SMAJ78CA
SMAJ78CA
    YINT(音特电子)
    SMA(DO-214AC)
    双向TVS 78V截止 峰值脉冲电流:3.2A
SMAJ78CA 数据手册
Transient Voltage Suppression Diodes SMAJ Series 400W Trustworthy electronic circuit protection expert SMAJ Series General Information The SMA series is designed to protect voltage sensitive components from high voltage, high energy transients. They have excellent clamping capability, high surge capability, low zener impedance and fast response time. The SMA series is supplied in YINT Semiconductor’s exclusive, cost-effective, highly reliable and is ideally suited for use in communication systems, automotive, numerical controls, process controls, medical equipment, business machines, power supplies and many other Molded plastic industrial/consumer Applications. glass passivated junction. Features Applications ●Case: DO-214AC/SMA TVS ●For surface mounted applications in order to optimize board space. protection of I/O Interfaces, VCC bus ●Polarity: Color band denoted positive end (cathode) except Bidirectional. and other vulnerable circuits used in ●Typical failure mode is short from over-specified voltage or current Telecom, ●High Temperature soldering:260°C/10 seconds at terminals. Consumer electronic applications.  devices are ideal for Computer, Industrial the and Terminal: Solder plated, solderable per MIL-STD-750,Method 2026. Electrical Characteristics (@ TA = 25°C Unless Otherwise Noted) Parameter Symbol Minimum Peak Pulse Power Dissipation (T = 1 ms) (note 1 note 2) Value Unit PPK 400 Watts IFSM 40 Amps PM(AV) 3.3 Watts VF 3.5/6.5 Volts TJ -55 to +150 °C TSTG -55 to +150 °C Peak Forward Surge Current 8.3 ms Single Half Sine Wave Superimposed on Rated Load (JEDEC Method) (Note 3) Steady State Power Dissipation @ TL = 75 °C Maximum Instantaneous Forward Voltage @ I PP = 35 A (For Unidirectional Units Only)(note 4 note 5) Operating Temperature Range Storage Temperature Range 1. Non-repetitive current pulse, per Pulse Waveform graph and derated above TA = 25 °C per Pulse Derating Curve. 2. Thermal Resistance Junction to Lead. 3. 8.3 ms Single Half-Sine Wave duty cycle = 4 pulses maximum per minute (unidirectional units only). 4. Single Phase, Half Wave, 60 Hz, resistive or inductive load. For capacitive load, derate current by 20 %. 5.VF
