RS07B
RS07B
    PINGWEI(平伟)
    SMF(SOD-123FL)
    RS07B
RS07B 数据手册
RS07A THRU RS07M 1.0 AMP. SURFACE MOUNT GENERAL PURPOSE FAST RECOVERY RECTIFIERS SOD-123FL FEATURES ·Glass passivated device ·Ideal for surface mouted applications ·Low reverse leakage ·Metallurgically bonded construction ·High temperature soldering guaranteed: 250°C /10 seconds at terminals. MECHANICAL DATA ·Case: JEDEC SOD-123FL,molded plastic over passivated chip ·Terminals:Solder Plated, solderable per MIL-STD-750, Method 2026 ·Polarity: Color band denotes cathode end ·Weight: 0.006 ounces, 0.02 gram ·Mounting position: Any Dimensions in millimeters MAXIMUM RATINGS AND ELECTRONICAL CHARACTERISTICS Ratings at 25°C ambient temperature unless otherwise specified. Single phase, half wave, 60Hz,resistive or inductive load. For capacitive load, derate current by 20%. SYMBOL RS07A RS07B RS07D RS07G RS07J RS07K RS07M Type Number units marking RA RB RD RG RJ RK RM Maximum Recurrent Peak Reverse Voltage VRRM 50 100 200 400 600 800 1000 V Maximum RMS Voltage VRMS 35 70 140 280 420 560 700 V Maximum DC Blocking Voltage VDC 50 100 200 400 600 800 1000 V Maximum Average Forward rectified Current at TA =65°C (Note 1) IF(AV) 1.0 A IFSM 25 A VF 1.3 V Peak Forward Surge Current 8.3ms single half sine-wave superimposed on rate load (JEDEC method) Maximum Instantaneous forward Voltage at 1.0 A DC Maximum DC Reverse Current @TA =25°C at rated DC blocking voltage @TA =125°C 10 IR µA 50.0 Maximum Reverse Recovery Time (Note 2) trr Typical Junction Capacitance (Note 3) CJ 4 pF Typical thermal resistance (Note 4) R(JA) 180 °C /W Storage Temperature Range TSTG -55 to +150 °C TJ -55 to +150 °C Operation Temperature Range 150 Note: 1. Averaged over any 20 ms period. 2.Test Conditions: IF=0.5A, IR=1.0A, IRR=0.25A 3. Measured at 1MHz and applied reverse voltage of 4.0 volts d.c. 4. Measured on P.C.Board with 0.2×0.2”(5.0×5.0mm)Copper Pad Areas - 157 - 250 500 nS RATING AND CHARACTERISTIC CURVES (RS07A THRU RS07M) - 158 -
RS07B 价格&库存
很抱歉,暂时无法提供与“RS07B”相匹配的价格&库存,您可以联系我们找货
