DFR1J F1J
DFR1J F1J
    MDD(辰达半导体)
    SMF(SOD-123FL)
    二极管配置:-;直流反向耐压(Vr):600V;平均整流电流(Io):1A;正向压降(Vf):1.3V@1A;反向恢复时间(trr):250ns;
DFR1J F1J 数据手册
DFR1A THRU DFR1M Reverse Voltage - 50 to 1000 Volts Forward Current - 1.0 Ampere SURFACE MOUNT FAST RECOVERY RECTIFIER Features SOD-123FL  Glass passivated device  Ideal for surface mouted applications  Low reverse leakage  Metallurgically bonded construction 0.075(1.90) 0.067(1.70) 0.031 (0.80) 0.043 (1.10) 0.114(2.90) 0.102(2.60)  High temperature soldering guaranteed: 250°C/10 seconds,0.375”(9.5mm) lead length, 0.043(1.10) 0.035(0.90) 5 lbs. (2.3kg) tension 0.008(0.20) 0.005(0.12) 0.035(0.90) 0.028(0.70) Mechanical Data 0.154(3.90) 0.141(3.60) Case: JEDEC 6OD-123FL molded plastic body Terminals: Solderable per MIL-STD-750,Method 2026 Polarity: Polarity symbol marking on body Mounting Position: Any Weight : 0.007 ounce, 0.02 grams Dimensions in inches and (millimeters) Maximum Ratings And Electrical Characteristics Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. Parameter Marking Code Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage Maximum average forward rectified current at TL(see fig.1) DFR1A DFR1B SYMBOLS VRMS VDC DFR1G DFR1J DFR1K DFR1M UNITS MDD MDD MDD MDD MDD MDD 50 35 50 100 70 100 200 105 200 400 280 400 600 420 600 800 560 800 1000 700 1000 F05A VRRM DFR1D MDD F1B F1D F1G F1J F1K F1M V V V I(AV) 1.0 A Peak forward surge current 8.3ms single half sine-wave superimposed onrated load (JEDEC Method) IFSM 30 A Maximum instantaneous forward voltage at 1.0A VF V Maximum DC reverse current TA=25℃ at rated DCblocking voltage TA=125℃ IR 1.3 5 Typical junction capacitance (NOTE 1) CJ Maximum Reverse Recovery Time (NOTE 2) trr Operating junction temperature range TJ -55 to +150 ℃ TSTG -55 to +150 ℃ Storage temperature range μA 100 15 150 pF 250 500 ns Note: 1.Measured at 1MHz and applied reverse voltage of 4.0V D.C. 2.Measured with IF=0.3A, IR=1A, Irr=0.25A. 3.PCB mounted on 0.2*0.2" (5.0*5.0mm) coppeer pad area. DN:T21618A0 http://www.microdiode.com Rev:2021A1 Page :1 DFR1A THRU DFR1M Reverse Voltage - 50 to 1000 Volts Forward Current - 1.0 Ampere Typical Characterisitics Fig.2 Typical Reverse Characteristics Fig.1 Forward Current Derating Curve 1.2 100 TJ=125°C 0.8 0.6 0.4 0.2 Single phase half-wave 60 Hz resistive or inductive load 0.0 25 50 75 100 125 150 175 Instaneous Reverse Current( ) A μ Average Forward Current (A) 1.0 10 1.0 TJ=25°C 0.1 00 Case Temperature (°C) 40 60 80 100 120 140 percent of Rated Peak Reverse Voltage (%) Fig.3 Typical Instaneous Forward Characteristics TJ=25°C Fig.4 Typical Junction Capacitance 100 10 TJ=25°C Junction Capacitance (pF) Instaneous Forward Current (A) 20 1.0 0.1 pulse with 300μ s 1% duty cycle 0.01 10 1 0.0 0.5 1.0 1.5 2.0 2.5 0.1 1.0 10 100 Reverse Voltage (V) Instaneous Forward Voltage (V) Fig.5 Maximum Non-Repetitive Peak Forward Surage Current Peak Forward Surage Current (A) 35 30 25 20 15 10 05 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 10 100 Number of Cycles The curve above is for reference only. http://www.microdiode.com Rev:2021A1 Page :2 DFR1A THRU DFR1M Reverse Voltage - 50 to 1000 Volts Forward Current - 1.0 Ampere Packing information unit:mm P0 P1 d Item Symbol Tolerance SOD-123FL A B C d D D1 D2 E F P P0 P1 T W W1 0.1 0.1 0.1 0.05 2.0 min 0.5 0.1 0.1 0.1 0.1 0.1 0.1 0.3 1.0 2.1 4.0 1.60 1.55 178.00 50.0 13.00 1.75 3.50 4.00 4.00 2.00 E F B A Carrier width Carrier length Carrier depth Sprocket hole 7" Reel outside diameter 7" Reel inner diameter Feed hole diameter Sprocket hole position Punch hole position Punch hole pitch Sprocket hole pitch Embossment center Overall tape thickness Tape width Reel width W P D2 T D1 C W1 D 0.25 8.15 10.5 Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above. Reel packing PACKAGE REEL SIZE REEL (pcs) COMPONENT SPACING (m/m) BOX (pcs) INNER BOX (m/m) REEL DIA, (m/m) CARTON SIZE (m/m) CARTON (pcs) SOD-123FL 7" 3,000 4.0 45,000 210*208*203 178 430*430*235 180,000 APPROX. GROSS WEIGHT (kg) 9.0 Suggested Pad Layout http://www.microdiode.com Symbol Unit (mm) A 1.2 0.047 B 0.047 C 1.2 3.2 0.126 D 2 0.079 E 4.4 0.173 Unit (inch) Rev:2021A1 Page :3
DFR1J F1J 价格&库存
很抱歉,暂时无法提供与“DFR1J F1J”相匹配的价格&库存,您可以联系我们找货
