MCR100-8W
FS
1.0A Sensitive Gate SCRs
Product Summary
Symbol
Value
Unit
IT(RMS)
1.0
A
VDRM VRRM
600 / 800
V
IGT
100
μA
Feature
Application
With high ability to withstand the shock loading of
large current, Provide high dv/dt rate with strong
resistance to electromagnetic interference.
Power charger, T-tools, massager, solid state
relay, AC Motor speed regulation and so on.
Package
Circuit diagram
SOT-223-3L
Marking
100-8
XXXX
www.fuxinsemi.com
Page 1
Ver2.1
MCR100-8W
FS
Absolute maximum ratings (Ta=25℃ unless otherwise noted)
Parameter
Symbol
Value
Unit
Repetitive peak off-state voltage
VDRM
600 / 800
V
Repetitive peak reverse voltage
VRRM
600 / 800
V
RMS on-state current
IT(RMS)
1.0
A
ITSM
12
A
I2t
0.72
A2s
dIT/dt
50
A/μs
IGM
0.5
A
PG(AV)
0.1
W
Junction Temperature
TJ
-40 ~ +110
Storage Temperature
TSTG
-40 ~ +150
Non repetitive surge peak on-state current
(full cycle, F=50Hz)
I2t value for fusing (tp=10ms)
Critical rate of rise of on-state current (IG =2×IGT)
Peak gate current
Average gate power dissipation
Electrical characteristics (TA=25 oC, unless otherwise noted)
Parameter
Symbol
Gate trigger current
IGT
Gate trigger voltage
VGT
Gate non-trigger voltage
VGD
Test Condition
VD =12V IT=10mA Tj =25℃
VD =1/2VDRM Tj =110℃
Value
Unit
Min
Max
100
μA
0.8
V
0.2
V
latching current
IL
VD =12V IG=0.5mA
5
mA
Holding current
IH
RGK=1kΩ Tj =25℃
4
mA
50
V/μs
1.7
V
Tj=25℃
5
μA
Tj=110℃
0.1
mA
Critical-rate of rise
of commutation voltage
dVD/dt
VD=2/3VDRM Gate Open
Tj =110℃
STATIC CHARACTERISTICS
Forward "on" voltage
VTM
Repetitive Peak Off-State Current
IDRM
Repetitive Peak Reverse Current
IRRM
ITM =2A tp=380μs
VD =VDRM VR =VRRM
THERMAL RESISTANCES
Thermal resistance
www.fuxinsemi.com
Rth(j-c)
Junction to case
TYP.
℃/W
Rth(j-a)
Junction to ambient
TYP.
60
℃/W
Page 2
Ver2.1
MCR100-8W
FS
Typical Characteristics
FIG1 Maximum power dissipation versus RMS
on-state current
FIG2 RMS on-state current versus case
temperature
1.2
IT(RMS)
1.2
1.0
1.0
0.8
0.8
0.6
0.6
0.4
0.4
0.2
0.2
P(w)
IT(RMS) (A)
0.4
0.6
0.2
0.8
1.0
Tc (℃)
50
75
100
125
FIG4 On-state characteristics (maximum
values)
FIG3 Surge peak on-state current versus
number of cycles
ITM (A)
ITSM (A)
8
tp=10ms
One cycle
12
Tj=Tjmax
9
1
6
3
Tj=25℃
10
Number of cycles
100
1000
FIG5 Non-repetitive surge peak on-state current
for a sinusoidal pulse with width tp
很抱歉,暂时无法提供与“MCR100-8W”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.59260
- 50+0.46818
- 150+0.40598
- 500+0.35932
- 2500+0.29344
- 4000+0.27476
