P4SMA12CA/TR13
P4SMA12CA/TR13
    YAGEO(国巨)
    SMA
    16.7V 夹子 24.6A Ipp TVS - 二极管 表面贴装型 DO-214AC(SMA)
P4SMA12CA/TR13 数据手册
DATA SHEET TRANSIENT VOLTAGE SUPPRESSORS AC/DC POWER SUPPLY P4SMA series Product specification– June 30, 2023 V.5 RoHS compliant & Halogen free Circuit Protection Product Specification Transient Voltage Suppressors 2 9 P4SMA Transient Voltage Suppressors (TVS) Data Sheet Features ■ For surface mounted applications in order to optimize board space ■ Low profile package ■ Glass passivated junction ■ Low inductance ■ Excellent clamping capability ■ 400W peak pulse power capability at 10/1000μs waveform, repetition rate (duty cycle): 0.01% ■ Fast response time ■ Typical IR less than 1μA above 10V ■ High Temperature soldering: 260℃/10 seconds at terminals ■ Plastic package has underwriters laboratory flammability 94V-0 ■ Meets MSL level 1, per J-STD-020 ■ Safety certification: UL ■ IEC61000-4-2 ESD 30KV Air, 30KV contact compliance Mechanical Data ■ Case: JEDEC DO-214AC. Molded plastic over glass passivated junction ■ Terminal: Tin plated, solderable per MIL-STD-750, Method 2026 ■ Polarity: Color band denotes cathode except bi-directional models ■ Standard Packaging: 12mm tape (EIA STD RS-481) ■ Weight: 0.07g Applications ■ I/O interface ■ AC/DC power supply ■ Low frequency signal transmission line (RS232, RS485, etc.) Maximum Ratings and Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. Rating Symbol Value Units Peak pulse power dissipation at 10/1000μs waveform (Note1, Note2, Fig.1) PPPM Minimum 400 Watts Peak pulse current of at 10/1000μs waveform (Note 1, Fig.3) IPPM See Table Amps PM(AV) 3.3 Watts IFSM 40 Amps TJ,TSTG -55 to +150 ℃ Typical thermal resistance junction to lead RθJL 30 ℃/W Typical thermal resistance junction to ambient RθJA 120 ℃/W Steady state power dissipation at TA=50℃ (Fig.5) Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load, (JEDEC Method) (Note3, Fig.6) Operating junction and Storage Temperature Range. Notes: 1. Non-repetitive current pulse, per Fig.3 and derated above T A=25℃ per Fig.2. 2. Mounted on 5.0mm×5.0mm (0.03mm thick) copper pads to each terminal. 3. 8.3ms single half sine-wave, or equivalent square wave, duty cycle=4 pulses per minutes maximum. www.ya geo.com Jun. 30, 2023 V.5 Circuit Protection Product Specification Transient Voltage Suppressors 3 9 P4SMA Dimensions (SMA/DO-214AC) Product: Millimeters Inches Symbol Cathode Band Min. Max. Min. Max. L 3.99 4.50 0.157 0.177 D 2.54 2.79 0.100 0.110 D1 1.25 1.65 0.049 0.065 T 4.93 5.28 0.194 0.208 T1 0.76 1.52 0.030 0.060 d - 0.203 - 0.008 H 2.00 2.50 0.079 0.098 H1 1.98 2.29 0.078 0.090 D1 D L H1 H d T1 T 1.68mm Pad: 1.75mm 1.88mm 1.75mm Electrical Characteristics (TA=25℃) Part Number Device Marking Code Reverse Stand-Off Voltage Breakdown Voltage @IT Test Current Maximum Clamping Voltage @IPP Peak Pulse Current Reverse Leakage @VRWM Unidirectional Bidirectional UNI BI VRWM(V) VBR(V) IT(mA) VC(V) IPP(A) IR(μA) P4SMA6.8A P4SMA6.8CA 6V8A 6V8C 5.80 6.45~7.14 10 10.5 39.0 1000 P4SMA7.5A P4SMA7.5CA 7V5A 7V5C 6.40 7.13~7.88 10 11.3 36.3 500 P4SMA8.2A P4SMA8.2CA 8V2A 8V2C 7.02 7.79~8.61 10 12.1 33.9 200 P4SMA9.1A P4SMA9.1CA 9V1A 9V1C 7.78 8.65~9.55 1 13.4 30.6 50 P4SMA10A P4SMA10CA 10A 10C 8.55 9.50~10.50 1 14.5 28.3 10 P4SMA11A P4SMA11CA 11A 11C 9.40 10.50~11.60 1 15.6 26.3 5 P4SMA12A P4SMA12CA 12A 12C 10.20 11.40~12.60 1 16.7 24.6 5 P4SMA13A P4SMA13CA 13A 13C 11.10 12.40~13.70 1 18.2 22.5 1 P4SMA15A P4SMA15CA 15A 15C 12.80 14.30~15.80 1 21.2 19.3 1 P4SMA16A P4SMA16CA 16A 16C 13.60 15.20~16.80 1 22.5 18.2 1 P4SMA18A P4SMA18CA 18A 18C 15.30 17.10~18.90 1 25.2 16.1 1 P4SMA20A P4SMA20CA 20A 20C 17.10 19.00~21.00 1 27.7 14.8 1 P4SMA22A P4SMA22CA 22A 22C 18.80 20.90~23.10 1 30.6 13.4 1 P4SMA24A P4SMA24CA 24A 24C 20.50 22.80~25.20 1 33.2 12.3 1 www.ya geo.com Jun. 30, 2023 V.5 Circuit Protection Product Specification Transient Voltage Suppressors Part Number Device Marking Code 4 9 P4SMA Reverse Stand-Off Voltage Breakdown Voltage @IT Test Current Maximum Clamping Voltage @IPP Peak Pulse Current Reverse Leakage @VRWM Unidirectional Bidirectional UNI BI VRWM(V) VBR(V) IT(mA) VC(V) IPP(A) IR(μA) P4SMA27A P4SMA27CA 27A 27C 23.10 25.70~28.40 1 37.5 10.9 1 P4SMA30A P4SMA30CA 30A 30C 25.60 28.50~31.50 1 41.4 9.9 1 P4SMA33A P4SMA33CA 33A 33C 28.20 31.40~34.70 1 45.7 9.0 1 P4SMA36A P4SMA36CA 36A 36C 30.80 34.20~37.80 1 49.9 8.2 1 P4SMA39A P4SMA39CA 39A 39C 33.30 37.10~41.00 1 53.9 7.6 1 P4SMA43A P4SMA43CA 43A 43C 36.80 40.90~45.20 1 59.3 6.9 1 P4SMA47A P4SMA47CA 47A 47C 40.20 44.70~49.40 1 64.8 6.3 1 P4SMA51A P4SMA51CA 51A 51C 43.60 48.50~53.60 1 70.1 5.8 1 P4SMA56A P4SMA56CA 56A 56C 47.80 53.20~58.80 1 77.0 5.3 1 P4SMA62A P4SMA62CA 62A 62C 53.00 58.90~65.10 1 85.0 4.8 1 P4SMA68A P4SMA68CA 68A 68C 58.10 64.60~71.40 1 92.0 4.5 1 P4SMA75A P4SMA75CA 75A 75C 64.10 71.30~78.80 1 103.0 4.0 1 P4SMA82A P4SMA82CA 82A 82C 70.10 77.90~86.10 1 113.0 3.6 1 P4SMA91A P4SMA91CA 91A 91C 77.80 86.50~95.50 1 125.0 3.3 1 P4SMA100A P4SMA100CA 100A 100C 85.50 95.00~105.00 1 137.0 3.0 1 P4SMA110A P4SMA110CA 110A 110C 94.00 105.00~116.00 1 152.0 2.7 1 P4SMA120A P4SMA120CA 120A 120C 102.00 114.00~126.00 1 165.0 2.5 1 P4SMA130A P4SMA130CA 130A 130C 111.00 124.00~137.00 1 179.0 2.3 1 P4SMA150A P4SMA150CA 150A 150C 128.00 143.00~158.00 1 207.0 2.0 1 P4SMA160A P4SMA160CA 160A 160C 136.00 152.00~168.00 1 219.0 1.9 1 P4SMA170A P4SMA170CA 170A 170C 145.00 162.00~179.00 1 234.0 1.8 1 P4SMA180A P4SMA180CA 180A 180C 154.00 171.00~189.00 1 246.0 1.7 1 P4SMA200A P4SMA200CA 200A 200C 171.00 190.00~210.00 1 274.0 1.5 1 P4SMA220A P4SMA220CA 220A 220C 185.00 209.00~231.00 1 328.0 1.3 1 P4SMA250A P4SMA250CA 250A 250C 214.00 237.00~263.00 1 344.0 1.2 1 P4SMA300A P4SMA300CA 300A 300C 256.00 285.00~315.00 1 414.0 1.0 1 P4SMA350A P4SMA350CA 350A 350C 300.00 332.00~368.00 1 482.0 0.85 1 P4SMA400A P4SMA400CA 400A 400C 342.00 380.00~420.00 1 548.0 0.75 1 P4SMA440A P4SMA440CA 440A 440C 376.00 418.00~462.00 1 602.0 0.68 1 P4SMA480A P4SMA480CA 480A 480C 408.00 456.00~504.00 1 658.0 0.61 1 P4SMA510A P4SMA510CA 510A 510C 434.00 485.00~535.00 1 698.0 0.57 1 P4SMA530A P4SMA530CA 530A 530C 450.00 503.50~556.50 1 725.0 0.55 1 P4SMA540A P4SMA540CA 540A 540C 459.00 513.00~567.00 1 740.0 0.54 1 P4SMA550A P4SMA550CA 550A 550C 467.00 522.50~577.50 1 760.0 0.52 1 P4SMA600A P4SMA600CA 600A 600C 510.00 570.00~630.00 1 828.0 0.48 1 www.ya geo.com Jun. 30, 2023 V.5 Circuit Protection Product Specification Transient Voltage Suppressors 5 9 P4SMA Ratings and Characteristic Curves (T A=25℃ unless otherwise noted) Figure 1. Peak Pulse Power Rating Curve Figure 2. Pulse Derating Curve Peak Pulse Power (PPP) or Current (IPP) Derating in Percentage % PPPM - Peak Pulse Power (kW) 10 1 0.2×0.2″(5.0×5.0mm) Copper Pad Area 0.1 1 10 100 100 80 60 40 20 0 1000 0 td-Pulse Width (µs) 100 125 150 175 10000 Bi-directional V=0V 1000 Cj (pF) IPPM - Peak Pulse Current, %IRSM 100 Uni-directional V=0V Peak Value IPPM Half Value IPPM (IPPM/2) Uni-directional @VR 100 50 10/1000µs Waveform as defined by R.E.A 10 td 0 0 Bi-directional @VR TJ=25℃ f=1.0MHz Vsig=50mVp-p 1 1.0 2.0 3.0 1 4.0 t-Time (ms) 1000 IFSM - Peak Forward Surve Current (A) Surge Current Uni-Directional Only 3.6 3.0 2.4 1.8 1.2 0.6 0 25 100 Figure 6. Maximum Non-Repetitive Forward Curve 0 10 VBR-Reverse Breakdown Voltage (V) Figure 5. Steady State Power Dissipation Derating PM(AV), Steady State Power Dissipation (W) 75 Figure 4. Typical Junction Capacitance TJ=25℃ Pulse Width(td) is defined as the point where the peak current decays to 50% of IPPM tr=10µs 50 TA-Ambient Temperature (℃) Figure 3. Pulse Waveform 150 25 50 75 100 125 TA-Ambient Temperature (℃) 150 175 45 40 35 30 25 20 15 10 5 0 1 10 100 Number of Cycles at 60Hz www.ya geo.com Jun. 30, 2023 V.5 Circuit Protection Product Specification Transient Voltage Suppressors 6 9 P4SMA Recommended Soldering Conditions Reflow Soldering Critical Zone TL to TP tP TP Ramp-up TL tL Temperature TS max TS min Ramp-down tS Preheat 25 t 25℃ to Peak Time Recommended Conditions Profile Feature Pb-Free Assembly Average ramp-up rate (TL to TP) 3℃/second max. Preheat -Temperature Min (TS min) -Temperature Max (TS max) -Time (min to max) (tS) 150℃ 200℃ 60-180 seconds TS max to TL -Ramp-up Rate 3℃/second max. Time maintained above: -Temperature (TL) -Time (tL) 217℃ 60-150 seconds Peak Temperature (TP) 260℃ Time within 5℃ of actual Peak Temperature (tP) Ramp-down Rate Time 25℃ to Peak Temperature 20-40 seconds 6℃/second max. 8 minutes max. www.ya geo.com Jun. 30, 2023 V.5 Circuit Protection Product Specification Transient Voltage Suppressors 7 9 P4SMA Marking Code Cathode Band YXXX YXXX 6V8A Logo 6V8C Internal control code Marking Code Logo Internal control code Marking Code Part Number Code P4SMA XXX C A / XXXX Package Code TR7:7 inch reel package TR13:13 inch reel package 5% VBR Voltage Tolerance Bidirectional VBR Voltage Series Code Ordering Code for Different Package 7 inch reel package: Add suffix “ /TR7 ” at the end of the part number, such as P4SMAXXXCA/TR7 13 inch reel package: Add suffix “ /TR13 ” at the end of the part number, such as P4SMAXXXCA/TR13 www.ya geo.com Jun. 30, 2023 V.5 Circuit Protection Product Specification Transient Voltage Suppressors 8 9 P4SMA Packaging Tape P0 P1 P2 D0 B W B0 D1 A K0 B Dimension (mm) W 12.00±0.20 P0 4.00±0.10 P1 4.00±0.10 P2 2.00±0.10 D0 Φ1.5±0.10 D1 Φ1.5±0.10 E 1.75±0.10 F 5.50±0.05 A0 2.79±0.10 B0 5.33±0.10 K0 2.55±0.15 T 0.25±0.05 D2 Φ178.0±2.0 D3 Φ50.0Min. D4 Φ13.0±0.5 W1 16.0±2.0 T E F A Symbol SECTION B-B A0 SECTION A-A 7” Reel D4 D3 D2 W1 Quantity: 1000PCS 13” Reel D5 Φ330.0±2.0 D6 Φ13.5±0.5 H 2.5±1.0 W2 16.0±2.0 Quantity: 5000PCS www.ya geo.com Jun. 30, 2023 V.5 Product specification Circuit Protection Components LEGAL DISCLAIMER YAGEO, its distributors and agents (collectively, “YAGEO”), hereby disclaims any and all liabilities for any errors, inaccuracies or incompleteness contained in any product related information, including but not limited to product specifications, datasheets, pictures and/or graphics. YAGEO may make changes, modifications and/or improvements to product related information at any time and without notice. YAGEO makes no representation, warranty, and/or guarantee about the fitness of its products for any particular purpose or the continuing production of any of its products. To the maximum exten t permitted by law, YAGEO disclaims (i) any and all liability arising out of the application or use of any YAGEO product, (ii) any and all liability, including without limitation special, consequential or incidental damages, and (iii) any and all implied warranties, including warranties of fitness for a particular purpose, non -infringement and merchantability. YAGEO products are designed for general purpose applications under normal operation and usage conditions. Please contact YAGEO for the applications listed below which require especially high reliability for the prevention of defects which might directly cause damage to the third party's life, body or property: Aerospace equipment (artificial satellite, rocket, etc.), Atomic energy -related equipment, Aviation equipment, Disaster prevention equipment, crime prevention equipment, Electric heating apparatus, burning equipment, Highly public information network equipment, data-processing equipment , Medical devices, Military equipment, Power generation control equipment, Safety equipment, Traffic signal equipment, Transportation equipment and Undersea equipment, or for any other application or use in which the failure of YAGEO products could result in personal injury or death, or serious property damage. P articularly YAGEO Corporation and its affiliates do not recommend the use of commercial or automotive grade products for high reliability applications or manned space flight. Information provided here is intended to indicate product specifications only. YAGEO reserves all the rights for revising this content without further notification, as long as products are unchanged. Any product change will be announced by PCN. www.yageo.com
P4SMA12CA/TR13
- 物料型号:P4SMA系列,包括多种型号,如P4SMA6.8A、P4SMA7.5A等,直到P4SMA600A。 - 器件简介:瞬态电压抑制二极管(TVS),适用于表面贴装,优化板空间,低轮廓封装,玻璃钝化结,低电感,优异的钳位能力。 - 引脚分配:文档中提到了极性,颜色带表示阴极,除了双向模型外。 - 参数特性:包括400W的峰值脉冲功率能力,快速响应时间,典型的IR小于1μA在10V以上,高温焊接能力,符合UL和IEC61000-4-2 ESD标准。 - 功能详解:用于输入/输出接口、交流/直流电源、低频信号传输线(如RS232、RS485等)。 - 应用信息:适用于多种应用,包括电路保护、电源、信号传输线等。 - 封装信息:JEDEC DO-214AC塑封,锡镀层,符合MIL-STD-750标准,标准包装为12mm胶带。
P4SMA12CA/TR13 价格&库存
很抱歉,暂时无法提供与“P4SMA12CA/TR13”相匹配的价格&库存,您可以联系我们找货
P4SMA12CA/TR13
  • 1+2.898701+0.36260
  • 10+1.7847010+0.22330
  • 100+1.12230100+0.14040
  • 500+0.83250500+0.10420
  • 1000+0.657601000+0.08230
  • 5000+0.509105000+0.06370
  • 25000+0.4827025000+0.06040
P4SMA12CA/TR13
  • 1+2.893431+0.36191
  • 10+1.7879910+0.22364
  • 100+1.11752100+0.13978
  • 500+0.82738500+0.10349
  • 1000+0.733241000+0.09171
  • 2000+0.653972000+0.08180
库存:4991
P4SMA12CA/TR13
  • 5000+0.512775000+0.06414
库存:4991
