FP7209XR-G13
FP7209XR-G13
    ANALOGYSEMI(类比半导体)
    SOP8_EP
FP7209XR-G13 数据手册
FP7209 Non-Synchronous PWM Boost Controller for LED Driver General Description The FP7209 is boost topology switching regulator for LED driver. It provides built-in gate driver pin for driving external N-MOSFET. The non-inverting input of error amplifier connects to a 0.25V reference voltage. There are three functions to protect system circuit like UVP, OVP and OCP. The LED current can be adjusted by an external signal connecting to the DIM pin. DIM pin accepts either a DC voltage or a PWM signal. The PWM signal filter components are contained within the chip. Current mode control and external compensation network make is easy and flexible to stabilize the system. The FP7209 is available in the small footprint SOP-8L(EP) package to fit in space-saving PCB layout for application fields. Features  Start-up Voltage: 2.8V  Wide Supply Voltage Operating Range: 5V to 24V  Precision Feedback Reference Voltage: 0.25V (Max.)  Analog and Digital Dimming Control  Shutdown Current: 6μA (Max.)  Fixed Switching Frequency: 150KHz  Input Under Voltage Protection (UVP)  Output Over Voltage Protection (OVP)  Switching MOSFET Over Current Protection (OCP)  Over Temperature Protection (OTP)  Package: SOP-8L(EP) Applications  LED Module  Display Backlight  Car Lighting  Portable LED Lighting This datasheet contains new product information. Advanced Analog Technology reserves the rights to modify the product specification without notice. No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product. Rev. 0.641 1/15 FP7209 Typical Application Circuit VLED VIN VDS EXT DIM HVDD FP7209 CS COMP FB GND OVP Function Block Diagram COMP Error Amp. FB HVDD UVLO 0.7V Soft Start LDO OVP OTP Max. 0.25V DIM OVP Dimming Control Thermal Regulation VREF PWM Comp. VDDI 4.5V Control and Driver Logic 150KHz VDS EXT OCP Oscillator VDS = 8V LDO Slope Compensation 0.1V CS GND Current Sense Amp. This datasheet contains new product information. Advanced Analog Technology reserves the rights to modify the product specification without notice. No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product. Rev. 0.641 2/15 FP7209 Pin Descriptions SOP-8L(EP) Top View 1 8 EXT DIM 2 7 HVDD COMP 3 6 CS FB FP7209 XXx-XXL VDS 4 5 Name No. I/O DIM 2 I Description Power Supply for Internal Control Circuits and Gate Drivers Analog and Digital Dimming Control VDS 1 P COMP 3 O Compensation FB 4 I Error Amplifier Inverting Input OVP 5 I Over Voltage Protection CS 6 I MOSFET Switch Current Sense HVDD 7 P IC Power Supply EXT 8 O GND 9(EP) P Gate Driver Output IC Ground (Exposed PAD) – Must Connect to Ground OVP Bottom View EP (GND) Marking Information SOP-8L(EP) FP7209 XXx-XXL Halogen Free Lot Number Internal ID Per - Half Month Year Halogen Free: Halogen free product indicator Lot Number: Wafer lot number's code Internal ID: Internal Identification Code Per-Half Month: Production period indicator in half month time unit For Example : A → First Half Month of January B → Second Half Month of January C → First Half Month of February D → Second Half Month of February Year: Production year’s last digit This datasheet contains new product information. Advanced Analog Technology reserves the rights to modify the product specification without notice. No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product. Rev. 0.641 3/15 FP7209 Ordering Information Part Number Operating Temperature Package MOQ Description FP7209XR-G11 -40°C ~ +85°C SOP-8L(EP) 2500EA Tape & Reel FP7209XR-G12 -40°C ~ +85°C SOP-8L(EP) 2500EA Tape & Reel FP7209XR-G13 -40°C ~ +85°C SOP-8L(EP) 2500EA Tape & Reel Absolute Maximum Ratings Symbol Conditions Min. Typ. Max. Unit HVDD - -0.3 - 26 V VDS,EXT Voltage - - -0.3 - 16 V Others Pin Voltage - - -0.3 - 6 V Thermal Resistance (Junction to Ambient) θJA SOP-8L(EP) - - +60 °C / W Thermal Resistance (Junction to Case) θJC SOP-8L(EP) - - +10 °C / W Junction Temperature TJ - - - +150 °C Operating Temperature TOP - -40 - +85 °C Storage Temperature TST - -65 - +150 °C - (soldering, 10 sec) - - +260 °C Parameter Supply Voltage Lead Temperature IR Re-flow Soldering Curve This datasheet contains new product information. Advanced Analog Technology reserves the rights to modify the product specification without notice. No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product. Rev. 0.641 4/15 FP7209 Recommended Operating Conditions Parameter Symbol Conditions Min. Typ. Max. Unit HVDD - 5 - 24 V TA Ambient Temperature -40 - +85 °C Supply Voltage Operating Temperature Range DC Electrical Characteristics (HVDD=12V, TA=25°C, unless otherwise specified) Parameter Symbol Conditions Min. Typ. Max. Unit System Supply Input Start-up Voltage HVDD 2.8 Input Supply Range HVDD 5 Under Voltage Lockout VUVLO V 24 2.6 UVLO Hysteresis Average Current ICC FB=0V, Switching Quiescent Current ICC FB=0.3V, No Switching Shutdown Current ICC VDIM=0V Input Supply Voltage VDS HVDD=12V, IDS=0A V V 0.2 V 2 mA 800 µA 6 µA 7.5 8.0 8.5 V 120 150 180 KHZ Oscillator Operation Frequency fOSC Maximum Duty Ratio % FB=0V 90 % 0.275 V DIM Voltage DIM Start-up Voltage Vst_up EXT Switching DIM Shutdown Voltage VDIM ICC
FP7209XR-G13 价格&库存
很抱歉,暂时无法提供与“FP7209XR-G13”相匹配的价格&库存,您可以联系我们找货
