DT1T10A-B
DT1T10A-B
    DOESHARE(德芯)
    TO92-3
    DT1T10A-B
DT1T10A-B 数据手册
DT1T Series TRIACs General description AR This product TRAIC is a sensitive gate for third quadrant used in TO-92 & SOT-223, These products are high commutation performance without snubber circuit. It can be triggered by logic level input. E DT1T TRIACs SILICON BIDIRECTIONAL THYRISTORS SOT-223 ES H FEATURES • Passivated die for reliability and uniformity • Three-quadrant triggering TRIAC • Over 1000V/ 800V VDRM/VRRM • Low level triggering and holding characteristics • Logic control compatible • “Green” molding compound, UL flammability classification 94V-0, (No Br. Sb. CI) • Lead free in RoHS II 2015/863/EU compliant • Moisture sensitivity meets industry standard IPC/JEDEC J-STD-020 TO-92 APPLICATIONS • General purpose motor control • Small loads in fan control • Solenoid drivers • LED Dimming • Digital control drivers DT1T Series TRIACs ELECTRICAL CHARACTERISTICS (Tj = 25°C, unless otherwise specified.) Absolute Ratings SYMBOL VALUE UNIT Peak repetitive off-state voltage ( Tj = -40 to 125°C, Full sine wave, 50 to 60 Hz; Gate open) (Note 1) VDRM VRRM 1000/ 800 V On-stage RMS current (Full sine wave, TC = 60°C ) IT(RMS) 1 A Peak non-repetitive surge current ( one full cycle 60 HZ, Tj = 25°C) ITSM 9 A Circuit fusing consideration ( t = 8.3ms) I2T 0.6 A2S Operating junction temperature range Tj -40 to +125 °C TSTG -40 to +150 °C DO PARAMETER Storage temperature range Note : (1) VDRM and VRRM for all types can be applied on a continuous basis. Blocking voltages shall not be tested with a constant current source such that the voltage ratings of the devices are exceeded. http://www.doeshare.net Version 02, Oct-2020 Page 1 of 9 DT1T Series TRIACs CHARACTERISTIC & CURVES (Tj = 25°C, unless otherwise specified.) Thermal Characteristics Junction to ambient (DC) (1) Maximum lead temperature for soldering purposes (1/8” form case for 10 seconds) Note 1: Without Heatsink Static Characteristics PARAMETER Threshold Voltage (Tj = 125°C) Dynamic resistors (Tj = 125°C) SOT-223 TO-92 SOT-223 Rth(j-c) Tj = 25°C Tj = 125°C UNIT 50 Max Rth(j-L) Max TL Max 20 50 °C/W 25 260 °C SYMBOL MIN. TYP. MAX. UNIT Vto -- -- 1.1 V Rd -- -- 500 mΩ IDRM IRRM -- -- 5 uA -- -- 0.5 mA ES H Peak repetitive forward or reverse blocking current ( VAK = rated VDRM and VRRM, gate open) TO-92 VALUE AR Thermal resistance from junction to lead (1) SYMBOL E PARAMETER ON Characteristics PARAMETER SYMBOL DT1T5X DT1T10X. UNIT VTM 1.56 -- Max V VD= VDRM , RL=100Ω, Tj=125°C VGD 0.3 -- Min V Gate trigger current ( VAK = 12V, RL=100Ω) IGT1 IGT2 IGT3 5 5 5 10 10 10 Max mA Gate trigger voltage ( VAK = 12V, RL=100Ω) VGT1 VGT2 VGT3 1 1 Max V Holding current ( VAK = 12V, RL=100Ω) IH1 IH3 5 10 Max mA Latching current ( VAK = 12V, RL=100Ω) IL1 IL2 IL3 10 20 10 25 25 25 Max mA DO Peak forward on-state voltage ( ITM = 1.4 A @ Tj = 25°C) http://www.doeshare.net Page 2 of 9 DT1T Series TRIACs CHARACTERISTIC & CURVES (Tj = 25°C, unless otherwise specified.) Dynamic Characteristics SYMBOL Critical rate of rise of off-stage voltage ( VAK = 67% rated VDRM , Tj = 125°C, gate open) UNIT dv/dt 200 600 Max V/us di/dt(s) 15 50 Max A/us Max A/ms di/dt(c) 0.3 1 DO ES H Tj=125°C, gate open, Without Snubber DT1T10X AR Critical rate of rise of on-state current, (VDRM=maximum VDRM ,Tj = 125°C) DT1T5X E PARAMETER http://www.doeshare.net Page 3 of 9 DT1T Series TRIACs DO ES H AR E CHARACTERISTIC & CURVES (Tj = 25°C, unless otherwise specified.) http://www.doeshare.net Page 4 of 9 DT1T Series TRIACs DO ES H AR E CHARACTERISTIC & CURVES (Tj = 25°C, unless otherwise specified.) http://www.doeshare.net Page 5 of 9 DT1T Series TRIACs CHARACTERISTIC & CURVES (Tj = 25°C, unless otherwise specified.) DIM Millimeters Min Max 6.40 3.40 1.45 0.03 6.60 3.60 1.65 0.15 DO A B C C1 ES H AR E SOT-223 Plastic Package http://www.doeshare.net DIM Millimeters Min Max c2 b B1 e 0.2 0.35 0.66 0.76 6.85 7.15 2.286(BSC) DIM L L1 θ Millimeters Min Max 0.76 1.16 1.70 1.80 0゜ 8゜ Page 6 of 9 DT1T Series TRIACs CHARACTERISTIC & CURVES (Tj = 25°C, unless otherwise specified.) DIM Inches Min Max 0.175 0.170 0.125 0.045 0.205 0.210 0.165 0.055 Millimeters Min Max 4.45 4.32 3.175 1.143 5.20 5.33 4.191 1.397 DIM E F G H Inches Min Max 0.095 0.500 0.080 0.135 0.105 0.105 Millimeters Min Max 2.413 12.70 2.04 3.43 2.667 2.66 DO A B C D ES H AR E TO-92 Plastic Package http://www.doeshare.net Page 7 of 9 DT1T Series TRIACs CHARACTERISTIC & CURVES (Tj = 25°C, unless otherwise specified.) Doeshare Standar products T for Triac series 16 for 16A, 1 for 1A T for 3Q, F for 4Q 35 means Igt 35mA, 5 means Igt 5mA A=>TO-92, C=>TO-126, D=> DPAK, E=>D2PAK, F=> TO-220F, G=>SOT-223 M=>ITO-3P, P=>TO-3P, T=> TO-220, Y=>TO251 A=> 600V, B=> 800V, C=> 1000V None=>125°C, H=>150°C ES H Type Code: Product Code: IT Amp Code: Quadrantal Code: IGT&VCEsat Code: Package Code: AR E Ordering information scheme DO Voltage Code: Operation Temp Code: http://www.doeshare.net Page 8 of 9 DT1T Series TRIACs CHARACTERISTIC & CURVES (Tj = 25°C, unless otherwise specified.) E Important Notice and Disclaimer AR DOESHARE has used reasonable care in preparing the information included in this document, but DOESHARE does not warrant that such information is error free. DOESHARE assumes no liability whatsoever for any damages incurred by you resulting from errors in or omissions from the information included herein. DOESHARE no warranty, representation or guarantee regarding the documents, circuits and products specification, DOESHARE reservation rights to make changes for any documents, products, circuits and specifications at any time without notice. Purchasers are solely responsible for the choice, selection and use of the DOESHARE products and services described herein, and DOESHARE assumes no liability whatsoever relating to the choice, selection or use of the products and services described herein. ES H No license, express or implied, by implication or otherwise under any intellectual property rights of DOESHARE. DO Resale of DOESHARE products with provisions different from the statements and/or technical features set forth in this document shall immediately void any warranty granted by DOESHARE for the DOESHARE product or service described herein and shall not create or extend in any anner whatsoever, any liability of DOESHARE. http://www.doeshare.net Page 9 of 9
DT1T10A-B 价格&库存
很抱歉,暂时无法提供与“DT1T10A-B”相匹配的价格&库存,您可以联系我们找货
