SLM6240AB-13GTR
SLM6240AB-13GTR
    SILLUMIN(数明半导体)
    SOIC8_EP
    升压型 4A 2.7V~5.5V
SLM6240AB-13GTR 数据手册
SLM6240 Sillumin Semiconductor Co., Ltd. Rev. 02 December 2015 24V 4A PWM STEP-UP DC-DC CONVERTER GENERAL DESCRIPTION FEATURES The SLM6240 devices are high-performance, fixed frequency, current-mode PWM step-up DC/DC converters that incorporate internal power MOSFETs. The SLM6240 includes an integrated 80-mΩ power switch that supports peak currents of up to 4A. The device is capable of providing an output voltage up to 24 V.     The SLM6240 uses peak current control topology to regulate the output voltage. In moderate to heavy load condition, the SLM6240 works in the pulse width modulation (PWM) mode. In light load condition, the device works in the pulse frequency modulation (PFM) mode to improve the efficiency. The SLM6240 utilizes simple external loop compensation allowing optimization between component size, cost and AC performance across a wide range of applications. Additional functions include an externally programmable soft-start function for easy inrush current control, internal overvoltage protection (OVP), cycle-by-cycle current limit protection, under voltage lock-out and thermal shutdown. The SLM6240 is available in the small SOIC8-EP package.           Input Voltage Range: 2.7 to 5.5V Adjustable Output Voltage Up to 24V 4A Switch Current Up to 85% Efficiency at VIN = 4.2V, VOUT = 12V, and IOUT = 0.7A Internal 24V 80-mΩ Power MOSFET 0.1µA Current into VIN Pin during Shutdown 800kHz Frequency Built-in Over-Voltage Protection (OVP) Open Protection Programmable Soft-Start Function Thermal Shutdowns Under-Voltage-Lockout Cycle-by-Cycle Overcurrent Protection SOIC8-EP Package APPLICATIONS      TM Battery-Powered Equipment (Bluetooth Speaker; E-Cigarette; Quick Charge Power Bank ) Portable POS Terminal TFT LCD Monitors Set-Top Boxes DSL and Cable Modems and Routers TYPICAL APPLICATION CIRCUIT Figure 1 Typical Application Circuit Copyright© 2015, Sillumin Semiconductor Co., Ltd. Rev 02, 12/02/2015 1 SLM6240 Sillumin Semiconductor Co., Ltd. Rev. 02 December 2015 PIN CONFIGURATION Package Pin Configuration (Top View) PGND 1 8 SW IN 2 7 SS EN 3 6 FB COMP 4 5 AGND SOIC8-EP PIN DESCRIPTION No. Pin Description 1 PGND Power Ground 2 IN Supply Input 3 EN Enable Control. Connect to a logic high level to enable the IC. Connect to a logic low level to disable the IC. When unused, connect EN pin to IN (do not leave pin floating). 4 COMP Error Amplifier Compensation Node 5 AGND Analog Ground 6 FB Feedback Input. Connect this pin a resistor divider from the output to set the output voltage. FB is regulated to 1.262V. 7 SS 8 SW - Exposed Pad Soft Start Control Input. Connect a capacitor from this pin to Ground to set soft-start timing duration. SS is discharged to ground in shutdown. SS may be left unconnected if soft start is not desired. Switch Output. Connect this pin to the inductor and the schottky diode. To minimize EMI, minimize the PCB trace path between this pin and the input bypass capacitor. Connected to Ground Copyright© 2015, Sillumin Semiconductor Co., Ltd. Rev 02, 12/02/2015 2 SLM6240 Sillumin Semiconductor Co., Ltd. Rev. 02 December 2015 ORDERING INFORMATION Industrial Range: -40°C to +125°C Order Part No. Package QTY SLM6240AB -13GTR SLM6240CB-13GTR SLM6240CB-GT SOIC8-EP 2500/Reel 2500/Reel 100/Tube FUNCTIONAL BLOCK DIAGRAM Copyright© 2015, Sillumin Semiconductor Co., Ltd. Rev 02, 12/02/2015 3 SLM6240 Sillumin Semiconductor Co., Ltd. Rev. 02 December 2015 ABSOLUTE MAXIMUM RATINGS SW to Ground VIN, EN, FB, SS, COMP to Ground Continuous SW Current Total power dissipation, PTOT Maximum junction temperature, TJMAX Storage temperature range, TSTG Operating temperature range, TA Junction to Ambient, Rth-JA Package Thermal Resistance Junction to Case, Rth-JC ESD (HBM) ESD (CDM) ESD (FICDM) Latch-up -0.3V ~ 28V -0.3V ~ 6.5V Internally Limited 1.5w (TS ≤100°C) 150°C -65°~+150°C -40°C~+125°C 60 °C/w 15 °C/w 2000 V 200 V 1500 V +/- 100mA Note: Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these or any other condition beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. ELECTRICAL CHARACTERISTICS (TBD) Test condition is TA = −40°C ~ +125°C. Typical values are at TA = 25°C, unless otherwise specified. Symbol VIN Parameter Condition Input voltage operation range Under voltage lockout threshold Min. Typ. 2.7 VIN Rising Max. Unit 5.5 V 2.5 V 200 mV UVLO Under voltage lockout hysteresis IQ Chip quiescent current ISHDN Supply current in shutdown fREQ Switching frequency DC Maximum duty cycle VFB Feedback voltage IFB Feedback input current LNR VIN=3.6V, VFB=1.4V, Nonswitching VIN=3.6V, VFB=1.0V, Switching 5 0.1 1.0 1.23 VIN=3.6V, Duty cycle = 70% Switching ON resistance VIN=3.6V, VSW =12V, Duty ISW Switch leakage current VSW =12V, EN=GND ISS Soft start pin bias current VSS=1.2V VIH EN pin logic high VIL EN pin logic low REN EN pull down resistor TSD 3.5 cycle = 70% 2.0 uA kHz 90 Switching peak current limit TSD_HYS 3 800 VFB from 2.7V to 5.5V RDSON 0.35 mA EN=GND Feedback voltage line regulation ICL 0.30 % 1.26 1.29 V 0 80 nA 0.05 0.15 %/V 4.0 A 80 mΩ 4.5 15 uA 7.0 uA 1.4 V 0.4 V 1 MΩ Thermal shutdown temperature 150 °C Thermal shutdown hysteresis 15 °C Copyright© 2015, Sillumin Semiconductor Co., Ltd. Rev 02, 12/02/2015 4 SLM6240 Sillumin Semiconductor Co., Ltd. Rev. 02 December 2015 APPLICATION INFORMATION The SLM6240 are highly efficient step-up DC/DC converters that employ a current mode, fixed frequency pulse-width modulation (PWM) architecture with excellent line and load regulation. The SLM6240 operate at constant switching frequency under medium to high load current conditions. At light loads, these devices operate in a pulse-skipping mode in order to improve light-load efficiency. Soft-Start The SLM6240 both offer a programmable soft-start function which minimizes inrush current during startup. The soft-start period is programmed by connecting a 10nF capacitor between SS and Ground. Operation of the soft-start function is as follows: when the IC is disabled, SS is actively discharged to Ground. Upon enabling the IC, CSS is charged with a 4.5μA current so that the voltage at SS increases in a controlled manner. The peak inductor current is limited by the voltage at SS, so that the input current is limited until the soft-start period expires, and the regulator can achieve its full output current rating. Setting the Output Voltage The both feature external adjustable output voltages of up to 24V. To program the output voltage, simply connect a resistive voltage divider between the output, FB, and GND, with resistors set according to the following equation:  V R1  R2   OUT  VFB     1   where VFB=1.26V overcurrent event, the output voltage begins to droop as a function of the load on the output. VOUT I   VIN   I CL  RIPPLE    2    I OUT where  VOUT is the output voltage of the boost regulator.  IOUT is the output current of the boost regulator.  VIN is the input voltage of the boost regulator.  ICL is the input switching peak current limit of the boost regulator.  IRIPPLE is the inductor ripple current of the boost regulator.  η is the power conversion efficiency. Open Circuit Protection Once the outputs achieve regulation, if the voltage at FB falls below 0.2V the controller will automatically disable, preventing the controller from running openloop and potentially damaging the IC and load. Shutdown Drive EN low to disable the IC and reduce the supply current to just 0.1μA. As with all non-synchronous step-up DC/DC converters, the external Schottky diode provides a DC path from the input to the output in shutdown. As a result, the output drops to one diode voltage drop below the input in shutdown. The SLM6240 both feature integrated thermal overload protection. Both devices are automatically disabled when their junction temperatures exceed +150°C, and automatically re-enable when the die temperature decreases by 15°C. Rectifier Selection For optimal performance, the rectifier should be a Schottky rectifier that is rated to handle both the output voltage as well as the peak switch current. Open Voltage Protection The features internal automatic over-voltage protection, when feedback voltage is higher than 115%. Overcurrent Protection The SLM6240 has a cycle-by-cycle overcurrent limit protection that turns off the power switch once the inductor current reaches the overcurrent limit threshold. The PWM circuitry resets itself at the beginning of the next switch cycle. During an Copyright© 2015, Sillumin Semiconductor Co., Ltd. Rev 02, 12/02/2015 5 SLM6240 Sillumin Semiconductor Co., Ltd. Rev. 02 December 2015 TYPICAL OPERATING CHARACTERISTICS Test condition is TA = 25°C, VIN = VEN = 5.0V, VFREQ = 0V, unless otherwise specified. Copyright© 2015, Sillumin Semiconductor Co., Ltd. Rev 02, 12/02/2015 6 SLM6240 Sillumin Semiconductor Co., Ltd. Rev. 02 December 2015 PACKAGE INFORMATION SOIC8-EP Note: All dimensions in millimeters unless otherwise stated. Copyright© 2015, Sillumin Semiconductor Co., Ltd. Rev 02, 12/02/2015 7 SLM6240 Sillumin Semiconductor Co., Ltd. Rev. 02 December 2015 IMPORTANT NOTICE Sillumin Semiconductor Co., Ltd. and its subsidiaries (SILLUMIN) reserve the right to make corrections, enhancements, improvements and other changes to its semiconductor products and services per JESD46, latest issue, and to discontinue any product or service per JESD48, latest issue. Buyers should obtain the latest relevant information before placing orders and should verify that such information is current and complete. All semiconductor products (also referred to herein as “components”) are sold subject to SILLUMIN’s terms and conditions of sale supplied at the time of order acknowledgment. SILLUMIN warrants performance of its components to the specifications applicable at the time of sale, in accordance with the warranty in SILLUMIN’s terms and conditions of sale of semiconductor products. Testing and other quality control techniques are used to the extent SILLUMIN deems necessary to support this warranty. Except where mandated by applicable law, testing of all parameters of each component is not necessarily performed. SILLUMIN assumes no liability for applications assistance or the design of Buyers’ products. Buyers are responsible for their products and applications using SILLUMIN components. To minimize the risks associated with Buyers’ products and applications, Buyers should provide adequate design and operating safeguards. SILLUMIN does not warrant or represent that any license, either express or implied, is granted under any patent right, copyright, mask work right, or other intellectual property right relating to any combination, machine, or process in which SILLUMIN components or services are used. Information published by SILLUMIN regarding third-party products or services does not constitute a license to use such products or services or a warranty or endorsement thereof. Use of such information may require a license from a third party under the patents or other intellectual property of the third party, or a license from SILLUMIN under the patents or other intellectual property of SILLUMIN. Reproduction of significant portions of SILLUMIN information in SILLUMIN data books or data sheets is permissible only if reproduction is without alteration and is accompanied by all associated warranties, conditions, limitations, and notices. SILLUMIN is not responsible or liable for such altered documentation. Information of third parties may be subject to additional restrictions. Resale of SILLUMIN components or services with statements different from or beyond the parameters stated by SILLUMIN for that component or service voids all express and any implied warranties for the associated SILLUMIN component or service and is an unfair and deceptive business practice. SILLUMIN is not responsible or liable for any such statements. Buyer acknowledges and agrees that it is solely responsible for compliance with all legal, regulatory and safety-related requirements concerning its products, and any use of SILLUMIN components in its applications, notwithstanding any applications-related information or support that may be provided by SILLUMIN. Buyer represents and agrees that it has all the necessary expertise to create and implement safeguards which anticipate dangerous consequences of failures, monitor failures and their consequences, lessen the likelihood of failures that might cause harm and take appropriate remedial actions. Buyer will fully indemnify SILLUMIN and its representatives against any damages arising out of the use of any SILLUMIN components in safety-critical applications. In some cases, SILLUMIN components may be promoted specifically to facilitate safety-related applications. With such components, SILLUMIN’s goal is to help enable customers to design and create their own end-product solutions that meet applicable functional safety standards and requirements. Nonetheless, such components are subject to these terms. No SILLUMIN components are authorized for use in FDA Class III (or similar life-critical medical equipment) unless authorized officers of the parties have executed a special agreement specifically governing such use. Only those SILLUMIN components which SILLUMIN has specifically designated as military grade or “enhanced plastic” are designed and intended for use in military/aerospace applications or environments. Buyer acknowledges and agrees that any military or aerospace use of SILLUMIN components which have not been so designated is solely at the Buyer's risk, and that Buyer is solely responsible for compliance with all legal and regulatory requirements in connection with such use. SILLUMIN has specifically designated certain components as meeting ISO/TS16949 requirements, mainly for automotive use. In any case of use of non-designated products, SILLUMIN will not be responsible for any failure to meet ISO/TS16949. Please refer to below URL for other products and solutions of Sillumin Semiconductor Co., Ltd. Address: Room 3010, No. 377 Bo’An Road, Songjiang, Shanghai, 201615 China Copyright© 2015, Sillumin Semiconductor Co., Ltd. Copyright© 2015, Sillumin Semiconductor Co., Ltd. Rev 02, 12/02/2015 8
SLM6240AB-13GTR 价格&库存
很抱歉,暂时无法提供与“SLM6240AB-13GTR”相匹配的价格&库存,您可以联系我们找货
