2SC945-P
2SC945-P
    BLUEROCKET(蓝箭电子)
    TO92-3
    TO-92塑封封装NPN半导体三极管 NPN 电流:150MA 电压:50V
2SC945-P 数据手册
2SC945 Rev.E Mar.-2016 描述 / DATA SHEET Descriptions TO-92 塑封封装 NPN 半导体三极管。Silicon NPN transistor in a TO-92 Plastic Package.  特征 / Features 耐压高,hFE 特性好。 High voltage, excellent hFE linearity. 用途 / Applications 用于音频放大及低速开关。 AF amplifier and low speed switching applications. 内部等效电路 引脚排列 12 / Equivalent Circuit / Pinning 3 PIN1:Base PIN 2:Collector 放大及印章代码 / hFE Classifications & Marking hFE Classifications Symbol hFE Range http://www.fsbrec.com PIN 3:Emitter R Q P K 90~180 135~270 200~400 300~600 1/6 2SC945 Rev.E Mar.-2016 极限参数 / DATA SHEET Absolute Maximum Ratings(Ta=25℃) 参数 Parameter 符号 Symbol 数值 Rating 单位 Unit Collector to Base Voltage VCBO 60 V Collector to Emitter Voltage VCEO 50 V Emitter to Base Voltage VEBO 5.0 V Collector Current - Continuous IC 150 mA Base Current – Continuous IB 20 mA Collector Power Dissipation PC 250 mW Junction Temperature Tj 150 ℃ Tstg -55~150 ℃ Storage Temperature Range 电性能参数 / Electrical Characteristics(Ta=25℃) 参数 Parameter Collector Cut-Off Current Emitter Cut-Off Current DC Current Gain Collector to Emitter Saturation Voltage Base to Emitter Saturation Voltage Base to Emitter Voltage Transition Frequency 符号 Symbol ICBO 最小值 典型值 最大值 Min Typ Max 0.1 VEB=5.0V IC=0 hFE(1) VCE=6.0V IC=1.0mA 90 hFE(2) VCE=6.0V IC=0.1mA 50 VCE(sat) IC=100mA IB=10mA 0.15 0.3 V VBE(sat) IC=100mA IB=10mA 0.86 1.0 V VBE VCE=6.0V IC=1.0mA 0.62 0.65 V fT VCE=6.0V IC=10mA 250 450 MHz VCB=6.0V f=1.0MHz VCE=6.0V Rg=2.0KΩ IE=0 3.0 4.0 pF 0.8 15 dB Cob Noise Figure NF IC=0.1mA f=1.0KHz 0.1 单位 Unit μA IEBO Collector Output Capacitance http://www.fsbrec.com 测试条件 Test Conditions VCB=60V IE=0 150 μA 600 2/6 2SC945 Rev.E Mar.-2016 电参数曲线图 DATA SHEET / Electrical Characteristic Curve http://www.fsbrec.com 3/6 2SC945 Rev.E Mar.-2016 外形尺寸图 DATA SHEET / Package Dimensions http://www.fsbrec.com 4/6 2SC945 Rev.E Mar.-2016 印章说明 / DATA SHEET Marking Instructions BR C945 R **** 说明: BR:    为公司代码 C945:  为型号代码 R: 为 hFE 分档代码 ****:  为生产批号代码,随生产批号变化。 Note: BR: Company Code. C945: Product Type. R: hFE Classifications Symbol ****: Lot No. Code,code change with Lot No. http://www.fsbrec.com 5/6 2SC945 Rev.E Mar.-2016 DATA SHEET 波峰焊温度曲线图(无铅) / Temperature Profile for Dip Soldering(Pb-Free) 说明: Note: 1、预热温度 25~150℃,时间 60~90sec; 1.Preheating:25~150℃, Time:60~90sec. 2、峰值温度 255±5℃,时间持续为 5±0.5sec; 2.Peak Temp.:255±5℃, Duration:5±0.5sec. 3、焊接制程冷却速度为 2~10℃/sec. 3. Cooling Speed: 2~10℃/sec. 耐焊接热试验条件 / Resistance to Soldering Heat Test Conditions 温度:270±5℃ 包装规格 散件包装 Units 包装数量 Units/Bag 只/袋 Bags/Inner Box 袋/盒 Units/Inner Box 只/盒 Dimension Inner Boxes/Outer Box 盒/箱 Units/Outer Box 只/箱 Bag 袋 包装尺寸 Inner Box 盒 (unit:mm3) Outer Box 箱 1,000 10 10,000 5 50,000 135×190 237×172×102 560×245×195 1,000 10 10,000 10 100,000 135×190 237×172×102 560×245×375 Units/tape 只/纸带 Tape/Inner Box 纸带/盒 Rows/Inner Box 纸带层/盒 Inner Boxes/Outer Box 盒/箱 Units/Outer Box 只/箱 Inner Box 盒 3,000 1 120 10 30,000 328×230×42 / AMMO Package Type 封装形式 使用说明 Time:10±1 sec / BULK TO-92 TO-92 Temp:270±5℃ / Packaging SPEC. Package Type 封装形式 编带包装 时间:10±1 sec. Units 包装数量 Dimension 包装尺寸 (unit:mm3) Outer Box 箱 小箱 480×346×235, 大箱 547×407×268 / Notices http://www.fsbrec.com 6/6
2SC945-P 价格&库存
很抱歉,暂时无法提供与“2SC945-P”相匹配的价格&库存,您可以联系我们找货
2SC945-P
  • 20+0.19019
  • 200+0.14818
  • 1000+0.12485
库存:134
