HX1001
HX8001
Synchronous Buck-Boost DC/DC Regulator
Features
Description
Synchronous rectification: Up to 95%
The HX8001 is high efficiency, fixed frequency,
efficiency
Buck-Boost DC/DC converters which operates
Single inductor
from input voltages above, below or equal to the
Fixed frequency operation with battery
output voltage. The devices are suitable for
single lithium-ion, multicell alkaline or NiMH
output
applications where the output voltage is within
Quiescent current 1mA (50uA low power
the battery voltage range.
mode: mode pin high)
The switching frequencies up to 1.5 MHz could
Up to 600mA continuous output current
be fixed by employing an external resistor, and
1.8V to 5.5V input and output voltage range
the oscillator could be synchronized to an
Programmable oscillator frequency from
external clock. the quiescent current is 1mA,
350kHz to 1.5MHz
and this feature maximizing the battery life in
No Schottky Diodes required
portable applications.
VOUT disconnected from VIN during
shutdown
Shutdown current: IQ 1µA
Package: small thermally enhanced 10-pin
MSOP
Other features include a 1 µA shutdown,
soft-start control, thermal shutdown and current
limit. The HX8001 converters are available in
the 10-pin thermally enhanced MSOP packages
(or upon request).
Application
Digital cameras and Wireless handsets
Palmtop computers
Handheld instruments
MP3/MP4 players
w w w. h x s e m i . c o m
1
HX8001
Typical Applications
Absolute Maximum Ratings
~ +6V
VRT,FB,SHDN/SS, SYNC ………………………………………….…………………- 0.3 V ~+ 6 V
V ………………………………………….……………………..……….….…..……- 0.3 V ~ + 6 V
V ……………………………………...……………………………….….…..….......- 0.3 V ~ + 6 V
Operating Temperature Range ………………...………….…………....….…........- 40℃ ~ + 85℃
Lead Temperature (Soldering 10 sec.) ….………………...………...….….…………………+ 300℃
Storage Temperature Range …………………...……………………….….……..- 65℃ ~ + 150℃
VIN ……………………………………………………………………….………….……- 0.3 V
SW
OUT
Pin Assignment
PIN
NUMBER
MSOP-10
PIN NAME
1
RT
2
MS
MODE/SYNC
3
SW1
Switch 1
4
SW2
Switch 2
5
GND
Ground
6
VOUT
Output
7
VIN
8
EN
Input
ON/OFF Control
(High Enable)
9
FB
Feedback
10
VC
Error Amp Output
FUNCTION
Program the Oscillator
MSOP-10L
www.hxsemi.com
Frequency
2
HX8001
Electrical Characteristics
Operating Conditions: TA=25
℃, V
IN=3.6V
PARAMETER
unless otherwise specified.
CONDITIONS
MIN
Input Start-Up Voltage
TYP
MAX
UNITS
1.8
1.9
V
Input Operating Range
1.8
5.5
V
Output Voltage Adjust Range
2.5
5.5
V
1.212
1.220
V
0.1
1
µA
Feedback Voltage
Quiescent
Shutdown
1.200
Current,
EN=0V, Not Including Switch
Leakage
, SYNC=0V
Quiescent Current, Active
VC=0V
NMOS Switch Leakage
Switches B and C
PMOS Switch Leakage
Switches A and D
NMOS
Switch
Resistance
On
PMOS
Switch
Resistance
On
mA
0.1
5
10
0.19
Ω
Switches A and D
0.22
Ω
1
Boost (% Switch C On)
55
Buck (% Switch A On)
100
A
75
Minimum Duty Cycle
Frequency Accuracy
0.8
SYNC Input High
1
MHz
2
SYNC Input Low
SYNC Input Current
µA
µA
Switches B and C
Input Current Limit
Maximum Duty Cycle
1
0.4
VSYNC=5.5V
0.01
1
V
µA
Error Amp AVOL
90
dB
Error Amp Source Current
1.5
µA
Error Amp Sink Current
380
A
EN Input High
EN Input Low
When IC is Enabled
1.8
0.4
EN Threshold
When EA is at Maximum Boost
Duty Cycle
2.2
EN Input Current
VEN=5.5V
0.01
www.hxsemi.com
V
V
1
3
µA
HX8001
Typical Performance Characteristics
Efficiency vs. Output Current
(VOUT=3.2V)
100
90
100
90
VIN =4.2V
80
80
70
Efficiency (%)
Efficiency (%)
(VOUT=5V)
V IN =2.7V
60
VIN =3.6V
50
40
30
70
V IN =4.2V
V IN =3V
60
50
40
30
10
VIN =2.7V
400
600
800 1000 1200
100 200 300 400 500 600 700
Output Current (mA)
Output Current (mA)
Output Voltage vs. Load Current
(VIN=3.6V,VOUT=3.2V)
(VIN=4.2V,VOUT=5V)
3.21
5.24
3.209
5.21
Output Voltage (V)
Output Voltage (V)
3.208
3.207
3.206
3.205
3.204
3.203
5.18
5.15
5.12
5.09
5.06
3.202
5.03
3.201
3.2
5
400
600
Load Current (mA)
www.hxsemi.com
800
1000
200 300 400 500
Load Current (mA)
4
600
700
HX8001
Application Information
RT (Pin 1): Timing Resistor to Program the Oscillator Frequency. The programming frequency range is
300kHzto 2MHz.
Mode (Pin 2): Synchronization of the internal oscillator. A clock frequency of twice the desired switching
frequency and with a pulse width between 100ns and 2µs is applied. The oscillator free running
frequency is set slower than the desired synchronized switching frequency to guarantee sync. The
oscillator RT component value required is given by:
Where fSW = desired synchronized switching frequency.
SW1 (Pin 3): Switch Pin Where the Internal Switches A and B are Connected. Connect inductor from
SW1 to SW2. An optional Schottky diode can be connected from SW1 to ground. Minimize trace length
to keep EMI down.
SW2 (Pin 4): Switch Pin Where the Internal Switches C and D are connected. For applications with
output voltages over 4.3V, a Schottky diode is required from SW2 to VOUT to ensure the SW pin does
not exhibit excess voltage.
GND (Pin 5): Signal and Power Ground for the IC.
VOUT (Pin 6): Output of the Synchronous Rectifier. A filter capacitor is placed from VOUT to GND.
VIN (Pin 7): Input Supply Pin, Internal VCC for the IC. A ceramic bypass capacitor as close to the VIN
pin and GND (Pin 5) is required.
EN (Pin 8): Combined Soft-Start and Shutdown. Grounding this pin shuts down the IC. Tie to >1.5V to
enable the IC and > 1.8V to ensure the error amp is not clamped from soft-start. An RC from the
shutdown command signal to this pin will provide a soft-start function by limiting the rise time of the VC
pin.
FB (Pin 9): Feedback Pin. Connect resistor divider tap here. The output voltage can be adjusted from
2.5V to 5.5V. The feedback reference voltage is typically 1.212V.
VC (Pin 10): Error Amp Output. A frequency compensation network is connected from this pin to the FB
pin to compensate the loop.
www.hxsemi.com
5
HX8001
Packaging Information
MSOP-10 Package Outline Dimension
Symbol
A
A1
A2
b
c
D
e
E
E1
L
θ
Dimensions in Millimeters
Min
Max
0.820
1.100
0.020
0.150
0.750
0.950
0.180
0.280
0.090
0.230
2.900
3.100
0.50(BSC)
2.900
3.100
4.750
5.050
0.400
0.800
0°
6°
Dimensions in Inches
Min
Max
0.032
0.043
0.001
0.006
0.030
0.037
0.007
0.011
0.004
0.009
0.114
0.122
0.020(BSC)
0.114
0.122
0.187
0.199
0.016
0.031
0°
6°
Subject changes without notice
www.hxsemi.com
6
Information furnished by Hexin Semiconductor is believed to be accurate and reliable. However, no responsibility is assumed for its use
很抱歉,暂时无法提供与“HX8001-AJC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.18600
- 10+3.11040
- 30+3.06720
