and Finish 1.5 3.4 Pin: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: Glass-filled PA 66, UL94V-0, natural (grayish color) Note: Models B( )B-CZWHK-B are the headers without the boss. RoHS compliance This product displays (LF)(SN) on a label. Side entry type As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. B 14.3 A Circuit No. B16B-CZWHK-B-1H…natural (grayish color) Y…yellow Line A / Circuit No.1 1.5 HJST 3.5 3.4 10.5 A1 B1 Line B / Circuit No.1 (3) 0.8 3.3 (2.5) CZW connector SMT type shrouded header Top entry type B Line A / Circuit No.1 0.5 36 BM36B-CZWSS-1-TF BM40B-CZWSS-1-TF Q'ty/reel A B 25.5 33.0 300 28.5 36.0 300 Material and Finish A1 36 RoHS compliance This product displays (LF)(SN) on a label. JST B1 1.5 8 10 2 Dimensions (mm) Press pin: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: PA, UL94V-0, natural (ivory) Note: Models BM( )B-CZWSS-TF are the headers without the boss. Line B / Circuit No.1 5 Model No. 40 A 1.5 Circuits 3.5 CZ FAMILY SERIES/CZ・CZW・CZH・CZHW・TZ・TZW TZ connector (Unit for wire-to-wire connection) Circuits 2 3 4 5 C A 3.8 5.4 6 7 1.9 8 9 3.9 10 11 10.6 H JST 7 14.5 12 13 14 15 16 17 18 B 3.2 19 5 20 Model No. BU02P-TZ-S BU03P-TZ-S BU04P-TZ-S BU05P-TZ-S BU06P-TZ-S BU07P-TZ-S BU08P-TZ-S BU09P-TZ-S BU10P-TZ-S BU11P-TZ-S BU12P-TZ-S BU13P-TZ-S BU14P-TZ-S BU15P-TZ-S BU16P-TZ-S BU17P-TZ-S BU18P-TZ-S BU19P-TZ-S BU20P-TZ-S Dimensions (mm) Q'ty/box A B C D E 1.5 5.9 3.5 6.3 9.9 500 3.0 7.4 5.0 7.8 11.4 500 4.5 8.9 6.5 9.3 12.9 500 6.0 10.4 8.0 10.8 14.4 500 7.5 11.9 9.5 12.3 15.9 250 9.0 13.4 11.0 13.8 17.4 250 10.5 14.9 12.5 15.3 18.9 250 12.0 16.4 14.0 16.8 20.4 250 13.5 17.9 15.5 18.3 21.9 250 15.0 19.4 17.0 19.8 23.4 250 16.5 20.9 18.5 21.3 24.9 250 18.0 22.4 20.0 22.8 26.4 250 19.5 23.9 21.5 24.3 27.9 250 21.0 25.4 23.0 25.8 29.4 250 22.5 26.9 24.5 27.3 30.9 250 24.0 28.4 26.0 28.8 32.4 250 25.5 29.9 27.5 30.3 33.9 150 27.0 31.4 29.0 31.8 35.4 150 28.5 32.9 30.5 33.3 36.9 100 Material and Finish Pin: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Housing: PA 66, UL94V-0, natural (white) RoHS compliance This product displays (LF)(SN) on a label. Note: D and E dimensions; Refer to the panel layout of TZ connector (Page2). TZW connector (Dual-row unit for wire-to-wire connection) Circuits Model No. 16 BU16P-TZW-S BU18P-TZW-S BU20P-TZW-S BU22P-TZW-S BU24P-TZW-S BU26P-TZW-S BU28P-TZW-S BU30P-TZW-S BU32P-TZW-S BU34P-TZW-S BU36P-TZW-S BU38P-TZW-S BU40P-TZW-S 18 B A 20 10.8 22 3.25 24 26 4.95 28 30 14.8 11.75 32 34 36 38 40 Dimensions (mm) Q'ty/box A B C D E 10.5 15.0 19.0 19.4 23.0 160 12.0 16.5 20.5 20.9 24.5 140 13.5 18.0 22.0 22.4 26.0 140 15.0 19.5 23.5 23.9 27.5 140 16.5 21.0 25.0 25.4 29.0 120 18.0 22.5 26.5 26.9 30.5 120 19.5 24.0 28.0 28.4 32.0 120 21.0 25.5 29.5 29.9 33.5 100 22.5 27.0 31.0 31.4 35.0 100 24.0 28.5 32.5 32.9 36.5 100 25.5 30.0 34.0 34.4 38.0 100 27.0 31.5 35.5 35.9 39.5 100 28.5 33.0 37.0 37.4 41.0 80 Material and Finish C 3.2 Pin: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Housing: PA 66, UL94V-0, natural (white) RoHS compliance This product displays (LF)(SN) on a label. Note: D and E dimensions; Refer to the panel layout of TZW connector (Page2). 6
CZHR-11V-S 价格&库存
很抱歉,暂时无法提供与“CZHR-11V-S”相匹配的价格&库存,您可以联系我们找货
CZHR-11V-S
    • 1000+0.51040
    库存:60000
    CZHR-11V-S
      • 1000+0.42460
      库存:10000
      CZHR-11V-S
      • 1+1.485301+0.19190
      • 10+1.2218010+0.15790
      • 25+1.0169025+0.13140
      • 100+0.91150100+0.11780
      • 250+0.77980250+0.10080
      • 1000+0.657601000+0.08500
      • 3000+0.596503000+0.07710
      • 10000+0.5438010000+0.07030
      • 20000+0.4911020000+0.06350
      CZHR-11V-S
        • 500+0.42141
        库存:60000
        CZHR-11V-S
          库存:3060
