FP6188XR-G1
FP6188XR-G1
    ANALOGYSEMI(类比半导体)
    SOP8_EP
    FP6188是一款集成两个0.13Q功率MOSFET的同步降压调节器,能够提供2A连续输出电流,支持4.5V至23V宽输入电压范围,具有340KHz固定频率,内置过流保护和热关断保护功能。
FP6188XR-G1 数据手册
FP6188 2A, 23V, 340KHz Synchronous Step-Down Converter General Description The FP6188 is a synchronous buck regulator with integrated two 0.13Ω power MOSFETs. It achieves 2A continuous output current over a wide input supply range with excellent load and line regulation. Current mode operation provides fast transient response and eases loop stabilization. The device includes cycle-by-cycle current limiting and thermal shutdown protection. The FP6188 requires a minimum number of readily available external components to complete a 2A buck regulator solution. Features  2A Output Current  0.13Ω Internal Power MOSFET Switches  Stable with Low ESR Output Ceramic Capacitors Up to 93% Efficiency  Programmable Soft-Start  Fixed 340KHz Frequency  Thermal Shutdown  Cycle-by-Cycle Over Current Protection  Wide 4.5V to 23V Operating Input Range  Output Adjustable From 0.923V to 16V  Available SOP-8L (EP) Package  Input Under Voltage Lockout Applications  Distributed Power Systems  Battery Charger Network Cards  Pre-Regulator for Linear Regulators  DSL Modems Typical Application Circuit VOUT 1 VIN 2 SS BS EN IN 8 7 VIN FP6188 3 4 SW GND COMP FB 6 5 This datasheet contains new product information. Feeling Technology reserves the rights to modify the product specification without notice. No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product. Website: http://www.feeling-tech.com.tw Rev. 0.70 1/11 FP6188 Function Block Diagram Pin Descriptions SOP-8L (EP) Top View Name No. I / O 1 8 SS IN 2 7 EN SW 3 6 COMP 4 FP6188 GND XXx-XXL BS 5 FB Bottom View Description BS 1 O Bootstrap IN 2 P Supply Voltage SW 3 O Switch GND 4 P Ground FB 5 I Feedback COMP 6 O Compensation EN 7 I Enable / UVLO SS 8 O Soft-Start EP 9 P Exposed PAD - Must connect to Ground EP This datasheet contains new product information. Feeling Technology reserves the rights to modify the product specification without notice. No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product. Website: http://www.feeling-tech.com.tw Rev. 0.70 2/11 FP6188 Marking Information SOP-8L (EP) FP6188 XXx - XXL Halogen Free Lot Number Internal ID Per - Half Month Year Halogen Free: Halogen free product indicator Lot Number: Wafer lot number’s last two digits For Example Lot : 123456 XXx-56L Internal ID: Internal Identification Code Per-Half Month: Production period indicator in half month time unit For Example : A → First Half Month of January B → Second Half Month of January C → First Half Month of February D → Second Half Month of February Year: Production year’s last digit This datasheet contains new product information. Feeling Technology reserves the rights to modify the product specification without notice. No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product. Website: http://www.feeling-tech.com.tw Rev. 0.70 3/11 FP6188 Ordering Information Part Number Operating Temperature Package MOQ Description -40°C ~ +85°C SOP-8L (EP) 2500EA Tape & Reel FP6188XR-G1 Absolute Maximum Ratings Parameter Symbol Conditions Min. Typ. Max. Unit Supply Voltage VIN -0.3 24 V Supply Voltage Vsw -1 VIN +0.3 V Bootstrap Voltage VBS Vsw -0.3 Vsw +6 V -0.3 6 V +150 °C All Other Pins Junction Temperature TJ Storage Temperature TS Allowable Power Dissipation θJA Thermal Resistance θJC +150 ℃ SOP-8L 800 mW SOP-8L (EP) 1500 mW -65 SOP-8L +156 ℃/W SOP-8L (EP) +83 ℃/W SOP-8L +55 ℃/W SOP-8L (EP) +10 ℃/W +260 ℃ Lead Temperature (soldering, 10 sec) IR Re-flow Soldering Curve This datasheet contains new product information. Feeling Technology reserves the rights to modify the product specification without notice. No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product. Website: http://www.feeling-tech.com.tw Rev. 0.70 4/11 FP6188 Recommended Operating Conditions Parameter Symbol Supply Voltage Conditions VIN Operating Temperature Ambient Temperature Min. Typ. Max. Unit 4.5 23 V -40 +85 ℃ DC Electrical Characteristics (Ta= 25℃, VIN=12V, unless otherwise noted) Parameter Symbol Test Conditions Standby Current ISB VEN≧3V,VFB≧1.0V Shutdown Supply Current IST VEN=0 Feedback Voltage VFB VIN=12V,VCOMP
FP6188XR-G1 价格&库存
很抱歉,暂时无法提供与“FP6188XR-G1”相匹配的价格&库存,您可以联系我们找货
