Technical Data 11206
Effective November 2020
15BJ
1500 W Transient voltage suppressor
Applications
Product features
Low profile SMBF package
Excellent clamping capability
1500 W peak pulse power capability at
10/1000 μs waveform
Typical IR less than 1 μA above 11 V
Fast response time: typically less than 1.0 ps
from 0 V to VBR minimum
High temperature reflow soldering:
+260 °C /40 s at terminal
Plastic package meets UL 94 V-0 flammability
rating
Meets moisture sensitivity level (MSL) level 1
Terminal: Solder plated leads,
solderable per J-STD-002
For surface mounted applications in order to
optimize board space
UL 497B recognized.
File No. : E198449 Guide QVGQ2
PIN configuration
Consumer electronics
Telecommunications
Computing and servers
Appliances
Industrial automation
Mobile and wearables
Environmental compliance and general
specifications
HALOGEN
Pb HF
FREE
Ordering part number
15BJ 6-0 C A
Family name
VR voltage
(“-” indicates decimal point)
Bi-/Uni-Directional
(Blank=Uni, C=Bi)
Voltage tolerance
15BJ
Absolute maximum ratings
(+25 °C, RH=45%-75%, unless otherwise noted)
Parameter
Symbol
Value
Unit
TSTG/ TJ
-55 to +150
°C
Steady state power dissipation at TL= +75 °C
PM(AV)
5.0
W
Peak pulse power dissipation on 10/1000 μs
waveform
PPP
1500
W
Maximum instantaneous forward voltage at
50 A for unidirectional
VF
5.0
V
Peak forward surge current, 8.3 ms single
half sine wave1
IFSM
200
A
Storage operating junction temperature range
1. Measured on 8.3 ms single half sine wave or equivalent square wave for unidirectional device only,
duty cycle = 4 per minute maximum
Mechanical parameters, pad layout- mm
Millimeters
Dimension Minimum
Part marking
Inches
Maximum
Minimum
Maximum
A
3.90
4.50
0.154
0.177
B
4.65
5.15
0.183
0.203
C
1.85
2.15
0.073
0.085
D
0.60
0.024
E
5.60
6.00
0.220
0.236
Cathode band (Uni-polar only)
F
2.05
2.35
0.081
0.093
G
0.12
0.28
0.005
0.011
Part marking: xxxx = Date code
yyy- Refer to marking designator
listed in Electrical Characteristics table
J
2.00
K
L
0.079
3.20
0.126
2.30
Packaging information (mm)
0.091
Dimensions
Millimeters
Inches
Drawing not to scale.
A0
4.50 ± 0.3
0.177 ± 0.012
Supplied in tape and reel packaging, 3,000 parts per 13” diameter reel
(EIA-481 compliant)
B0
6.10 ± 0.3
0.240 ± 0.012
C
330.0
13.0
D0
1.55 ± 0.1
0.061 ± 0.004
2
www.eaton.com/electronics
E
1.75 ± 0.2
0.069 ± 0.008
E1
13.3 ± 0.3
0.524 ± 0.012
F
5.5 ± 0.2
0.217 ± 0.008
P0
4.00 ± 0.2
0.157 ± 0.008
P1
8.00 ± 0.2
0.315 ± 0.008
P2
2.00 ± 0.2
0.079 ± 0.008
W
12.0 ± 0.2
0.472 ± 0.008
W1
15.7 ± 2.0
0.618 ± 0.079
15BJ
Electrical characteristics (+25 °C)
Part number
Uni-polar
Bi-polar
Marking
Uni
Bi
VR
(V)
IR @ VR
(μA)
VBR @ IT
min (V)
max (V)
IT
(mA)
VC @ IPP
max (V)
IPP
(A)
15BJ5-0A
15BJ5-0CA
GDE
BDE
5
300
6.4
7
10
9.2
163
15BJ6-0A
15BJ6-0CA
GDG
BDG
6
250
6.67
7.37
10
10.3
145.6
15BJ6-5A
15BJ6-5CA
GDK
BDK
6.5
150
7.22
7.98
10
11.2
134
15BJ7-0A
15BJ7-0CA
GDM
BDM
7
100
7.78
8.6
10
12
125
15BJ7-5A
15BJ7-5CA
GDP
BDP
7.5
50
8.33
9.21
1
12.9
116.3
15BJ8-0A
15BJ8-0CA
GDR
BDR
8
30
8.89
9.83
1
13.6
110.3
15BJ8-5A
15BJ8-5CA
GDT
BDT
8.5
10.4
1
14.4
104.2
15BJ9-0A
15BJ9-0CA
GDV
BDV
9
10
10
11.1
1
15.4
97.4
15BJ10A
15BJ10CA
GDX
BDX
10
5
11.1
12.3
1
17
88.2
15BJ11A
15BJ11CA
GDZ
BDZ
11
2
12.2
13.5
1
18.2
82.4
15BJ12A
15BJ12CA
GEE
BEE
12
1
13.3
14.7
1
19.9
75.4
15BJ13A
15BJ13CA
GEG
BEG
13
1
14.4
15.9
1
21.5
69.8
15BJ14A
15BJ14CA
GEK
BEK
14
1
15.6
17.2
1
23.2
64.7
15BJ15A
15BJ15CA
GEM
BEM
15
1
16.7
18.5
1
24.4
61.5
15BJ16A
15BJ16CA
GEP
BEP
16
1
17.8
19.7
1
26
57.7
15BJ17A
15BJ17CA
GER
BER
17
1
18.9
20.9
1
27.6
54.4
15BJ18A
15BJ18CA
GET
BET
18
1
1
29.2
51.4
15BJ20A
15BJ20CA
GEV
BEV
22.2
24.5
1
32.4
46.3
15BJ22A
15BJ22CA
GEX
BEX
22
1
24.4
26.9
1
35.5
42.3
15BJ24A
15BJ24CA
GEZ
BEZ
24
1
26.7
29.5
1
38.9
38.6
15BJ26A
15BJ26CA
GFE
BFE
26
1
28.9
31.9
1
42.1
35.6
15BJ28A
15BJ28CA
GFG
BFG
28
1
31.1
34.4
1
45.4
33.1
15BJ30A
15BJ30CA
GFK
BFK
30
1
33.3
36.8
1
48.4
31
15BJ33A
15BJ33CA
GFM
BFM
33
1
36.7
40.6
1
53.3
28.2
15BJ36A
15BJ36CA
GFP
BFP
36
1
40
44.2
1
58.1
25.8
15BJ40A
15BJ40CA
GFR
BFR
40
1
44.4
49.1
1
64.5
23.3
15BJ43A
15BJ43CA
GFT
BFT
43
1
47.8
52.8
1
69.4
21.6
15BJ45A
15BJ45CA
GFV
BFV
45
1
50
55.3
1
72.7
20.6
15BJ48A
15BJ48CA
GFX
BFX
48
1
53.3
58.9
1
77.4
19.4
15BJ51A
15BJ51CA
GFZ
BFZ
51
1
56.7
62.7
1
82.4
18.2
15BJ54A
15BJ54CA
GGE
BGE
54
1
60
66.3
1
87.1
17.2
15BJ58A
15BJ58CA
GGG
BGG
58
1
64.4
71.2
1
93.6
16.1
15BJ60A
15BJ60CA
GGK
BGK
60
1
66.7
73.7
1
96.8
15.5
15BJ64A
15BJ64CA
GGM
BGM
64
1
71.1
78.6
1
103
14.6
15BJ70A
15BJ70CA
GGP
BGP
70
1
77.8
86
1
113
13.3
15BJ75A
15BJ75CA
GGR
BGR
75
1
83.3
92.1
1
121
12.4
15BJ78A
15BJ78CA
GGT
BGT
78
1
86.7
95.8
1
126
11.9
15BJ85A
15BJ85CA
GGV
BGV
85
1
94.4
104
1
137
11
15BJ90A
15BJ90CA
GGX
BGX
90
1
100
111
1
146
10.3
15BJ100A
15BJ100CA
GGZ
BGZ
100
1
111
123
1
162
9.3
15BJ110A
15BJ110CA
GHE
BHE
110
1
122
135
1
177
8.5
15BJ120A
15BJ120CA
GHG
BHG
120
1
133
147
1
193
7.8
15BJ130A
15BJ130CA
GHK
BHK
130
1
144
159
1
209
7.2
15BJ150A
15BJ150CA
GHM
BHM
150
1
167
185
1
243
6.2
15BJ160A
15BJ160CA
GHP
BHP
160
1
178
197
1
259
5.8
15BJ170A
15BJ170CA
GHR
BHR
170
1
189
209
1
275
5.5
15BJ180A
15BJ180CA
GHT
BHT
180
1
201
222
1
292
5.2
15BJ190A
15BJ190CA
GHU
BHU
190
1
211
234
1
307
4.9
15BJ200A
15BJ200CA
GHV
BHV
200
1
224
247
1
324
4.7
15BJ210A
15BJ210CA
GHX
BHX
210
1
233
258
1
337
4.5
15BJ220A
15BJ220CA
GHZ
BHZ
220
1
246
272
1
356
4.2
15BJ250A
15BJ250CA
GIE
BIE
250
1
279
309
1
405
3.7
15BJ300A
15BJ300CA
GIG
BIG
300
1
335
371
1
486
3.1
15BJ350A
15BJ350CA
GIK
BIK
350
1
391
432
1
567
2.6
15BJ400A
15BJ400CA
GIM
BIM
400
1
447
494
1
648
2.3
15BJ440A
15BJ440CA
GIP
BIP
440
1
492
543
1
713
2.1
3
15BJ
Ratings and V-I characteristic curves (+25 °C unless otherwise noted)
V- I curve characteristics (Uni-directional)
V- I curve characteristics (Bi-directional)
Surge waveform: 10/1000 μs
VR: Stand-off voltage -- Maximum voltage that can be applied
VBR: Breakdown voltage
VC: Clamping voltage -- Peak voltage measured across the suppressor at a specified IPP
IR: Reverse leakage current
IT: Test current
VF: Forward voltage drop for Uni-directional TVS diode
Pulse derating curve
150
tr = rise time to peak value
td = decay time to half value
IPPM (% IRSM)
tr=10 μs
100
Peak value
Half value
50
td
1.0
2.0
t (ms)
4
PPP derating in percentage (%)
Pulse waveform
3.0
4.0
100
80
60
40
50
75
100
125
150
TJ-Initial junction temperature (°C)
175
15BJ
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
t
Table 1 - Standard SnPb solder (Tc)
Package
thickness
Volume
mm3
很抱歉,暂时无法提供与“15BJ45A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.95880
- 200+0.75806
- 500+0.73149
- 1000+0.71831
