DS32W THRU DS320W SOD123FL
Surface Mount Schottky Barrier Rectifier
Pinning
Reverse Voltage - 20 to 200 V
1.Cathode
Forward Current – 3.0 A
2.Anode
1
FEATURES
Metal silicon junction, majority carrier conduction
For surface mounted applications
Low power loss, high efficiency
2
SOD123FL
High forward surge current capability
Marking Code
For use in low voltage, high frequency inverters,
free wheeling, and polarity protection applications
DS32W
K32
S32
DS34W
K34
S34
Lead free in comply with EU RoHS 2011/65/EU directives
DS36W
K36
S36
MECHANICAL DATA
Case: SOD-123FL
Terminals: Solderable per MIL-STD-750, Method 2026
DS38W
K38
S38
DS310W
K310
S310
DS312W
K312
S312
DS315W
K315
S315
DS320W
K320
S320
Approx. Weight: 15mg / 0.00048oz
Absolute Maximum Ratings and Electrical characteristics
Ratings at 25 ° ambient temperature unless otherwise specified.Single phase, half wave, 60Hz resistive or inductive load,
for capacitive load, derate by 20 %
Parameter
Symbols
DS32W
DS34W
DS36W
DS38W
DS310W
DS312W
DS315W
DS320W
Units
Maximum Repetitive Peak Reverse Voltage
VRRM
60
80
100
120
150
200
V
Maximum RMS voltage
VRMS
14
28
42
56
70
84
105
140
V
Maximum DC Blocking Voltage
VDC
60
80
100
120
150
200
V
Maximum Average Forward Rectified Current
IF(AV)
Peak Forward Surge Current, 8.3ms Single Half Sinewave Superimposed On Rated Load (JEDEC method)
3.0
IFSM
A
80
70
A
Maximum Instantaneous Forward Voltage at 3 A
VF
0.55
Maximum Instantaneous Reverse Current TA = 25°C
at Rated DC Reverse Voltage
TA = 100°C
IR
0.5
10
0.3
5
mA
Typical Junction Capacitance(1)
Cj
250
160
pF
Typical Thermal Resistance
(2)
Operating Junction Temperature Range
Storage Temperature Range
0.70
0.85
0.95
V
RθJA
80
°C/W
Tj
-55 ~ +150
°C
Tstg
-55 ~ +150
°C
(1)Measured at 1 MHz and applied reverse voltage of 4 V D.C
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
www.yfwdiode.com
1/3
Dongguan YFW Electronics Co, Ltd.
Fig.2 Typical Reverse Characteristics
Instaneous Reverse Current ( μA)
Fig.1 Forward Current Derating Curve
Average Forward Current (A)
3.5
3.0
2.5
2.0
1.5
1.0
0.5
Single phase half-wave 60 Hz
0.0
25
50
75
100
125
150
10 4
10 3
T J =100°C
10 2
T J =75°C
DS32W/DS34W
DS36W-DS320W
10 1
T J =25°C
10 0
Case Temperature (°C)
60
80
100
Fig.4 Typical Junction Capacitance
500
T J =25°C
Junction Capacitance ( pF)
1.0
DS32W/DS34W
DS36W/DS38W
DS310W/DS312W
DS315W/DS320W
0.1
0.2
0.6
0.8
1.0
1.2
1.4
1.6
200
100
50
DS32W/DS34W
DS36W-DS320W
10
1.8
10
1
0.1
100
Instaneous Forward Voltage (V)
Reverse Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
Fig.6- Typical Transient Thermal Impedance
Transient Thermal Impedance( °C /W)
Instaneous Forward Current (A)
Fig.3 Typical Forward Characteristic
Peak Forward Surage Current (A)
40
Percent of Rated Peak Reverse Voltage(%)
100
DS32W~DS38W
DS310W~DS312W
80
60
40
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
100
Number of Cycles at 60Hz
www.yfwdiode.com
200
100
10
1
0.01
0.1
1
10
100
t, Pulse Duration(sec)
2/3
SOD-123FL
Package Outline
Plastic surface mounted package; 2 leads
∠ALL ROUND
C
A
∠ALL ROUND
VM
D
E
A
g
g
pad
e
E
A
pad
HE
Top View
A
C
D
E
e
g
HE
max
1.3
0.20
2.9
1.9
1.1
0.9
3.8
min
0.9
0.12
2.6
1.7
0.8
0.7
3.5
max
43
7.9
114
75
43
35
150
min
35
4.7
102
67
31
28
138
UNIT
mm
mil
Bottom View
7°
The recommended mounting pad size
1.2
(47)
2.0
(79)
1.2
(47)
1.2
(47)
Unit: mm
(mil)
Summary of Packing Options
Package
SOD-123FL
www.yfwdiode.com
Packing Description
Packing Quantity
Industry Standard
Tape/Reel,13”reel
10000
EIA-481-1
Tape/Reel,7”reel
3000
EIA-481-1
3/3
很抱歉,暂时无法提供与“DS310W”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.39906
- 100+0.33426
- 300+0.30186
- 3000+0.23868
- 6000+0.21924
- 9000+0.20942
- 国内价格
- 10+0.31546
- 100+0.25906
- 600+0.23086
- 1200+0.22740
- 3000+0.17587
