ES07A THRU ES07J
ES07A THRU ES07J
1.0 AMP. SURFACE MOUNT GENERAL PURPOSE SUPER FAST RECTIFIERS
SOD-123FL
FEATURES
·Glass passivated device
·Ideal for surface mouted applications
·Low reverse leakage
·Metallurgically bonded construction
·Superfast recovery time for high efficiency
·High temperature soldering guaranteed:
250℃/10 seconds at terminals.
.031(0.8)
.047(1.2)
.067(1.7)
.075(1.9)
.106(2.7)
.114(2.9)
.138(3.5)
.154(3.9)
MECHANICAL DATA
·Case: JEDEC SOD-123FL,molded plastic
over passivated chip
·Terminals:Solder Plated, solderable per
MIL-STD-750, Method 2026
·Polarity: Color band denotes cathode end
·Weight: 0.006 ounces, 0.02 gram
·Mounting position: Any
.047(1.2)
.055(1.4)
.006(0.15)
.010(0.25)
.020(0.5)
.031(0.8)
Dimensions in millimeters
MAXIMUM RATINGS AND ELECTRONICAL CHARACTERISTICS
Ratings at 25℃ ambient temperature unless otherwise specified.
Single phase, half wave, 60Hz,resistive or inductive load. For capacitive load, derate current by 20%.
SYM
BOL
marking
Type Number
Maximum Recurrent Peak Reverse Voltage
Maximum RMS Voltage
Maximum DC Blocking Voltage
Maximum Average Forward rectified Current
VRRM
VRMS
VDC
IF(AV)
ES07A
ES07B
ES07D
ES07G
ES07J
EA
EB
ED
EG
EJ
50
100
200
400
600
V
35
70
140
280
420
V
50
100
200
400
600
V
units
1.0
A
25
A
Peak Forward Surge Current 8.3ms single half
sine-wave superimposed on rate load (JEDEC
IFSM
method)
Maximum Instantaneous forward Voltage at
1.0 A DC
Maximum DC Reverse Current
at rated DC blocking voltage
@TJ =25°C
@TJ =125°C
Maximum Reverse Recovery Time (Note 2)
Typical Junction Capacitance (Note 3)
Typical thermal resistance (Note 4)
Storage Temperature Range
Operation Temperature Range
VF
0.95
1.3
1.7
5.0
IR
µA
100.0
trr
CJ
R(JA)
TSTG
TJ
35
Note: 1.Test Conditions: IF=0.5A, IR=1.0A, IRR=0.25A
2. Measured at 1MHz and applied reverse voltage of 4.0 volts d.c.
3. Measured on P.C.Board with 0.2×0.2”(5.0×5.0mm)Copper Pad Areas
1
nS
10
V
pF
180
°C /W
-55 to +150
°C
-55 to +150
°C
ES07A THRU ES07J
RATING AND CHARACTERISTIC CURVES (ES07A THRU ES07J)
0V
40
0V
60
TJ=25℃
Pulse Width=300μs
1% Duty Cycle
LEAD TEMPERTURE,(℃)
INSTANEOUS FORWARD VOLTAGE,(V)
FIG.3-MAXIMUN NON-REPETITIVE
FORWARD SURGE CURRENT
FIG.4-TYPICAL REVERSE
CHARACTERISTICS
INSTANEOUS REVERSE
CURRENT,(μA)
PEAK FORWARD SURGE
CURRENT,(A)
Single Phase Half
Wave 60Hz
Resistive or
inductive Load
50
V20
0V
FIG.2-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
INSTANEOUS FORWARD
CURRENT,(A)
AVERGE FORWARD
RECTIFIED CURRENT,(A)
FIG.1-TYPICAL FORWARD CURRENT
DERATING CURVE
8.3ms Single Half
Sine-Wave (JEDEC
Method)
TJ=125℃
TJ=100℃
TJ=25℃
1
PERCENT OF RATED PEAK REVERSE
VOLTAGE,(%)
NUMBER OF CYCLES AT 60Hz
FIG.5-TEST CIRCUIT DIAGRAM AND REVERSE
RECOVERY TIME CHARACTERSITIC
50 Ω
NONINDUCTIVE
10 Ω
NONINDUCTIVE
25Vdc
(approx)
PULSE
GENERATOR
(NOTE 2)
1Ω
(NOTE 1)
NON- OSCILOSCOPE
INDUCTIVE
NOTES:1. Rise Time=7ns max, Input
Impedance= 1 megohm.22pF.
2. Rise Time=10ns max,
Souce Impedance= 50 ohms.
2
ES07A THRU ES07J
Marking and packaging illustration
1、Marking
SYMBOL
EX
A
B
B
A
Explanation
Color Band Denotes Cathode
Product Name
2、Packaging
d
Top cover tape thickness
0.10mm(0.004") max.thick
W1
Embossed
carrier tape
°MAX
A
°MAX
Embossed cavity
SPECIFICATIONS
mm(inch)
SYMBOL
PACKAGE
SOD-123FL
ITEM
Carrier width
A
2.1(0.083)Max
Carrier length
B
4.0(0.157)Max
Sprocket hole
d
ø1.55(0.061)Typ
Reel outer diameter
D
177.8(7)Typ
Reel inner diameter
D1
50.0(1.969)Min
Feed hole diameter
D2
13.0(0.512)Typ
Sprocket hole position
J
1.75(0.069)Typ
Punch hole position
H
3.50(0.138)Typ
Carrier depth
K
1.60(0.063)Typ
Punch hole pitch
P
4.00(0.157)Typ
Sprocket hole pitch
P0
4.00(0.157)Typ
Embossment center
P1
2.00(0.079)Typ
Overall tape thickness
T
0.25(0.098)Typ
Tape width
W
8.15(0.321)Typ
Reel width
W1
10.5(0.413)Min
3
很抱歉,暂时无法提供与“EJ-ES07J”相匹配的价格&库存,您可以联系我们找货
