SMAJE48A
SMAJE48A
    EATON(伊顿)
    SMA(DO-214AC)
    77.4V 夹子 5.2A Ipp TVS - 二极管 表面贴装型 SMA
SMAJE48A 数据手册
Technical Data 11213 Effective November 2020 SMAJE 400 W Transient voltage suppressor Applications Product features • Low profile SMA package • Excellent clamping capability • 400 W peak pulse power capability at 10/1000 μs waveform • Typical IR less than 1 μA above 10 V • Fast response time: typically less than 1.0 ps from 0 V to VBR minimum • High temperature reflow soldering: +260 °C /40 s at terminal • Plastic package meets UL 94 V-0 flammability rating • Meets moisture sensitivity level (MSL) level 1 • Terminal: Solder plated leads, solderable per J-STD-002 • For surface mounted applications in order to optimize board space • UL 497B recognized. File No. : E198449 Guide QVGQ2 PIN configuration • Consumer electronics • Telecommunications • Computing and servers • Appliances • Industrial automation • Mobile and wearables Environmental compliance and general specifications HALOGEN Pb HF FREE Ordering part number SMAJE 5-0 C A Family name VR voltage (“-” indicates decimal point) Bi-/Uni-Directional (Blank=Uni, C=Bi) Voltage tolerance SMAJE 400 W Transient voltage suppressor  Technical Data 11213 Effective November 2020 Absolute maximum ratings (+25 °C, RH=45%-75%, unless otherwise noted) Parameter Symbol Value Unit TSTG/ TJ -55 to +150 °C Steady state power dissipation at TL= +75 °C PM(AV) 3.3 W Peak pulse power dissipation on 10/1000 μs waveform PPP 400 W Maximum instantaneous forward voltage at 100 A for unidirectional VF 5.0 V Peak forward surge current, 8.3 ms single half sine wave1 IFSM 60 A Typical thermal resistance junction to lead R JL 30 °C/W Typical thermal resistance junction to ambient R JA 120 °C/W Storage operating junction temperature range 1. Measured on 8.3 ms single half sine wave or equivalent square wave for unidirectional device only, duty cycle = 4 per minute maximum Mechanical parameters, pad layout- mm Millimeters Dimension Minimum Part marking Inches Maximum Minimum Maximum A 2.60 3.00 0.102 0.118 B 4.15 4.65 0.163 0.183 C 1.25 1.65 0.049 0.065 D 0.95 1.52 0.037 0.060 E 4.90 5.30 0.193 0.209 F 0.051 0.203 0.002 0.008 G 0.15 0.31 0.006 0.012 H 2.00 2.44 0.079 0.096 J 2.00 K L Part marking: xxxx = Date code yy- Refer to marking designator listed in Electrical Characteristics table 0.079 2.30 0.091 1.80 Packaging information (mm) Cathode band (Uni-polar only) 0.071 Dimension Millimeters Inches Drawing not to scale. A0 2.79 ± 0.3 0.110 ± 0.012 Supplied in tape and reel packaging, 5,000 parts per 13” diameter reel (EIA-481 compliant) B0 5.33 ± 0.3 0.210 ± 0.012 C 330.0 13.0 D0 1.55 ± 0.1 0.061 ± 0.004 E 1.75 ± 0.2 0.069 ± 0.008 E1 13.3 ± 0.3 0.524 ± 0.012 F 5.50 ± 0.2 0.217 ± 0.008 P0 4.00 ± 0.2 0.157 ± 0.008 P1 4.00 ± 0.2 0.157 ± 0.008 P2 2.00 ± 0.2 0.079 ± 0.008 W 12.0 ± 0.2 0.472 ± 0.008 W1 15.7 ± 2.0 0.618 ± 0.079 2 www.eaton.com/electronics Technical Data 11213 SMAJE 400 W Transient voltage suppressor  Effective November 2020 Electrical characteristics (+25 °C) Part number Uni-polar Bi-polar Marking Uni Bi VR (V) IR @ VR (μA) VBR @ IT min (V) max (V) IT (mA) VC @ IPP max (V) IPP (A) SMAJE5-0A SMAJE5-0CA HE TE 5 120 6.4 7 10 9.2 43.5 SMAJE6-0A SMAJE6-0CA HG TG 6 120 6.67 7.37 10 10.3 38.8 SMAJE6-5A SMAJE6-5CA HK TK 6.5 80 7.22 7.98 10 11.2 35.7 SMAJE7-0A SMAJE7-0CA HM TM 7 50 7.78 8.6 10 12 33.3 SMAJE7-5A SMAJE7-5CA HP TP 7.5 50 8.33 9.21 1 12.9 31 SMAJE8-0A SMAJE8-0CA HR TR 8 20 8.89 9.83 1 13.6 29.4 SMAJE8-5A SMAJE8-5CA HT TT 8.5 10 9.44 10.4 1 14.4 27.8 SMAJE9-0A SMAJE9-0CA HV TV 9 5 10 11.1 1 15.4 26 SMAJE10A SMAJE10CA HX TX 10 2 11.1 12.3 1 17 23.5 SMAJE11A SMAJE11CA HZ TZ 11 1 12.2 13.5 1 18.2 22 SMAJE12A SMAJE12CA IE UE 12 1 13.3 14.7 1 19.9 20.1 SMAJE13A SMAJE13CA IG UG 13 1 14.4 15.9 1 21.5 18.6 SMAJE14A SMAJE14CA IK UK 14 1 15.6 17.2 1 23.2 17.3 SMAJE15A SMAJE15CA IM UM 15 1 16.7 18.5 1 24.4 16.4 SMAJE16A SMAJE16CA IP UP 16 1 17.8 19.7 1 26 15.4 SMAJE17A SMAJE17CA IR UR 17 1 18.9 20.9 1 27.6 14.5 SMAJE18A SMAJE18CA IT UT 18 1 20 22.1 1 29.2 13.7 SMAJE20A SMAJE20CA IV UV 20 1 22.2 24.5 1 32.4 12.4 SMAJE22A SMAJE22CA IX UX 22 1 24.4 26.9 1 35.5 11.3 SMAJE24A SMAJE24CA IZ UZ 24 1 26.7 29.5 1 38.9 10.3 SMAJE26A SMAJE26CA JE VE 26 1 28.9 31.9 1 42.1 9.5 SMAJE28A SMAJE28CA JG VG 28 1 31.1 34.4 1 45.4 8.8 SMAJE30A SMAJE30CA JK VK 30 1 33.3 36.8 1 48.4 8.3 SMAJE33A SMAJE33CA JM VM 33 1 36.7 40.6 1 53.3 7.5 SMAJE36A SMAJE36CA JP VP 36 1 40 44.2 1 58.1 6.9 SMAJE40A SMAJE40CA JR VR 40 1 44.4 49.1 1 64.5 6.2 SMAJE43A SMAJE43CA JT VT 43 1 47.8 52.8 1 69.4 5.8 SMAJE45A SMAJE45CA JV VV 45 1 50 55.3 1 72.7 5.5 SMAJE48A SMAJE48CA JX VX 48 1 53.3 58.9 1 77.4 5.2 SMAJE51A SMAJE51CA JZ VZ 51 1 56.7 62.7 1 82.4 4.9 SMAJE54A SMAJE54CA RE WE 54 1 60 66.3 1 87.1 4.6 SMAJE58A SMAJE58CA RG WG 58 1 64.4 71.2 1 93.6 4.3 SMAJE60A SMAJE60CA RK WK 60 1 66.7 73.7 1 96.8 4.1 SMAJE64A SMAJE64CA RM WM 64 1 71.1 78.6 1 103 3.9 SMAJE70A SMAJE70CA RP WP 70 1 77.8 86 1 113 3.6 3.3 SMAJE75A SMAJE75CA RR WR 75 1 83.3 92.1 1 121 SMAJE78A SMAJE78CA RT WT 78 1 86.7 95.8 1 126 3.2 SMAJE85A SMAJE85CA RV WV 85 1 94.4 104 1 137 2.9 SMAJE90A SMAJE90CA RX WX 90 1 100 111 1 146 2.8 SMAJE100A SMAJE100CA RZ WZ 100 1 111 123 1 162 2.5 SMAJE110A SMAJE110CA SE XE 110 1 122 135 1 177 2.3 SMAJE120A SMAJE120CA SG XG 120 1 133 147 1 193 2.1 1.9 SMAJE130A SMAJE130CA SK XK 130 1 144 159 1 209 SMAJE150A SMAJE150CA SM XM 150 1 167 185 1 243 1.7 SMAJE160A SMAJE160CA SP XP 160 1 178 197 1 259 1.6 1.5 SMAJE170A SMAJE170CA SR XR 170 1 189 209 1 275 SMAJE180A SMAJE180CA ST XT 180 1 201 222 1 292 1.4 SMAJE200A SMAJE200CA SX XX 200 1 224 247 1 324 1.3 SMAJE220A SMAJE220CA ZE YE 220 1 246 272 1 356 1.1 SMAJE250A SMAJE250CA ZG YG 250 1 279 309 1 405 1 SMAJE300A SMAJE300CA ZK YK 300 1 335 371 1 486 0.8 SMAJE350A SMAJE350CA ZM YM 350 1 391 432 1 567 0.7 SMAJE400A SMAJE400CA ZP YP 400 1 447 494 1 648 0.6 SMAJE440A SMAJE440CA ZR YR 440 1 492 543 1 713 0.6 www.eaton.com/electronics 3 SMAJE 400 W Transient voltage suppressor  Technical Data 11213 Effective November 2020 Ratings and V-I characteristic curves (+25 °C unless otherwise noted) V- I curve characteristics (Uni-directional) V- I curve characteristics (Bi-directional) Surge waveform: 10/1000 μs VR: Stand-off voltage -- Maximum voltage that can be applied VBR: Breakdown voltage VC: Clamping voltage -- Peak voltage measured across the suppressor at a specified IPP IR: Reverse leakage current IT: Test current VF: Forward voltage drop for Uni-directional TVS diode Pulse derating curve 150 tr = rise time to peak value td = decay time to half value IPPM (% IRSM) tr=10 μs 100 PPP derating in percentage (%) Pulse waveform Peak value Half value 50 0 0 td 1.0 2.0 3.0 100 Ppp (kW) 400 W at 10/1000 μs +25 °C 10 1.0 0.1 td-Pulse width (ms) 4 www.eaton.com/electronics 60 40 20 25 50 75 100 125 150 TJ-Initial junction temperature (°C) Peak pulse power dissipation vs. pulse width 0.01 80 0 0 4.0 t (ms) 0.1 0.001 100 1.0 10 175 Technical Data 11213 SMAJE 400 W Transient voltage suppressor Effective November 2020  Solder reflow profile TP TC -5°C tP Max. Ramp Up Rate = 3°C/s Max. Ramp Down Rate = 6°C/s Temperature TL Preheat A T smax t Table 1 - Standard SnPb solder (Tc) Package thickness Volume mm3
SMAJE48A
物料型号:SMAJE系列,例如SMAJE5-0CA、SMAJE6-0A等。
器件简介:SMAJE系列是一种瞬态电压抑制二极管,具有400W的峰值脉冲功率能力,在10/1000μs波形下工作。适用于消费电子、通信、计算和服务器、家电、工业自动化、移动和可穿戴设备等领域。
引脚分配:文档中提到了SMAJE系列的PIN配置,但具体的引脚分配图或描述未在文档摘要中提及。
参数特性: - 工作温度范围:-55°C至+150°C。 - 稳态功率消耗:在+75°C时为3.3W。 - 峰值脉冲功率消耗:在10/1000μs波形下为400W。 - 最大瞬态正向电压:在单向设备上为5.0V(100A时)。 - 峰值正向浪涌电流:60A(8.3ms单半正弦波)。
功能详解:SMAJE系列具有低轮廓SMA封装、优秀的钳位能力、快速响应时间(从0V到VBR最小值通常小于1.0ps)、高温回流焊接能力(+260°C/40s在端子上)。
应用信息:适用于需要瞬态电压保护的各种应用,如电子消费品、通信设备、计算服务器、家用电器、工业自动化设备、移动设备和可穿戴设备。
封装信息:塑料封装符合UL 94 V-0可燃性等级,满足湿度敏感等级(MSL)1级,端子为镀锡引线,符合J-STD-002可焊性标准。
SMAJE48A 价格&库存
很抱歉,暂时无法提供与“SMAJE48A”相匹配的价格&库存,您可以联系我们找货
SMAJE48A
    • 1+0.54476
    • 200+0.21082
    • 500+0.20348
    • 1000+0.19980
    SMAJE48A
      • 5000+0.721485000+0.09379
      • 10000+0.6867110000+0.08927
      库存:10000
      SMAJE48A
      • 5000+0.66717
      • 10000+0.64082
      库存:10000
      SMAJE48A
      • 5000+0.54410
      • 10000+0.51992
      库存:10000
