SB3T80 规格书
SB3T80
3.0AMPS. SCHOTTKY BARRIER RECTIFIERS
FEATURE
DO-27/DO-201AD
.For surface mounted application
.High current capability
.Low forward voltage drop
.Low power loss, high efficiency
.High surge current capability
.High temperature soldering guaranteed:
260℃/10 seconds at terminals.
0.96(24.4)
MIN.
.220(5.6)
.187(5.0)
.375(9.5)
.335(8.5)
MECHANICAL DATA
0.96(24.4)
MIN.
.Terminal: Solder plated
.Case: Molded with UL-94 Class V-0 recognized
Flame Retardant Epoxy (free halogen)
.Polarity: color band denotes cathode
DIA.
.051(1.3)
.043(1.1)
DIA.
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25℃ ambient temperature unless otherwise specified.
Single phase, half wave, 60Hz,resistive or inductive load.
For capacitive load, derate current by 20%
SYM
BOL
Type Number
SB3T80
units
80
V
56
V
Maximum DC blocking Voltage
VRRM
VRMS
VDC
80
V
Maximum Average Forward Rectified Current
IF(AV)
3.0
A
IFSM
80.0
A
VF(MAX)
VF(TYPE)
VF(MAX)
0.58
Maximum Recurrent Peak Reverse Voltage
Maximum RMS Voltage
Peak Forward Surge Current 8.3ms single half
sine-wave superimposed on rated load (JEDEC
method)
@TA =25°C
Forward Voltage at 3.0A DC
@TA =125°C
Maximum DC Reverse Current
@TJ=25°C
atrated DCblockingvoltage
@TJ =100°C
Typical Junction Capacitance (Note1)
Typical Thermal Resistance (Note2)
Storage Temperature
Operating Junction Temperature
IR
CJ
R(JA)
TSTG
TJ
Note:
1. Measured at 1.0 MHz and applied reverse voltage of 4.0Vdc
2. Measured on P.C.Board with 0.2×0.2”(5.0×5.0mm)Copper Pad Areas.
-1-
0.52
V
0.51
0.1
10.0
mA
370
pF
45
°C/W
-55 to +150
°C
-55 to +150
°C
SB3T80 规格书
RATING AND CHARACTERISTIC CURVES (SB3T80)
3.0
1.5
Single Phase Half Wave
60Hz Resistive or
inductive Load
FIG.2-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
INSTANEOUS FORWARD
CURRENT,(A)
AVERGE FORWARD
RECTIFIED CURRENT,(A)
FIG.1-TYPICAL FORWARD CURRENT
DERATING CURVE
TJ=25℃
Pulse Width=300μ
s 1% Duty Cycle
.1
LEAD TEMPERTURE,(℃)
60
30
INSTANEOUS REVERSE
CURRENT,(mA)
PEAK FORWARD SURGE
CURRENT,(A)
90
8.3ms Single Half
Sine-Wave (JEDEC
Method)
.5
.7
.9
FIG.4-TYPICAL REVERSE
CHARACTERISTICS
FIG.3-MAXIMUN NON-REPETITIVE
FORWARD SURGE CURRENT
120
.3
INSTANEOUS FORWARD
VOLTAGE,(V)
TJ=25℃
PERCENT OF RATED PEAK REVERSE
VOLTAGE,(%)
NUMBER OF CYCLES AT 60Hz
-2-
SB3T80 规格书
Marking and packaging illustration
1、Marking
A
SB3T80
PY
B
C
SYMBOL
A
B
C
Explanation
Color Band Denotes Cathode
Product Name
Trademark
2、Packaging
ITEM
SYMBOL
SPECIFICATIONS
SPECIFICATIONS
(mm)
(inch)
Component alignment
Z
1.2max
0.048max
Tape width
T
6.0±0.4
0.236±0.016
Exposed adhesive
E
0.8max
0.032max
Body eccentricity
|L1-L2|
1.0max
0.040max
Component
A
10.0±0.5
0.4±0.02
Inner tap
B
52.0~53.5
2.05~2.11
NOTE:
Each component lead shall be sandwiched between tapes for a minimum of 2.5mm(0.1inch)
-3-
很抱歉,暂时无法提供与“SB3T80”相匹配的价格&库存,您可以联系我们找货
