1.5SMBJ18CA
1.5SMBJ18CA
    BORN(伯恩半导体)
    SMB(DO-214AA)
    双向TVS 18V截止 峰值脉冲电流:51.4A
1.5SMBJ18CA 数据手册
1.5SMBJxxA(CA) Transient Voltage Suppressors 1.5SMBJxxA(CA) ROHS DESCRIPTION: TVS diodes can be used in a wide range ofapplications which like consumer electronic products, automotive industries, munitions, telecommunications, aerospace industries, and intelligent control systems. SMB FEATURES:  Glass passivated or planner junction  Excellent clamping capability  Repetition rate (duty cycle): 0.01%  Typical IR less than 1μA above 10V.  Low profile package and low inductance  1500W Peak Pulse power capability at 10×1000μs waveform.  Fast response time: typically less than 1.0ps from 0V to VBR min.  High temperature soldering: 260℃/10s at terminals. Symbol  Plastic package has Underwriters Laboratory Flammability 94V-0.  For surface mounted applications in order to optimize board space ABSOLUTE MAXIMUM RATINGS (TA=25ºC, RH=45%-75%, unless otherwisenoted) Parameter Storage temperature range Operating junction temperature range Steady state power dissipation at TL=75℃ Peak pulse power dissipation on 10/1000μs waveform Maximum Instantaneous Forward Voltage at 50A for Unidirectional 1/5 Symbol Value Tstg -55 to +150 Unit ℃ Tj -55 to +150 ℃ PM(AV) 5.0 W PPP 1500 W VF 5.0 V 1.5SMBJxxA(CA) Transient Voltage Suppressors 1.5SMBJxxA(CA) ROHS ELECTRICAL CHARACTERISTICS (TA=25℃) Part Number Uni-Polar Bi-Polar VR IR@ VR V μA VBR@IT min(V) max(V) IT VC@IPP IPP① mA max(V) A 1.5SMBJ5.0A 1.5SMBJ5.0CA 5.0 200 6.40 7.00 10 9.2 163.0 1.5SMBJ6.0A 1.5SMBJ6.0CA 6.0 200 6.67 7.37 10 10.3 145.6 1.5SMBJ6.5A 1.5SMBJ6.5CA 6.5 100 7.22 7.98 10 11.2 134.0 1.5SMBJ7.0A 1.5SMBJ7.0CA 7.0 80 7.78 8.60 10 12.0 125.0 1.5SMBJ7.5A 1.5SMBJ7.5CA 7.5 50 8.33 9.21 1 12.9 116.3 1.5SMBJ8.0A 1.5SMBJ8.0CA 8.0 20 8.89 9.83 1 13.6 110.3 1.5SMBJ8.5A 1.5SMBJ8.5CA 8.5 10 9.44 10.40 1 14.4 104.2 1.5SMBJ9.0A 1.5SMBJ9.0CA 9.0 5 10.00 11.10 1 15.4 97.4 1.5SMBJ10A 1.5SMBJ10CA 10 2 11.10 12.30 1 17.0 88.2 1.5SMBJ11A 1.5SMBJ11CA 11 1 12.20 13.50 1 18.2 82.4 1.5SMBJ12A 1.5SMBJ12CA 12 1 13.30 14.70 1 19.9 75.4 1.5SMBJ13A 1.5SMBJ13CA 13 1 14.40 15.90 1 21.5 69.8 1.5SMBJ14A 1.5SMBJ14CA 14 1 15.60 17.20 1 23.2 64.7 1.5SMBJ15A 1.5SMBJ15CA 15 1 16.70 18.50 1 24.4 61.5 1.5SMBJ16A 1.5SMBJ16CA 16 1 17.80 19.70 1 26.0 57.7 1.5SMBJ17A 1.5SMBJ17CA 17 1 18.90 20.90 1 27.6 54.4 1.5SMBJ18A 1.5SMBJ18CA 18 1 20.00 22.10 1 29.2 51.4 1.5SMBJ20A 1.5SMBJ20CA 20 1 22.20 24.50 1 32.4 46.3 1.5SMBJ22A 1.5SMBJ22CA 22 1 24.40 26.90 1 35.5 42.3 1.5SMBJ24A 1.5SMBJ24CA 24 1 26.70 29.50 1 38.9 38.6 1.5SMBJ26A 1.5SMBJ26CA 26 1 28.90 31.90 1 42.1 35.6 1.5SMBJ28A 1.5SMBJ28CA 28 1 31.10 34.40 1 45.4 33.1 1.5SMBJ30A 1.5SMBJ30CA 30 1 33.30 36.80 1 48.4 31.0 1.5SMBJ33A 1.5SMBJ33CA 33 1 36.70 40.60 1 53.3 28.2 1.5SMBJ36A 1.5SMBJ36CA 36 1 40.00 44.20 1 58.1 25.8 1.5SMBJ40A 1.5SMBJ40CA 40 1 44.40 49.10 1 64.5 23.3 1.5SMBJ43A 1.5SMBJ43CA 43 1 47.80 52.80 1 69.4 21.6 1.5SMBJ45A 1.5SMBJ45CA 45 1 50.00 55.30 1 72.7 20.6 1.5SMBJ48A 1.5SMBJ48CA 48 1 53.30 58.90 1 77.4 19.4 1.5SMBJ51A 1.5SMBJ51CA 51 1 56.70 62.70 1 82.4 18.2 2/5 1.5SMBJxxA(CA) Transient Voltage Suppressors 1.5SMBJxxA(CA) ROHS ELECTRICAL CHARACTERISTICS (TA=25℃, continued) Part Number Uni-Polar Bi-Polar VR IR@ VR V μA min(V) ① VBR@IT IT VC@IPP max(V) mA max(V) IPP A 1.5SMBJ54A 1.5SMBJ54CA 54 1 60.00 66.30 1 87.1 17.2 1.5SMBJ58A 1.5SMBJ58CA 58 1 64.40 71.20 1 93.6 16.1 1.5SMBJ60A 1.5SMBJ60CA 60 1 66.70 73.70 1 96.8 15.5 1.5SMBJ64A 1.5SMBJ64CA 64 1 71.10 78.60 1 103.0 14.6 1.5SMBJ70A 1.5SMBJ70CA 70 1 77.80 86.00 1 113.0 13.3 1.5SMBJ75A 1.5SMBJ75CA 75 1 83.30 92.10 1 121.0 12.4 1.5SMBJ78A 1.5SMBJ78CA 78 1 86.70 95.80 1 126.0 11.9 1.5SMBJ85A 1.5SMBJ85CA 85 1 94.40 104.0 1 137.0 11.0 1.5SMBJ90A 1.5SMBJ90CA 90 1 100.0 111.0 1 146.0 10.3 1.5SMBJ100A 1.5SMBJ100CA 100 1 111.0 123.0 1 162.0 9.3 1.5SMBJ110A 1.5SMBJ110CA 110 1 122.0 135.0 1 177.0 8.5 1.5SMBJ120A 1.5SMBJ120CA 120 1 133.0 147.0 1 193.0 7.8 1.5SMBJ130A 1.5SMBJ130CA 130 1 144.0 159.0 1 209.0 7.2 1.5SMBJ150A 1.5SMBJ150CA 150 1 167.0 185.0 1 243.0 6.2 1.5SMBJ160A 1.5SMBJ160CA 160 1 178.0 197.0 1 259.0 5.8 1.5SMBJ170A 1.5SMBJ170CA 170 1 189.0 209.0 1 275.0 5.5 1.5SMBJ180A 1.5SMBJ180CA 180 1 201.0 222.0 1 292.0 5.2 1.5SMBJ190A 1.5SMBJ190CA 190 1 211.0 234.0 1 307.0 4.9 1.5SMBJ200A 1.5SMBJ200CA 200 1 224.0 247.0 1 324.0 4.7 ①Surge waveform: 10/1000μs VR :Stand-off Voltage -- Maximum voltage that can be applied VBR: Breakdown Voltage VC:Clamping Voltage -- Peak voltage measured across the suppressor at a specified Ipp IR: Reverse Leakage Current 3/5 1.5SMBJxxA(CA) Transient Voltage Suppressors 1.5SMBJxxA(CA) ROHS ORDERING INFORMATION 1.5SMBJ xx C A 1500W SMB Series 5% VBR Voltage tolerance VR Voltage C: Bi-directional RATINGS AND V-I CHARACTERISTICS CURVES (TA=25ºC, unless otherwise noted) FIG.1:V- I curve characteristics (Uni-directional) FIG.2:V- I curve characteristics (Bi-directional) IPP VC VBR VR IT IR VC VBR VR V VF V IR IT VR VBR VC IPP IPP FIG.4: Pulse derating curve FIG.3: Pulse waveform PPP derating in percentage(%) 100 IPPM(%IRSM) 150 tr = rise time to peak value td = decay time to half value tr=10μs 80 100 Peak value 60 Half value 40 50 20 td t(ms) 0 0 4/5 1.0 2.0 3.0 4.0 0 0 TA(℃) 25 50 75 100 125 150 175 1.5SMBJxxA(CA) Transient Voltage Suppressors 1.5SMBJxxA(CA) ROHS SOLDERING PARAMETERS -Temperature Min (Ts(min)) Pb-Free assembly (see FIG.5) +150℃ -Temperature Max(Ts(max)) +200℃ -Time (Min to Max) (ts) 60-180 secs. Pre Heat FIG.5: Reflow condition tp TP Critical Zone TL to TP Ramp-up Average ramp up rate (Liquid us Temp (TL) to peak) 3℃/sec. Max Ts(max) to TL - Ramp-up Rate 3℃/sec. Max -Temperature(TL)(Liquid us) +217℃ -Temperature(tL) 60-150 secs. TL Ramp-down Preheat TS(min) ts 25 Reflow Peak Temp (Tp) +260(+0/-5)℃ Time within 5℃of actual Peak Temp (tp) 30 secs. Max Ramp-down Rate 6℃/sec. Max Time 25℃to Peak Temp (TP) 8 min. Max Do not exceed +260℃ tL TS(max) Temperature Reflow Condition time to peak temperatue (t 25℃ to peak) Time PACKAGE MECHANICAL DATA A Dimensions C Ref. H G D E L J K Millimeters Min. Max. Min. Max. A 4.25 4.75 0.167 0.187 B 3.30 3.94 0.130 0.155 C 1.85 2.21 0.073 0.087 D 0.76 1.52 0.030 0.060 E 5.08 5.59 0.200 0.220 F 0.051 0.203 0.002 0.008 G 0.15 0.31 0.006 0.012 H 2.11 2.44 0.083 0.096 J 6.80 5/5 L 0.270 2.60 K DO-214AA (SMB) Inches 2.40 0.100 0.090
1.5SMBJ18CA 价格&库存
很抱歉,暂时无法提供与“1.5SMBJ18CA”相匹配的价格&库存,您可以联系我们找货
1.5SMBJ18CA
    • 1+0.72050
    • 200+0.49720
    • 1500+0.45210
    • 3000+0.42240
    库存:3000
    1.5SMBJ18CA
      • 5+0.80396
      • 50+0.63807
      • 150+0.55512
      • 500+0.49292
      • 3000+0.46732
      • 6000+0.44237
      库存:2882
