SL3120R
SL3120R
    SLKOR(萨科微)
    DIP-8
    DC输入 2通道
SL3120R 数据手册
SL3120R Series DC Input, 2.5A, Gate Driver Photo Coupler SCHEMATIC Description The SL3120R series combine an AlGaAs infrared 1 8 2 7 different lead forming options. 3 6 Features 4 5 emitting diode as the emitter which is optically coupled to an integrated circuit with a power output stage in a plastic DIP8 package with  High isolation 5000 VRMS  DC input with a high speed driver  Operating temperature range - 40 °C to PIN DEFINITION 1.NC 2.Anode 3.Cathode 4.NC 100 °C  REACH compliance  MSL class 1  Regulatory Approvals (Pending Approved)  UL - UL1577  VDE - EN60747-5-5(VDE0884-5)  CQC – GB4943.1, GB8898 Applications  Isolated IGBT/Power MOSFET gate drive  Industrial Inverter  AC brushless and DC motor drives  Induction Heating www.slkormicro.com 1 8.VCC 7.VO 6.VO 5.GND SL3120R Series ABSOLUTE MAXIMUM RATINGS PARAMETER SYMBOL VALUE UNIT Note INPUT Forward Current IF 25 mA Peak Forward Current IFP 50 mA 1 Peak Transient Current IF(trans) 1 A 2 Operating Frequency f 50 kHz Reverse Voltage VR 5 V Input Power Dissipation PI 100 mW OUTPUT Supply Voltage VCC 35 V Output Voltage VO 35 V Peak Output Current IO 2.5 A Output Power Dissipation PO 250 mW COMMON Total Power Dissipation Ptot 295 mW Isolation Voltage Viso 5000 Vrms Operating Temperature Topr -55~100 °C Storage Temperature Tstg -55~150 °C Soldering Temperature Tsol 260 °C 3 4 Note 1. 50% duty, 1ms P.W Note 2. ≤1μs P.W, 300pps Note 3. AC For 1 Minute, R.H. = 40 ~ 60% Note 4. For 10 seconds TRUTH TABLE LED VDD-VSS "Positive Going" (Turn-on) VDD-VSS "Negative Going" (Turn-off) VO Off 0V to 30V 0V to 30V Low On 0V to 11.5V 0V to 10V Low On 11.5V to 13.5V 10V to 12V Transition On 13.5V to 30V 12V to 30V High www.slkormicro.com 2 SL3120R Series RECOMMENDED OPERATION CONDITIONS PARAMETER SYMBOL MIN. MAX. UNIT Operating Temperature TA -40 100 °C Supply Voltage VCC 15 30 V Input Current (ON) IF(ON) 7 16 mA Input Voltage (OFF) VF(OFF) 0 0.8 V ELECTRICAL OPTICAL CHARACTERISTICS (VCC=30V, VEE=GND, TA=25°C unless specified otherwise) PARAMETER SYMBOL MIN. TYP. MAX. UNIT TEST CONDITION NOTE INPUT CHARACTERISTICS Forward Voltage VF - 1.38 1.8 V IF=10mA Reverse Current IR - - 10 μA VR=5V Input Capacitance Cin - 13 - pF V=0, f=1MHz OUTPUT CHARACTERISTICS High Level Supply Current ICCH - 1.75 3 mA IF= 7mA to 10mA, VO= Open Low Level Supply Current ICCL - 1.85 3 mA VF = 0 to 0.8V, VO= Open TRANSFER CHARACTERISTICS High Level Output Voltage VOH Low Level Output Voltage VOL High Level Output Current IOPH Low Level Output Current IOPL Input Threshold Current VCC-1.5 VCC-1.2 - - VEE+0.1 VEE+0.25 V IF= 10mA, IO= -100mA V IF= 0mA, IO= 100mA -1 - - A VO= VCC-3.5V -2.5 - - A VO= VCC-6.0V 1 - - A VO= VEE+1.5V 2.5 - - A VO= VEE+3.5V IFLH - 2 5 mA IO= 0mA, VO> 5V Input Threshold Voltage VFHL 0.8 - - V IO= 0mA, VO< 5V Under Voltage Lockout VUVLO+ 11 11.68 13.5 V IO= 10mA, VO> 5V Threshold VUVLO- 9.5 10.68 12 V IO= 10mA, VO< 5V Isolation Resistance Riso 10^12 10^14 - Ω DC500V, 40 ~ 60% R.H. Floating Capacitance CIO - 1.0 - pF V=0, f=1MHz www.slkormicro.com 3 3 SL3120R Series ELECTRICAL OPTICAL CHARACTERISTICS (VCC=30V, VEE=GND, TA=25°C unless specified otherwise) PARAMETER SYMBOL MIN. TYP. MAX. UNIT TEST CONDITION SWITCHING CHARACTERISTICS Propagation Delay Time TPHL 50 195 500 ns TPLH 50 255 500 ns Pulse Width Distortion |TPHL-TPLH| - 60 200 ns f= 10kHz, Duty = 50%, Propagation Delay Skew tPSK -200 - 200 ns TA= 25 °C Rise Time tr - 30 - ns Fall Time tf - 30 - ns UVLO Turn On Delay tUVLO(ON) - 1.6 - μs IF= 10mA, VO> 5V UVLO Turn Off Delay tUVLO(OFF) - 0.4 - μs IF= 10mA, VO< 5V to Output Low Level Propagation Delay Time to Output High Level Common Mode Transient Immunity at Logic High Common Mode Transient Immunity at Logic Low www.slkormicro.com IF= 7 to 16mA, CL= 10nF, RL= 10Ω, IF=7 to 16mA CMH -20 - - kV/μs VCC= 30V, TA= 25 oC, VCM= 2kV IF=0mA CML 20 - - kV/μs VCC= 30V, RL, TA= 25 oC, VCM= 2kV 4 NOTE SL3120R Series CHARACTERISTIC CURVES Fig.1 Forward Current vs. Forward Voltage Fig.2 Forward Voltage vs. Ambient Temperature Fig.3 Supply Current vs. Ambient Temperature Fig.4 Supply Current vs. Supply Voltage Fig.5 High Level Output Voltage vs. High Level Output Current Fig.6 Low Level Output Voltage vs. Low Level Output Current www.slkormicro.com 5 SL3120R Series CHARACTERISTIC CURVES Fig.7 High Level Output Voltage vs. Ambient Temperature Fig.8 Low Level Output Voltage vs. Ambient Temperature Fig.9 Output Voltage vs. Forward Current Fig.10 Output Voltage vs. Supply Voltage Fig.11 Forward Current vs. Ambient Temperature Fig.12 Propagation Delay vs. Supply Voltage www.slkormicro.com 6 SL3120R Series CHARACTERISTIC CURVES Fig.13 Propagation Delay vs. Forward Current Fig.14 Propagation Delay vs. Ambient Temperature Fig.15 Propagation Delay vs. Load Resistance Fig.16 Propagation Delay vs. Load Capacitance www.slkormicro.com 7 SL3120R Series TEST CIRCUITS Fig.17 Test Circuits for IOH Fig.18 Test Circuits for IOL www.slkormicro.com 8 SL3120R Series TEST CIRCUITS Fig.19 Test Circuits for TPHL, TPLH, tr, tf Fig.20 Waveforms of TPHL, TPLH, tr, tf www.slkormicro.com 9 SL3120R Series TEST CIRCUITS Fig.21 Test Circuits for Common Mode Transient Immunity Fig.22 Waveforms of Common Mode Transient Immunity www.slkormicro.com 10 SL3120R Series PACKAGE DIMENSIONS (Dimensions in mm unless otherwise stated) Standard DIP – Through Hole (DIP Type) Gullwing (400mil) Lead Forming – Through Hole (M Type) www.slkormicro.com 11 SL3120R Series PACKAGE DIMENSIONS (Dimensions in mm unless otherwise stated) Surface Mount Lead Forming (S Type) Surface Mount (Low Profile) Lead Forming (SL Type) www.slkormicro.com 12 SL3120R Series PACKAGE DIMENSIONS (Dimensions in mm unless otherwise stated) Surface Mount (Gullwing) Lead Forming (SLM Type) Recommended Solder Mask (Dimensions in mm unless otherwise stated) Surface Mount Lead Forming & Surface Mount (Low Profile) Lead Forming Surface Mount (Gullwing) Lead Forming www.slkormicro.com 13 SL3120R Series Carrier Tape Specifications (Dimensions in mm unless otherwise stated) Option S(T1) & SL(T1) Option S(T2) & SL(T2) www.slkormicro.com 14 SL3120R Series Carrier Tape Specifications (Dimensions in mm unless otherwise stated) Option SLM(T1) Option SLM(T2) www.slkormicro.com 15 SL3120R Series REFLOW INFORMATION REFLOW PROFILE Profile Feature Sn-Pb Assembly Profile Pb-Free Assembly Profile Temperature Min. (Tsmin) 100 150°C Temperature Max. (Tsmax) 150 200°C Time (ts) from (Tsmin to Tsmax) 60-120 seconds 60-120 seconds Ramp-up Rate (tL to tP) 3°C/second max. 3°C/second max. Liquidous Temperature (TL) 183°C 217°C Time (tL) Maintained Above (TL) 60 – 150 seconds 60 – 150 seconds Peak Body Package Temperature 235°C +0°C / -5°C 260°C +0°C / -5°C Time (tP) within 5°C of 260°C 20 seconds 30 seconds Ramp-down Rate (TP to TL) 6°C/second max 6°C/second max Time 25°C to Peak Temperature 6 minutes max. 8 minutes max. www.slkormicro.com 16
SL3120R 价格&库存
很抱歉,暂时无法提供与“SL3120R”相匹配的价格&库存,您可以联系我们找货
SL3120R
    • 50+3.75840
    • 100+3.69360
    • 150+3.62880
