FP6151XR-G1
FP6151XR-G1
    ANALOGYSEMI(类比半导体)
    SOP8_EP
    FP6151是一款内置内部功率MOSFET的降压调节器,能够实现5A连续输出电流,适用于广泛的输入电压范围,具有出色的负载和线路调节性能。该设备包括欠压锁定和热关断保护功能。关断模式下仅消耗10uA的...
FP6151XR-G1 数据手册
FP6151 5A, 36V, Step-Down Converter General Description The FP6151 is a buck regulator with a built in internal power MOSFET. It achieves 5A continuous output current over a wide input supply range with excellent load and line regulation. Current mode operation provides fast transient response and eases loop stabilization. A wide switching frequency range allows efficiency and external component size to be optimized. The device includes under voltage lockout and thermal shutdown protection. The regulator only consumes 10µA supply current in shutdown mode. The FP6151 requires a minimum number of readily available external components to complete a 5A buck regulator solution. Features  Operating Input Range up to 36V  5A Output Current  Built-in Soft-Start  65mΩ Internal Power MOSFET Switch  Up to 90% Efficiency  10μA Shutdown Mode Current  Adjustable Switching Frequency using external Resistance setting  Thermal Shutdown  Under Voltage Lockout  Available SOP8 With Exposed PAD Applications  Automotive Distributed Power Systems  Battery Charger  Pre-Regulator for Linear Regulators Typical Application Circuit Vout 1 OFF ON 2 SW BS VIN EN FP6151 3 COMP 4 FB RT GND 8 7 Vin 6 5 This datasheet contains new product information. Feeling Technology reserves the rights to modify the product specification without notice. No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product. Website: http://www.feeling-tech.com.tw Rev. 0.61 1/12 FP6151 Function Block Diagram VIN HVIN + Current sense amplifier RT - LVDD LVDDBG + FB Oscillator CMP 0.3V 0.808V BS LVDDBS S CLK LVDD - LVDD LVDDBG - EA + + + LVDDBG PLMT S Q R Q SW PWM Comparator Soft-start COMP EN HVIN
FP6151XR-G1 价格&库存
很抱歉,暂时无法提供与“FP6151XR-G1”相匹配的价格&库存,您可以联系我们找货
