OR-6N139
OR-6N139
    ORIENT(奥伦德)
    DIP-8
    DC输入 隔离电压(RMS):5000V
OR-6N139 数据手册
Shenzhen Orient Components Co ., Ltd OR-6N138/6N139 ORIENT Photo coupler Product Data Sheet Part Number: OR-6N138/6N139 Customer: Date: SHENZHEN ORIENT COMPONENTS CO ., LTD Block A 3rd Floor No.4 Building,Tian’an Cyber Park,Huangge Rd,LongGang Dist,Shenzhen,GD TEL:0755-29681816 FAX:0755-29681200 www.orient-opto.com Copyright© 2019 Orient .All rights Reserved 1 V2 Shenzhen Orient Components Co ., Ltd OR-6N138/6N139 1. Features • High current transfer ratio – 2000%typical. • Low input current requirements – 0.5mA • High output current – 60mA • CTR guarantee – 0~70℃. • Instantaneous common mode rejection10KV/μsec • MSL Class Ⅰ 2. Instructions The 6N138/6N139 devices each consists of an infrared emitting diode, optically coupled to a high gain split Darlington photo detector. They provide extremely high current transfer ratio between input and output, with access to a base terminal to adjust the gain bandwidth.These devices are packaged in an 8-pin DIP package and available in wide-lead spacing and SMD options. 3. Application Range • Digital logic ground isolation • Low input current line receiver • Telephone ring detector • EIA-RS-232C line receiver • Current loop receiver • High common mode noise line receiver 4. Functional Diagram Copyright© 2019 Orient .All rights Reserved 2 V2 Shenzhen Orient Components Co ., Ltd OR-6N138/6N139 是 5. Absolute Maximum Ratings (Ta=25℃)*1 Parameter Input Symbol Rated Value Unit Average Forward Input Current IF 20 mA Reverse Input Voltage VR 5 V Power Dissipation PI 40 mV Enable Input Voltage VB VCC+0.5 V Enable Input current IE 5 mA Output Collector Current IO 50 mA Output Collector Voltage VO -0.5~7 V Output Supply Voltage OR-6N138 OR-6N139 -0.5~18 VCC OR-6N138 OR-6N139 V -0.5~18 Output Collector Power Dissipation *2 -0.5~7 PO 100 mW Insulation Voltage Viso 5000 Vrms Working Temperature Topr -40 ~+ 85 Storage Temperature Tstg -55~ + 125 Soldering Temperature Tsol 260 ℃ *1. Room temperature = 25 ℃. Exceeding the maximum absolute rating can permanently damage the device. Working long hours at the maximum absolute rating can affect reliability. *2. soldering time is 10 seconds. Copyright© 2019 Orient .All rights Reserved 3 V2 Shenzhen Orient Components Co ., Ltd OR-6N138/6N139 6. Recommended Operating Conditions Parameter Operating Temperature Supply Voltage Symbol Min Max Unit TA -40 110℃ ℃ VCC 2.7 3.6 V 4.5 5.5 Low Level Input Current IFL 0 250 μA High Level Input Current IFH 5 15 mA Low Level Enable Voltage VEL 0 0.8 V High Level Enable Voltage VEH 2 VCC V Output Pull-up Resistor RL 330 4k Ω Fan Out (at RL=1kΩ per N — 5 TTL Loads channel) Copyright© 2019 Orient .All rights Reserved 4 V2 Shenzhen Orient Components Co ., Ltd OR-6N138/6N139 7. Opto-electronic Characteristics Parameter Symbol Condition Min Typ Max Unit Input Forward voltage Temperature Coefficient OF VF IF= 1.6mA — 1.1 1.7 V ΔVF/ ΔT IF= 1.6mA — -1.9 — mV/℃ BV R IR = 10μA 5 — — V — 0.05 10 mA — 0.6 1.5 mA — 0.01 100 μA — — 250 — 0.1 0.4 — 0.1 Forward Voltage Reverse Voltage Output High Level Supply Current OR-6N138 Low Level Supply Current OR-6N138 High Level Output Current OR-6N138 ICCH OR-6N139 ICCL OR-6N139 IOH Vo= OPEN, VCC=18V,IF=0mA Vo= OPEN, VCC=18V,IF=1.6mA VCC=VO=18V, IF=0μA OR-6N139 IF=1.6mA;Vcc=4.5V OR-6N138 Io=4.8mA IF=0.5mA;Vcc=4.5V Logic low output voltage VOL Io=2mA IF=1.6mA;Vcc=4.5V Io=8mA OR-6N139 V 0.4 IF=5mA;Vcc=4.5V Io=15mA IF=12mA;Vcc=4.5V Io=24mA IF=1.6mA;Vcc=0.4V; OR-6N138 Current transfer ratio CTR Vcc=4.5V IF=0.5mA;Vo=0.4V; OR-6N139 Vcc=4.5V IF=1.6mA;Vcc=0.4V; Vcc=4.5V — 0.2 300 1600 2600 400 2000 5000 500 1600 2600 % Recommended temperature range (TA= -40℃—+85℃,4.5V≤VCC ≤5.5V),IF= 7.5mA Unless otherwise stated. Typical values,TA =25℃,VCC =5.0 V. Copyright© 2019 Orient .All rights Reserved 5 V2 Shenzhen Orient Components Co ., Ltd OR-6N138/6N139 8. Switching Characteristics Parameter Propagation Delay Time to Low Output Level Propagation Delay Time to High Output Level OR-6N138 Symbol tPHL OR-6N139 OR-6N138 tPLH OR-6N139 Logic High Common Mode Transient Immunity |CMH| Logic Low Common Mode Transient Immunity |CML| Condition Min Typ Max IF=1.6mA; RL=2.2KΩ - 1.6 10 IF=0.5mA; RL=4.7KΩ IF=12mA; RL=270Ω IF=1.6mA; RL=2.2KΩ IF=0.5mA; RL=4.7KΩ IF=12mA; RL=270Ω IF=0mA; |VCM|=10V RL=2.2KΩ IF=1.6mA; |VCM|=10V RL=2.2KΩ Unit μs - 5 25 - 0.1 1 - 10 35 μs - 18 60 - 2 7 1 10 - KV/µs 1 10 - KV/µs *All Typical at TA =25℃ Copyright© 2019 Orient .All rights Reserved 6 V2 Shenzhen Orient Components Co ., Ltd OR-6N138/6N139 9. Order Information Part Number Or OR-6N138X-W-Y-Z OR-6N139X-W-Y-Z Note X = Lead form option (S, M or none) W = Tape and reel option ( TA,TA1 or none). Y = ‘V’ code for VDE safety (This options is not necessary). Z = ‘G’ code for Halogen free (This options is not necessary). * VDE Code can be selected. * Halogen Free can be selected. Option Description Packing quantity None Standard SMD Option 45 units per tube M Wide lead bend (0.4 inch spacing) 45 units per tube TA Surface mount lead form (low profile) + TA tape & reel option 1000 units per reel TA1 Surface mount lead form (low profile) + TA1 tape & reel option 1000 units per reel Copyright© 2019 Orient .All rights Reserved 7 V2 Shenzhen Orient Components Co ., Ltd OR-6N138/6N139 10. Naming Rule NOTE: 1. ORIENT. 2. Part Number. 3. Year Code: '9' means '2019' and so on. 4. Week Code: 01 represents the first week, 02 represents the second week, and so on. 5. Day Code: ‘A to F’ means ‘Monday to Sunday’. 6. Anode. * Halogen Free Mark can be selected. * VDE Mark can be selected. Copyright© 2019 Orient .All rights Reserved 8 V2 Shenzhen Orient Components Co ., Ltd OR-6N138/6N139 11. Outer Dimension (1)OR-6N13X (2)OR-6N13XM Copyright© 2019 Orient .All rights Reserved 9 V2 Shenzhen Orient Components Co ., Ltd OR-6N138/6N139 (3)OR-6N13XS 12. Recommended Foot Print Patterns (Mount Pad) (unit:mm) Copyright© 2019 Orient .All rights Reserved 10 V2 Shenzhen Orient Components Co ., Ltd OR-6N138/6N139 13. Taping Dimensions (1)OR-6N13X-TA (2)OR-6N13X-TA1 type symbol Size: mm ( inches ) bandwidth W 16±0.3(0.63) pitch P0 4±0.1(0.15) F 7.5±0.1(0.295) P2 2±0.1(0.079) P1 12±0.1(0.472) pitch interval Encapsulation TA/TA1 type amount (pcs) Copyright© 2019 Orient .All rights Reserved 1000 11 V2 Shenzhen Orient Components Co ., Ltd OR-6N138/6N139 14. Package Dimension (1) package dimension DIP/M type SOP type (2)Packing Label Sample 1. MTL NO:Contents with "Order Information" in the specification. 2. LOT NO:The production cycle of the product. 3. BATCH:The CTR RANK of the product. 4. Quantity:Product packaging quantity. 5. Product Data: The data when product be made. Copyright© 2019 Orient .All rights Reserved 12 V2 Shenzhen Orient Components Co ., Ltd OR-6N138/6N139 15. Reliability Test Copyright© 2019 Orient .All rights Reserved 13 V2 Shenzhen Orient Components Co ., Ltd OR-6N138/6N139 16. Temperature Profile Of Soldering (1) IR Reflow soldering (JEDEC-STD-020C compliant) Note: one solder backflow is recommended under the conditions described below in the temperature and time profile. Do not weld more than three times. Profile item Conditions Preheat 150˚C - Temperature Min (T Smin ) 200˚C - Temperature Max (T Smax ) 90±30 sec - Time (min to max) (ts) Soldering zone - Temperature (TL ) 217˚C - Time (t L ) 60 sec Peak Temperature 260˚C Peak Temperature time 20 sec Ramp-up rate 3˚C / sec max. Ramp-down rate from peak temperature 3~6˚C / sec Reflow times ≤3 Copyright© 2019 Orient .All rights Reserved 14 V2 Shenzhen Orient Components Co ., Ltd OR-6N138/6N139 (2) Wave soldering (JEDEC22A111 compliant) One-time welding is recommended under the temperature condition. Temperature 260+0/-5˚C Time 10 sec Preheat temperature 5 to 140˚C 30 to 80 sec Preheat time (3) Hand soldering by soldering iron Single lead welding is allowed in each process and one-time welding is recommended. Copyright© 2019 Orient .All rights Reserved Temperature 380+0/-5˚C Time 3 sec max 15 V2 Shenzhen Orient Components Co ., Ltd OR-6N138/6N139 17. Switching time test circuit Figure 1: Single Channel Test Circuit for tPHL and tPLH Figure 2: Single Channel Test Circuit for Common Mode Transient Immunity Copyright© 2019 Orient .All rights Reserved 16 V2 Shenzhen Orient Components Co ., Ltd OR-6N138/6N139 18. Characteristics Curve Copyright© 2019 Orient .All rights Reserved 17 V2 Shenzhen Orient Components Co ., Ltd Copyright© 2019 Orient .All rights Reserved 18 OR-6N138/6N139 V2
OR-6N139 价格&库存
很抱歉,暂时无法提供与“OR-6N139”相匹配的价格&库存,您可以联系我们找货
