MBR10150GCT
MBR10150GCT
    PINGWEI(平伟)
    TO-252(DPAK)
    电压:150V 电流:5A
MBR10150GCT 数据手册
MBR10150GCT&MBR10150DCT MBR10150GCT&MBR10150DCT 10.0AMPS. SCHOTTKY BARRIER RECTIFIERS FEATURE .High current capability .Low forward voltage drop .Low power loss, high efficiency .High surge capability .High temperature soldering guaranteed 260°C /10seconds, 0.25"(6.35mm)from case. TO-252 MBR10150GCT TO-251 MBR10150DCT MECHANICAL DATA .Case: Molded with UL-94 Class V-0 recognized Flame Retardant Epoxy .Mounting position: any Single phase, half wave, 60Hz,resistive or inductive load. For capacitive load, derate current by 20% MAXIMUM RATINGS (TC=25℃ unless otherwise noted) Parameter Symbol MBR10150GCT&MBR10150DCT Units Maximum Recurrent Peak Reverse Voltage VRRM VRMS VDC 150 V 105 V 150 V Maximum RMS Voltage Maximum DC blocking Voltage Maximum Average Forward Rectified Current Per Leg Total device at TC =100°C Peak Forward Surge Current 8.3ms single half sine-wave superimposed on rated load (JEDEC method) Operation Junction Temperature and Storage Temperature A 10.0 IFSM 100.0 A CJ TJ, TSTG 112 pF -55 to +150 °C Per Leg Typical Junction Capacitance (Note 1) 5.0 IF(AV) ELECTRICAL CHARACTERISTICS -(per leg) (TA=25℃ unless otherwise noted) Parameter Symbol Test conditions TJ=25℃ Forward voltage drop VF TJ=125℃ Reverse leakage current IR TJ=25℃ TJ=125℃ IF=3A IF=5A IF=3A IF=5A VR=150V VR=150V Typ Max 0.72 ---- 0.77 0.88 0.60 ---- 0.64 0.75 ---- 0.1 ---- 10 Units V mA THERMAL CHARACTERISTICS (TC=25℃ unless otherwise noted) Parameter Symbol MBR10150GCT MBR10150DCT Units Typical Thermal Resistance (Note 2) R(JC) 6.5 6.5 °C /W Notes: 1. Measured at 1.0 MHz and applied reverse voltage of 4.0Vdc 2. Thermal Resistance from Junction to Case Version1.0-2015.2 1 www.perfectway.cn MBR10150GCT&MBR10150DCT RATING AND CHARACTERISTIC CURVES FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE FIG.2-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS 10.0 INSTANEOUS FORWARD CURRENT,(A) AVERGE FORWARD RECTIFIED CURRENT,(A) 100 5.0 Single Phase Half Wave 60Hz Resistive or inductive Load 0 0 50 100 150 200 1 0.1 CASE TEMPERTURE,(℃) INSTANEOUS REVERSE CURRENT,(mA) PEAK FORWARD SURGE CURRENT,(A) 40 10 100 NUMBER OF CYCLES AT 60Hz Version1.0-2015.2 1.1 10 TJ=125℃ 1 0.1 0.01 1 0.9 100 80 0 0.7 0.5 0.3 FIG.4-TYPICAL REVERSE CHARACTERISTICS 8.3ms Single Half Sine-Wave (JEDEC Method) 120 TJ=25℃ Pulse Width=300μs 1% Duty Cycle INSTANEOUS FORWARD VOLTAGE,(V) FIG.3-MAXIMUN NON-REPETITIVE FORWARD SURGE CURRENT 160 TJ=125℃ 10 2 0.001 TJ=25℃ 0 30 60 90 120 150 PERCENT OF RATED PEAK REVERSE VOLTAGE,(V) www.perfectway.cn MBR10150GCT&MBR10150DCT PACKAGE OUTLINE DIMENSIONS TO-252 L B C I 2 N A B C H D A E F 3 PIN 1 G D H J E G F Dim M K I J K a L P P M N a TO-252 Min Max .230(5.85) .246(6.25) .250(6.35) .264(6.75) .207(5.27) .218(5.54) .037(0.93) .045(1.14) .106(2.70) .138(3.50) .028(0.72) .033(0.84) .024(0.60) .041(1.05) .028(0.72) .043(1.10) .085(2.15) .096(2.45) .037(0.95) .047(1.20) .018(0.45) .026(0.65) .018(0.45) .024(0.60) .081(2.05) .094(2.40) .000(0.00) .006(0.15) -.008(0.20) 0° 10° Dimensions in inches and (millimeters) TO-251 L B C N Dim I A B H PIN 1 2 C D A E 3 F D H J I E J F K P K L N P TO-251 Min Max .230(5.85) .246(6.25) .250(6.35) .266(6.75) .207(5.27) .218(5.54) .037(0.93) .045(1.14) .173(4.40) .205(5.20) .028(0.72) .033(0.84) .028(0.70) .043(1.10) .085(2.15) .096(2.45) .037(0.95) .047(1.20) .018(0.45) .026(0.65) .018(0.45) .024(0.60) -.008(0.20) .081(2.05) .094(2.40) Dimensions in inches and (millimeters) Version1.0-2015.2 3 www.perfectway.cn
MBR10150GCT 价格&库存
很抱歉,暂时无法提供与“MBR10150GCT”相匹配的价格&库存,您可以联系我们找货
