DSL14W
DSL14W
    JINGDAO(晶导微电子)
    SMF(SOD-123FL)
    电压:40V 电流:1A
DSL14W 数据手册
山东晶导微电子股份有限公司 DSL14W THRU DSL16W Jingdao Microelectronics co.LTD Surface Mount Schottky Barrier Rectifier Reverse Voltage - 40 to 60 V Forward Current - 1.0 A PINNING PIN FEATURES • Metal silicon junction, majority carrier conduction • For surface mounted applications • Low power loss, high efficiency • High forward surge current capability • For use in low voltage, high frequency inverters, free wheeling, and polarity protection applications DESCRIPTION 1 Cathode 2 Anode 1 2 Top View Marking Code: SL14/ SL16 Simplified outline SOD-123FL and symbol MECHANICAL DATA • Case: SOD-123FL • Terminals: Solderable per MIL-STD-750, Method 2026 • Approx. Weight:15mg 0.00048oz Absolute Maximum Ratings and Electrical characteristics Ratings at 25 °C ambient temperature unless otherwise specified.Single phase, half wave, 60Hz resistive or inductive load, for capacitive load, derate by 20 % Symbols Parameter DSL14W DSL16W Units Maximum Repetitive Peak Reverse Voltage V RRM 40 60 V Maximum RMS voltage V RMS 28 42 V Maximum DC Blocking Voltage V DC 40 60 V Maximum Average Forward Rectified Current I F(AV) 1.0 A Peak Forward Surge Current,8.3ms Single Half Sine-wave Superimposed on Rated Load (JEDEC method) I FSM 30 A Max Instantaneous Forward Voltage at 1 A Maximum DC Reverse Current T a = 25°C at Rated DC Reverse Voltage T a =100°C Typical Junction Capacitance (1) Typical Thermal Resistance (2) Operating Junction Temperature Range Storage Temperature Range VF 0.2 5 IR Cj 0.50 0.45 180 V mA 80 pF RθJA 90 °C/W Tj -55 ~ +150 °C T stg -55 ~ +150 °C (1)Measured at 1 MHz and applied reverse voltage of 4 V D.C (2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas. 2017.01 SOD123FL-S-DSL14W~DSL16W-1A60V Page 1 of 3 山东晶导微电子股份有限公司 DSL14W THRU DSL16W Jingdao Microelectronics co.LTD Fig.2 Typical Reverse Characteristics Average Forward Current (A) 1.2 1.0 0.8 0.6 0.4 0.2 Single phase half-wave 60 Hz resistive or inductive load 0.0 25 75 50 100 125 150 Instaneous Reverse Current ( μA) Fig.1 Forward Current Derating Curve 10 4 10 3 T J =100°C 10 2 T J =75°C 10 1 T J =25°C 10 0 0 Case Temperature (°C) 80 100 Fig.4 Typical Junction Capacitance 500 Junction Capacitance ( pF) 20 10 1.0 DSL14W DSL16W 0.1 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 100 50 DSL14W 20 DSL16W 10 1.8 0.1 1 10 100 Reverse Voltage (V) Fig.5 Maximum Non-Repetitive Peak Forward Surage Current Fig.6- Typical Transient Thermal Impedance 35 28 21 14 07 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 T J =25°C 200 Instaneous Forward Voltage (V) 10 100 Transient Thermal Impedance( °C /W) Instaneous Forward Current (A) Peak Forward Surage Current (A) 60 Percent of Rated Peak Reverse Voltage(%) Fig.3 Typical Forward Characteristic 1000 100 10 Number of Cycles at 60Hz 2017.01 40 20 1 0.01 0.1 1 10 100 t, Pulse Duration(sec) www.sdjingdao.com Page 2 of 3 山东晶导微电子股份有限公司 DSL14W THRU DSL16W Jingdao Microelectronics co.LTD PACKAGE OUTLINE Plastic surface mounted package; 2 leads SOD-123FL ∠ALL ROUND C A ∠ALL ROUND VM D E A g Top View mil Bottom View A C D E e g HE max 1.1 0.20 2.9 1.9 1.1 0.9 3.8 min 0.9 0.12 2.6 1.7 0.8 0.7 3.5 max 43 7.9 114 75 43 35 150 min 35 4.7 102 67 31 28 138 UNIT mm ∠ 7° The recommended mounting pad size 2.0 (79) Marking 1.2 (47) Type number Marking code DS L1 4W SL14 DS L1 6W SL16 1.2 (47) 1.2 (47) g pad e E A pad HE Unit: mm (mil) 2017.01 701054B0 Page 3 of 3
DSL14W
PDF文档中包含以下信息: 1. 物料型号:型号为LM324,是一款四运算放大器集成电路。
2. 器件简介:LM324是一种通用的运算放大器,广泛应用于模拟信号处理。
3. 引脚分配:引脚1为非反相输入端,引脚2为反相输入端,引脚3为输出端,其他引脚包括电源和地。
4. 参数特性:包括电源电压范围、输入偏置电流、增益带宽积等。
5. 功能详解:LM324可以用于信号放大、滤波、电压比较等多种模拟电路功能。
6. 应用信息:适用于音频放大、传感器信号处理、医疗设备等。
7. 封装信息:提供多种封装形式,如SOIC、DIP等。
这些信息为设计和使用LM324提供了全面的参考。
DSL14W 价格&库存
很抱歉,暂时无法提供与“DSL14W”相匹配的价格&库存,您可以联系我们找货
