SB360R
SB360R
    PINGWEI(平伟)
    DO-27(DO-201AA)
    电压:60V 电流:3A
SB360R 数据手册
S B360R S . SCHOTTKY BARRIER RECTIFIERS 3 . 0AMP 0AMPS DO-27/DO-201AD FEATURE .High current capability .Low forward voltage drop .Low power loss, high efficiency .High surge capability .High temperature soldering guaranteed 260°C /10sec/ 0.375" lead length at 5 lbs tension 0.96(24.4) MIN. .Terminal: Plated axial leads solderable per MIL-STD 202E, method 208C .Case: Molded with UL-94 Class V-0 recognized Flame Retardant Epoxy(free halogen) .Polarity: color band denotes cathode .Mounting position: any DIA. + .375(9.5) .335(8.5) MECHANICAL DATA .220(5.6) .187(5.0) - 0.96(24.4) MIN. .051(1.3) .043(1.1) DIA. Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25℃ ambient temperature unless otherwise specified. Single phase, half wave, 60Hz,resistive or inductive load. For capacitive load, derate current by 20% Type Number Maximum Recurrent Peak Reverse Voltage Maximum RMS Voltage Maximum DC blocking Voltage Maximum Average Forward Rectified Current .375"(9.5mm) lead length at TL =90°C SYM BOL SB360R units VRRM VRMS VDC 60 V 42 V 60 V IF(AV) 3.0 A IFSM 80.0 A VF 0.70 V Peak Forward Surge Current 8.3ms single half sine-wave superimposed on rated load (JEDEC method) Maximum Forward Voltage at 3.0A DC Maximum DC Reverse Current @TA =25°C atrated DC blocking voltage @ TA =100°C Typical Junction Capacitance(Note1) Typical Thermal Resistance(Note2) Storage Temperature Operating Junction Temperature 0.1 IR 10.0 CJ R(JA) TSTG TJ 300 pF 40 °C /W -55 to +150 °C -55 to +150 °C Note: 1. Measured at 1.0 MHz and applied reverse voltage of 4.0Vdc 2. Thermal Resistance from Junction to Ambient at 0.375"(9.5mm) lead length, vertical P.C. Board Mounted -1- mA SB360R)) RATING AND CHARACTERISTIC CURVES (SB360R FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE FIG.2-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS 3.0 INSTANEOUS FORWARD CURRENT,(A) AVERGE FORWARD RECTIFIED CURRENT,(A) 10 1.5 Single Phase Half Wave 60Hz Resistive or inductive Load 0 0 50 100 150 1 .1 .01 200 TJ=25℃ Pulse Width=300μs 1% Duty Cycle .6 .4 .2 .8 1.0 INSTANEOUS FORWARD VOLTAGE,(V) LEAD TEMPERTURE,(℃) FIG.4-TYPICAL REVERSE CHARACTERISTICS FIG.3-MAXIMUN NON-REPETITIVE FORWARD SURGE CURRENT 120 8.3ms Single Half Sine-Wave (JEDEC Method) 90 INSTANEOUS REVERSE CURRENT,(mA) PEAK FORWARD SURGE CURRENT,(A) 10 60 30 0 0 10 1.0 TJ=25℃ .1 .01 100 0 20 40 60 80 100 120 PERCENT OF RATED PEAK REVERSE VOLTAGE,(%) NUMBER OF CYCLES AT 60Hz -2- 140
SB360R 价格&库存
很抱歉,暂时无法提供与“SB360R”相匹配的价格&库存,您可以联系我们找货
