PSM20U200GS
PSM20U200GS
    PINGWEI(平伟)
    TO-252(DPAK)
    电压:200V 电流:20A
PSM20U200GS 数据手册
PS20U100S&PS20U100FS PSM20U200GS&PSM20U200DS 20.0AMPS. SCHOTTKY BARRIER RECTIFIERS FEATURE .High current capability .Ultra low forward voltage drop .Low power loss, high efficiency .High surge capability .High temperature soldering guaranteed 260°C /10seconds, 0.25"(6.35mm)from case. TO-252 PSM20U200GS TO-251 PSM20U200DS MECHANICAL DATA .Case: Molded with UL-94 Class V-0 recognized Flame Retardant Epoxy .Mounting position: any Single phase, half wave, 60Hz,resistive or inductive load. For capacitive load, derate current by 20% MAXIMUM RATINGS (TC=25℃ unless otherwise noted) Parameter Symbol PSM20U200GS&PSM20U200DS Units Maximum Recurrent Peak Reverse Voltage VRRM VRMS VDC 200 V 140 V 200 V IF(AV) 20.0 A IFSM 200.0 A CJ TJ, TSTG 1000 pF -55 to +150 °C Maximum RMS Voltage Maximum DC blocking Voltage Maximum Average Forward Rectified Current at TC =100°C Total device Peak Forward Surge Current 8.3ms single half sine-wave superimposed on rated load (JEDEC method) Typical Junction Capacitance (Note 1) Operation Junction Temperature and Storage Temperature ELECTRICAL CHARACTERISTICS (TC=25℃ unless otherwise noted) Parameter Symbol TJ=25℃ Forward voltage drop VF TJ=125℃ Reverse leakage current TJ=25℃ TJ=125℃ IF=5A IF=10A IF=20A IF=5A IF=10A IF=20A VR=200V VR=200V IR THERMAL CHARACTERISTICS (TC=25℃ unless otherwise noted) Typ Max 0.70 ---- 0.76 0.85 0.87 0.95 0.57 ---- 0.64 0.72 0.72 0.80 ---- 0.10 ---- 25.0 Units V mA Parameter Symbol PSM20U200GS PSM20U200DS Units Typical Thermal Resistance (Note 2) R(JC) 6.5 6.5 °C /W Notes: 1. Measured at 1.0 MHz and applied reverse voltage of 4.0Vdc 2. Thermal Resistance from Junction to Case 1 PS20U100S&PS20U100FS RATING AND CHARACTERISTIC CURVES FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE FIG.2-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS 20.0 INSTANEOUS FORWARD CURRENT,(A) AVERGE FORWARD RECTIFIED CURRENT,(A) 100 10.0 Single Phase Half Wave 60Hz Resistive or inductive Load 0 0 50 100 150 200 0.1 INSTANEOUS REVERSE CURRENT,(mA) PEAK FORWARD SURGE CURRENT,(A) 8.3ms Single Half Sine-Wave (JEDEC Method) 10 0.9 1.1 10 50 1 0.7 0.5 FIG.4-TYPICAL REVERSE CHARACTERISTICS 100 0 0.3 INSTANEOUS FORWARD VOLTAGE,(V) FIG.3-MAXIMUN NON-REPETITIVE FORWARD SURGE CURRENT 150 TJ=25℃ 1 CASE TEMPERTURE,(℃) 200 TJ=125℃ 10 100 NUMBER OF CYCLES AT 60Hz 2 TJ=125℃ 1.0 0.1 0.01 0 TJ=25℃ 40 80 120 160 PERCENT OF RATED PEAK REVERSE VOLTAGE,(V) 200 PS20U100S&PS20U100FS PACKAGE OUTLINE DIMENSIONS TO-252 L B C I 2 N A B C H D A E F 3 PIN 1 G D H J E G F Dim M K I J K a L P P M N a TO-252 Min Max .230(5.85) .246(6.25) .250(6.35) .264(6.75) .207(5.27) .218(5.54) .037(0.93) .045(1.14) .106(2.70) .138(3.50) .028(0.72) .033(0.84) .024(0.60) .041(1.05) .028(0.72) .043(1.10) .085(2.15) .096(2.45) .037(0.95) .047(1.20) .018(0.45) .026(0.65) .018(0.45) .024(0.60) .081(2.05) .094(2.40) .000(0.00) .006(0.15) -.008(0.20) 0° 10° Dimensions in inches and (millimeters) TO-251 L B C Dim I A B N H PIN 1 2 C D A E 3 F D H J I E J F K P K L N P TO-251 Min Max .230(5.85) .246(6.25) .250(6.35) .266(6.75) .207(5.27) .218(5.54) .037(0.93) .045(1.14) .173(4.40) .205(5.20) .028(0.72) .033(0.84) .028(0.70) .043(1.10) .085(2.15) .096(2.45) .037(0.95) .047(1.20) .018(0.45) .026(0.65) .018(0.45) .024(0.60) -.008(0.20) .081(2.05) .094(2.40) Dimensions in inches and (millimeters) 3
PSM20U200GS 价格&库存
很抱歉,暂时无法提供与“PSM20U200GS”相匹配的价格&库存,您可以联系我们找货
