SMAJ200CA
SMAJ200CA
    CREATEKMICRO(达晶微)
    SMA(DO-214AC)
    双向TVS 200V截止 峰值浪涌电流:1.23A
SMAJ200CA 数据手册
SMAJ Series CREATEK Microelectronics Power TVS in DO-214AC/SMA Features ■ Glass passivated chip Bidirectional ■ 400W peak pulse power(10/1000us) 1 ■ High accuracy, 5% tolerance ■ Uni and Bidirectional unit 1 ■ Low clamping voltage ■ Low Leakage current 2 2 ■ Very fast response time Mechanical Data Unidirectional ■ Case: DO-214AC/SMA (plastic package). RoHS compliant ■ Molding Compound Flammability Rating: UL 94 V-0 ■ Terminals: High temperature soldering guaranteed: 260 °C/10 sec. at terminals 1 1 2 2 Applications ■ Computers ■ Telecom system ■ Industrial equipments ■ Consumer electronic applications ■ Other VCC bus and I/O interfaces Absolute Maximum Ratings Ratings at 25 °C, ambient temperature unless otherwise specified Parameter Peak pulse power dissipation with a 10/1000us waveform (1) Maximum peak reverse pulse current a 10/1000us waveform Peak forward surge current 8.3ms single half sine-wave (1) (2 ) Operating junction and storage temperature range Symbol Value Unit PPP 400 W I PP See Next Table A I FSM 40 A TJ, TSTG -55 to +150 ℃ Notes: 1.Non-repetitive current pulse,per Fi g.5 and detated above TA=25°C per Fig.1 2.Measured on 8.3ms single half sine-wave,or equivalent square wave,duty cycle=4 pulses per minute maximum Rev. 1.0, 23-May-2012 www.crea-tek.com 1 SMAJ Series CREATEK Microelectronics Electrical Characteristics (TA = 25 °C unless otherwise specified) Part Number Direction Maximum Working Voltage VRWM (V) Maximum Reverse Current@VRWM IR max(uA) VBR min(V) VBR max(V) IT(mA) Peak Surge Current IPP (A) Maximum Clamping Voltage@IPP VC (V) Breakdown Voltage@IT SMAJ5.0A Uni-Dir 5.0 800 6.4 7.07 10 43.48 9.2 SMAJ5.0CA Bi-Dir 5.0 1600 6.4 7.07 10 43.48 9.2 SMAJ6.0A Uni-Dir 6.0 800 6.67 7.37 10 38.83 10.3 SMAJ6.0CA Bi-Dir 6.0 1600 6.67 7.37 10 38.83 10.3 SMAJ6.5A Uni-Dir 6.5 500 7.22 7.98 10 35.71 11.2 SMAJ6.5CA Bi-Dir 6.5 1000 7.22 7.98 10 35.71 11.2 SMAJ7.0A Uni-Dir 7.0 200 7.78 8.60 10 33.33 12.0 SMAJ7.0CA Bi-Dir 7.0 400 7.78 8.60 10 33.33 12.0 SMAJ7.5A Uni-Dir 7.5 100 8.33 9.21 1 31.01 12.9 SMAJ7.5CA Bi-Dir 7.5 200 8.33 9.21 1 31.01 12.9 SMAJ8.0A Uni-Dir 8.0 50 8.89 9.83 1 29.41 13.6 SMAJ8.0CA Bi-Dir 8.0 100 8.89 9.83 1 29.41 13.6 SMAJ8.5A Uni-Dir 8.5 10 9.44 10.40 1 27.78 14.4 SMAJ8.5CA Bi-Dir 8.5 20 9.44 10.40 1 27.78 14.4 SMAJ9.0A Uni-Dir 9.0 5 10.00 11.10 1 25.97 15.4 SMAJ9.0CA Bi-Dir 9.0 10 10.00 11.10 1 25.97 15.4 SMAJ10A Uni-Dir 10.0 5 11.10 12.30 1 23.53 17.0 SMAJ10CA Bi-Dir 10.0 10 11.10 12.30 1 23.53 17.0 SMAJ11A Uni-Dir 11.0 1 12.20 13.50 1 21.98 18.2 SMAJ11CA Bi-Dir 11.0 1 12.20 13.50 1 21.98 18.2 SMAJ12A Uni-Dir 12.0 1 13.30 14.70 1 20.10 19.9 SMAJ12CA Bi-Dir 12.0 1 13.30 14.70 1 20.10 19.9 SMAJ13A Uni-Dir 13.0 1 14.40 15.90 1 18.60 21.5 SMAJ13CA Bi-Dir 13.0 1 14.40 15.90 1 18.60 21.5 SMAJ14A Uni-Dir 14.0 1 15.60 17.20 1 17.24 23.2 SMAJ14CA Bi-Dir 14.0 1 15.60 17.20 1 17.24 23.2 SMAJ15A Uni-Dir 15.0 1 16.70 18.50 1 16.39 24.4 SMAJ15CA Bi-Dir 15.0 1 16.70 18.50 1 16.39 24.4 SMAJ16A Uni-Dir 16.0 1 17.80 19.70 1 15.38 26.0 SMAJ16CA Bi-Dir 16.0 1 17.80 19.70 1 15.38 26.0 SMAJ17A Uni-Dir 17.0 1 18.90 20.90 1 14.49 27.6 SMAJ17CA Bi-Dir 17.0 1 18.90 20.90 1 14.49 27.6 SMAJ18A Uni-Dir 18.0 1 20.00 22.10 1 13.70 29.2 SMAJ18CA Bi-Dir 18.0 1 20.00 22.10 1 13.70 29.2 SMAJ19A Uni-Dir 19.0 1 21.10 23.30 1 13.00 30.8 SMAJ19CA Bi-Dir 19.0 1 21.10 23.30 1 13.00 30.8 SMAJ20A Uni-Dir 20.0 1 22.20 24.50 1 12.35 32.4 SMAJ20CA Bi-Dir 20.0 1 22.20 24.50 1 12.35 32.4 Rev. 1.0, 23-May-2012 www.crea-tek.com 2 SMAJ Series CREATEK Microelectronics Part Number SMAJ22A Direction Uni-Dir Maximum Working Voltage VRWM (V) Maximum Reverse Current@VRWM IR max(uA) VBR min(V) VBR max(V) 22.0 1 24.40 26.90 IT(mA) Peak Surge Current IPP (A) Maximum Clamping Voltage@IPP VC (V) 1 11.27 35.5 Breakdown Voltage@IT SMAJ22CA Bi-Dir 22.0 1 24.40 26.90 1 11.27 35.5 SMAJ24A Uni-Dir 24.0 1 26.70 29.50 1 10.28 38.9 SMAJ24CA Bi-Dir 24.0 1 26.70 29.50 1 10.28 38.9 SMAJ26A Uni-Dir 26.0 1 28.90 31.90 1 9.50 42.1 SMAJ26CA Bi-Dir 26.0 1 28.90 31.90 1 9.50 42.1 SMAJ28A Uni-Dir 28.0 1 31.10 34.40 1 8.81 45.4 SMAJ28CA Bi-Dir 28.0 1 31.10 34.40 1 8.81 45.4 SMAJ30A Uni-Dir 30.0 1 33.30 36.80 1 8.26 48.4 SMAJ30CA Bi-Dir 30.0 1 33.30 36.80 1 8.26 48.4 SMAJ33A Uni-Dir 33.0 1 36.70 40.60 1 7.50 53.3 SMAJ33CA Bi-Dir 33.0 1 36.70 40.60 1 7.50 53.3 SMAJ36A Uni-Dir 36.0 1 40.00 44.20 1 6.88 58.1 SMAJ36CA Bi-Dir 36.0 1 40.00 44.20 1 6.88 58.1 SMAJ40A Uni-Dir 40.0 1 44.40 49.10 1 6.20 64.5 SMAJ40CA Bi-Dir 40.0 1 44.40 49.10 1 6.20 64.5 SMAJ43A Uni-Dir 43.0 1 47.80 52.80 1 5.76 69.4 SMAJ43CA Bi-Dir 43.0 1 47.80 52.80 1 5.76 69.4 SMAJ45A Uni-Dir 45.0 1 50.00 55.30 1 5.50 72.7 SMAJ45CA Bi-Dir 45.0 1 50.00 55.30 1 5.50 72.7 SMAJ48A Uni-Dir 48.0 1 53.30 58.90 1 5.17 77.4 SMAJ48CA Bi-Dir 48.0 1 53.30 58.90 1 5.17 77.4 SMAJ51A Uni-Dir 51.0 1 56.70 62.70 1 4.85 82.4 SMAJ51CA Bi-Dir 51.0 1 56.70 62.70 1 4.85 82.4 SMAJ54A Uni-Dir 54.0 1 60.00 66.30 1 4.59 87.1 SMAJ54CA Bi-Dir 54.0 1 60.00 66.30 1 4.59 87.1 SMAJ58A Uni-Dir 58.0 1 64.40 71.20 1 4.27 93.6 SMAJ58CA Bi-Dir 58.0 1 64.40 71.20 1 4.27 93.6 SMAJ60A Uni-Dir 60.0 1 66.70 73.70 1 4.13 96.8 SMAJ60CA Bi-Dir 60.0 1 66.70 73.70 1 4.13 96.8 SMAJ64A Uni-Dir 64.0 1 71.10 78.60 1 3.88 103.0 SMAJ64CA Bi-Dir 64.0 1 71.10 78.60 1 3.88 103.0 SMAJ70A Uni-Dir 70.0 1 77.80 86.00 1 3.54 113.0 SMAJ70CA Bi-Dir 70.0 1 77.80 86.00 1 3.54 113.0 SMAJ75A Uni-Dir 75.0 1 83.30 92.10 1 3.31 121.0 SMAJ75CA Bi-Dir 75.0 1 83.30 92.10 1 3.31 121.0 SMAJ78A Uni-Dir 78.0 1 86.70 95.80 1 3.17 126.0 SMAJ78CA Bi-Dir 78.0 1 86.70 95.80 1 3.17 126.0 Rev. 1.0, 23-May-2012 www.crea-tek.com 3 SMAJ Series CREATEK Microelectronics Part Number SMAJ80A Direction Uni-Dir Maximum Working Voltage VRWM (V) Maximum Reverse Current@VRWM IR max(uA) VBR min(V) VBR max(V) 80.0 1 88.80 97.60 IT(mA) Peak Surge Current IPP (A) Maximum Clamping Voltage@IPP VC (V) 1 3.09 129.6 Breakdown Voltage@IT SMAJ80CA Bi-Dir 80.0 1 88.80 97.60 1 3.09 129.6 SMAJ85A Uni-Dir 85.0 1 94.40 104.00 1 2.92 137.0 SMAJ85CA Bi-Dir 85.0 1 94.40 104.00 1 2.92 137.0 SMAJ90A Uni-Dir 90.0 1 100.00 111.00 1 2.74 146.0 SMAJ90CA Bi-Dir 90.0 1 100.00 111.00 1 2.74 146.0 SMAJ100A Uni-Dir 100.0 1 111.00 123.00 1 2.47 162.0 SMAJ100CA Bi-Dir 100.0 1 111.00 123.00 1 2.47 162.0 SMAJ110A Uni-Dir 110.0 1 122.00 135.00 1 2.26 177.0 SMAJ110CA Bi-Dir 110.0 1 122.00 135.00 1 2.26 177.0 SMAJ120A Uni-Dir 120.0 1 133.00 147.00 1 2.07 193.0 SMAJ120CA Bi-Dir 120.0 1 133.00 147.00 1 2.07 193.0 SMAJ130A Uni-Dir 130.0 1 144.00 159.00 1 1.91 209.0 SMAJ130CA Bi-Dir 130.0 1 144.00 159.00 1 1.91 209.0 SMAJ140A Uni-Dir 140.0 1 155.00 171.00 1 1.76 226.8 SMAJ140CA Bi-Dir 140.0 1 155.00 171.00 1 1.76 226.8 SMAJ150A Uni-Dir 150.0 1 167.00 185.00 1 1.65 243.0 SMAJ150CA Bi-Dir 150.0 1 167.00 185.00 1 1.65 243.0 SMAJ160A Uni-Dir 160.0 1 178.00 197.00 1 1.54 259.0 SMAJ160CA Bi-Dir 160.0 1 178.00 197.00 1 1.54 259.0 SMAJ170A Uni-Dir 170.0 1 189.00 209.00 1 1.45 275.0 SMAJ170CA Bi-Dir 170.0 1 189.00 209.00 1 1.45 275.0 291.6 SMAJ180A Uni-Dir 180.0 1 200.00 220.00 1 1.37 SMAJ180CA Bi-Dir 180.0 1 200.00 220.00 1 1.37 291.6 SMAJ190A Uni-Dir 190.0 1 211.00 232.00 1 1.30 307.8 SMAJ190CA Bi-Dir 190.0 1 211.00 232.00 1 1.30 307.8 SMAJ200A Uni-Dir 200.0 1 224.00 247.00 1 1.23 324.0 SMAJ200CA Bi-Dir 200.0 1 224.00 247.00 1 1.23 324.0 SMAJ220A Uni-Dir 220.0 1 246.00 272.00 1 1.12 356.0 SMAJ220CA Bi-Dir 220.0 1 246.00 272.00 1 1.12 356.0 SMAJ250A Uni-Dir 250.0 1 279.00 309.00 1 0.99 405.0 SMAJ250CA Bi-Dir 250.0 1 279.00 309.00 1 0.99 405.0 SMAJ300A Uni-Dir 300.0 1 335.00 371.00 1 0.82 486.0 SMAJ300CA Bi-Dir 300.0 1 335.00 371.00 1 0.82 486.0 SMAJ350A Uni-Dir 350.0 1 391.00 432.00 1 0.71 567.0 SMAJ350CA Bi-Dir 350.0 1 391.00 432.00 1 0.71 567.0 SMAJ400A Uni-Dir 400.0 1 447.00 494.00 1 0.62 648.0 SMAJ400CA Bi-Dir 400.0 1 447.00 494.00 1 0.62 648.0 SMAJ440A Uni-Dir 440.0 1 492.00 543.00 1 0.56 713.0 SMAJ440CA Bi-Dir 440.0 1 492.00 543.00 1 0.56 713.0 Rev. 1.0, 23-May-2012 www.crea-tek.com 4 SMAJ Series CREATEK Microelectronics Typical Characteristics (Tamb = 25 °C unless otherwise specified) Fig. 1 - Pulse Derating Curve Fig. 3 - Steady State Power Derating Curve Fig. 5 - Pulse Waveform Rev. 1.0, 23-May-2012 Fig. 2 - Maximum Non-Repetitive Surge Current Fig. 4 - Peak Pulse Power Rating Curve Fig. 6 - Typical Junction Capacitance www.crea-tek.com 5 SMAJ Series CREATEK Microelectronics Package Dimensions C A Symbol A B C D E F G H B H D F E G Dimensions in millimeters Min Max 1.27 1.63 4.00 4.60 2.40 2.65 1.90 2.25 0.80 1.50 0.10 0.20 4.80 5.20 0.15 0.31 Ordering information Order code Package Packaging option Base quantity Packaging specification SMAJ Series DO-214AC/SMA Tape and reel 7500pcs / reel EIA STD RS-481 Revision history Date Revision 23-May-2012 1.0 Rev. 1.0, 23-May-2012 Changes Initial release www.crea-tek.com 6 SMAJ Series CREATEK Microelectronics CAUTION / WARNING Information in this document is believed to be accurate and reliable. However, CREATEK does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Users should independently evaluate the suitability of and test each product selected for their own applications, and CREATEK assumes no liability whatsoever relating to the choice, selection or use of the CREATEK products and services described herein. CREATEK reserves the right to change or update, without notice, any information contained in this publication; to change, without notice, the design, construction, processing, or specification of any product; and to discontinue or limit production or distribution of any product. Information in this document supersedes and replaces all information previously supplied. Products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an CREATEK product can reasonably be expected to result in personal injury, death or severe property or environmental damage. CREATEK accepts no liability for inclusion and/or use of CREATEK products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. Resale of CREATEK products with provisions different from the statements and/or technical features set forth in this document shall immediately void any warranty granted by CREATEK for the CREATEK product or service described herein and shall not create or extend in any manner whatsoever, any liability of CREATEK. CREATEK expressly disclaims all implied warranties regarding the information contained herein, including, but not limited to, any implied warranties of merchantability or fitness for a particular purpose. CREATEK only obligations are those in the CREATEK Standard Terms and Conditions of Sale and in no case will CREATEK be liable for any incidental, indirect, or consequential damages arising from the sale, resale, use, or misuse of its products. Specifications are subject to change without notice © Copyright 2009,CREATEK Microelectronics t ® is a registered trademark of CREATEK Microelectronics All rights reserved Rev. 1.0, 23-May-2012 www.crea-tek.com 7
SMAJ200CA 价格&库存
很抱歉,暂时无法提供与“SMAJ200CA”相匹配的价格&库存,您可以联系我们找货
