Application Note: SY6981
High Efficiency, 1.2A
Two-cell Boost Li-Ion Battery Charger
General Description
Features
SY6981 is a 3.6-5.5VIN, 1.2A two-cell synchronous
Boost Li-Ion battery charger which integrates 1MHz
switching frequency and full protection functions. The
charge current up to 1.2A can be programmed by using
the external resistor for different portable applications
and indicates the charger current information
simultaneously. It also has a programmable charge
timeout for safety battery charge operation and a
programmable input voltage threshold for adaptive
input current limit. SY6981 can disconnect output
when there is an output short circuit or shutdown. It
consists of 18V rating FETs with extremely low on
resistance to achieve high charge efficiency and simple
peripheral circuit design.
Low Profile QFN3×3 Package
Integrated Synchronous Boost with 18V Rating
Low RDSON FETs for High Charge Efficiency
Trickle Current / Constant Current / Constant
Voltage Charge Mode
Programmable Input Voltage Threshold for
Adaptive Current Limit.
Maximum 1.2A Constant Charge Current
Charge Current Information Indication.
Programmable Charge Timeout
Programmable Constant Charge Current
Selectable Constant Voltage
±0.5% Battery Voltage Accuracy
Thermal Regulation Protection
External Shutdown Function
Input Voltage UVLO and OVP
Over Temperature Protection
Output Short Circuit Protection
Charge Status Indication
Normal Synchronous Boost Operation When the
Battery is Removed
SY6981 along with small QFN3×3 footprint provides
small PCB area application.
Ordering Information
SY6981 □(□□
Applications
Tempera ture Code
Packa ge Code
Optiona l Spec Code
Ordering Number
SY6981QDC
Package type
QFN3×3-16
Cellular Telephones, PDA, MP3 Players, MP4
Players
Digital Cameras
Bluetooth Applications
PSP Game Players, NDS Game Players
Notebook
Note
Typical Applications
CBD
CBST
BST BD
L
INPUT
Sync
FET
LX
Block
FET
Charge
Pump
Main
FET
DIND
Battery Charge
Control &
Protection Logic
Csvin
COUT
Li-Ion
Battery
RNTC
NTC
SY6981
SVIN
RNOR
BAT
ICHG
TIM
CTIM
RICHG CICHG
EN
STAT
SVIN
Rup
CV2
CV1
Low/Floating High/Low
SGND/
PGND
VSEN
Rdown
Figure1. Schematic Diagram
AN_SY6981 Rev. 0.9
Silergy Corp. Confidential- Prepared for Customer Use Only
1
AN_SY6981
Pinout (top view)
Name
STAT
CV2
TIM
NTC
CV1
VSEN
EN
SGND
ICHG
BD
BST
BAT
LX
PGND
SVIN
STAT
CV2
TIM
NTC
CV1
VSEN
1
2
3
4
5
6
SVIN
16
7
EN
PGND
15
8
SGND
LX
14
9
ICHG
BD
13
10
BD
BAT
12
11
BST
(QFN3×3-16)
Top Mark: cRxyz, (Device code: cR, x=year code, y=week code, z= lot number code)
Pin Number
Description
Charge status indication pin. It is open-drain output pin and pulled high to SVIN through
1
a LED to indicate the charge in process. When the charge is done, the LED will be off.
Battery CV voltage selection pin. Program 4 different CV thresholds by setting different
2
voltage on this pin and pin5. Floating or grounding this pin in the application. CV2 pin
can’t be pulled high to any bias voltage higher than 3.3V.
Charge time limit pin. Connect this pin with a capacitor to ground. Internal current source
3
charge the capacitor for TC mode and CC mode’s charge time limit. TC charge time limit
is about 1/9 of CC charge time.
Thermal protection pin. UTP threshold is typical 76% of VSVIN and OTP threshold is
typical 30.5% of VSVIN. Pull up to SVIN can disable charge logic and make the IC operate
4
as a normal Boost regulator. Pull down to ground can shut down the IC.
5
voltage on this pin and pin2. The detailed information is shown in description section.
Voltage sense of SVIN. If the voltage drops to internal 1.195V reference voltage, the
6
SVIN will be clamped to setting value and input current will be limited.
7
Enable control pin. High logic for enable on, and low logic for enable off.
8
Signal ground pin.
Charge current program pin. Pull down to GND with a resistor RICHG. The mirror current
about 1/10000 of the blocking FET current will dump into the external RC network
9
through ICHG pin and compared to the internal reverence 1V.
So ICC = (1V/ RICHG) ×10000, ITC = (1V/ RICHG)×1000+0.02.
Connect it to the drain of internal blocking FET. Bypass at least a 4.7µF ceramic cap to
10, 13
GND.
Boost-strap pin. Supply rectified FET’s gate driver. Decouple this pin to LX with a 0.1µF
11
ceramic cap.
12
Battery positive pin.
14
Switch node pin. Connect it to the external inductor.
15
Power ground pin.
Analog power input pin. Connect a MLCC from this pin to ground to decouple high
16
harmonic noise. This pin has OVP and UVLO function to make the charger operate
within safe input voltage range.
AN_SY6981 Rev. 0.9
2
AN_SY6981
Absolute Maximum Ratings (Note1)
STAT, NTC, CV1, VSEN, EN, ICHG, BD, BAT, LX, SVIN ------------------------------------------------------------ 18V
CV2, TIM, BST-LX -------------------------------------------------------------------------------------------------------------- 4V
LX Pin Continuous Current ------------------------------------------------------------------------------------------------------ 5A
Power Dissipation, PD @ TA = 25°C, QFN3×3 ---------------------------------------------------------------------------- 2.6W
Package Thermal Resistance (Note2)
θ JA ------------------------------------------------------------------------------------------------------------------- 38°C/W
θ JC --------------------------------------------------------------------------------------------------------------------- 4°C/W
Junction Temperature Range ------------------------------------------------------------------------------------ -40°C to 125°C
Lead Temperature (Soldering, 10 sec.) ----------------------------------------------------------------------------------- 260°C
Storage Temperature Range ------------------------------------------------------------------------------------- -65°C to 125°C
Recommended Operating Conditions (Note3)
SVIN -------------------------------------------------------------------------------------------------------------------- 3.6V to 5.5V
STAT, NTC, CV1, VSEN, EN, ICHG, BD, BAT, LX, -------------------------------------------------------- -0.3V to 16V
CV2, TIM, BST-LX ------------------------------------------------------------------------------------------------ -0.3V to 3.3V
LX Pin Continuous Current ---------------------------------------------------------------------------------------------------- 5A
Ambient Temperature Range ------------------------------------------------------------------------------------ -40°C to 85°C
AN_SY6981 Rev. 0.9
3
AN_SY6981
Electrical Characteristics
TA=25°C, VIN=5V, GND=0V, CIN=4.7µF, L=0.68µH, RICHG=10kΩ, CTIM=470nF, unless otherwise specified.
Parameter
Bias Supply (VSVIN)
Supply Voltage
Symbol
Conditions
VSVIN
VSVIN Under Voltage Lockout
Threshold
VUVLO
Hysteresis
∆VUVLO
Input Over Voltage Protection
VOVP
Hysteresis
Quiescent Current
∆VOVP
Battery Discharge Current
IBAT
Input Quiescent Current
IIN
Oscillator and PWM
Switching Frequency
fSW
Main N-FET Minimum Off Time
tMIN_OFF
Main N-FET Maximum Off Time
Main N-FET Minimum On Time
Min
Typ
3.6
VSVIN rising and
measured from VSVIN to
GND
Measured from VSVIN
to GND
VSVIN rising and
GND
Measured from VSVIN
to GND
Max
Unit
16
V
3.6
V
100
mV
5.8
V
0.5
Shut down IC,
EN=NTC=0
Disable charge,
EN=1,NTC=0
V
10
µA
1.5
mA
1000
kHz
With 18V rating
100
ns
tMAX_OFF
With 18V rating
30
µs
tMIN_ON
With 18V rating
100
ns
Power MOSFET
RDS(ON) of Main N-FET
RNFET_M
100
mΩ
RDS(ON) of Rectified N-FET
RNFET_R
50
mΩ
RDS(ON) of Blocking N-FET
RNFET_B
50
mΩ
Voltage Regulation
Battery Charge Voltage
VBAT_REG
High Level Logic for CV1
VCV_H
Low Level Logic for CV1,CV2
VCV_L
Recharge Threshold
Refer to VBAT_REG
Trickle Current Charge Mode
Battery Voltage Threshold
AN_SY6981 Rev. 0.9
VCV1>1.5V, VCV2 is
floating
VCV11.5V, VCV2
