1N4148WT
1N4148WT
    LGE(鲁光)
    SOD-523(SC-79)
1N4148WT 数据手册
1N4148WT High Speed Switching Diodes SOD-523 FEATURES z Fast switching speed. z Ultra-small surface mount package. z For general purpose switching application. z High conductance. z Lead free product. Dimensions in inches and (millimeters) APPLICATIONS z High-speed switching in surface mounted circuits. ORDERING INFORMATION Type No. Marking 1N4148WT T4 Package Code SOD-523 MAXIMUM RATING @ Ta=25℃ unless otherwise specified Parameter Symbol Limits Unit Non-Repetitive peak reverse voltage VRM 100 V Reverse voltage VR 80 V RMS Reverse voltage VR(RMS) 80 V Continuous forward current (Max.) IFM 250 mA Average rectified output current IO 125 mA IFSM 2.0 1.0 A Total power dissipation Ptot 150 mW Thermal resistance junction to ambient air RθJA 833 ℃/W Junction temperature Tj 150 ℃ Storage temperature Tstg -65 to +150 ℃ Non-Repetitive peak forward surge current ht t p : // Revision:20170701-P1 t=1.0μs t=100ms www.lgesemi .c o m mail:lge@lgesemi.com 1N4148WT High Speed Switching Diodes ELECTRICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified Parameter Symbol Min. Reverse breakdown voltage V(BR)R 75 Forward voltage VF Typ. Max. Unit Conditions IR=1.0μA 0.715 V IF=1mA 0.855 V IF=10mA 1.0 V IF=50mA 1.25 V IF=150mA 1.0 μA VR=75V 25 nA VR=20V Reverse current IR Diode capacitance Cd 2.0 pF VR=0,f=1.0MHz Reverse recovery time trr 4.0 ns IF=IR=10mA,Irr=0.1* IR, RL=100Ω TYPICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified ht t p : // Revision:20170701-P1 www.lgesemi .c o m mail:lge@lgesemi.com 1N4148WT High Speed Switching Diodes ht t p : // Revision:20170701-P1 www.lgesemi .c o m mail:lge@lgesemi.com
1N4148WT 价格&库存
很抱歉,暂时无法提供与“1N4148WT”相匹配的价格&库存,您可以联系我们找货
1N4148WT
  • 1+0.24090
  • 200+0.08019
  • 1500+0.05005
  • 3000+0.03982
库存:3000
