SMF5.0CA
SMF5.0CA
    SEMIWARE(赛米微尔)
    SOD-123FL
    ESD抑制器/TVS二极管 双向 5V 21.7A 200W SOD-123FL
SMF5.0CA 数据手册
SMF SERIES R Transient Voltage Suppressors FEATURES Low profile package Ideal for automated placement SOD-123FL 200 Watt peak pulse power capability with a 10/1000μs waveform For surface mounted applicatons to optimize board space Excellent clamping capability Uni-directionnal Very fast response time Low incremental surge resistance Bi-directionnal APPROVALS APPLICATIONS Power supply protection RoHS Compliance with 2011/65/EU Automotive application HF Industrial application Compliance with IEC61249-2-21:2003 Power management MAXIMUM RATINGS (TA=25°C ) Parameter Symbol Value PD 1.0 P PPM Peak Pulse Power Dissipation on 10/1000us waveform (Note1) Steady State Power Dissipation at TA=50°C 200 Notes : 1.Non-repetitive current pulse,TA=25°C. Unit Watts Watts 2.8.3ms single half sine-wave, or equivalent square wave, Duty cycle = 4 pulses per minutes maximum THERMAL CONSIDERATIONS Parameter Operating Junction Temperature Symbol Junction to Ambient on printed circuit Product Datasheet Rev. A2.0 1/7 Unit -55 to +150 ℃ TJ -55 to +150 RθJA 220 TSTG Storage Temperature Range Value Build Your Design As You Will ℃ ℃/W Http://semiware.com SMF SERIES R ELECTRICAL CHARACTERISTICS (TA=25℃) Device Marking Code Part Number Uni-Polar Bi-Polar Uni SMF5.0A SMF5.0CA AE SMF6.5A SMF6.5CA SMF7.5A SMF7.5CA SMF3.3A HZ GZ SMF6.0CA AG FG SMF7.0CA AM FM SMF8.0A SMF8.0CA AR FR SMF9.0A SMF9.0CA AV FV SMF6.0A SMF7.0A SMF8.5A SMF10A SMF11A SMF12A SMF13A SMF14A SMF15A SMF16A SMF17A SMF18A SMF20A SMF22A SMF24A SMF26A SMF28A SMF30A SMF33A SMF36A SMF40A SMF43A SMF45A SMF48A SMF51A SMF54A SMF58A Product Datasheet SMF3.3CA Bi SMF8.5CA SMF10CA AK AP AT AX FE FK FP FT GG SMF15CA BM GM SMF17CA BR GR SMF14CA SMF16CA SMF18CA SMF20CA SMF22CA BK BP BT BV BX GK GP GT GV GX SMF24CA BZ GZ SMF28CA CG HG SMF33CA CM HM SMF40CA CR HR SMF26CA SMF30CA SMF36CA SMF43CA SMF45CA SMF48CA CE CK CP CT CV CX HE HK HP HT HV HX SMF51CA CZ HZ SMF58CA DG IG SMF54CA Rev. A2.0 DE VBR(V) IT(mA) VC(V) IPP(A) IR(uA) 5.0 6.4 7.00 10 9.2 21.7 800 3.3 IE 5.2 6.00 10 8.0 25.0 800 6.0 6.67 7.37 10 10.3 19.4 800 7.0 7.78 8.60 10 12.0 16.7 200 6.5 7.22 7.5 8.33 8.0 8.89 8.5 9.44 9.0 12.0 BG BE VBR(V) GE SMF13CA SMF12CA FZ Reverse Leakage @VRWM VRWM(V) 10.0 AZ Maximum Peak Reverse BreakdownBreakdown Clamping Test Voltage Pulse Stand-off Voltage Voltage Current Current Voltage Min.@IT Max.@IT @IPP FX SMF11CA Transient Voltage Suppressors 10.0 11.1 11.0 12.2 13.3 13.0 14.4 14.0 15.6 15.0 16.7 16.0 17.8 17.0 18.9 18.0 20.0 20.0 22.2 22.0 24.4 24.0 26.7 26.0 28.9 28.0 31.1 30.0 33.3 33.0 36.7 36.0 40.0 40.0 44.4 43.0 47.8 45.0 50.0 48.0 53.3 51.0 56.7 54.0 60.0 58.0 64.4 2/7 7.98 9.21 9.83 10.4 11.1 12.3 13.5 14.7 15.9 17.2 18.5 19.7 20.9 22.1 24.5 26.9 29.5 31.9 34.4 36.8 40.6 44.2 49.1 52.8 55.3 58.9 62.7 66.3 71.2 10 11.2 1 12.9 1 14.4 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 13.6 15.4 17.0 18.2 19.9 21.5 23.2 24.4 26.0 27.6 29.2 32.4 35.5 38.9 42.1 45.4 48.4 53.3 58.1 64.5 69.4 72.7 77.4 82.4 87.1 93.6 Build Your Design As You Will 17.9 500 15.5 100 13.9 20 14.7 13.0 11.8 11.0 10.1 9.3 8.6 8.2 7.7 7.2 6.8 6.2 5.6 5.1 4.8 4.4 4.1 3.8 3.4 3.1 2.9 2.8 2.6 2.4 2.3 2.1 50 10 5 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Http://semiware.com SMF SERIES R Transient Voltage Suppressors Part Number Uni-Polar Device Marking Code Maximum Bi-Polar Uni Bi SMF64CA DM IM SMF75A SMF75CA DR IR SMF85A SMF85CA DV IV SMF100CA EZ JZ SMF60A SMF60CA SMF70A SMF70CA SMF64A SMF78A SMF90A SMF100A SMF110A SMF78CA SMF90CA SMF110CA DK DP DT DX EE IK Reverse BreakdownBreakdown Clamping Test Voltage Stand-off Voltage Voltage Current Min.@IT Max.@IT Voltage @IPP VRWM(V) VBR(V) VBR(V) IT(mA) VC(V) 64.0 71.1 78.6 1 103.0 60.0 66.7 73.7 1 96.8 Peak Pulse Current Reverse Leakage @VRWM 1.86 1 IPP(A) IR(uA) 1.75 1 IP 70.0 77.8 86.0 1 113.0 1.59 1 IT 78.0 86.7 95.8 1 126.0 1.43 1 IX 75.0 83.3 85.0 90.0 94.4 104.0 111.0 123.0 100.0 100.0 92.1 111.0 1 1 1 1 121.0 137.0 146.0 162.0 1.49 1.31 1.23 0.93 1 122.0 135.0 1 177.0 1.02 JK 130.0 144.0 159.0 1 209.0 0.86 SMF120CA EG JG SMF150A SMF150CA EM JM 150.0 167.0 185.0 1 243.0 0.74 1 SMF170CA ER JR 170.0 189.0 209.0 1 275.0 0.65 1 SMF190CA EU JU SMF210CA EW JW SMF130CA SMF160A SMF160CA SMF180A SMF180CA SMF170A SMF190A SMF200A SMF210A SMF220A Product Datasheet SMF200CA SMF220CA Rev. A2.0 EK EP ET EV EY JP JT JV JY 160.0 178.0 180.0 201.0 190.0 209.0 200.0 224.0 210.0 231.0 220.0 246.0 3/7 197.0 222.0 243.0 247.0 269.0 272.0 1 1 1 1 1 1 1 193.0 1 SMF120A SMF130A 147.0 1 1 110.0 133.0 1 1.11 JE 120.0 1 259.0 292.0 308.0 324.0 340.0 356.0 Build Your Design As You Will 0.69 0.66 0.63 0.59 0.57 0.54 1 1 1 1 1 1 1 Http://semiware.com SMF SERIES R Transient Voltage Suppressors CHARACTERISTIC CURVES TVS Transients Clamping Waveform Peak Pulse Power Rating Curve 10 P PPM -Peak Pulse Power(kW) Voltage Transients Voltage or Current Voltage Across TVS Current Through TVS 1 0.1 0.000001 Time 0.00001 t d -Pulse Width(sec.) 150 I PPM - Peak Pulse Current,%I RSM Peak Pulse Power (P PP ) or Current (I PP ) Derating in Percentage % 100 80 60 40 20 0 25 50 75 100 125 150 175 Rev. A2.0 4/7 tr=10µsec TJ=25℃ Pulse Width(td)is defined as the point where the peak current decays to 50% of IPPM Peak Value I PPM 100 Half Value=(I PPM /2) 50 0 T A - Initial Junction Temperature (℃) Product Datasheet 0.001 Pulse Waveform Pulse Derating Curve 0 0.0001 10/1000µsec. Waveform as defined by R.E.A 0 td 1.0 2.0 t-Time (ms) Build Your Design As You Will 3.0 4.0 Http://semiware.com SMF SERIES R Transient Voltage Suppressors Steady State Power Dissipaton Deraiting Curve Typical Junction Capacitance 1.1 Bi-directional V=0V cj(PF) 1000 Uni-directional V=0V Uni-directional@V R 100 Bi-directional @V R 10 1 P D , Steady State Power Dissipation(W) 10000 Tj=25℃ f=1.0MHz 1.0 Vsig=50mV P-P 10.0 100.0 V BR -Reverse Breakdown Voltage(V) 1000.0 1.0 0.9 0.8 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0 0 25 50 75 100 T A -Ambient temperature( ℃ ) 125 150 SOLDERING PARAMETERS Pre Heat Temperature Max (T s(min) ) Temperature Max (T s(max) ) Time (min to max) (t s ) Average ramp up rate (Liquidus Temp (T L ) to peak Reflow T S (max) to T L - Ramp-up Rate Temperature (T L ) (Liquidus) Time (min to max) (t L ) Peak Temperature (T P ) Lead‒free assembly 150°C 200°C TP 3°C/second max TL 60 ‒ 180 secs 3°C/second max 260°C Time 25°C to peak Temperature (T P ) 8 minutes max. Do not exceed Product Datasheet Rev. A2.0 T s(min) 60 ‒ 150 seconds 20 ‒ 40 seconds tp Ramp-up tL T s(max) 217°C Time within 5°C of actual peak Temperature (t p ) Ramp-down Rate Temperature (T) Reflow Condition 25°C 6°C/second max Critical Zone t L to t P Ramp-down t s Preheat t 25°C to Peak Time (t) 260°C 5/7 Build Your Design As You Will Http://semiware.com SMF SERIES R SOD-123FL PACKAGE INFORMATION Ref. Polarity Band (for uni-directional products only) A A1 D E A L b b A1 c D c HE Transient Voltage Suppressors Millimeters Min. Max. 0.00 0.10 0.95 0.70 0.05 E 2.50 HE 3.40 L 0.037 0.057 1.20 0.028 0.047 2.00 0.000 0.004 0.002 0.012 0.059 0.079 3.10 0.098 0.122 3.90 0.134 0.154 0.90 0.35 Max. 1.45 0.30 1.50 Min. Inches 0.014 0.035 RECOMMENDED PAD LAYOUT DIMENSIONS A B C SMFxx(C)A Product Datasheet Rev. A2.0 Millimeters Inches A 4.20 0.165 C 1.20 0.047 1.50 B ORDERING INFORMATION Part Number Ref. Component Package QTY/Reel SOD-123FL 3000PCS 6/7 Build Your Design As You Will 0.059 Reel Size 7” Http://semiware.com SMF SERIES R Headquarters No.3387 Shendu Road Pujiang I&E Park Minhang Shanghai China 201000 Hotline 400-021-5756 Web Https://www.semiware.com Transient Voltage Suppressors Sales Center Tel: 86-21-3463-7458 Email: sales18@semiware.com Customer Service Tel: 86-21-5484-1001 Email: sales17@semiware.com Technical Support Tel: 86-21-3463-7654 Email: fae01@semiware.com Complaint & Suggestions Tel: 86-21-3463-7172 Ext: 8868 Email: cs03@semiware.com By QR Code Website Wechat To find your local partner within Semiware’s global website: www.semiware.com C 2022 Semiware Semiconductor Inc. The content of this document has been carefully checked and understood. However, neither Semiware nor its subsidiaries assume any liability whatsoever for any errors or inaccuracies of this document and the consequences thereof. Published specifications are subject to change without notice. Product suitability for any area of application must ultimately be determined by the customer. In all cases, products must never be operated outside their published specifications. Semiware does not guarantee the availability of all published products. This disclaimer shall be governed by substantive Chinese law and resulting disputes shall be settled by the courts at the place of business of Semiware. Latest publications and a complete disclaimer can be downloaded from the Semiware website. All trademarks recognized. Product Datasheet Rev. A2.0 7/7 Build Your Design As You Will Http://semiware.com
SMF5.0CA 价格&库存
很抱歉,暂时无法提供与“SMF5.0CA”相匹配的价格&库存,您可以联系我们找货
SMF5.0CA
  • 10+0.19840
  • 100+0.18560
  • 500+0.17280
  • 2000+0.15360
  • 5000+0.14720
  • 10000+0.14336
库存:3000
SMF5.0CA
  • 1+0.31374
  • 10+0.25154
  • 30+0.22043
  • 100+0.19710
  • 500+0.17853
  • 1000+0.16913
库存:521
