RS1GL
RS1GL
    SMCDIODESOLUTIONS(桑德斯)
    SMF(SOD-123FL)
    耐压:400V 电流:1A 反向恢复时间:150NS
RS1GL 数据手册
RS1AL THRU RS1ML Technical Data Data Sheet N1935, Rev. - RS1AL THRU RS1ML SINGLE PHASE 1.0AMP SURFACE MOUNT FAST RECOVERY RECTIFIER Features         SOD-123FL   Circuit Diagram Glass passivated device Ideal for surface mouted applications Low reverse leakage Metallurgically bonded construction High temperature soldering guaranteed: 260 C/10 seconds,0.375”(9.5mm) lead length, 5 lbs. (2.3kg) tension Plastic material-UL flammability 94V-0 This is a Halogen Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request Mechanical Data     Case: SOD-123FL, molded plastic Terminals: Plated leads, solderable per MIL-STD-750, Method 2026 Polarity: Color band dentes cathode end Mounting Position: Any Maximum Ratings and Electrical Characteristics @TA=25°C unless otherwise specified Type Number Symbol Marking Code Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage Maximum RMS Voltage RS1 AL R1AL RS1 BL RS1 DL RS1 GL RS1 JL RS1 KL RS1 ML R1BL R1DL R1GL R1JL R1KL R1ML VRRM VRWM VR 50 100 200 400 600 800 1000 VR(RMS) 35 70 140 280 420 560 700 Units V IO 1.0 A Peak Forward Surge Current 8.3ms Single half sine-wave superimposed on rated load (JEDEC Method) IFSM 30.0 A Forward Voltage VF 1.3 V IR 5.0 100 µA Typical junction capacitance (Note 1) CJ 15 pF Maximum Reverse Recovery Time (Note 2) Trr Average Rectified Output Current @TA =30°C @IF = 1.0A, TJ=25°C Maximum DC reverse current at rated DC blocking voltage TA = 25°C TA = 100°C Typical thermal resistance (Note 3) Operating junction and storage temperature range 150 250 500 ns RθJA 85 °C/W TJ,TSTG -55 to +150 °C Note: 1. Measured at 1.0 MHZ and applied reverse voltage of 4.0 VDC 2. Measured with IF=0.5A, IR=1.0A, Irr=0.25A, 3. Thermal resistance from junction to ambient at 0.375" (9.5mm)lead length,P.C.B. Mounted  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  RS1AL THRU RS1ML Technical Data Data Sheet N1935, Rev. - Ratings and Characteristics Curves  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  RS1AL THRU RS1ML Technical Data Data Sheet N1935, Rev. - Mechanical Dimensions SOD-123FL(Inches/Millimeters) Ordering Information Device RS1AL THRU RS1ML RS1ALTR THRU RS1MLTR Marking Diagram Package Shipping SOD-123FL 3000pcs / reel SOD-123FL 3000pcs / reel For information on tape and reel specifications, including part orientation and tape sizes, please refer to our tape and reel packaging specification. R1AL = Marking Code Carrier Tape Specification SOD-123FL SYMBOL A B C d E F P P0 P1 W Millimeters Min. Max. 1.95 3.85 1.35 1.50 1.65 3.40 3.90 3.90 1.90 7.90  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  2.15 4.05 1.55 1.60 1.85 3.60 4.10 4.10 2.10 8.30 RS1AL THRU RS1ML Technical Data Data Sheet N1935, Rev. DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC Diode Solutions sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC Diode Solutions be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC Diode Solution assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC Diode Solutions be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC Diode Solutions. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC Diode Solutions. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations..  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com 
RS1GL 价格&库存
很抱歉,暂时无法提供与“RS1GL”相匹配的价格&库存,您可以联系我们找货
