www.msksemi.com
RB520S-30-MS
Semiconductor
Compiance
PINNING
Silicon Epitaxial Planar Schottky Barrier Diode
PIN
for low current rectification and high speed
switching applications
DESCRIPTION
1
Cathode
2
Anode
2
1
Features
• Extremely small surface mounting type
SOD-523
• High reliability
Absolute Maximum Ratings (Ta = 25 OC)
Parameter
Symbol
Value
Unit
VR
30
V
Mean Rectifying Current
IF(AV)
200
mA
Peak Forward Surge Current (60 Hz for 1 Cyc.)
IFSM
1
A
Tj
125
O
C
Tstg
- 40 to + 125
O
C
Symbol
Max.
Unit
Forward Voltage
at IF = 200 mA
VF
0.6
V
Reverse Current
at VR = 10 V
IR
1
µA
Reverse Voltage
Junction Temperature
Storage Temperature Range
Characteristics at Ta = 25 OC
Parameter
Note: ESD sensitive product handling required.
www.msksemi.com
RB520S-30-MS
Semiconductor
Forward Characteristics
1000
Reverse Characteristics
1000
100
REVERSE CURRENT IR
(uA)
(mA)
IF
FORWARD CURRENT
o
Ta=100 C
100
10
1
0.1
0.01
200
300
FORWARD VOLTAGE
400
VF
500
o
Ta=25 C
1
10
(mV)
15
30
REVERSE VOLTAGE V (V)
R
Capacitance Characteristics
100
10
0.1
600
Compiance
Power Derating Curve
120
Ta=25℃
f=1MHz
PD(mW)
30
POWER DISSIPATION
CAPACITANCE BETWEEN TERMINALS
CT(pF)
100
10
80
60
40
3
10
REVERSE VOLTAGE V
15
R
(V)
50
75
AMBIENT TEMPERATURE T
100
a
125
www.msksemi.com
RB520S-30-MS
Semiconductor
PACKAGE MECHANICAL DATA
Symbol
A
A1
b
c
D
E
E1
E2
L
Dimensions In Millimeters
Min
Max
0.510
0.770
0.500
0.700
0.250
0.350
0.080
0.150
0.750
0.850
1.100
1.300
1.500
1.700
0.200 REF
0.010
0.070
7° REF
Dimensions In Inches
Min
Max
0.020
0.031
0.020
0.028
0.010
0.014
0.003
0.006
0.030
0.033
0.043
0.051
0.059
0.067
0.008 REF
0.001
0.003
7° REF
REEL SPECIFICATION
P/N
RB520S-30-MS
PKG
SOD-523
QTY
3000
Compiance
RB520S-30-MS
Semiconductor
Compiance
Attention
■ Any and all MSKSEMI Semiconductor products described or contained herein do not have specifications
that can handle applications that require extremely high levels of reliability, such as life-support systems,
aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious
physical and/or material damage. Consult with your MSKSEMI Semiconductor representative
nearest
you
before using any MSKSEMI Semiconductor products described or contained herein in such applications.
■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products
at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or
other parameters) listed in products specificationsof any andall MSKSEMI Semiconductor products described
orcontained herein.
■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the
performance, characteristics, and functions of the described products in the independent state, and are not
guarantees of the performance, characteristics, and functions of the described products as mounted in the
customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent
device, the customer should always evaluate and test devices mounted in the customer’sproducts orequipment.
■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all
semiconductor products fail with someprobability. It is possiblethat these probabilistic failures could give rise to
accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause
damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents
or events cannot occur. Such measures include but are not limited to protective circuits anderror prevention
circuitsfor safedesign, redundant design, and structural design.
■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described
or contained herein are controlled under any of applicable local export control laws and regulations, such
products must not be exported without obtaining the export license from theauthorities
concerned
in
accordance with the above law.
■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or
mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise,
without the prior written permission of MSKSEMI Semiconductor.
■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not
guaranteed for volume production. MSKSEMI Semiconductor believes information herein is accurate and reliable,
but no guarantees are made or implied regarding its use or any infringementsof intellectual property rights or
other rightsof third parties.
■ Any and all information described or contained herein are subject to change without notice due to
product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the
MSKSEMI Semiconductor productthat you intend to use.
www.msksemi.com
很抱歉,暂时无法提供与“RB520S-30-MS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.08176
- 500+0.06718
- 3000+0.05368
- 6000+0.04882
- 24000+0.04461
- 51000+0.04223
