SMAJE10CAH
SMAJE10CAH
    EATON(伊顿)
    SMA(DO-214AC)
    17V 夹子 23.5A Ipp TVS - 二极管 表面贴装型 SMA
SMAJE10CAH 数据手册
Technical Data ELX1062 Effective June 2021 SMAJE Automotive grade 400 W Transient voltage suppressor Applications Product features • Automotive grade (AEC-Q101 qualified) • Low profile SMA package • Excellent clamping capability • High reliability application • 400 W peak pulse power capability at 10/1000 μs waveform • Typical IR less than 1 μA above 10 V • Fast response time: typically less than 1.0 ps from 0 V to VBR minimum • Plastic package meets UL 94 V-0 flammability rating • Meets moisture sensitivity level (MSL) level 1 • Terminal: tin plated, solderable per J-STD-002 • UL 497B recognized. File No. : E198449 Guide QVGQ2 • Automotive chassis and safety systems • Advanced driver assistance systems (ADAS) • Communication and infotainment systems • Network systems and body electronics • Power Train controls • xEV and battery systems Environmental compliance and general specifications • AEC-Q101 qualified Ordering part number SMAJE 5-0 C A H Family name VR voltage (“-” indicates decimal point) Bi-/Uni-Directional (Blank=Uni, C=Bi) Voltage tolerance High reliability application PIN configuration SMAJE Automotive grade 400 W Transient voltage suppressor  Technical Data ELX1062 Effective June 2021 Absolute maximum ratings (+25 °C, RH=45%-75%, unless otherwise noted) Symbol Value Unit Storage operating junction temperature range Parameter TSTG/ TJ -55 to +150 °C Steady state power dissipation at TL= +75 °C PM(AV) 3.3 W Peak pulse power dissipation on 10/1000 μs waveform PPP 400 W Maximum instantaneous forward voltage at 100 A for unidirectional VF 5 V Peak forward surge current, 8.3 ms single half sine wave1 IFSM 60 A Typical thermal resistance junction to lead R JL 30 °C/W Typical thermal resistance junction to ambient R JA 120 °C/W 1. Measured on 8.3 ms single half sine wave or equivalent square wave for unidirectional device only, duty cycle = 4 per minute maximum Mechanical parameters, pad layout- mm/inches Millimeters Part marking Inches Dimension Minimum Maximum Minimum Maximum A 2.60 3.00 0.102 0.118 B 4.15 4.65 0.163 0.183 C 1.25 1.65 0.049 0.065 D 0.95 1.52 0.037 0.060 E 4.90 5.30 0.193 0.209 F 0.051 0.203 0.002 0.008 G 0.15 0.31 0.006 0.012 H 2.00 2.44 0.079 0.096 J 2.00 - 0.079 - K - 2.30 - 0.091 L 1.80 - 0.071 - Cathode band (uni-polar only) Part marking: xxxx = Date code yy- Refer to marking designator listed in Electrical characteristics table Packaging information - mm/inches Drawing not to scale. Supplied in tape and reel packaging, 5,000 parts per 13” diameter reel (EIA-481 compliant) 2 www.eaton.com/electronics Dimensions Millimeters Inches A0 2.79 ± 0.3 0.110 ± 0.012 B0 5.33 ± 0.3 0.210 ± 0.012 C 330.0 13.0 D0 1.55 ± 0.1 0.061 ± 0.004 E 1.75 ± 0.2 0.069 ± 0.008 E1 13.3 ± 0.3 0.524 ± 0.012 F 5.50 ± 0.2 0.217 ± 0.008 P0 4.00 ± 0.2 0.157 ± 0.008 P1 4.00 ± 0.2 0.157 ± 0.008 P2 2.00 ± 0.2 0.079 ± 0.008 W 12.0 ± 0.2 0.042 ± 0.008 W1 15.7 ± 2.0 0.618 ± 0.079 Technical Data ELX1062 SMAJE  Automotive grade 400 W Transient voltage suppressor Effective June 2021 Electrical specifications (+25 °C) Part number VR IR @ VR VBR @ IT IT VC @ IPP IPP Uni-polar Bi-polar Marking Uni Bi (V) (µA) min (V) max (V) (mA) max (V) (A) SMAJE5-0AH SMAJE5-0CAH HE TE 5 120 6.4 7 10 9.2 43.5 SMAJE6-0AH SMAJE6-0CAH HG TG 6 120 6.67 7.37 10 10.3 38.8 SMAJE6-5AH SMAJE6-5CAH HK TK 6.5 80 7.22 7.98 10 11.2 35.7 SMAJE7-0AH SMAJE7-0CAH HM TM 7 50 7.78 8.6 10 12 33.3 SMAJE7-5AH SMAJE7-5CAH HP TP 7.5 50 8.33 9.21 1 12.9 31 SMAJE8-0AH SMAJE8-0CAH HR TR 8 20 8.89 9.83 1 13.6 29.4 SMAJE8-5AH SMAJE8-5CAH HT TT 8.5 10 9.44 10.4 1 14.4 27.8 SMAJE9-0AH SMAJE9-0CAH HV TV 9 5 10 11.1 1 15.4 26 SMAJE10AH SMAJE10CAH HX TX 10 2 11.1 12.3 1 17 23.5 SMAJE11AH SMAJE11CAH HZ TZ 11 1 12.2 13.5 1 18.2 22 SMAJE12AH SMAJE12CAH IE UE 12 1 13.3 14.7 1 19.9 20.1 SMAJE13AH SMAJE13CAH IG UG 13 1 14.4 15.9 1 21.5 18.6 SMAJE14AH SMAJE14CAH IK UK 14 1 15.6 17.2 1 23.2 17.3 SMAJE15AH SMAJE15CAH IM UM 15 1 16.7 18.5 1 24.4 16.4 SMAJE16AH SMAJE16CAH IP UP 16 1 17.8 19.7 1 26 15.4 SMAJE17AH SMAJE17CAH IR UR 17 1 18.9 20.9 1 27.6 14.5 SMAJE18AH SMAJE18CAH IT UT 18 1 20 22.1 1 29.2 13.7 SMAJE20AH SMAJE20CAH IV UV 20 1 22.2 24.5 1 32.4 12.4 SMAJE22AH SMAJE22CAH IX UX 22 1 24.4 26.9 1 35.5 11.3 SMAJE24AH SMAJE24CAH IZ UZ 24 1 26.7 29.5 1 38.9 10.3 SMAJE26AH SMAJE26CAH JE VE 26 1 28.9 31.9 1 42.1 9.5 SMAJE28AH SMAJE28CAH JG VG 28 1 31.1 34.4 1 45.4 8.8 SMAJE30AH SMAJE30CAH JK VK 30 1 33.3 36.8 1 48.4 8.3 SMAJE33AH SMAJE33CAH JM VM 33 1 36.7 40.6 1 53.3 7.5 SMAJE36AH SMAJE36CAH JP VP 36 1 40 44.2 1 58.1 6.9 SMAJE40AH SMAJE40CAH JR VR 40 1 44.4 49.1 1 64.5 6.2 SMAJE43AH SMAJE43CAH JT VT 43 1 47.8 52.8 1 69.4 5.8 SMAJE45AH SMAJE45CAH JV VV 45 1 50 55.3 1 72.7 5.5 SMAJE48AH SMAJE48CAH JX VX 48 1 53.3 58.9 1 77.4 5.2 SMAJE51AH SMAJE51CAH JZ VZ 51 1 56.7 62.7 1 82.4 4.9 SMAJE54AH SMAJE54CAH RE WE 54 1 60 66.3 1 87.1 4.6 SMAJE58AH SMAJE58CAH RG WG 58 1 64.4 71.2 1 93.6 4.3 SMAJE60AH SMAJE60CAH RK WK 60 1 66.7 73.7 1 96.8 4.1 SMAJE64AH SMAJE64CAH RM WM 64 1 71.1 78.6 1 103 3.9 SMAJE70AH SMAJE70CAH RP WP 70 1 77.8 86 1 113 3.6 SMAJE75AH SMAJE75CAH RR WR 75 1 83.3 92.1 1 121 3.3 SMAJE78AH SMAJE78CAH RT WT 78 1 86.7 95.8 1 126 3.2 SMAJE85AH SMAJE85CAH RV WV 85 1 94.4 104 1 137 2.9 SMAJE90AH SMAJE90CAH RX WX 90 1 100 111 1 146 2.8 SMAJE100AH SMAJE100CAH RZ WZ 100 1 111 123 1 162 2.5 SMAJE110AH SMAJE110CAH SE XE 110 1 122 135 1 177 2.3 SMAJE120AH SMAJE120CAH SG XG 120 1 133 147 1 193 2.1 SMAJE130AH SMAJE130CAH SK XK 130 1 144 159 1 209 1.9 SMAJE150AH SMAJE150CAH SM XM 150 1 167 185 1 243 1.7 SMAJE160AH SMAJE160CAH SP XP 160 1 178 197 1 259 1.6 SMAJE170AH SMAJE170CAH SR XR 170 1 189 209 1 275 1.5 SMAJE180AH SMAJE180CAH ST XT 180 1 201 222 1 292 1.4 SMAJE200AH SMAJE200CAH SX XX 200 1 224 247 1 324 1.3 SMAJE220AH SMAJE220CAH ZE YE 220 1 246 272 1 356 1.1 SMAJE250AH SMAJE250CAH ZG YG 250 1 279 309 1 405 1 SMAJE300AH SMAJE330CAH ZK YK 300 1 335 371 1 486 0.8 SMAJE350AH SMAJE350CAH ZM YM 350 1 391 432 1 567 0.7 SMAJE400AH SMAJE400CAH ZP YP 400 1 447 494 1 648 0.6 SMAJE440AH SMAJE440CAH ZR YR 440 1 492 543 1 713 0.6 www.eaton.com/electronics 3 Technical Data ELX1062 Effective June 2021 SMAJE Automotive grade 400 W Transient voltage suppressor  Ratings and V-I characteristic curves (+25 °C unless otherwise noted) V- I curve characteristics (Uni-directional) V- I curve characteristics (Bi-directional) Surge waveform: 10/1000 μs VR: Stand-off voltage -- Maximum voltage that can be applied VBR: Breakdown voltage VC: Clamping voltage -- Peak voltage measured across the suppressor at a specified IPP IR: Reverse leakage current IT: Test current VF: Forward voltage drop for Uni-directional Pulse waveform IPPM (% IRSM) PPP derating in percentage (%) Pulse derating curve t (ms) TJ (°C) PPP (KW) Peak pulse power dissipation curve td - Pulse width (ms) 4 www.eaton.com/electronics Technical Data ELX1062 SMAJE  Automotive grade 400 W Transient voltage suppressor Effective June 2021  Solder reflow profile TP TC -5°C tP Max. Ramp Up Rate = 3°C/s Max. Ramp Down Rate = 6°C/s Temperature TL Preheat A T smax t Table 1 - Standard SnPb solder (Tc) Package thickness Volume mm3
SMAJE10CAH
物料型号:SMAJE系列,包括多种电压等级的型号,如SMAJE5-0AH、SMAJE6-0AH等。
器件简介:SMAJE系列是汽车级400W瞬态电压抑制器,适用于多种汽车系统,包括底盘与安全系统、高级驾驶辅助系统(ADAS)、通信与信息娱乐系统、网络系统与车身电子、动力传动控制以及xEV和电池系统。
引脚分配:文档中未明确提供引脚分配图,但通常这类器件为SMA封装,具有两个引脚,分别为阳极和阴极。
参数特性: - 符合汽车级标准(AEC-Q101合格)。 - 低矮的SMA封装。 - 优秀的钳位能力。 - 高可靠性应用。 - 400W峰值脉冲功率能力,在10/1000μs波形下。 - 典型IR小于10V以上的1μA。 - 快速响应时间:从0V到VBR最小值通常小于1.0ps。
功能详解:SMAJE系列瞬态电压抑制器主要用于保护汽车电子系统免受电压瞬变的影响,如ESD、EFT/B等。
应用信息:适用于汽车底盘与安全系统、ADAS、通信与信息娱乐系统、网络系统与车身电子、动力传动控制以及xEV和电池系统。
封装信息:塑料封装符合UL 94 V-0可燃性等级,符合湿度敏感性等级(MSL)1级,端子为锡镀层,符合J-STD-002可焊性标准,UL 497B认可。
SMAJE10CAH 价格&库存
很抱歉,暂时无法提供与“SMAJE10CAH”相匹配的价格&库存,您可以联系我们找货
SMAJE10CAH
    • 1+0.19419
    • 200+0.07517
    • 500+0.07258
    • 1000+0.07118
