Technical Data 11211
Effective February 2022
Supersedes November 2020
P4SMA
400 W Transient voltage suppressor
Applications
Product features
Low profile SMA package
Excellent clamping capability
400 W peak pulse power capability at
10/1000 μs waveform
Typical IR less than 1 μA above 12 V
Fast response time: typically less than 1.0 ps
from 0 V to VBR minimum
High temperature reflow soldering:
+260 °C /40 s at terminal
Plastic package meets UL 94 V-0 flammability
rating
Meets moisture sensitivity level (MSL) level 1
Terminal: Tin plated leads,
solderable per J-STD-002
For surface mounted applications in order to
optimize board space
UL 497B recognized.
File No. : E198449 Guide QVGQ2
PIN configuration
Consumer electronics
Telecommunications
Computing and servers
Appliances
Industrial automation
Mobile and wearables
Environmental compliance and general
specifications
HALOGEN
Pb HF
FREE
Ordering part number
P4SMA 6-8 C A
Family name
VR voltage
(“-” indicates decimal point)
Bi-/Uni-Directional
(Blank=Uni, C=Bi)
Voltage tolerance
P4SMA
Absolute maximum ratings
(+25 °C, RH=45%-75%, unless otherwise noted)
Symbol
Value
Unit
Storage operating junction temperature range
Parameter
TSTG/ TJ
-55 to +150
°C
Steady state power dissipation at TL= +75 °C
PM(AV)
3.3
W
Peak pulse power dissipation on 10/1000 μs
waveform
PPP
400
W
Maximum instantaneous forward voltage at
100 A for unidirectional
VF
5.0
V
Peak forward surge current, 8.3 ms single
half sine wave1
IFSM
60
A
Typical thermal resistance junction to lead
R
JL
30
°C/W
Typical thermal resistance junction to ambient
R
JA
120
°C/W
1. Measured on 8.3 ms single half sine wave or equivalent square wave for unidirectional device only,
duty cycle = 4 per minute maximum
Mechanical parameters, pad layout- mm
Millimeters
Part marking
Inches
Dimension
Minimum
Maximum
Minimum
Maximum
A
2.60
3.00
0.102
0.118
B
4.15
4.65
0.163
0.183
C
1.25
1.65
0.049
0.065
D
0.95
1.52
0.037
0.060
E
4.90
5.30
0.193
0.209
F
0.051
0.203
0.002
0.008
G
0.15
0.31
0.006
0.012
H
2.00
2.44
0.079
0.096
J
2.00
K
L
0.079
2.30
0.091
1.80
Packaging information (mm)
Cathode band (Uni-polar only)
Part marking: xxxx = Date code
yyyy- Refer to marking designator
listed in Electrical Characteristics table
0.071
Dimensions
Millimeters
Inches
Drawing not to scale.
A0
2.79 ± 0.3
0.110 ± 0.012
Supplied in tape and reel packaging, 5,000 parts per 13” diameter reel
(EIA-481 compliant)
B0
5.33 ± 0.3
0.210 ± 0.012
C
330.0
13.0
D0
1.55 ± 0.1
0.061 ± 0.004
E
1.75 ± 0.2
0.069 ± 0.008
E1
13.3 ± 0.3
0.524 ± 0.012
F
5.50 ± 0.2
0.217 ± 0.008
P0
4.00 ± 0.2
0.157 ± 0.008
P1
4.00 ± 0.2
0.157 ± 0.008
P2
2.00 ± 0.2
0.079 ± 0.008
W
12.0 ± 0.2
0.479 ± 0.008
W1
15.7 ± 2.0
0.618 ± 0.079
2
www.eaton.com/electronics
P4SMA
Electrical characteristics (+25 °C)
Part number
Uni-polar
Bi-polar
Marking
Uni
Bi
VR
(V)
IR @ VR
(μA)
VBR @ IT
min (V)
max (V)
IT
(mA)
VC @ IPP
max (V)
IPP
(A)
P4SMA6-8A
P4SMA6-8CA
6V8A
6V8C
5.8
120
6.45
7.14
10
10.5
39
P4SMA7-5A
P4SMA7-5CA
7V5A
7V5C
6.4
80
7.13
7.88
10
11.3
36.3
P4SMA8-2A
P4SMA8-2CA
8V2A
8V2C
7.02
50
7.79
8.61
10
12.1
33.9
P4SMA9-1A
P4SMA9-1CA
9V1A
9V1C
7.78
9.55
1
13.4
30.6
P4SMA10A
P4SMA10CA
10A
10C
8.55
10
9.5
10.5
1
14.5
28.3
P4SMA11A
P4SMA11CA
11A
11C
9.4
5
10.5
11.6
1
15.6
26.3
P4SMA12A
P4SMA12CA
12A
12C
10.2
2
11.4
12.6
1
16.7
24.6
P4SMA13A
P4SMA13CA
13A
13C
11.1
1
12.4
13.7
1
18.2
22.5
P4SMA15A
P4SMA15CA
15A
15C
12.8
1
14.3
15.8
1
21.2
19.3
P4SMA16A
P4SMA16CA
16A
16C
13.6
1
15.2
16.8
1
22.5
18.2
P4SMA18A
P4SMA18CA
18A
18C
15.3
1
17.1
18.9
1
25.2
16.1
P4SMA20A
P4SMA20CA
20A
20C
17.1
1
19
21
1
27.7
14.8
P4SMA22A
P4SMA22CA
22A
22C
18.8
1
20.9
23.1
1
30.6
13.4
P4SMA24A
P4SMA24CA
24A
24C
20.5
1
22.8
25.2
1
33.2
12.3
P4SMA27A
P4SMA27CA
27A
27C
23.1
1
25.7
28.4
1
37.5
10.9
P4SMA30A
P4SMA30CA
30A
30C
25.6
1
28.5
31.5
1
41.4
9.9
P4SMA33A
P4SMA33CA
33A
33C
28.2
1
31.4
34.7
1
45.7
9
P4SMA36A
P4SMA36CA
36A
36C
30.8
1
34.2
37.8
1
49.9
8.2
P4SMA39A
P4SMA39CA
39A
39C
33.3
1
37.1
41
1
53.9
7.6
P4SMA43A
P4SMA43CA
43A
43C
36.8
1
40.9
45.2
1
59.3
6.9
P4SMA47A
P4SMA47CA
47A
47C
40.2
1
44.7
49.4
1
64.8
6.3
P4SMA51A
P4SMA51CA
51A
51C
43.6
1
48.5
53.6
1
70.1
5.8
P4SMA56A
P4SMA56CA
56A
56C
47.8
1
53.2
58.8
1
77
5.2
P4SMA62A
P4SMA62CA
62A
62C
53
1
58.9
65.1
1
85
4.8
P4SMA68A
P4SMA68CA
68A
68C
58.1
1
64.6
71.4
1
92
4.5
P4SMA75A
P4SMA75CA
75A
75C
64.1
1
71.3
78.8
1
103
4
P4SMA82A
P4SMA82CA
82A
82C
70.1
1
77.9
86.1
1
113
3.6
P4SMA91A
P4SMA91CA
91A
91C
77.8
1
86.5
95.5
1
125
3.3
P4SMA100A
P4SMA100CA
100A
100C
85.5
1
95
105
1
137
3
P4SMA110A
P4SMA110CA
110A
110C
94
1
105
116
1
152
2.7
P4SMA120A
P4SMA120CA
120A
120C
102
1
114
126
1
165
2.5
P4SMA130A
P4SMA130CA
130A
130C
111
1
124
137
1
179
2.3
P4SMA150A
P4SMA150CA
150A
150C
128
1
143
158
1
207
2
P4SMA160A
P4SMA160CA
160A
160C
136
1
152
168
1
219
1.9
P4SMA170A
P4SMA170CA
170A
170C
145
1
162
179
1
234
1.8
P4SMA180A
P4SMA180CA
180A
180C
154
1
171
189
1
246
1.6
P4SMA200A
P4SMA200CA
200A
200C
171
1
190
210
1
274
1.5
P4SMA220A
P4SMA220CA
220A
220C
185
1
209
231
1
328
1.3
P4SMA235A
P4SMA235CA
235A
235C
200
1
223
246
1
324
1.3
P4SMA250A
P4SMA250CA
250A
250C
214
1
237
263
1
344
1.2
P4SMA300A
P4SMA300CA
300A
300C
256
1
285
315
1
414
1
P4SMA350A
P4SMA350CA
350A
350C
300
1
332
368
1
482
0.9
P4SMA400A
P4SMA400CA
400A
400C
342
1
380
420
1
548
0.8
P4SMA440A
P4SMA440CA
440A
440C
376
1
418
462
1
602
0.7
3
P4SMA
Ratings and V-I characteristic curves (+25 °C unless otherwise noted)
V- I curve characteristics (Uni-directional)
V- I curve characteristics (Bi-directional)
Surge waveform: 10/1000 μs
VR: Stand-off voltage -- Maximum voltage that can be applied
VBR: Breakdown voltage
VC: Clamping voltage -- Peak voltage measured across the suppressor at a specified IPP
IR: Reverse leakage current
IT: Test current
VF: Forward voltage drop for Uni-directional TVS diode
Pulse derating curve
150
tr = rise time to peak value
td = decay time to half value
IPPM (% IRSM)
tr=10 μs
100
PPP derating in percentage (%)
Pulse waveform
Peak value
Half value
50
td
1.0
2.0
3.0
4.0
t (ms)
100
Ppp (kW)
400 W at 10/1000 μs +25 °C
10
1.0
0.01
0.1
td-Pulse width (ms)
4
80
60
40
50
75
100
125
150
TJ-Initial junction temperature (°C)
Peak pulse power dissipation vs. pulse width
0.1
0.001
100
1.0
10
175
P4SMA
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
t
Table 1 - Standard SnPb solder (Tc)
Package
thickness
Volume
mm3
很抱歉,暂时无法提供与“P4SMA47CA”相匹配的价格&库存,您可以联系我们找货
