PS10U100GS
PS10U100GS
    PINGWEI(平伟)
    TO-252(DPAK)
    电压:100V 电流:10A
PS10U100GS 数据手册
PS10U100GS&PS10U100DS PS10U100GS&PS10U100DS 10.0AMPS. SCHOTTKY BARRIER RECTIFIERS FEATURE .High current capability .Ultra low forward voltage drop .Low power loss, high efficiency .High surge capability .High temperature soldering guaranteed 260°C /10seconds, 0.25"(6.35mm)from case. TO-252 PS10U100GS TO-251 PS10U100DS MECHANICAL DATA .Case: Molded with UL-94 Class V-0 recognized Flame Retardant Epoxy .Mounting position: any Single phase, half wave, 60Hz,resistive or inductive load. For capacitive load, derate current by 20% MAXIMUM RATINGS (TC=25℃ unless otherwise noted) Parameter Symbol PS10U100GS&PS10U100DS Units Maximum Recurrent Peak Reverse Voltage VRRM VRMS VDC 100 V 70 V 100 V IF(AV) 10.0 A IFSM 120.0 A CJ TJ, TSTG 655 pF -55 to +150 °C Maximum RMS Voltage Maximum DC blocking Voltage Maximum Average Forward Rectified Current at TC =100°C Total device Peak Forward Surge Current 8.3ms single half sine-wave superimposed on rated load (JEDEC method) Typical Junction Capacitance (Note 1) Operation Junction Temperature and Storage Temperature ELECTRICAL CHARACTERISTICS (TC=25℃ unless otherwise noted) Parameter Symbol Test conditions TJ=25℃ Forward voltage drop VF TJ=125℃ Reverse leakage current IR TJ=25℃ TJ=125℃ IF=3A IF=5A IF=10A IF=3A IF=5A IF=10A VR=100V VR=100V Units Typ Max 0.47 --- 0.53 --- 0.65 0.72 0.42 --- 0.50 --- 0.62 0.70 --- 100 μA --- 15 mA V THERMAL CHARACTERISTICS (TC=25℃ unless otherwise noted) Parameter Symbol PS10U100DS PS10U100GS Units Typical Thermal Resistance (Note 2) R(JC) 6.5 6.5 °C /W Notes: 1. Measured at 1.0 MHz and applied reverse voltage of 4.0Vdc 2. Thermal Resistance from Junction to Case 1 PS10U100GS&PS10U100DS RATING AND CHARACTERISTIC CURVES FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE FIG.2-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS 10.0 INSTANEOUS FORWARD CURRENT,(A) AVERGE FORWARD RECTIFIED CURRENT,(A) 100 5.0 Single Phase Half Wave 60Hz Resistive or inductive Load 0 0 50 100 150 200 TJ=125℃ 10 1 0.1 CASE TEMPERTURE,(℃) TJ=25℃ 0.5 0.3 0.1 0.7 0.9 INSTANEOUS FORWARD VOLTAGE,(V) FIG.4-TYPICAL REVERSE CHARACTERISTICS FIG.3-MAXIMUN NON-REPETITIVE FORWARD SURGE CURRENT 160 8.3ms Single Half Sine-Wave (JEDEC Method) 120 INSTANEOUS REVERSE CURRENT,(mA) PEAK FORWARD SURGE CURRENT,(A) 100 80 40 0 10 0.1 0.01 1 10 100 NUMBER OF CYCLES AT 60Hz 2 TJ=125℃ 1 0.001 TJ=25℃ 0 20 40 60 80 PERCENT OF RATED PEAK REVERSE VOLTAGE,(V) 100 PS10U100GS&PS10U100DS PACKAGE OUTLINE DIMENSIONS TO-252 L B C I 2 N A B C H D A E F 3 PIN 1 G D J E G F Dim H M K I J a P K L P M N a TO-252 Min Max .230(5.85) .246(6.25) .250(6.35) .264(6.75) .207(5.27) .218(5.54) .037(0.93) .045(1.14) .106(2.70) .138(3.50) .028(0.72) .033(0.84) .024(0.60) .041(1.05) .028(0.72) .043(1.10) .085(2.15) .096(2.45) .037(0.95) .047(1.20) .018(0.45) .026(0.65) .018(0.45) .024(0.60) .081(2.05) .094(2.40) .000(0.00) .006(0.15) -.008(0.20) 0° 10° Dimensions in inches and (millimeters) TO-251 L B C N I H D PIN 1 2 P A B C A D E 3 F E F Dim J H I J K K L N P TO-251 Min Max .230(5.85) .246(6.25) .250(6.35) .266(6.75) .207(5.27) .218(5.54) .037(0.93) .045(1.14) .173(4.40) .205(5.20) .028(0.72) .033(0.84) .028(0.70) .043(1.10) .085(2.15) .096(2.45) .037(0.95) .047(1.20) .018(0.45) .026(0.65) .018(0.45) .024(0.60) -.008(0.20) .081(2.05) .094(2.40) Dimensions in inches and (millimeters) 3
PS10U100GS 价格&库存
很抱歉,暂时无法提供与“PS10U100GS”相匹配的价格&库存,您可以联系我们找货
