SMAJ48CA
SMAJ48CA
    SMCDIODESOLUTIONS(桑德斯)
    SMA(DO-214AC)
SMAJ48CA 数据手册
SMAJ SERIES Automotive qualified Technical Data Data Sheet N0223, Rev. C SMAJ5.0A THRU SMAJ300CA SURFACE MOUNT TRANSIENT VOLTAGE SUPPRESSOR Features            SMA Circuit Diagram Glass Passivated Die Construction 400W Peak Pulse Power Dissipation 5.0V- 300V Standoff Voltage Uni- and Bi-Directional Versions Available Excellent Clamping Capability Fast Response Time Plastic Case Material has UL Flammability Classification Rating 94V-O ROHS Compliant All SMC Parts are Traceable to the Wafer Lot Additional testing can be offered upon request “-A” suffix is for Automotive qualified Mechanical Data      Unipolar Case: SMA Low Profile Molded Plastic Terminals: Solder Plated , Solderable per MIL-STD 750, Method 2026 Polarity: Color band denotes cathode except Bipolar Mounting Position: Any Weight:0.064 grams(approx.) Bipolar Maximum Ratings and Thermal Characteristics@TA=25°C unless otherwise specified Parameter Peak Pulse Power Dissipation at TA=25°C by 10x1000μs Waveform (Fig.2)(Note 1, 2) Peak Forward Surge Current, 8.3ms Single Half Sine Wave ( Fig.7),(Note 3) Power Dissipation on Infinite Heat Sink at TA=50°C Operating Junction and Storage Temperature Range Typical Thermal Resistance Junction to Lead Typical Thermal Resistance Junction to Ambient Symbol Value Unit PPPM 400 W IFSM 40 A PM(AV) 3.3 W TJ,TSTG -55 to 150 °C RθJL 30 °C/W RθJA 120 °C/W Notes: 1. Non-repetitive current pulse, per Fig. 3 and derated above TA = 25°C per Fig. 2. 2. Mounted on 5.0mm² copper pads to each terminal. 3. Measured on 8.3ms single half sine wave or equivalent square wavefor unidirectional device only.  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  SMAJ SERIES Automotive qualified Technical Data Data Sheet N0223, Rev. C Electrical Characteristics@TA=25°C unless otherwise specified UNI-POLAR BI-POLAR SMAJ5.0A SMAJ6.0A SMAJ6.5A SMAJ7.0A SMAJ7.5A SMAJ8.0A SMAJ8.5A SMAJ9.0A SMAJ10A SMAJ11A SMAJ12A SMAJ13A SMAJ14A SMAJ15A SMAJ16A SMAJ17A SMAJ18A SMAJ20A SMAJ22A SMAJ24A SMAJ26A SMAJ28A SMAJ30A SMAJ33A SMAJ36A SMAJ40A SMAJ43A SMAJ45A SMAJ48A SMAJ51A SMAJ54A SMAJ58A SMAJ60A SMAJ64A SMAJ70A SMAJ75A SMAJ78A SMAJ85A SMAJ90A SMAJ100A SMAJ110A SMAJ120A SMAJ130A SMAJ150A SMAJ160A SMAJ170A SMAJ180A SMAJ220A SMAJ300A SMAJ5.0CA SMAJ6.0CA SMAJ6.5CA SMAJ7.0CA SMAJ7.5CA SMAJ8.0CA SMAJ8.5CA SMAJ9.0CA SMAJ10CA SMAJ11CA SMAJ12CA SMAJ13CA SMAJ14CA SMAJ15CA SMAJ16CA SMAJ17CA SMAJ18CA SMAJ20CA SMAJ22CA SMAJ24CA SMAJ26CA SMAJ28CA SMAJ30CA SMAJ33CA SMAJ36CA SMAJ40CA SMAJ43CA SMAJ45CA SMAJ48CA SMAJ51CA SMAJ54CA SMAJ58CA SMAJ60CA SMAJ64CA SMAJ70CA SMAJ75CA SMAJ78CA SMAJ85CA SMAJ90CA SMAJ100CA SMAJ110CA SMAJ120CA SMAJ130CA SMAJ150CA SMAJ160CA SMAJ170CA SMAJ180CA SMAJ220CA SMAJ300CA DEVICE MARKING CODE UNI BI HE HG HK HM HP HR HT HV HX HZ IE IG IK IM IP IR IT IV IX IZ JE JG JK JM JP JR JT JV JX JZ RE RG RK RM RP RR RT RV RX RZ SE SG SK SM SP SR ST SX TE TE TG TK TM TP TR TT TV TX TZ UE UG UK UM UP UR UT UV UX UZ VE VG VK VM VP VR VT VV VX VZ WE WG WK WM WP WR WT WV WX WZ XE XG XK XM XP XR XT XX UE REVERSE STANDOFF VOLTAGE VRWM (V) 5 6 6.5 7 7.5 8 8.5 9 10 11 12 13 14 15 16 17 18 20 22 24 26 28 30 33 36 40 43 45 48 51 54 58 60 64 70 75 78 85 90 100 110 120 130 150 160 170 180 220 300 BREAKDOWN VOLTAGE VBR (V) MIN. @IT BREAKDOWN VOLTAGE VBR (V) MAX. @IT TEST CURRE NT IT(MA) 6.4 6.67 7.22 7.78 8.33 8.89 9.44 10 11.1 12.2 13.3 14.4 15.6 16.7 17.8 18.9 20 22.2 24.4 26.7 28.9 31.1 33.3 36.7 40 44.4 47.8 50 53.3 56.7 60 64.4 66.7 71.1 77.8 83.3 86.7 94.4 100 111 122 133 144 167 178 189 201 246 335 7 7.37 7.98 8.6 9.21 9.83 10.4 11.1 12.3 13.5 14.7 15.9 17.2 18.5 19.7 20.9 22.1 24.5 26.9 29.5 31.9 34.4 36.8 40.6 44.2 49.1 52.8 55.3 58.9 62.7 66.3 71.2 73.7 78.6 86 92.1 95.8 104 111 123 135 147 159 185 197 209 222 272 371 10 10 10 10 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 MAXMUM CLAMPING VOLTAGE @IPP VC(V) 9.2 10.3 11.2 12 12.9 13.6 14.4 15.4 17 18.2 19.9 21.5 23.2 24.4 26 27.6 29.2 32.4 35.5 38.9 42.1 45.4 48.4 53.3 58.1 64.5 69.4 72.7 77.4 82.4 87.1 93.6 96.8 103 113 121 126 137 146 162 177 193 209 243 259 275 292 356 486  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  PEAK PULSE CURRE NT IPP(A) 43.5 38.8 35.7 33.3 31 29.4 27.8 26 23.5 22 20.1 18.6 17.2 16.4 15.4 14.5 13.7 12.3 11.3 10.3 9.5 8.8 8.3 7.5 6.9 6.2 5.8 5.5 5.2 4.9 4.6 4.3 4.1 3.9 3.5 3.3 3.2 2.9 2.7 2.5 2.3 2.1 1.9 1.6 1.5 1.5 1.4 1.1 0.8 REVERSE LEAKAGE @VRWM IR(uA) 800 800 500 200 100 50 20 10 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 SMAJ SERIES Technical Data Data Sheet N0223, Rev. C Automotive qualified For bidirectional type having VRWM of 10 volts and less, the IR limit is double. For parts without A (VBR is + 10% and VC is 5% higher than with A parts). Ratings and Characteristics Curves  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  SMAJ SERIES Automotive qualified Technical Data Data Sheet N0223, Rev. C Mechanical Dimensions SMA SYMBOL Ordering Information Device SMAJ5.0A THRU SMAJ300CA SMAJ5.0ATR THRU SMAJ300CATR Millimeters Inches Min. Max. Min. Max. A 2.40 2.84 0.094 0.112 B 3.99 4.75 0.157 0.187 C 1.05 1.70 0.041 0.067 D 0.15 0.51 0.006 0.020 E 4.80 5.28 0.189 0.208 F 2.00 2.44 0.078 0.098 G 0.05 0.203 0.002 0.008 H 0.76 1.52 0.030 0.600 Marking Diagram Where XXXXX is YYWWL Package Shipping SMA (Pb-Free) 5000pcs / reel HE/TE YY WW L SMA (Pb-Free) 5000pcs / reel Cautions:Molding resin Epoxy resin UL:94V-0 For information on tape and reel specifications, including part orientation and tape sizes, please refer to our tape and reel packaging specification.  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  = Marking code = Year = Week = Lot Number SMAJ SERIES Automotive qualified Technical Data Data Sheet N0223, Rev. C Carrier Tape Specification SMA SYMBOL A B C d E F P P0 P1 T W Min. Millimeters 2.97 5.70 2.32 1.40 1.40 5.60 3.90 3.90 1.90 0.25 11.80 Max. 3.17 5.90 2.52 1.60 1.60 5.70 4.10 4.10 2.10 0.35 12.20 DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC Diode Solutions sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC Diode Solutions be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC Diode Solution assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC Diode Solutions be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC Diode Solutions. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC Diode Solutions. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations..  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com 
