RB-RS07B
RB-RS07B
    PINGWEI(平伟)
    SMF(SOD-123FL)
    RB-RS07B
RB-RS07B 数据手册
RS07A THRU RS07M RS07A THRU RS07M 1.0 AMP. SURFACE MOUNT GENERAL PURPOSE FAST RECOVERY RECTIFIERS SOD-123FL FEATURES ·Glass passivated device ·Ideal for surface mouthed applications ·Low reverse leakage ·Metallurgically bonded construction ·High temperature soldering guaranteed: 250°C /10 seconds at terminals. .031(0.8) .047(1.2) .067(1.7) .075(1.9) .106(2.7) .114(2.9) .138(3.5) .154(3.9) MECHANICAL DATA ·Case: JEDEC SOD-123FL,molded plastic over passivated chip ·Terminals:Solder Plated, solderable per MIL-STD-750, Method 2026 ·Polarity: Color band denotes cathode end ·Weight: 0.006 ounces, 0.02 gram ·Mounting position: Any .047(1.2) .055(1.4) .006(0.15) .010(0.25) .020(0.5) .031(0.8) Dimensions in millimeters MAXIMUM RATINGS AND ELECTRONICAL CHARACTERISTICS Ratings at 25°C ambient temperature unless otherwise specified. Single phase, half wave, 60Hz,resistive or inductive load. For capacitive load, derate current by 20%. SYMBOL RS07A RS07B RS07D RS07G RS07J RS07K RS07M Type Number units marking RA RB RD RG RJ RK RM Maximum Recurrent Peak Reverse Voltage VRRM 50 100 200 400 600 800 1000 V Maximum RMS Voltage VRMS 35 70 140 280 420 560 700 V Maximum DC Blocking Voltage VDC 50 100 200 400 600 800 1000 V Maximum Average Forward rectified IF(AV) 1.0 A IFSM 30 A VF 1.3 V Peak Forward Surge Current 8.3ms single half sine-wave superimposed on rate load (JEDEC method) Maximum Instantaneous forward Voltage at 1.0 A DC 5.0 Maximum DC Reverse Current @TJ =25°C at rated DC blocking voltage @TJ =125°C IR Maximum Reverse Recovery Time (Note 2) trr Typical Junction Capacitance (Note 3) CJ 10 pF Typical thermal resistance (Note 4) R(JA) 180 °C /W Storage Temperature Range TSTG -55 to +150 °C TJ -55 to +150 °C Operation Temperature Range µA 100.0 150 Note: 1. Averaged over any 20 ms period. 2.Test Conditions: IF=0.5A, IR=1.0A, IRR=0.25A 3. Measured at 1MHz and applied reverse voltage of 4.0 volts d.c. 4. Measured on P.C.Board with 0.2×0.2”(5.0×5.0mm)Copper Pad Areas 1 250 500 nS RS07A THRU RS07M RATING AND CHARACTERISTIC CURVES (RS07A THRU RS07M) FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE FIG.2-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS INSTANEOUS FORWARD CURRENT,(A) AVERGE FORWARD RECTIFIED CURRENT,(A) 10 1.0 0.5 Single Phase Half Wave 60Hz Resistive or inductive Load 1.0 0.1 .01 5 0.8 1.1 1.7 INSTANEOUS FORWARD VOLTAGE,(V) FIG.3-MAXIMUN NON-REPETITIVE FORWARD SURGE CURRENT FIG.4-TYPICAL REVERSE CHARACTERISTICS 40 8.3ms Single Half Sine-Wave (JEDEC Method) 30 1.4 LEAD TEMPERTURE,(℃) INSTANEOUS REVERSE CURRENT,(μA) PEAK FORWARD SURGE CURRENT,(A) TJ=25℃ Pulse Width=300μs 1% Duty Cycle 20 10 TJ=125℃ TJ=100℃ TJ=25℃ 1 PERCENT OF RATED PEAK REVERSE VOLTAGE,(%) NUMBER OF CYCLES AT 60Hz FIG.5-TEST CIRCUIT DIAGRAM AND REVERSE RECOVERY TIME CHARACTERSITIC 50 Ω NONINDUCTIVE (+) 25Vdc (approx) (-) 10 Ω NONINDUCTIVE (-) PULSE GENERATOR (NOTE 2) 1Ω (NOTE 1) NON- OSCILOSCOPE INDUCTIVE NOTES:1. Rise Time=7ns max, Input Impedance= 1 megohm.22pF. 2. Rise Time=10ns max, Souce Impedance= 50 ohms. 2 (+) RS07A THRU RS07M Marking and packaging illustration 1、Marking RX SYMBOL A B B A Explanation Color Band Denotes Cathode Product Name 2、Packaging SPECIFICATIONS Carrier width SYM BOL A 2.1(0.083)Max SPECIFICATIONS mm(inch) SYM ITEM BOL K Carrier depth Carrier length B 4.0(0.157)Max Punch hole pitch P 4.00(0.157)Typ Sprocket hole d ø1.55(0.061)Typ Sprocket hole pitch P0 4.00(0.157)Typ Reel outer diameter D 177.8(7)Typ Embossment center P1 2.00(0.079)Typ Reel inner diameter D1 50.0(1.969)Min Overall tape thickness T 0.25(0.098)Typ Feed hole diameter D2 13.0(0.512)Typ Tape width W 8.15(0.321)Typ Sprocket hole position J 1.75(0.069)Typ Reel width W1 10.5(0.413)Min Punch hole position H 3.50(0.138)Typ PACKAGE mm(inch) ITEM SOD-123FL 3 PACKAGE SOD-123FL 1.60(0.063)Typ
RB-RS07B 价格&库存
很抱歉,暂时无法提供与“RB-RS07B”相匹配的价格&库存,您可以联系我们找货
