BT131S Series
1.0A 4Quadrants TRIACs
Product Summary
Symbol
Value
Unit
IT(RMS)
1.0
A
VDRM VRRM
600/800
V
VTM
1.55
V
Feature
Application
With high ability to withstand the shock loading of
large current,With high commutation performances,
4 quadrants products especially recommended for
use on inductive load.
Washing machine, vacuums, massager, solid state
relay, AC Motor speed regulation and so on.
Package
Circuit diagram
SOT-223-3L
Marking
BT131
XXXX
www.fuxinsemi.com
Page 1
Ver2.1
BT131S Series
Absolute maximum ratings (Ta=25℃ unless otherwise noted)
Parameter
Symbol
Value
Unit
Repetitive peak off-state voltage
VDRM
600/800
V
Repetitive peak reverse voltage
VRRM
600/800
V
RMS on-state current
IT(RMS)
1
A
ITSM
16
A
I2t
1.28
A2s
Non repetitive surge peak on-state current
(full cycle, F=50Hz)
I2t value for fusing (tp=10ms)
Critical rate of rise of on-state current (IG =2×IGT)
Peak gate current
dI/dt
Ⅰ-Ⅱ-Ⅲ
50
Ⅳ
10
A/μs
IGM
2
A
PG(AV)
0.5
W
Junction Temperature
TJ
-40 ~ +125
Storage Temperature
TSTG
-40 ~ +150
Average gate power dissipation
Electrical characteristics (TA=25 oC, unless otherwise noted)
Parameter
Symbol
Test Condition
Gate trigger current
IGT
Gate trigger voltage
VGT
Gate non-trigger voltage
VGD
VD =VDRM Tj =125℃
latching current
IL
VD =12V IGT = 0.1A
Holding current
IH
Critical-rate of rise
of commutation voltage
dV/dt
VD =12V IT = 0.1A
Tj =25℃
Value
Ⅰ-Ⅱ-Ⅲ
Ⅳ
Ⅰ-Ⅱ-Ⅲ-Ⅳ
Tj =25℃
Ⅰ-Ⅲ-Ⅳ
Ⅱ
MAX.
Unit
5
10
mA
MAX.
1.3
V
MIN.
0.2
V
MAX.
10
15
mA
MAX.
5
mA
VD=2/3VDRM Gate Open Tj =125℃
MIN.
50
V/μs
ITM =1.5A tp=380μs
MAX.
1.55
V
Tj=25℃
MAX.
5
μA
Tj=125℃
MAX.
100
μA
Ⅰ-Ⅱ-Ⅲ-Ⅳ
STATIC CHARACTERISTICS
Forward "on" voltage
VTM
Repetitive Peak Off-State Current
IDRM
Repetitive Peak Reverse Current
IRRM
VD =VDRM VR =VRRM
THERMAL RESISTANCES
Thermal resistance
www.fuxinsemi.com
Rth(j-c)
Junction to case(AC)
TYP.
23
℃/W
Rth(j-a)
Junction to ambient
TYP.
60
℃/W
Page 2
Ver2.1
BT131S Series
Typical Characteristics
FIG.2: RMS on-state current versus case temperature
(full cycle)
I T(RMS) (A)
P(W)
FIG.1: Maximum power dissipation versus RMS
on-state current (full cycle)
1.4
1.2
1.2
1.0
1.0
0.8
0.8
0.6
0.6
0.4
0.4
0.2
0.2
0.4
0.6
0.8
1.0
I T(RMS) (A)
150
Tc
FIG.4: On-state characteristics (maximum values)
2.0
I TM (A)
I TMS (A)
FIG.3: Surge peak on-state current versus number of cycles
50
15
12
Tj=125ºC
1.5
9
1.0
Tj=25ºC
6
0.5
3
100
1000
Number of cycles
0.5
1.0
2.0
V TM (V)
1.5
FIG.6: Relative variations of gate trigger current, holding
current and latching current versus junction
temperature (typical values)
FIG.5: Non-repetitive surge peak on-state current for
a sinusoidal pulse with width tp < 10ms
2.5
I GT,I H,I L(T) / I GT,I H,I L(T=25
I TMS (A)
1000
2.0
1.5
100
IH
IGT
IT
1.0
0.5
10
0.01
0.1
www.fuxinsemi.com
1
10
tp(ms)
0.0
-40
-20
60
80
100
120
140
Tj
Page 3
Ver2.1
BT131S Series
Ordering Information
BT 131 S
_
600
Triacs
IT(RMS): 1A
600:VDRM /VRRM≥600V
800:VDRM /VRRM≥800V
S:SOT-223-3L
SOT-223-3L Package Information
www.fuxinsemi.com
Page 4
Ver2.1
很抱歉,暂时无法提供与“BT131S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.58740
- 200+0.37950
- 2000+0.32890
- 4000+0.29260
- 国内价格
- 5+0.81173
- 50+0.68213
- 150+0.61733
- 500+0.56873
- 2500+0.46991
- 4000+0.45036
