8550-C
8550-C
    BLUEROCKET(蓝箭电子)
    TO92-3
    PNP 电流:1.5A 电压:25V
8550-C 数据手册
8550 Rev.F Jul.-2019 DATA SHEET  描述 / Descriptions TO-92 塑封封装 PNP 半导体三极管。Silicon PNP transistor in a TO-92 Plastic Package.  特征 / Features PC,IC 大,与 8050 互补。 High PC and IC, complementary pair with 8050. 用途 / Applications 用于 2W 乙类推挽功放。 2W output amplifier of portable radios in class B push-pull operation. 内部等效电路 引脚排列 12 / Equivalent Circuit / Pinning 3 PIN1:Collector 放大及印章代码 PIN 2:Base PIN 3:Emitter / hFE Classifications & Marking hFE Classifications Symbol hFE Range http://www.fsbrec.com B C D 85~160 120~200 160~300 1/6 8550 Rev.F Jul.-2019 极限参数 / DATA SHEET Absolute Maximum Ratings(Ta=25℃) 参数 Parameter 符号 Symbol 数值 Rating 单位 Unit Collector to Base Voltage VCBO -40 V Collector to Emitter Voltage VCEO -25 V Emitter to Base Voltage VEBO -6.0 V IC -1.5 A ICM(t≤1ms) -3 A Base Current - Continuous IB -0.5 A Collector Power Dissipation PC 1.0 W Junction Temperature Tj 150 ℃ Tstg -55~150 ℃ Collector Current - Continuous Storage Temperature Range 电性能参数 / Electrical Characteristics(Ta=25℃) 参数 Parameter Collector to Base Breakdown Voltage Collector to Emitter Breakdown Voltage 符号 Symbol 测试条件 Test Conditions 最小值 典型值 最大值 单位 Min Typ Max Unit VCBO IC=-0.1mA IE=0 -40 V VCEO IC=-2.0mA IB=0 -25 V Emitter to Base Breakdown Voltage VEBO IE=-0.1mA IC=0 -6.0 V Collector Cut-Off Current ICBO VCB=-35V IE=0 -0.1 μA Emitter Cut-Off Current IEBO VEB=-6.0V IC=0 -0.1 μA hFE(1) VCE=-1.0V IC=-100mA 85 hFE(2) VCE=-1.0V IC=-800mA 40 hFE(3) VCE=-1.0V IC=-5.0mA 45 Collector to Emitter Saturation Voltage VCE(sat) IC=-800mA IB=-80mA -0.28 -0.5 V Base to Emitter Saturation Voltage VBE(sat) IC=-800mA IB=-80mA -0.98 -1.2 V VBE VCE=-1.0V IC=-10mA -0.66 -1.0 V fT VCE=-10V IC=-50mA Cob VCB=-10V f=1.0MHz IE=0 DC Current Gain Base to Emitter Voltage Transition Frequency Collector Output Capacitance http://www.fsbrec.com 100 300 200 MHz 15 pF 2/6 8550 Rev.F Jul.-2019 电参数曲线图 DATA SHEET / Electrical Characteristic Curve http://www.fsbrec.com 3/6 8550 Rev.F Jul.-2019 外形尺寸图 DATA SHEET / Package Dimensions http://www.fsbrec.com 4/6 8550 Rev.F Jul.-2019 印章说明 / DATA SHEET Marking Instructions BR 8550 B **** 说明: BR:  为公司代码 8550: 为产品型号 B: 为 hFE 分档代码 ****: 为生产批号代码,随生产批号变化。 Note: BR: Company Code. 8550: Product Type. B: hFE Classifications Symbol. ****: Lot No. Code, code change with Lot No. http://www.fsbrec.com 5/6 8550 Rev.F Jul.-2019 DATA SHEET 波峰焊温度曲线图(无铅) / Temperature Profile for Dip Soldering(Pb-Free) 说明: Note: 1、预热温度 25~150℃,时间 60~90sec; 1.Preheating:25~150℃, Time:60~90sec. 2、峰值温度 255±5℃,时间持续为 5±0.5sec; 2.Peak Temp.:255±5℃, Duration:5±0.5sec. 3、焊接制程冷却速度为 2~10℃/sec. 3. Cooling Speed: 2~10℃/sec. 耐焊接热试验条件 / 温度:270±5℃ 包装规格 散件包装 Time:10±1 sec Units 包装数量 Units/Bag 只/袋 Bags/Inner Box 袋/盒 Units/Inner Box 只/盒 Dimension Inner Boxes/Outer Box 盒/箱 Units/Outer Box 只/箱 Bag 袋 包装尺寸 Inner Box 盒 (unit:mm3) Outer Box 箱 1,000 10 10,000 5 50,000 135×190 237×172×102 560×245×195 1,000 10 10,000 10 100,000 135×190 237×172×102 560×245×375 Units/tape 只/纸带 Tape/Inner Box 纸带/盒 Rows/Inner Box 纸带层/盒 Inner Boxes/Outer Box 盒/箱 Units/Outer Box 只/箱 Inner Box 盒 3,000 1 120 10 30,000 328×230×42 / AMMO Package Type 封装形式 使用说明 Temp.:270±5℃ / BULK TO-92 TO-92 时间:10±1 sec. / Packaging SPEC. Package Type 封装形式 编带包装 Resistance to Soldering Heat Test Conditions Units 包装数量 Dimension 包装尺寸 (unit:mm3) Outer Box 箱 小箱 480×346×235, 大箱 547×407×268 / Notices http://www.fsbrec.com 6/6
8550-C 价格&库存
很抱歉,暂时无法提供与“8550-C”相匹配的价格&库存,您可以联系我们找货
