MS80N03
MS80N03
    MSKSEMI(美森科)
    TO-252(DPAK)
    N沟道 MOSFET,电流:80A,耐压:30V
MS80N03 数据手册
www.msksemi.com MS80N03 Semiconductor Compiance Schematic diagram Features VDS = 30V,ID =80A RDS(ON),3.5mΩ(Typ) @ VGS =10V . RDS(ON), 7mΩ(Typ) @ VGS =4 5V Low on resistance Low gate charge Fast switching Low reverse transfer capacitances Application DC-DC converters TO-252 Synchronous Rectifier Absolute Maximum Ratings(TA=25℃ unless otherwise noted) Parameter Symbol Value Unit Drain-Source Voltage VDS 30 V Gate-Source Voltage VGS ±20 V 80 A 63 A Drain Current-ContinuousNote3 TC=25℃ TC=100℃ ID Drain Current-Pulsed IDM 200 A Avalanche Energy EAS 280 mJ Avalanche Current IAS 33 A PD 105 W TSTG -55 to +150 ℃ TJ -55 to +150 ℃ Note1 Note4 Maximum Power Dissipation TC=25℃ Storage Temperature Range Operating Junction Temperature Range Thermal Resistance Parameter Thermal Resistance,Junction-to-Case Symbol Min. Typ. Max Unit RθJC - 3.3 - ℃/W www.msksemi.com MS80N03 Semiconductor Compiance Electrical Characteristics(TJ=25℃ unless otherwise noted) OFF CHARACTERISTICS Parameter Symbol Conditions VGS=0V,IDS=250uA Min. Typ. Max. Unit 30 - - V Drain-Source Breakdown Voltage BVDSS Zero Gate Voltage Drain Current IDSS VDS=30V,VGS=0V - - 1 uA Gate-Body Leakage IGSS VGS=±20V,VDS=0V - - ±100 nA ON CHARACTERISTICS Parameter Symbol Conditions Min. Typ. Max. Unit Gate Threshold Voltage VGS(TH) VDS=VGS,IDS=250uA 1.0 1.7 2.5 V Drain-Source On-State Resistance RDS(ON) VGS=10V,IDS=30A - 3.5 5.5 VGS=4.5V,IDS=20A - 7 8.9 Conditions Min. Typ. Max. - 1963 - - 248 - - 221 - - 1.43 - Ω Min. Typ. Max. Unit - 55 - - 36.4 - - 37.5 - - 14 - - 41 - - 6.4 - - 11 - mΩ DYNAMIC CHARACTERISTICS Parameter Symbol Input Capacitance CiSS Output Capacitance COSS Reverse Transfer Capacitance C rss Gate Resisitance Rg VDS =15V, VGS = 0V, f=1MHz VDD=0V,VGS=1V, F=1MHz Unit pF SWITCHING CHARACTERISTICS Parameter Turn-On Delay Time Rise Time Symbol Td(on) tr Turn-Off Delay Time Fall Time Td(off) Conditions VGS=10V,VDs=15V, RGEN=3Ω ID=20A tf Total Gate Charge at 10V Qg Gate to Source Gate Charge Qgs Gate to Drain“Miller”Charge Qgd V DS=15V,IDS=45A, V GS=10V ns nC DRAIN-SOURCE DIODE CHARACTERISTICS AND MAXIMUM RATINGS Parameter Symbol Conditions Min. Typ. Max. Unit VSD VGS=0V,IDS=20A - - 1.2 V Reverse Recovery Time trr TJ=25℃,IF=20A - 21.7 - nS Reverse Recovery Charge Qrr di/dt=100A/us - 7.2 - nC Drain-Source Diode Forward Voltage Notes: 1: Repetitive rating, pulse width limited by maximum junction temperature. 2: Surface mounted on FR4 Board, t≤10sec. 3: Pulse width ≤ 300μs, duty cycle ≤ 2%. 4: EAS condition: L=0.5mH,VDD=15V,VG=10V,VGATE=30V,Start TJ=25℃. www.msksemi.com MS80N03 Semiconductor Compiance www.msksemi.com MS80N03 Semiconductor Compiance www.msksemi.com MS80N03 Semiconductor Compiance www.msksemi.com MS80N03 Semiconductor Compiance PACKAGE MECHANICAL DATA D A D1 c V L3 h A1 L4 L E φ L2 L1 D2 b e Symbol A A1 b c D D1 D2 E e L L1 L2 L3 L4 Φ θ h V Dimensions In Millimeters Min. Max. 2.200 2.400 0.000 0.127 0.635 0.770 0.460 0.580 6.500 6.700 5.100 5.460 4.830 REF. 6.000 6.200 2.186 2.386 9.712 10.312 2.900 REF. 1.400 1.700 1.600 REF. 0.600 1.000 1.100 1.300 0° 8° 0.000 0.300 5.250 REF. Dimensions In Inches Min. Max. 0.087 0.094 0.000 0.005 0.025 0.030 0.018 0.023 0.256 0.264 0.201 0.215 0.190 REF. 0.236 0.244 0.086 0.094 0.382 0.406 0.114 REF. 0.055 0.067 0.063 REF. 0.024 0.039 0.043 0.051 0° 8° 0.000 0.012 0.207 REF. REEL SPECIFICATION P/N PKG QTY MS80N03 TO-252 2500 www.msksemi.com MS80N03 Semiconductor Compiance Attention ■ Any and all MSKSEMI Semiconductor products described or contained herein do not have specifications that can handle applications that require extremely high levels of reliability, such as life-support systems, aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your MSKSEMI Semiconductor representative nearest you before using any MSKSEMI Semiconductor products described or contained herein in such applications. ■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products specificationsof any andall MSKSEMI Semiconductor products described orcontained herein. ■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the customer’sproducts orequipment. ■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all semiconductor products fail with someprobability. It is possiblethat these probabilistic failures could give rise to accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures include but are not limited to protective circuits anderror prevention circuitsfor safedesign, redundant design, and structural design. ■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described or contained herein are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the export license from theauthorities concerned in accordance with the above law. ■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of MSKSEMI Semiconductor. ■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume production. MSKSEMI Semiconductor believes information herein is accurate and reliable, but no guarantees are made or implied regarding its use or any infringementsof intellectual property rights or other rightsof third parties. ■ Any and all information described or contained herein are subject to change without notice due to product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the MSKSEMI Semiconductor productthat you intend to use. www.msksemi.com
MS80N03 价格&库存
很抱歉,暂时无法提供与“MS80N03”相匹配的价格&库存,您可以联系我们找货
