SOD1H8 U8
SOD1H8 U8
    MDD(辰达半导体)
    SMF(SOD-123FL)
    二极管配置:-;直流反向耐压(Vr):1kV;平均整流电流(Io):1A;正向压降(Vf):1.7V@1A;反向恢复时间(trr):75ns;
SOD1H8 U8 数据手册
SOD1H1 THRU SOD1H8 Reverse Voltage - 50 to 1000 Volts Forward Current - 1.0 Ampere SURFACE MOUNT HIGH EFFICIENCY RECTIFIER Features     SOD-123FL Glass passivated device Ideal for surface mouted applications 0.075(1.90) 0.067(1.70) 0.031 (0.80) 0.043 (1.10) Low reverse leakage Metallurgically bonded construction  High temperature soldering guaranteed: 0.114(2.90) 0.102(2.60) 250°C/10 seconds,0.375”(9.5mm) lead length, 5 lbs. (2.3kg) tension 0.043(1.10) 0.035(0.90) 0.008(0.20) 0.005(0.12) 0.035(0.90) 0.028(0.70) Mechanical Data 0.154(3.90) 0.141(3.60) Case : JEDEC SOD-123FL Molded plastic body Terminals : Solder plated, solderable per MIL-STD-750,Method 2026 Polarity : Polarity symbol marking on body Mounting Position : Any Weight : 0.0007 ounce, 0.02 grams Dimensions in inches and (millimeters) Maximum Ratings And Electrical Characteristics Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. Parameter SOD1H1 SOD1H2 SOD1H3 SOD1H4 SOD1H5 SOD1H6 SOD1H7 SOD1H8 UNITS SYMBOLS Marking Code U1 U2 U3 U4 U5 U6 U7 U8 Maximum repetitive peak reverse voltage VRRM 50 100 200 300 400 600 800 1000 V Maximum RMS voltage VRMS 35 70 140 210 280 420 560 700 V Maximum DC blocking voltage VDC 50 100 200 300 400 600 800 1000 V Maximum average forward rectified current at TL=65℃ I(AV) 1.0 A Peak forward surge current 8.3ms single half sine-wave superimposed onrated load (JEDEC Method) IFSM 25 A Maximum instantaneous forward voltage at 1.0A VF Maximum DC reverse current at rated DCblocking voltage IR Maximum reverse recovery time TA=25℃ TA=125℃ (NOTE 1) Typical junction capacitance (NOTE 2) Typical thermal resistance Operating junction and storage temperature range trr 1.0 1.30 1.70 5.0 100.0 50 V μA 75 ns CJ 15.0 pF RJA 85 ℃/W TJ,TSTG -55to+150 ℃ Rev:2022A1 Page :1 Note: 1.Measured with IF=0.5A, IR=1A, Irr=0.25A. DN:T22507A1 http://www.microdiode.com SOD1H1 THRU SOD1H8 Reverse Voltage - 50 to 1000 Volts Forward Current - 1.0 Ampere AVERAGE FORWARD RECTIFIED CURRENT, AMPERES Ratings And Characteristic Curves FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD SURGE CURRENT PEAK FORWARD SURGE CURRENT, AMPERES FIG. 1- FORWARD CURRENT DERATING CURVE 1.0 0.8 0.6 Single Phase Half Wave 60Hz Resistive or inductive Load 0.4 0.2 0 0 25 50 75 100 125 150 30 8.3ms SINGLE HALF SINE-WAVE (JEDEC Method) 25 20 15 10 5.0 0 1 175 10 100 NUMBER OF CYCLES AT 60 Hz AMBIENT TEMPERATURE, C 20 10 TJ=25 C PULSE WIDTH=300 µs 1%DUTY CYCLE 1 0.1 SOD1H1-SOD1H4 SOD1H5 SOD1H6-SOD1H8 0.01 0.2 0.6 1.0 1.4 1.8 2.0 FIG. 4-TYPICAL REVERSE CHARACTERISTICS INSTANTANEOUS REVERSE CURRENT, MICROAMPERES INSTANTANEOUS FORWARD CURRENT,AMPERES FIG. 3-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS 1,000 100 TJ=100 C 10 1 TJ=25 C 0.1 0.01 INSTANTANEOUS FORWARD VOLTAGE, VOLTS 0 20 40 60 80 100 PERCENT OF PEAK REVERSE VOLTAGE,% The curve above is for reference only. http://www.microdiode.com Rev:2022A1 Page :2 SOD1H1 THRU SOD1H8 Reverse Voltage - 50 to 1000 Volts Forward Current - 1.0 Ampere Packing information unit:mm P0 P1 Item d E A W P D2 D1 T C W1 D Tolerance SOD-123FL A B C d D D1 D2 E F P P0 P1 T W W1 0.1 0.1 0.1 0.05 2.0 min 0.5 0.1 0.1 0.1 0.1 0.1 0.1 0.3 1.0 2.1 4.0 1.60 1.55 178.00 50.0 13.00 1.75 3.50 4.00 4.00 2.00 Carrier width Carrier length Carrier depth Sprocket hole 7" Reel outside diameter 7" Reel inner diameter Feed hole diameter Sprocket hole position Punch hole position Punch hole pitch Sprocket hole pitch Embossment center Overall tape thickness Tape width Reel width F B Symbol 0.25 8.15 10.5 Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above. Reel packing PACKAGE REEL SIZE REEL (pcs) COMPONENT SPACING (m/m) BOX (pcs) INNER BOX (m/m) REEL DIA, (m/m) CARTON SIZE (m/m) CARTON (pcs) SOD-123FL 7" 3,000 4.0 45,000 210*208*203 178 430*430*235 180,000 APPROX. GROSS WEIGHT (kg) 9.0 Suggested Pad Layout http://www.microdiode.com Symbol Unit (mm) A 1.2 0.047 B 0.047 C 1.2 3.2 0.126 D 2 0.079 E 4.4 0.173 Unit (inch) Rev:2022A1 Page :3
SOD1H8 U8 价格&库存
很抱歉,暂时无法提供与“SOD1H8 U8”相匹配的价格&库存,您可以联系我们找货
